    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Homoran Global Moderator Administrators @Tiger last edited by Homoran
      @tiger sagte in Update System iobroker failed:
      when everything was working and all adapters was working too.
      but also with very very old versions, which may not be able to be updated as we have seen today, or am I wrong?
      And you can not play back that image and install the latest OS. this will be overwritten
        Tiger @Homoran last edited by
        I agree, I'll made a new SD Card.
        With all new...
        Just hopped that the backup of IOBROKER will avoid me to reprogram everything.
        But in this way, I'll always have a version of SD Card with something working untill I've finished the new and correct one 🙂
        version of OS without desktop... will I have internet navigator on it? will it be started from cmd as we made since the beginning?
          that was the plan! a kind of hardware backup
          what for?
          a server is maintained by console
            @homoran said in Update System iobroker failed:
            what for?
            As I don't know the navigation by console 🙂
            that why I thing it should be better for me with desktop instead of your proposal. if not, even to upload log file it will be difficult... today I had just to drag and drop the file... one step by one step 🙂
            Today was a good day as I'm on holiday, but after will be more difficult 😉
            Anyway, with or without desktop, we'll achieve a good installation thanks to your help.
            once I'll have found back my old trouble version but working... I'll give you the instance and adapter installed
            Many thanks
              Thomas Braun Most Active @Tiger last edited by
              @tiger
              It's easier to maintain a server without a desktop.
                not now! but you will do!
                there is just a little you have to do by cmd.
                (concerning iob!)
                I don't know what the other applications need
                  Tiger @Homoran last edited by Tiger
                  to finish, after a big stress as I had an error from win32diskimage when writting the old files... but was ok the second time...
                  All is working as before...
                  So I've listed instances and adapters (some don't need and was installed for test)
                  Really need should be at least :
                  • Node-Red
                  • Alexa
                  • S7
                  • history
                  • Rfxcom
                  • Zigbee
                  • Vis
                  • script is also used
                  result for the both list
                  please stay sit down before reading the version of all my adapters 🙂
                  pi@raspberrypi:~ $ iobroker list adapters
                  system.adapter.admin                   : admin          - v4.0.10
                  system.adapter.alexa2                  : alexa2         - v3.9.1
                  system.adapter.chromecast              : chromecast     - v2.3.1
                  system.adapter.cloud                   : cloud          - v3.0.4
                  system.adapter.daswetter               : daswetter      - v3.0.1
                  system.adapter.discovery               : discovery      - v2.3.7
                  system.adapter.flot                    : flot           - v1.9.2
                  system.adapter.history                 : history        - v1.9.10
                  system.adapter.homeconnect             : homeconnect    - v0.0.30
                  system.adapter.info                    : info           - v1.7.2
                  system.adapter.iot                     : iot            - v1.5.3
                  system.adapter.javascript              : javascript     - v4.6.26
                  system.adapter.lovelace                : lovelace       - v1.0.16
                  system.adapter.mqtt                    : mqtt           - v2.1.4
                  system.adapter.node-red                : node-red       - v1.17.2
                  system.adapter.ping                    : ping           - v1.4.8
                  system.adapter.rfxcom                  : rfxcom         - v1.0.1
                  system.adapter.s7                      : s7             - v1.1.9
                  system.adapter.scenes                  : scenes         - v1.1.0
                  system.adapter.socketio                : socketio       - v3.0.13
                  system.adapter.sonoff                  : sonoff         - v2.3.3
                  system.adapter.sonus                   : sonus          - v0.1.1
                  system.adapter.sql                     : sql            - v1.15.2
                  system.adapter.text2command            : text2command   - v1.3.0
                  system.adapter.upnp                    : upnp           - v1.0.16
                  system.adapter.vis                     : vis            - v1.4.15
                  system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
                  system.adapter.vis-colorpicker         : vis-colorpicker - v1.1.1
                  system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
                  system.adapter.vis-history             : vis-history    - v1.0.0
                  system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.4
                  system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                  system.adapter.vis-justgage            : vis-justgage   - v1.0.2
                  system.adapter.vis-metro               : vis-metro      - v1.1.2
                  system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                  system.adapter.vis-weather             : vis-weather    - v2.5.2
                  system.adapter.web                     : web            - v3.0.12
                  system.adapter.zigbee                  : zigbee         - v1.2.1
                  pi@raspberrypi:~ $ iobroker list instances
                  + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.chromecast.0            : chromecast            -  enabled
                  + system.adapter.cloud.0                 : cloud                 -  enabled
                    system.adapter.daswetter.0             : daswetter             -  enabled
                  + system.adapter.discovery.0             : discovery             -  enabled
                    system.adapter.flot.0                  : flot                  -  enabled
                  + system.adapter.history.0               : history               -  enabled
                  + system.adapter.homeconnect.0           : homeconnect           -  enabled
                  + system.adapter.info.0                  : info                  -  enabled
                  + system.adapter.iot.0                   : iot                   -  enabled
                  + system.adapter.javascript.0            : javascript            -  enabled
                  + system.adapter.node-red.0              : node-red              -  enabled, port: 1880, bind: 0.0.0.0
                  + system.adapter.ping.0                  : ping                  -  enabled
                  + system.adapter.rfxcom.0                : rfxcom                -  enabled
                  + system.adapter.s7.0                    : s7                    -  enabled
                  + system.adapter.s7.1                    : s7                    -  enabled
                  + system.adapter.scenes.0                : scenes                -  enabled
                  + system.adapter.socketio.0              : socketio              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                  + system.adapter.sql.0                   : sql                   -  enabled
                  + system.adapter.text2command.0          : text2command          -  enabled
                  + system.adapter.upnp.0                  : upnp                  -  enabled
                    system.adapter.vis-canvas-gauges.0     : vis-canvas-gauges     -  enabled
                    system.adapter.vis-colorpicker.0       : vis-colorpicker       -  enabled
                    system.adapter.vis-fancyswitch.0       : vis-fancyswitch       -  enabled
                    system.adapter.vis-history.0           : vis-history           -  enabled
                    system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
                    system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
                    system.adapter.vis-justgage.0          : vis-justgage          -  enabled
                    system.adapter.vis-metro.0             : vis-metro             -  enabled
                    system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
                    system.adapter.vis-weather.0           : vis-weather           -  enabled
                    system.adapter.vis.0                   : vis                   -  enabled
                  + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.zigbee.0                : zigbee                -  enabled, port: /dev/ttyACM0
                  + instance is alive
                  pi@raspberrypi:~ $ node -v
                  v10.22.0
                  pi@raspberrypi:~ $ npm -v
                  6.14.6
                  Thanks for your help, your time and your patient 🙂
                    Hello,
                    so, I bought the Sdcard, installed OS Lite...
