    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Tiger @Thomas Braun last edited by
      @thomas-braun said in Update System iobroker failed:
      curl -fsL https://iobroker.net/fix.sh | bash -
      already in /opt/iobriker?
        @thomas-braun may there be another installation in an unappropriate directory?
          Homoran Global Moderator Administrators @Tiger last edited by
          @tiger sagte in Update System iobroker failed:
          yes, but broker 😄
            first failed... and strange, as you said... seems not to be installed
            pi@raspberrypi:/opt/iobroker $ curl -fsL https://iobroker.net/fix.sh | bash -
            library: loaded
            Library version=2022-06-15
            ioBroker is not installed in /opt/iobroker! Cannot fix anything...
            Second is on the road... but tell me that password will be asked few time... don't remember that I'had a password .. hum hum
              Thomas Braun Most Active @Tiger last edited by Thomas Braun
              The password is for your linux user, more specific for the root (or root entiteled) user.
                @thomas-braun that what I said.. I don't remember I'd one...
                As the raspberry was only for iobroker
                  @tiger
                  The user 'pi' has a password.
                    security issue if you didn't change it raspberry
                      pi@raspberrypi:/opt/iobroker $ curl -sLf https://iobroker.net/install.sh | bash -
                      library: loaded
                          Welcome to the ioBroker installer!
                          Installer version: 2022-06-03
                          You might need to enter your password a couple of times.
                          Installing prerequisites (1/4)
                      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                      Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                      Reading package lists... Done
                      Changing npm registry to https://registry.npmjs.org
                      Installed gcc-c++
                          Creating ioBroker user and directory (2/4)
                      Created /etc/sudoers.d/iobroker
                      Directory /opt/iobroker created
                          Installing ioBroker (3/4)
                      npm ERR! code 32
                      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                      npm ERR! command failed
                      npm ERR! command sh -c node iobroker.js setup first
                      npm ERR! Successfully migrated 2308 objects to Redis Sets
                      npm ERR! object _design/system updated
                      npm ERR! host.raspberrypi install adapter backitup
                      npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                      npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                      npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                      npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                      npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                      npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                      npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                      npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                      npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                      npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                      npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                      npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                      npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                      npm ERR!     /home/pi/.npm/_logs/2022-08-15T15_38_44_496Z-debug-0.log
                          Finalizing installation (4/4)
                      Enabling autostart...
                      Autostart enabled!
                      Fixing directory permissions...
                          ioBroker was installed successfully
                          Open http://192.168.0.100 192.168.1.16:8081 in a browser and start configuring!
                      You need to re-login before doing anything else on the console!
                      log 2022-08-15T15_38_44_496Z-debug-0.log
                      how to re-login?
                        two different Subnets for LAN and WLAN?
                          Tiger @Homoran last edited by Tiger
                          yes, both was connected, I tryed but
                          This site can’t be reached
                          localhost refused to connect.
                            Homoran Global Moderator Administrators @Tiger last edited by Homoran
                            try with IP
                            otherwise we have to proceed with the console
                              already tryied
                              same issue
                              192.168.1.16 refused to connect.
                                @Thomas-Braun
                                npm ERR! code 32
                                Did you see?
                                  did you call ip:8081?
                                  if yes, does iobroker list instances work this time?
                                    Of course I did...this is what I written : http://192.168.1.16:8081/
                                    but iobroker list instances has same result as before... (I tryied in directory /opt/iobroker and in the directory show here after)
                                    pi@raspberrypi:~ $ iobroker list instances
                                    node:internal/modules/cjs/loader:936
                                      throw err;
                                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                                        at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                                        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                                        at node:internal/main/run_main_module:17:47 {
                                      code: 'MODULE_NOT_FOUND',
                                      requireStack: []
                                      @tiger Sorry, I don't have any clue. we have to wait for @Thomas-Braun
                                        for information, I found in directory the backup of this morning 😉 if it can help to restart from there...
                                          if you want listen to my advice from earlier this day:
                                          take a new SD card, install the latest RaspberryOS lite and iobroker by curl -sLf https://iobroker.net/install.sh | bash - and restore it there.
                                          and don"t vorget to save your history folder
                                            Thomas Braun Most Active last edited by
                                            @homoran sagte in Update System iobroker failed:
                                            Me neither.
                                            1.0k
                                            update iobroker
                                            20425
