    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Tiger @Homoran last edited by
      @homoran said in Update System iobroker failed:
      don't know about this stuff.
      but if you still "play back" an image/mirrored disk, you also play back all faulty stuff.
      This wouldn't be a good idea
      Of course there is fault, but it's the image of my sdcard when everything was working and all adapters was working too.
      With this image, I will be able to have all instances and adapters installed if needed for you
      If i install everything new on a new Sdcard after... I don't see the problem.
      The only things that I've not in this imagedisk is the backup of iobroker from this morning, that's why I want to have it 🙂
        Homoran Global Moderator Administrators @Tiger last edited by Homoran
        @tiger sagte in Update System iobroker failed:
        but also with very very old versions, which may not be able to be updated as we have seen today, or am I wrong?
        And you can not play back that image and install the latest OS. this will be overwritten
          I agree, I'll made a new SD Card.
          With all new...
          Just hopped that the backup of IOBROKER will avoid me to reprogram everything.
          But in this way, I'll always have a version of SD Card with something working untill I've finished the new and correct one 🙂
          version of OS without desktop... will I have internet navigator on it? will it be started from cmd as we made since the beginning?
            that was the plan! a kind of hardware backup
            what for?
            a server is maintained by console
              what for?
              As I don't know the navigation by console 🙂
              that why I thing it should be better for me with desktop instead of your proposal. if not, even to upload log file it will be difficult... today I had just to drag and drop the file... one step by one step 🙂
              Today was a good day as I'm on holiday, but after will be more difficult 😉
              Anyway, with or without desktop, we'll achieve a good installation thanks to your help.
              once I'll have found back my old trouble version but working... I'll give you the instance and adapter installed
              Many thanks
                Thomas Braun Most Active @Tiger last edited by
                @tiger
                It's easier to maintain a server without a desktop.
                  not now! but you will do!
                  there is just a little you have to do by cmd.
                  (concerning iob!)
                  I don't know what the other applications need
                    Tiger @Homoran last edited by Tiger
                    to finish, after a big stress as I had an error from win32diskimage when writting the old files... but was ok the second time...
                    All is working as before...
                    So I've listed instances and adapters (some don't need and was installed for test)
                    Really need should be at least :
                    • Node-Red
                    • Alexa
                    • S7
                    • history
                    • Rfxcom
                    • Zigbee
                    • Vis
                    • script is also used
                    result for the both list
                    please stay sit down before reading the version of all my adapters 🙂
                    pi@raspberrypi:~ $ iobroker list adapters
                    system.adapter.admin                   : admin          - v4.0.10
                    system.adapter.alexa2                  : alexa2         - v3.9.1
                    system.adapter.chromecast              : chromecast     - v2.3.1
                    system.adapter.cloud                   : cloud          - v3.0.4
                    system.adapter.daswetter               : daswetter      - v3.0.1
                    system.adapter.discovery               : discovery      - v2.3.7
                    system.adapter.flot                    : flot           - v1.9.2
                    system.adapter.history                 : history        - v1.9.10
                    system.adapter.homeconnect             : homeconnect    - v0.0.30
                    system.adapter.info                    : info           - v1.7.2
                    system.adapter.iot                     : iot            - v1.5.3
                    system.adapter.javascript              : javascript     - v4.6.26
                    system.adapter.lovelace                : lovelace       - v1.0.16
                    system.adapter.mqtt                    : mqtt           - v2.1.4
                    system.adapter.node-red                : node-red       - v1.17.2
                    system.adapter.ping                    : ping           - v1.4.8
                    system.adapter.rfxcom                  : rfxcom         - v1.0.1
                    system.adapter.s7                      : s7             - v1.1.9
                    system.adapter.scenes                  : scenes         - v1.1.0
                    system.adapter.socketio                : socketio       - v3.0.13
                    system.adapter.sonoff                  : sonoff         - v2.3.3
                    system.adapter.sonus                   : sonus          - v0.1.1
                    system.adapter.sql                     : sql            - v1.15.2
                    system.adapter.text2command            : text2command   - v1.3.0
                    system.adapter.upnp                    : upnp           - v1.0.16
                    system.adapter.vis                     : vis            - v1.4.15
                    system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
                    system.adapter.vis-colorpicker         : vis-colorpicker - v1.1.1
                    system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
                    system.adapter.vis-history             : vis-history    - v1.0.0
                    system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.4
                    system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                    system.adapter.vis-justgage            : vis-justgage   - v1.0.2
                    system.adapter.vis-metro               : vis-metro      - v1.1.2
                    system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                    system.adapter.vis-weather             : vis-weather    - v2.5.2
                    system.adapter.web                     : web            - v3.0.12
                    system.adapter.zigbee                  : zigbee         - v1.2.1
                    pi@raspberrypi:~ $ iobroker list instances
                    + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.chromecast.0            : chromecast            -  enabled
                    + system.adapter.cloud.0                 : cloud                 -  enabled
                      system.adapter.daswetter.0             : daswetter             -  enabled
                    + system.adapter.discovery.0             : discovery             -  enabled
                      system.adapter.flot.0                  : flot                  -  enabled
                    + system.adapter.history.0               : history               -  enabled
                    + system.adapter.homeconnect.0           : homeconnect           -  enabled
                    + system.adapter.info.0                  : info                  -  enabled
                    + system.adapter.iot.0                   : iot                   -  enabled
                    + system.adapter.javascript.0            : javascript            -  enabled
                    + system.adapter.node-red.0              : node-red              -  enabled, port: 1880, bind: 0.0.0.0
                    + system.adapter.ping.0                  : ping                  -  enabled
                    + system.adapter.rfxcom.0                : rfxcom                -  enabled
                    + system.adapter.s7.0                    : s7                    -  enabled
                    + system.adapter.s7.1                    : s7                    -  enabled
                    + system.adapter.scenes.0                : scenes                -  enabled
                    + system.adapter.socketio.0              : socketio              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    + system.adapter.sql.0                   : sql                   -  enabled
                    + system.adapter.text2command.0          : text2command          -  enabled
                    + system.adapter.upnp.0                  : upnp                  -  enabled
                      system.adapter.vis-canvas-gauges.0     : vis-canvas-gauges     -  enabled
                      system.adapter.vis-colorpicker.0       : vis-colorpicker       -  enabled
                      system.adapter.vis-fancyswitch.0       : vis-fancyswitch       -  enabled
                      system.adapter.vis-history.0           : vis-history           -  enabled
                      system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
                      system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
                      system.adapter.vis-justgage.0          : vis-justgage          -  enabled
                      system.adapter.vis-metro.0             : vis-metro             -  enabled
                      system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
                      system.adapter.vis-weather.0           : vis-weather           -  enabled
                      system.adapter.vis.0                   : vis                   -  enabled
                    + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.zigbee.0                : zigbee                -  enabled, port: /dev/ttyACM0
                    + instance is alive
                    pi@raspberrypi:~ $ node -v
                    v10.22.0
                    pi@raspberrypi:~ $ npm -v
                    6.14.6
                    Thanks for your help, your time and your patient 🙂
                      Hello,
                      so, I bought the Sdcard, installed OS Lite...