                    Connect to my wifi and installed iobroker.
                    Now I have access to iobroker from my web browser on my PC.
                    One question, If I understood well, it is possible to connect to the Raspberry pi with computer and made all modification and command from the PC and not directly on the Raspberry Pi correct?
                    As finally the Raspberry will not be connected to a Screen and keyboard...
                    But I didn't yet search to do it, one step...
                    So now, what is the next step to restore the backup ?
                    Actually the backup is saved on my computer.
                    And in the webpage of iobroker it's written "WELCOME" and wanted to start the assistant.
                    Thanks in advance
                      wonderful! ...but...
                      Connect to my wifi
                      why wifi? wired is more stable. No one recommends wifi for a server.
                      correct!
                      get yourself a ssh client. i prefer puTTY, but you also can use powershell.
                      therefore you'll need a filetransfer program as filezilla.
                      If you login to your raspi you should use the credentials of your user you installed iobroker with
                      caution.
                      if you know what to do don't use the discovery. just follow the initisl steps and if you choose using credentials, write them down!
                        Juste because The place where it will be has no wired connexion
                        i'm going to saerch with the SSH as I saw it directly on raspberry
                        This is the biggest point... where You lost me...
                        instead of filezilla, can I put on USB key? more easy for me I think.
                        caution.
                        Are you speaking chinese? 😊
                        follow the intialization steps... Supposed you are speaking about the assistant shown in the web browser with iobroker.
                        what I didn't understood (perhaps you didn't mentionned presently) is once initialization step will be done, how I will use the restore...
                        in my idea, is from USB key, and I supposed that qitch the command we will restore and used the file on the usb key
                        don't forget I was a newbee on System installation and upgrade, but already a very big newbee to work only with command 🙂
                          Juste one more point...
                          Can I change the password of my Raspberry? I let the "pi" username, but if I activate the SSH... It should be better to have another password.
                          Thanks
                            @tiger
                            Change your password in
                            sudo raspi-config
                              but not for me 🙂
                              surely you can do. But I don't know about mount and so.
                              no! it's suaheli!
                              Yes!
                              but after the initial settings, there you will be asked to start an automated device search. (this is the discovery adapter)
                              I think you don't need it. Maybe it will bring more confusion than benefits.
                              using the cli with iobroker restore filenameOfBackup you first have to copy the backup into /opt/iobroker/backups. after a clean install you have to create this folder
                              then you can call the restore command with the appropriate filename
                              you should!
                              at bootup the pi will tell you that not changing it is a security issue!
                                ok, SSD : Done
                                Connexion from distant PC : Done
                                Password change : Done
                                but not for me 🙂
                                No you're a specialist 🙂 If I understood weel, I have juste to copy the file from my USB key to the folder you mentionned...
                                If it's correct, I will search how to copy it 🙂
                                Searching is easy for me... finding... it's different 😊
                                  no I'm just a regular user! Maybe a little advanced by nearly 10 years with iobroker.
                                  but don't change the rights
                                  let's ask @Thomas-Braun , he really is the specialist for linux commands
                                    You instist, but how can I change the rights?
                                    I've just coopy the backup file from the old Sdcard...
                                    Used same user in the Raspberry.
                                    Or you mean the username and password of iobroker? if it's that... I've to restart and you've to tell me how to find it frome the old system... and hoping I can change this... if not I will have to restart from beginning 🙂
                                    or there is something I'd miss... we'll see...
                                    Maybe? for sure 🙂
                                      @tiger
                                      The backup file is on the usb stick now?
                                      And it is sticking in the USB port of your raspberry?
                                        Tiger @Thomas Braun last edited by
                                        yes it is
                                        and USB key is inserted
                                        file name is
                                          Thomas Braun Most Active @Tiger last edited by Thomas Braun
                                          file name is
                                          Which path?
                                          Is that FileZilla that you are using as a filemanager?
                                            file is directly on the usb key, not in a folder
                                            1.0k
                                            update iobroker
                                            20420
