    4. Zigbee iobroker Error while opening serialport
      CommandaP last edited by
      v5.3.4
      142
      Log-Größe: 4.8 KB
      Zeit
      Nachricht
      zigbee.0
      	2022-04-11 09:49:46.596	error	Error herdsman start
      zigbee.0
      	2022-04-11 09:49:46.596	error	Failed to start Zigbee
      zigbee.0
      	2022-04-11 09:49:46.596	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0
      	2022-04-11 09:49:46.500	info	Installed Version: iobroker.zigbee@1.6.16
      zigbee.0
      	2022-04-11 09:49:46.494	info	Starting Zigbee npm ...
      zigbee.0
      	2022-04-11 09:49:46.494	info	Try to reconnect. 1 attempts left
      zigbee.0
      	2022-04-11 07:49:36.492	error	Error herdsman start
      zigbee.0
      	2022-04-11 07:49:36.492	error	Failed to start Zigbee
      zigbee.0
      	2022-04-11 07:49:36.491	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
      zigbee.0
      	2022-04-11 07:49:36.443	error	Re-commissioning your network will require re-pairing of all devices!
      zigbee.0
      	2022-04-11 07:49:36.443	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
      zigbee.0
      	2022-04-11 07:49:36.443	error	Please update configuration to prevent further issues.
      zigbee.0
      	2022-04-11 07:49:36.443	error	- Channel List: configured=11, adapter=11
      zigbee.0
      	2022-04-11 07:49:36.443	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0b
      zigbee.0
      	2022-04-11 07:49:36.443	error	- Extended PAN ID: configured=00124b0022983abc, adapter=00124b0022983abc
      zigbee.0
      	2022-04-11 07:49:36.442	error	- PAN ID: configured=6754, adapter=6753
      zigbee.0
      	2022-04-11 07:49:36.442	error	Configuration is not consistent with adapter state/backup!
      zigbee.0
      	2022-04-11 07:49:36.256	info	Installed Version: iobroker.zigbee@1.6.16
      zigbee.0
      	2022-04-11 07:49:36.144	info	Starting Zigbee npm ...
      zigbee.0
      	2022-04-11 07:49:36.107	info	starting. Version 1.6.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 4.0.19
      zigbee.0
      	2022-04-11 07:49:32.210	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0
      	2022-04-11 07:49:32.210	info	terminating
      zigbee.0
      	2022-04-11 07:49:32.210	warn	Failed to stop zigbee during startup
      zigbee.0
      	2022-04-11 07:49:32.181	info	Zigbee: disabling joining new devices.
      zigbee.0
      	2022-04-11 07:49:32.179	info	cleaned everything up...
      zigbee.0
      	2022-04-11 07:49:32.177	info	Got terminate signal TERMINATE_YOURSELF
      Ich habe den Adpter mal neugestartet damit Ihr das ales sehen könnt.
      • Asgothian
        Asgothian Developer @CommandaP last edited by
        @commandap 🤦
        Danke fürs Posten. Hast du es auch gelesen ?
        Da steht genau was nicht passt:
        • Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
        • Configuration is not consistent with adapter state/backup!
        • PAN ID: configured=6754, adapter=6753
        Da steht auch was du tun sollst:
        • Please update configuration to prevent further issues.
        Alternativ:
        • If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
        Was das bedeutet wird sogar auch noch erklärt:
        • Re-commissioning your network will require re-pairing of all devices!
        A.
        C 1 Reply Last reply Reply Quote 2
          CommandaP @Asgothian last edited by
          @asgothian vielen Dank, als ich den Post gemacht habe und den log nochmal gelesen habe von vorne habe ich das auch gesehen dumm
          Habe die Adapter ID und den Key geändert und Zack wurde es so grün. Jihaa, habe mich so auf die blöde Port Sache versteift das ich das Tutorial mit dem durchreichen 3 Mal gemacht habe.
          Vielen Dank!!!
            wusa last edited by wusa
            leider schaffe ich es nicht, den Adapter zum Laufen zu bekommen.
            Auf meinem Test System lief der Stick wunderbar. Jetzt auf dem Echtsystem will dieser allerdings nicht mehr.
