    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Thomas Braun Most Active @Tiger last edited by
      @tiger
      It's easier to maintain a server without a desktop.
        Homoran Global Moderator Administrators @Tiger last edited by Homoran
        @tiger sagte in Update System iobroker failed:
        As I don't know the navigation by console
        not now! but you will do!
        there is just a little you have to do by cmd.
        (concerning iob!)
        I don't know what the other applications need
          Tiger @Homoran last edited by Tiger
          to finish, after a big stress as I had an error from win32diskimage when writting the old files... but was ok the second time...
          All is working as before...
          So I've listed instances and adapters (some don't need and was installed for test)
          Really need should be at least :
          • Node-Red
          • Alexa
          • S7
          • history
          • Rfxcom
          • Zigbee
          • Vis
          • script is also used
          result for the both list
          please stay sit down before reading the version of all my adapters 🙂
          pi@raspberrypi:~ $ iobroker list adapters
          system.adapter.admin                   : admin          - v4.0.10
          system.adapter.alexa2                  : alexa2         - v3.9.1
          system.adapter.chromecast              : chromecast     - v2.3.1
          system.adapter.cloud                   : cloud          - v3.0.4
          system.adapter.daswetter               : daswetter      - v3.0.1
          system.adapter.discovery               : discovery      - v2.3.7
          system.adapter.flot                    : flot           - v1.9.2
          system.adapter.history                 : history        - v1.9.10
          system.adapter.homeconnect             : homeconnect    - v0.0.30
          system.adapter.info                    : info           - v1.7.2
          system.adapter.iot                     : iot            - v1.5.3
          system.adapter.javascript              : javascript     - v4.6.26
          system.adapter.lovelace                : lovelace       - v1.0.16
          system.adapter.mqtt                    : mqtt           - v2.1.4
          system.adapter.node-red                : node-red       - v1.17.2
          system.adapter.ping                    : ping           - v1.4.8
          system.adapter.rfxcom                  : rfxcom         - v1.0.1
          system.adapter.s7                      : s7             - v1.1.9
          system.adapter.scenes                  : scenes         - v1.1.0
          system.adapter.socketio                : socketio       - v3.0.13
          system.adapter.sonoff                  : sonoff         - v2.3.3
          system.adapter.sonus                   : sonus          - v0.1.1
          system.adapter.sql                     : sql            - v1.15.2
          system.adapter.text2command            : text2command   - v1.3.0
          system.adapter.upnp                    : upnp           - v1.0.16
          system.adapter.vis                     : vis            - v1.4.15
          system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
          system.adapter.vis-colorpicker         : vis-colorpicker - v1.1.1
          system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
          system.adapter.vis-history             : vis-history    - v1.0.0
          system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.4
          system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
          system.adapter.vis-justgage            : vis-justgage   - v1.0.2
          system.adapter.vis-metro               : vis-metro      - v1.1.2
          system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
          system.adapter.vis-weather             : vis-weather    - v2.5.2
          system.adapter.web                     : web            - v3.0.12
          system.adapter.zigbee                  : zigbee         - v1.2.1
          pi@raspberrypi:~ $ iobroker list instances
          + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.chromecast.0            : chromecast            -  enabled
          + system.adapter.cloud.0                 : cloud                 -  enabled
            system.adapter.daswetter.0             : daswetter             -  enabled
          + system.adapter.discovery.0             : discovery             -  enabled
            system.adapter.flot.0                  : flot                  -  enabled
          + system.adapter.history.0               : history               -  enabled
          + system.adapter.homeconnect.0           : homeconnect           -  enabled
          + system.adapter.info.0                  : info                  -  enabled
          + system.adapter.iot.0                   : iot                   -  enabled
          + system.adapter.javascript.0            : javascript            -  enabled
          + system.adapter.node-red.0              : node-red              -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.ping.0                  : ping                  -  enabled
          + system.adapter.rfxcom.0                : rfxcom                -  enabled
          + system.adapter.s7.0                    : s7                    -  enabled
          + system.adapter.s7.1                    : s7                    -  enabled
          + system.adapter.scenes.0                : scenes                -  enabled
          + system.adapter.socketio.0              : socketio              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.sql.0                   : sql                   -  enabled
          + system.adapter.text2command.0          : text2command          -  enabled
          + system.adapter.upnp.0                  : upnp                  -  enabled
            system.adapter.vis-canvas-gauges.0     : vis-canvas-gauges     -  enabled
            system.adapter.vis-colorpicker.0       : vis-colorpicker       -  enabled
            system.adapter.vis-fancyswitch.0       : vis-fancyswitch       -  enabled
            system.adapter.vis-history.0           : vis-history           -  enabled
            system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
            system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
            system.adapter.vis-justgage.0          : vis-justgage          -  enabled
            system.adapter.vis-metro.0             : vis-metro             -  enabled
            system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
            system.adapter.vis-weather.0           : vis-weather           -  enabled
            system.adapter.vis.0                   : vis                   -  enabled
          + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.zigbee.0                : zigbee                -  enabled, port: /dev/ttyACM0
          + instance is alive
          pi@raspberrypi:~ $ node -v
          v10.22.0
          pi@raspberrypi:~ $ npm -v
          6.14.6
          Thanks for your help, your time and your patient 🙂
            Hello,
            so, I bought the Sdcard, installed OS Lite...
