    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Tiger @Homoran last edited by Tiger
      yes, both was connected, I tryed but
      This site can’t be reached
      localhost refused to connect.
        Homoran Global Moderator Administrators @Tiger last edited by Homoran
        @tiger sagte in Update System iobroker failed:
        try with IP
        otherwise we have to proceed with the console
          already tryied
          same issue
          192.168.1.16 refused to connect.
            @Thomas-Braun
            npm ERR! code 32
            npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
            npm ERR! command failed
            Did you see?
              did you call ip:8081?
              if yes, does iobroker list instances work this time?
                Of course I did...this is what I written : http://192.168.1.16:8081/
                but iobroker list instances has same result as before... (I tryied in directory /opt/iobroker and in the directory show here after)
                pi@raspberrypi:~ $ iobroker list instances
                node:internal/modules/cjs/loader:936
                  throw err;
                Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                    at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                    at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                    at node:internal/main/run_main_module:17:47 {
                  code: 'MODULE_NOT_FOUND',
                  requireStack: []
                  @tiger Sorry, I don't have any clue. we have to wait for @Thomas-Braun
                    for information, I found in directory the backup of this morning 😉 if it can help to restart from there...
                      if you want listen to my advice from earlier this day:
                      take a new SD card, install the latest RaspberryOS lite and iobroker by curl -sLf https://iobroker.net/install.sh | bash - and restore it there.
                      and don"t vorget to save your history folder
                        Thomas Braun Most Active last edited by
                        @homoran sagte in Update System iobroker failed:
                        Me neither.
                          to be honest as I installed everything some years ago... I don't remember everyting to reinstalled.
                          But I can buy new one and try.
                          am I right
                          • Reinstall OS on the new one
                          • install iobroker with yout command
                          And after? restore from the backup made?
                          history is just for temperature... not big issue even if I lost it.
                          In waiting for that, I suppose that I can use my imagedisk to have my domotic runs?
                          I'd already try to search to reinstall raspberry, to flash the new SdCard with the raspberry OS lite, Can I do it from my PC windows?
                          Which version you recommended? (32bit or 64 bit as i've the raspberry pi4) I suppose for me the version lite with desktop?
                          Why not with desktop and recommended software?
                          Stupid question... how can I save my backup file from iobroker ? as the file is on the actual sdcard...
                          thanks
                            Thomas Braun Most Active @Tiger last edited by
                            @tiger
                            Use the Raspberry OS Imager, go for the 64bit (lite) Version.
                            No Desktop for added security, speed and convenience.
                              am I right
                              YES!!
                              even though, save the folder /opt/iobroker/iobroker-data/history and simply copy it back on the new install.
                              other questions answered by Thomas. You won't get other answers by me 😀
                              There are no stupid questions at all - just stupid answers!
                              use filezilla, but log in as the same user u will use later on. it should be pi
                                Tiger @Thomas Braun last edited by
                                ok I will try... perhaps too hard for my actual knowledge...
                                I'll comeback when new sdcard will be operating, and when I will have made the command you asked to install.
                                What I'm going to do...
                                • Copy the iobroker backup on USB key
                                • restore from image disk to have access to my domotics
                                • on new SDcard, install the last Raspberry OSbit without desktop 😧
                                • install iobroker
                                and come back to have your support.
                                Many thanks to both of you for your help and time
                                  @homoran said in Update System iobroker failed:
                                  so what is the answer? 🙂
                                  Filezilla is to send the iobroker backup if I'm right
                                  sorry to much information for me today lol
                                    no, I'm sure!
                                    but if you insist, we will brush up your skills.
                                    please ask!
                                    that's another possibility - ok
                                    don't know about this stuff.
                                    but if you still "play back" an image/mirrored disk, you also play back all faulty stuff.
                                    This wouldn't be a good idea
                                    we will wait for you!
                                      filezilla is a file transfer programm using sftp
                                        Of course there is fault, but it's the image of my sdcard when everything was working and all adapters was working too.
                                        With this image, I will be able to have all instances and adapters installed if needed for you
                                        If i install everything new on a new Sdcard after... I don't see the problem.
                                        The only things that I've not in this imagedisk is the backup of iobroker from this morning, that's why I want to have it 🙂
                                          but also with very very old versions, which may not be able to be updated as we have seen today, or am I wrong?
                                          And you can not play back that image and install the latest OS. this will be overwritten
                                            I agree, I'll made a new SD Card.
                                            With all new...
                                            Just hopped that the backup of IOBROKER will avoid me to reprogram everything.
                                            But in this way, I'll always have a version of SD Card with something working untill I've finished the new and correct one 🙂
                                            version of OS without desktop... will I have internet navigator on it? will it be started from cmd as we made since the beginning?
                                            update iobroker
                                            20433