            Hier die Logs.
            zigbee.0
            2022-06-09 22:04:52.616	error	Error herdsman start
            zigbee.0
            2022-06-09 22:04:52.614	error	Failed to start Zigbee
            zigbee.0
            2022-06-09 22:04:52.610	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
            zigbee.0
            2022-06-09 22:04:51.913	info	Installed Version: iobroker.zigbee@1.7.5
            zigbee.0
            2022-06-09 22:04:51.864	info	Starting Zigbee npm ...
            zigbee.0
            2022-06-09 22:04:51.861	info	Try to reconnect. 1 attempts left
            zigbee.0
            2022-06-09 22:04:41.851	error	Error herdsman start
            zigbee.0
            2022-06-09 22:04:41.849	error	Failed to start Zigbee
            zigbee.0
            2022-06-09 22:04:41.847	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
            zigbee.0
            2022-06-09 22:04:41.064	error	Re-commissioning your network will require re-pairing of all devices!
            zigbee.0
            2022-06-09 22:04:41.062	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
            zigbee.0
            2022-06-09 22:04:41.060	error	Please update configuration to prevent further issues.
            zigbee.0
            2022-06-09 22:04:41.058	error	- Channel List: configured=20, adapter=11
            zigbee.0
            2022-06-09 22:04:41.055	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
            zigbee.0
            2022-06-09 22:04:41.053	error	- Extended PAN ID: configured=23d1dddddd23c1ab, adapter=00124b0024c8bc28
            zigbee.0
            2022-06-09 22:04:41.051	error	- PAN ID: configured=6754, adapter=6754
            zigbee.0
            2022-06-09 22:04:41.049	error	Configuration is not consistent with adapter state/backup!
            Der Adapter ist wie folgt eingestellt:
            Genau der Beitrag über mir hat die selben Probleme, aber ich verstehe nicht, wie das passieren kann?
            Der Stick ist erstmalig in Betrieb gegangen auf diesem System.
            Edit: ich habe die Datei nvbackup.json gelöscht. Aber die Frage bleibt, woher kommen die Backups auf einem komplett neuen System an dem der Stick noch nie war?
              Thomas Braun Most Active @wusa last edited by
              @wusa
              Du musst die aufgeführten Parameter jetzt überein bringen.
              • Y
                Yoshi last edited by
                Kann mir hier einer bitte helfen.
                Habe den Conbee II Stick und habe ihn auch zum laufen bekommen. Habe ein paar Teilnehmer angelernt und dann den Raspy nochmal neugestartet und nun verbindet er sich nicht mehr mit dem Stick. Habe den Stick mal umgesteckt dann lief es mal kurz und nun wieder nicht.
                Egal was ich mache kommt immer diese Fehlermeldung
                zigbee.0
                2022-08-15 17:48:22.472	error	Error herdsman start
                zigbee.0
                2022-08-15 17:48:22.471	error	Failed to start Zigbee
                zigbee.0
                2022-08-15 17:48:22.470	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'"
                zigbee.0
                2022-08-15 17:48:22.252	info	Installed Version: iobroker.zigbee@1.7.6
                zigbee.0
                2022-08-15 17:48:22.209	info	Starting Zigbee npm ...
                zigbee.0
                2022-08-15 17:48:22.208	info	Try to reconnect. 1 attempts left
                zigbee.0
                2022-08-15 17:48:12.208	info	Installed Version: iobroker.zigbee@1.7.6
                zigbee.0
                2022-08-15 17:48:12.204	error	Error herdsman start
                zigbee.0
                2022-08-15 17:48:12.204	error	Failed to start Zigbee
                zigbee.0
                2022-08-15 17:48:12.203	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'"
                zigbee.0
                2022-08-15 17:48:11.473	info	Starting Zigbee npm ...
                zigbee.0
                2022-08-15 17:48:11.469	info	delete old Backup files. keep only last 10
                zigbee.0
                2022-08-15 17:48:11.344	info	starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.16.0, js-controller: 4.0.23
                • Asgothian
                  Asgothian Developer @Yoshi last edited by
                  @yoshi du musst auch das Log des 1. Startversuchs zeigen. Du zeigst nur den 2. und 3. Startversuch. Nach dem ersten ist die serielle Schnittstelle noch geöffnet und daher kann der Adapter nicht laufen.
                  A.