            Connect to my wifi and installed iobroker.
            Now I have access to iobroker from my web browser on my PC.
            One question, If I understood well, it is possible to connect to the Raspberry pi with computer and made all modification and command from the PC and not directly on the Raspberry Pi correct?
            As finally the Raspberry will not be connected to a Screen and keyboard...
            But I didn't yet search to do it, one step...
            So now, what is the next step to restore the backup ?
            Actually the backup is saved on my computer.
            And in the webpage of iobroker it's written "WELCOME" and wanted to start the assistant.
            Thanks in advance
              wonderful! ...but...
              Connect to my wifi
              why wifi? wired is more stable. No one recommends wifi for a server.
              correct!
              get yourself a ssh client. i prefer puTTY, but you also can use powershell.
              therefore you'll need a filetransfer program as filezilla.
              If you login to your raspi you should use the credentials of your user you installed iobroker with
              caution.
              if you know what to do don't use the discovery. just follow the initisl steps and if you choose using credentials, write them down!
                Juste because The place where it will be has no wired connexion
                i'm going to saerch with the SSH as I saw it directly on raspberry
                This is the biggest point... where You lost me...
                instead of filezilla, can I put on USB key? more easy for me I think.
                caution.
                Are you speaking chinese? 😊
                follow the intialization steps... Supposed you are speaking about the assistant shown in the web browser with iobroker.
                what I didn't understood (perhaps you didn't mentionned presently) is once initialization step will be done, how I will use the restore...
                in my idea, is from USB key, and I supposed that qitch the command we will restore and used the file on the usb key
                don't forget I was a newbee on System installation and upgrade, but already a very big newbee to work only with command 🙂
                  Juste one more point...
                  Can I change the password of my Raspberry? I let the "pi" username, but if I activate the SSH... It should be better to have another password.
                  Thanks
                    @tiger
                    Change your password in
                    sudo raspi-config
                      but not for me 🙂
                      surely you can do. But I don't know about mount and so.
                      no! it's suaheli!
                      Yes!
                      but after the initial settings, there you will be asked to start an automated device search. (this is the discovery adapter)
                      I think you don't need it. Maybe it will bring more confusion than benefits.
                      using the cli with iobroker restore filenameOfBackup you first have to copy the backup into /opt/iobroker/backups. after a clean install you have to create this folder
                      then you can call the restore command with the appropriate filename
                      you should!
                      at bootup the pi will tell you that not changing it is a security issue!
                        ok, SSD : Done
                        Connexion from distant PC : Done
                        Password change : Done
                        but not for me 🙂
                        No you're a specialist 🙂 If I understood weel, I have juste to copy the file from my USB key to the folder you mentionned...
                        If it's correct, I will search how to copy it 🙂
                        Searching is easy for me... finding... it's different 😊
                          no I'm just a regular user! Maybe a little advanced by nearly 10 years with iobroker.
                          but don't change the rights
                          let's ask @Thomas-Braun , he really is the specialist for linux commands
                            @homoran said in Update System iobroker failed:
                            You instist, but how can I change the rights?
                            I've just coopy the backup file from the old Sdcard...
                            Used same user in the Raspberry.
                            Or you mean the username and password of iobroker? if it's that... I've to restart and you've to tell me how to find it frome the old system... and hoping I can change this... if not I will have to restart from beginning 🙂
                            or there is something I'd miss... we'll see...
                            Maybe? for sure 🙂
                              @tiger
                              The backup file is on the usb stick now?
                              And it is sticking in the USB port of your raspberry?
                                Tiger @Thomas Braun last edited by
                                yes it is
                                and USB key is inserted
                                file name is
                                  Thomas Braun Most Active @Tiger last edited by Thomas Braun
                                  file name is
                                  Which path?
                                  Is that FileZilla that you are using as a filemanager?
                                    file is directly on the usb key, not in a folder
                                      Tiger @Thomas Braun last edited by Tiger
                                      I've nothing installed on the raspberry
                                      only iobroker and the OS lite
                                        @tiger
                                        But in Linux all files are in a path.
                                        Usually usb sticks are mounted in /media/
                                          I understand, but As I said... as I don't know Linux... difficult to know the path 🙂
                                            @tiger
                                            But where is the stick now plugged? In your Desktop computer? In your Raspberry?
                                            update iobroker
                                            20414
