    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Tiger @Homoran last edited by
      Juste one more point...
      Can I change the password of my Raspberry? I let the "pi" username, but if I activate the SSH... It should be better to have another password.
      Thanks
        Thomas Braun Most Active @Tiger last edited by
        @tiger
        Change your password in
        sudo raspi-config
          Homoran Global Moderator Administrators @Tiger last edited by
          @tiger sagte in Update System iobroker failed:
          instead of filezilla, can I put on USB key? more easy for me I think.
          but not for me 🙂
          surely you can do. But I don't know about mount and so.
          Are you speaking chinese?
          no! it's suaheli!
          Supposed you are speaking about the assistant shown in the web browser with iobroker.
          Yes!
          but after the initial settings, there you will be asked to start an automated device search. (this is the discovery adapter)
          I think you don't need it. Maybe it will bring more confusion than benefits.
          how I will use the restore...
          using the cli with iobroker restore filenameOfBackup you first have to copy the backup into /opt/iobroker/backups. after a clean install you have to create this folder
          then you can call the restore command with the appropriate filename
          you should!
          at bootup the pi will tell you that not changing it is a security issue!
            ok, SSD : Done
            Connexion from distant PC : Done
            Password change : Done
            but not for me 🙂
            No you're a specialist 🙂 If I understood weel, I have juste to copy the file from my USB key to the folder you mentionned...
            If it's correct, I will search how to copy it 🙂
            Searching is easy for me... finding... it's different 😊
              no I'm just a regular user! Maybe a little advanced by nearly 10 years with iobroker.
              but don't change the rights
              let's ask @Thomas-Braun , he really is the specialist for linux commands
                Tiger @Homoran last edited by Tiger
                @homoran said in Update System iobroker failed:
                You instist, but how can I change the rights?
                I've just coopy the backup file from the old Sdcard...
                Used same user in the Raspberry.
                Or you mean the username and password of iobroker? if it's that... I've to restart and you've to tell me how to find it frome the old system... and hoping I can change this... if not I will have to restart from beginning 🙂
                or there is something I'd miss... we'll see...
                Maybe? for sure 🙂
                  @tiger
                  The backup file is on the usb stick now?
                  And it is sticking in the USB port of your raspberry?
                    Tiger @Thomas Braun last edited by
                    yes it is
                    and USB key is inserted
                    file name is
                      Thomas Braun Most Active @Tiger last edited by Thomas Braun
                      file name is
                      Which path?
                      Is that FileZilla that you are using as a filemanager?
                        file is directly on the usb key, not in a folder
                          Tiger @Thomas Braun last edited by Tiger
                          I've nothing installed on the raspberry
                          only iobroker and the OS lite
                            @tiger
                            But in Linux all files are in a path.
                            Usually usb sticks are mounted in /media/
                              I understand, but As I said... as I don't know Linux... difficult to know the path 🙂
                                @tiger
                                But where is the stick now plugged? In your Desktop computer? In your Raspberry?
                                  plug on the raspberry, and i've install without desktop... as recommended
                                    @tiger
                                    I don't get it...
                                    ls -la /media
                                      Sorry, I didn't found up to know how to copy text from PuTTY
                                        @tiger
                                        Copy the backupfile from your Desktop computer over to the Raspberry with FileZilla. Target directroy /opt/iobroker/backups
                                        T 3 Replies Last reply Reply Quote 0
                                          ok, I've to search how to achieve it... Filezila should be installed on raspberry? or only on y desktop computer?
                                          If you've a website with some tuto or explanation... it should good 🙂
                                          I'm going to work now... will try later.
                                          Thanks a lot.
                                            ok found an explanation...
                                            will try later.
                                            update iobroker
                                            20404