                  Y 1 Reply Last reply Reply Quote 0
                  • Y
                    Yoshi @Asgothian last edited by
                    @asgothian
                    Hab die Instanz nochmal gestartet und dann kam das raus
                    zigbee.0
                    2022-08-15 18:01:38.138	error	Error herdsman start
                    zigbee.0
                    2022-08-15 18:01:38.137	error	Failed to start Zigbee
                    zigbee.0
                    2022-08-15 18:01:38.135	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2149258-if00'"
                    zigbee.0
                    2022-08-15 18:01:37.901	info	Installed Version: iobroker.zigbee@1.7.6
                    zigbee.0
                    2022-08-15 18:01:37.874	info	Starting Zigbee npm ...
                    zigbee.0
                    2022-08-15 18:01:37.873	info	Try to reconnect. 1 attempts left
                    zigbee.0
                    2022-08-15 18:01:27.873	info	Installed Version: iobroker.zigbee@1.7.6
                    zigbee.0
                    2022-08-15 18:01:27.869	error	Error herdsman start
                    zigbee.0
                    2022-08-15 18:01:27.869	error	Failed to start Zigbee
                    zigbee.0
                    2022-08-15 18:01:27.867	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2149258-if00'"
                    zigbee.0
                    2022-08-15 18:01:27.198	info	Starting Zigbee npm ...
                    zigbee.0
                    2022-08-15 18:01:27.195	info	delete old Backup files. keep only last 10
                    zigbee.0
                    2022-08-15 18:01:27.052	info	starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.16.0, js-controller: 4.0.23
                    zigbee.0
                    2022-08-15 18:01:19.986	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    zigbee.0
                    2022-08-15 18:01:19.984	info	terminating
                    zigbee.0
                    2022-08-15 18:01:19.954	info	Zigbee: disabling joining new devices.
                    zigbee.0
                    2022-08-15 18:01:19.892	info	cleaned everything up...
                    zigbee.0
                    2022-08-15 18:01:19.890	info	Got terminate signal TERMINATE_YOURSELF
                    zigbee.0
                    2022-08-15 18:01:09.457	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                    • Asgothian
                      @yoshi lesen bildet:
                      @asgothian sagte in Zigbee iobroker Error while opening serialport:
                      A.
                      zigbee.0
                      auch diese Meldung stammt von einem vorherigen Startversuch.
                      Bitte folgendes machen:
                      • Adapter anhalten
                      • 30 Sekunden warten
                      • adapter starten
                      • ALLE Meldungen des Adapters ab dem Startzeitpunkt posten. Nicht nur Fehler oder Warnmeldungen
                      A.
                      • Y
                        @asgothian
                        Genauso gemacht und leider kommt das selbe bei raus
                        • Asgothian
                          @yoshi
                          ich habe Probleme das zu glauben. Auf jeden fall gibt es ein problem damit das die serielle Schnittstelle von einem anderen Prozess genutzt wird und noch geöffnet ist.
                          A.
                          • Y
                            Yoshi @Asgothian last edited by Yoshi
                            @asgothian
                            ich versuche den Adapter nochmal zu installieren
                            • Asgothian
                              @yoshi sagte in Zigbee iobroker Error while opening serialport:
                              @asgothian
                              das bringt nix. Du musst prüfen welcher Prozess auf den Conbee zugreift. Hast du die decent software noch installiert / aktiv ?
                              A.
                              • Y
                                @asgothian
                                Ich hab in der Phoscon Oberfläche das Gateway zurückgesetzt und Deconz komplett deinstalliert.
                                Wie kann ich das prüfen was den Stick belegt ?
                                • Asgothian
                                  Bist du sicher ? mach mal bitte in der console
                                  ps -ax | grep -e deconz
                                  und poste die Ausgaben hier.
                                  A.
                                  • Y
                                    @asgothian said in Zigbee iobroker Error while opening serialport:
                                    16936 pts/0    S+     0:00 grep --color=auto -e deconz
                                    • Asgothian
                                      @yoshi hmm.. bitte zieh des Stick mal ab, warte 30 Sekunden, und steck den danach wieder an.
                                      Danach nochmal den Adapter starten.
                                      A.
                                      • Y
                                        @asgothian
                                        leider das gleich Problem,
                                        aber wie schon oben beschrieben, hatte ich ihn schon mal zum laufen bekommen. Was auch mal funktioniert hat, den USB Port zu wechseln und dann die Instanz neu starten.
                                        Nun geht nichts davon
                                        Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                                        • Glasfaser
                                          Glasfaser @Yoshi last edited by
                                          BITTE keine Aussagen .... immer Log´s dazu zeigen !!!
                                            Thomas Braun Most Active @Yoshi last edited by
                                            @yoshi
                                            systemctl status deconz deconz-gui
                                            231
                                            42441
