    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Thomas Braun Most Active @Tiger last edited by
      @tiger
      Use the Raspberry OS Imager, go for the 64bit (lite) Version.
      No Desktop for added security, speed and convenience.
        Homoran Global Moderator Administrators @Tiger last edited by
        @tiger sagte in Update System iobroker failed:
        am I right
        Reinstall OS on the new one
        install iobroker with yout command
        And after? restore from the backup made?
        YES!!
        history is just for temperature... not big issue even if I lost it.
        even though, save the folder /opt/iobroker/iobroker-data/history and simply copy it back on the new install.
        other questions answered by Thomas. You won't get other answers by me 😀
        Stupid question... how can I save my backup file from iobroker
        There are no stupid questions at all - just stupid answers!
        Can I do it from my PC windows?
        use filezilla, but log in as the same user u will use later on. it should be pi
          Tiger @Thomas Braun last edited by
          ok I will try... perhaps too hard for my actual knowledge...
          I'll comeback when new sdcard will be operating, and when I will have made the command you asked to install.
          What I'm going to do...
          • Copy the iobroker backup on USB key
          • restore from image disk to have access to my domotics
          • on new SDcard, install the last Raspberry OSbit without desktop 😧
          • install iobroker
          and come back to have your support.
          Many thanks to both of you for your help and time
            Tiger @Homoran last edited by
            @homoran said in Update System iobroker failed:
            so what is the answer? 🙂
            Filezilla is to send the iobroker backup if I'm right
            sorry to much information for me today lol
              no, I'm sure!
              but if you insist, we will brush up your skills.
              please ask!
              that's another possibility - ok
              don't know about this stuff.
              but if you still "play back" an image/mirrored disk, you also play back all faulty stuff.
              This wouldn't be a good idea
              we will wait for you!
                @homoran sagte in Update System iobroker failed:
                filezilla is a file transfer programm using sftp
                  Of course there is fault, but it's the image of my sdcard when everything was working and all adapters was working too.
                  With this image, I will be able to have all instances and adapters installed if needed for you
                  If i install everything new on a new Sdcard after... I don't see the problem.
                  The only things that I've not in this imagedisk is the backup of iobroker from this morning, that's why I want to have it 🙂
                    Homoran Global Moderator Administrators @Tiger last edited by Homoran
                    but also with very very old versions, which may not be able to be updated as we have seen today, or am I wrong?
                    And you can not play back that image and install the latest OS. this will be overwritten
                      I agree, I'll made a new SD Card.
                      With all new...
                      Just hopped that the backup of IOBROKER will avoid me to reprogram everything.
                      But in this way, I'll always have a version of SD Card with something working untill I've finished the new and correct one 🙂
                      version of OS without desktop... will I have internet navigator on it? will it be started from cmd as we made since the beginning?
                        that was the plan! a kind of hardware backup
                        what for?
                        a server is maintained by console
                          what for?
                          As I don't know the navigation by console 🙂
                          that why I thing it should be better for me with desktop instead of your proposal. if not, even to upload log file it will be difficult... today I had just to drag and drop the file... one step by one step 🙂
                          Today was a good day as I'm on holiday, but after will be more difficult 😉
                          Anyway, with or without desktop, we'll achieve a good installation thanks to your help.
                          once I'll have found back my old trouble version but working... I'll give you the instance and adapter installed
                          Many thanks
                            @tiger
                            It's easier to maintain a server without a desktop.
                              not now! but you will do!
                              there is just a little you have to do by cmd.
                              (concerning iob!)
                              I don't know what the other applications need
                                Tiger @Homoran last edited by Tiger
                                to finish, after a big stress as I had an error from win32diskimage when writting the old files... but was ok the second time...
                                All is working as before...
                                So I've listed instances and adapters (some don't need and was installed for test)
                                Really need should be at least :
                                • Node-Red
                                • Alexa
                                • S7
                                • history
                                • Rfxcom
                                • Zigbee
                                • Vis
                                • script is also used
                                result for the both list
                                please stay sit down before reading the version of all my adapters 🙂
                                pi@raspberrypi:~ $ iobroker list adapters
                                system.adapter.admin                   : admin          - v4.0.10
                                system.adapter.alexa2                  : alexa2         - v3.9.1
                                system.adapter.chromecast              : chromecast     - v2.3.1
                                system.adapter.cloud                   : cloud          - v3.0.4
                                system.adapter.daswetter               : daswetter      - v3.0.1
                                system.adapter.discovery               : discovery      - v2.3.7
                                system.adapter.flot                    : flot           - v1.9.2
                                system.adapter.history                 : history        - v1.9.10
                                system.adapter.homeconnect             : homeconnect    - v0.0.30
                                system.adapter.info                    : info           - v1.7.2
                                system.adapter.iot                     : iot            - v1.5.3
                                system.adapter.javascript              : javascript     - v4.6.26
                                system.adapter.lovelace                : lovelace       - v1.0.16
                                system.adapter.mqtt                    : mqtt           - v2.1.4
                                system.adapter.node-red                : node-red       - v1.17.2
                                system.adapter.ping                    : ping           - v1.4.8
                                system.adapter.rfxcom                  : rfxcom         - v1.0.1
                                system.adapter.s7                      : s7             - v1.1.9
                                system.adapter.scenes                  : scenes         - v1.1.0
                                system.adapter.socketio                : socketio       - v3.0.13
                                system.adapter.sonoff                  : sonoff         - v2.3.3
                                system.adapter.sonus                   : sonus          - v0.1.1
                                system.adapter.sql                     : sql            - v1.15.2
                                system.adapter.text2command            : text2command   - v1.3.0
                                system.adapter.upnp                    : upnp           - v1.0.16
                                system.adapter.vis                     : vis            - v1.4.15
                                system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
                                system.adapter.vis-colorpicker         : vis-colorpicker - v1.1.1
                                system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
                                system.adapter.vis-history             : vis-history    - v1.0.0
                                system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.4
                                system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                                system.adapter.vis-justgage            : vis-justgage   - v1.0.2