                      Connect to my wifi and installed iobroker.
                      Now I have access to iobroker from my web browser on my PC.
                      One question, If I understood well, it is possible to connect to the Raspberry pi with computer and made all modification and command from the PC and not directly on the Raspberry Pi correct?
                      As finally the Raspberry will not be connected to a Screen and keyboard...
                      But I didn't yet search to do it, one step...
                      So now, what is the next step to restore the backup ?
                      Actually the backup is saved on my computer.
                      And in the webpage of iobroker it's written "WELCOME" and wanted to start the assistant.
                      Thanks in advance
                        wonderful! ...but...
                        Connect to my wifi
                        why wifi? wired is more stable. No one recommends wifi for a server.
                        correct!
                        get yourself a ssh client. i prefer puTTY, but you also can use powershell.
                        therefore you'll need a filetransfer program as filezilla.
                        If you login to your raspi you should use the credentials of your user you installed iobroker with
                        caution.
                        if you know what to do don't use the discovery. just follow the initisl steps and if you choose using credentials, write them down!
                          Juste because The place where it will be has no wired connexion
                          i'm going to saerch with the SSH as I saw it directly on raspberry
                          This is the biggest point... where You lost me...
                          instead of filezilla, can I put on USB key? more easy for me I think.
                          caution.
                          Are you speaking chinese? 😊
                          follow the intialization steps... Supposed you are speaking about the assistant shown in the web browser with iobroker.
                          what I didn't understood (perhaps you didn't mentionned presently) is once initialization step will be done, how I will use the restore...
                          in my idea, is from USB key, and I supposed that qitch the command we will restore and used the file on the usb key
                          don't forget I was a newbee on System installation and upgrade, but already a very big newbee to work only with command 🙂
                            Juste one more point...
                            Can I change the password of my Raspberry? I let the "pi" username, but if I activate the SSH... It should be better to have another password.
                            Thanks
                              @tiger
                              Change your password in
                              sudo raspi-config
                                but not for me 🙂
                                surely you can do. But I don't know about mount and so.
                                no! it's suaheli!
                                Yes!
                                but after the initial settings, there you will be asked to start an automated device search. (this is the discovery adapter)
                                I think you don't need it. Maybe it will bring more confusion than benefits.
                                using the cli with iobroker restore filenameOfBackup you first have to copy the backup into /opt/iobroker/backups. after a clean install you have to create this folder
                                then you can call the restore command with the appropriate filename
                                you should!
                                at bootup the pi will tell you that not changing it is a security issue!
                                  ok, SSD : Done
                                  Connexion from distant PC : Done
                                  Password change : Done
                                  but not for me 🙂
                                  No you're a specialist 🙂 If I understood weel, I have juste to copy the file from my USB key to the folder you mentionned...
                                  If it's correct, I will search how to copy it 🙂
                                  Searching is easy for me... finding... it's different 😊
                                    no I'm just a regular user! Maybe a little advanced by nearly 10 years with iobroker.
                                    but don't change the rights
                                    let's ask @Thomas-Braun , he really is the specialist for linux commands
                                      You instist, but how can I change the rights?
                                      I've just coopy the backup file from the old Sdcard...
                                      Used same user in the Raspberry.
                                      Or you mean the username and password of iobroker? if it's that... I've to restart and you've to tell me how to find it frome the old system... and hoping I can change this... if not I will have to restart from beginning 🙂
                                      or there is something I'd miss... we'll see...
                                      Maybe? for sure 🙂
                                        @tiger
                                        The backup file is on the usb stick now?
                                        And it is sticking in the USB port of your raspberry?
                                          Tiger @Thomas Braun last edited by
                                          yes it is
                                          and USB key is inserted
                                          file name is
                                            Thomas Braun Most Active @Tiger last edited by Thomas Braun
                                            file name is
                                            Which path?
                                            Is that FileZilla that you are using as a filemanager?
                                            update iobroker
                                            20409
