    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Tiger @Thomas Braun last edited by
      @thomas-braun that what I said.. I don't remember I'd one...
      As the raspberry was only for iobroker
        Thomas Braun Most Active @Tiger last edited by
        @tiger
        The user 'pi' has a password.
          Homoran Global Moderator Administrators @Tiger last edited by
          @tiger sagte in Update System iobroker failed:
          security issue if you didn't change it raspberry
            pi@raspberrypi:/opt/iobroker $ curl -sLf https://iobroker.net/install.sh | bash -
            library: loaded
            Library version=2022-06-15
                Welcome to the ioBroker installer!
                Installer version: 2022-06-03
                You might need to enter your password a couple of times.
                Installing prerequisites (1/4)
            Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Hit:2 http://archive.raspberrypi.org/debian buster InRelease
            Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
            Reading package lists... Done
            Changing npm registry to https://registry.npmjs.org
            Installed gcc-c++
                Creating ioBroker user and directory (2/4)
            Created /etc/sudoers.d/iobroker
            Directory /opt/iobroker created
                Installing ioBroker (3/4)
            npm ERR! code 32
            npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
            npm ERR! command failed
            npm ERR! command sh -c node iobroker.js setup first
            npm ERR! Successfully migrated 2308 objects to Redis Sets
            npm ERR! object _design/system updated
            npm ERR! host.raspberrypi install adapter backitup
            npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
            npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
            npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
            npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
            npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
            npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
            npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
            npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
            npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
            npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
            npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
            npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
            npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
            npm ERR!     /home/pi/.npm/_logs/2022-08-15T15_38_44_496Z-debug-0.log
                Finalizing installation (4/4)
            Enabling autostart...
            Autostart enabled!
            Fixing directory permissions...
                ioBroker was installed successfully
                Open http://192.168.0.100 192.168.1.16:8081 in a browser and start configuring!
            You need to re-login before doing anything else on the console!
            log 2022-08-15T15_38_44_496Z-debug-0.log
            how to re-login?
              two different Subnets for LAN and WLAN?
                Tiger @Homoran last edited by Tiger
                yes, both was connected, I tryed but
                This site can’t be reached
                localhost refused to connect.
                  Homoran Global Moderator Administrators @Tiger last edited by Homoran
                  try with IP
                  otherwise we have to proceed with the console
                    already tryied
                    same issue
                    192.168.1.16 refused to connect.
                      @Thomas-Braun
                      npm ERR! code 32
                      Did you see?
                        did you call ip:8081?
                        if yes, does iobroker list instances work this time?
                          Of course I did...this is what I written : http://192.168.1.16:8081/
                          but iobroker list instances has same result as before... (I tryied in directory /opt/iobroker and in the directory show here after)
                          pi@raspberrypi:~ $ iobroker list instances
                          node:internal/modules/cjs/loader:936
                            throw err;
                          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                              at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                              at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                              at node:internal/main/run_main_module:17:47 {
                            code: 'MODULE_NOT_FOUND',
                            requireStack: []
                            @tiger Sorry, I don't have any clue. we have to wait for @Thomas-Braun
                              for information, I found in directory the backup of this morning 😉 if it can help to restart from there...
                                if you want listen to my advice from earlier this day:
                                take a new SD card, install the latest RaspberryOS lite and iobroker by curl -sLf https://iobroker.net/install.sh | bash - and restore it there.
                                and don"t vorget to save your history folder
                                  Thomas Braun Most Active last edited by
                                  @homoran sagte in Update System iobroker failed:
                                  Me neither.
                                    to be honest as I installed everything some years ago... I don't remember everyting to reinstalled.
                                    But I can buy new one and try.
                                    am I right
                                    • Reinstall OS on the new one
                                    • install iobroker with yout command
                                    And after? restore from the backup made?
                                    history is just for temperature... not big issue even if I lost it.
                                    In waiting for that, I suppose that I can use my imagedisk to have my domotic runs?
                                    I'd already try to search to reinstall raspberry, to flash the new SdCard with the raspberry OS lite, Can I do it from my PC windows?
                                    Which version you recommended? (32bit or 64 bit as i've the raspberry pi4) I suppose for me the version lite with desktop?
                                    Why not with desktop and recommended software?
                                    Stupid question... how can I save my backup file from iobroker ? as the file is on the actual sdcard...
                                    thanks
                                      @tiger
                                      Use the Raspberry OS Imager, go for the 64bit (lite) Version.
                                      No Desktop for added security, speed and convenience.
                                        am I right
                                        YES!!
                                        even though, save the folder /opt/iobroker/iobroker-data/history and simply copy it back on the new install.
                                        other questions answered by Thomas. You won't get other answers by me 😀
                                        There are no stupid questions at all - just stupid answers!
                                        use filezilla, but log in as the same user u will use later on. it should be pi
                                          ok I will try... perhaps too hard for my actual knowledge...
                                          I'll comeback when new sdcard will be operating, and when I will have made the command you asked to install.
                                          What I'm going to do...
                                          • Copy the iobroker backup on USB key
                                          • restore from image disk to have access to my domotics
                                          • on new SDcard, install the last Raspberry OSbit without desktop 😧
                                          • install iobroker
                                          and come back to have your support.
                                          Many thanks to both of you for your help and time
                                            @homoran said in Update System iobroker failed:
                                            so what is the answer? 🙂
                                            Filezilla is to send the iobroker backup if I'm right
                                            sorry to much information for me today lol
                                            1.0k
                                            update iobroker
                                            20427