                                system.adapter.vis-metro               : vis-metro      - v1.1.2
                                system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                                system.adapter.vis-weather             : vis-weather    - v2.5.2
                                system.adapter.web                     : web            - v3.0.12
                                system.adapter.zigbee                  : zigbee         - v1.2.1
                                pi@raspberrypi:~ $ iobroker list instances
                                + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.chromecast.0            : chromecast            -  enabled
                                + system.adapter.cloud.0                 : cloud                 -  enabled
                                  system.adapter.daswetter.0             : daswetter             -  enabled
                                + system.adapter.discovery.0             : discovery             -  enabled
                                  system.adapter.flot.0                  : flot                  -  enabled
                                + system.adapter.history.0               : history               -  enabled
                                + system.adapter.homeconnect.0           : homeconnect           -  enabled
                                + system.adapter.info.0                  : info                  -  enabled
                                + system.adapter.iot.0                   : iot                   -  enabled
                                + system.adapter.javascript.0            : javascript            -  enabled
                                + system.adapter.node-red.0              : node-red              -  enabled, port: 1880, bind: 0.0.0.0
                                + system.adapter.ping.0                  : ping                  -  enabled
                                + system.adapter.rfxcom.0                : rfxcom                -  enabled
                                + system.adapter.s7.0                    : s7                    -  enabled
                                + system.adapter.s7.1                    : s7                    -  enabled
                                + system.adapter.scenes.0                : scenes                -  enabled
                                + system.adapter.socketio.0              : socketio              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                + system.adapter.sql.0                   : sql                   -  enabled
                                + system.adapter.text2command.0          : text2command          -  enabled
                                + system.adapter.upnp.0                  : upnp                  -  enabled
                                  system.adapter.vis-canvas-gauges.0     : vis-canvas-gauges     -  enabled
                                  system.adapter.vis-colorpicker.0       : vis-colorpicker       -  enabled
                                  system.adapter.vis-fancyswitch.0       : vis-fancyswitch       -  enabled
                                  system.adapter.vis-history.0           : vis-history           -  enabled
                                  system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
                                  system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
                                  system.adapter.vis-justgage.0          : vis-justgage          -  enabled
                                  system.adapter.vis-metro.0             : vis-metro             -  enabled
                                  system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
                                  system.adapter.vis-weather.0           : vis-weather           -  enabled
                                  system.adapter.vis.0                   : vis                   -  enabled
                                + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + system.adapter.zigbee.0                : zigbee                -  enabled, port: /dev/ttyACM0
                                + instance is alive
                                pi@raspberrypi:~ $ node -v
                                v10.22.0
                                pi@raspberrypi:~ $ npm -v
                                6.14.6
                                Thanks for your help, your time and your patient 🙂
                                  Hello,
                                  so, I bought the Sdcard, installed OS Lite...
                                  Connect to my wifi and installed iobroker.
                                  Now I have access to iobroker from my web browser on my PC.
                                  One question, If I understood well, it is possible to connect to the Raspberry pi with computer and made all modification and command from the PC and not directly on the Raspberry Pi correct?
                                  As finally the Raspberry will not be connected to a Screen and keyboard...
                                  But I didn't yet search to do it, one step...
                                  So now, what is the next step to restore the backup ?
                                  Actually the backup is saved on my computer.
                                  And in the webpage of iobroker it's written "WELCOME" and wanted to start the assistant.
                                  Thanks in advance
                                    wonderful! ...but...
                                    Connect to my wifi
                                    why wifi? wired is more stable. No one recommends wifi for a server.
                                    correct!
                                    get yourself a ssh client. i prefer puTTY, but you also can use powershell.
                                    therefore you'll need a filetransfer program as filezilla.
                                    If you login to your raspi you should use the credentials of your user you installed iobroker with
                                    caution.
                                    if you know what to do don't use the discovery. just follow the initisl steps and if you choose using credentials, write them down!
                                      Juste because The place where it will be has no wired connexion
                                      i'm going to saerch with the SSH as I saw it directly on raspberry
                                      This is the biggest point... where You lost me...
                                      instead of filezilla, can I put on USB key? more easy for me I think.
                                      caution.
                                      Are you speaking chinese? 😊
                                      follow the intialization steps... Supposed you are speaking about the assistant shown in the web browser with iobroker.
                                      what I didn't understood (perhaps you didn't mentionned presently) is once initialization step will be done, how I will use the restore...
                                      in my idea, is from USB key, and I supposed that qitch the command we will restore and used the file on the usb key
                                      don't forget I was a newbee on System installation and upgrade, but already a very big newbee to work only with command 🙂
                                        Juste one more point...
                                        Can I change the password of my Raspberry? I let the "pi" username, but if I activate the SSH... It should be better to have another password.
                                        Thanks
                                          @tiger
                                          Change your password in
                                          sudo raspi-config
                                            but not for me 🙂
                                            surely you can do. But I don't know about mount and so.
                                            no! it's suaheli!
                                            Yes!
                                            but after the initial settings, there you will be asked to start an automated device search. (this is the discovery adapter)
                                            I think you don't need it. Maybe it will bring more confusion than benefits.
                                            using the cli with iobroker restore filenameOfBackup you first have to copy the backup into /opt/iobroker/backups. after a clean install you have to create this folder
                                            then you can call the restore command with the appropriate filename
                                            you should!
                                            at bootup the pi will tell you that not changing it is a security issue!
                                            update iobroker
                                            20416
