    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Tiger @Homoran last edited by
      ok, SSD : Done
      Connexion from distant PC : Done
      Password change : Done
      but not for me 🙂
      surely you can do. But I don't know about mount and so.
      No you're a specialist 🙂 If I understood weel, I have juste to copy the file from my USB key to the folder you mentionned...
      If it's correct, I will search how to copy it 🙂
      Searching is easy for me... finding... it's different 😊
        Homoran Global Moderator Administrators @Tiger last edited by
        @tiger sagte in Update System iobroker failed:
        no I'm just a regular user! Maybe a little advanced by nearly 10 years with iobroker.
        but don't change the rights
        let's ask @Thomas-Braun , he really is the specialist for linux commands
          Tiger @Homoran last edited by Tiger
          @homoran said in Update System iobroker failed:
          You instist, but how can I change the rights?
          I've just coopy the backup file from the old Sdcard...
          Used same user in the Raspberry.
          Or you mean the username and password of iobroker? if it's that... I've to restart and you've to tell me how to find it frome the old system... and hoping I can change this... if not I will have to restart from beginning 🙂
          or there is something I'd miss... we'll see...
          Maybe? for sure 🙂
            Thomas Braun Most Active @Tiger last edited by
            @tiger
            The backup file is on the usb stick now?
            And it is sticking in the USB port of your raspberry?
              Tiger @Thomas Braun last edited by
              yes it is
              and USB key is inserted
              file name is
                Thomas Braun Most Active @Tiger last edited by Thomas Braun
                file name is
                Which path?
                Is that FileZilla that you are using as a filemanager?
                  file is directly on the usb key, not in a folder
                    Tiger @Thomas Braun last edited by Tiger
                    I've nothing installed on the raspberry
                    only iobroker and the OS lite
                      @tiger
                      But in Linux all files are in a path.
                      Usually usb sticks are mounted in /media/
                        I understand, but As I said... as I don't know Linux... difficult to know the path 🙂
                          @tiger
                          But where is the stick now plugged? In your Desktop computer? In your Raspberry?
                            plug on the raspberry, and i've install without desktop... as recommended
                              @tiger
                              I don't get it...
                              ls -la /media
                                Sorry, I didn't found up to know how to copy text from PuTTY
                                  @tiger
                                  Copy the backupfile from your Desktop computer over to the Raspberry with FileZilla. Target directroy /opt/iobroker/backups
                                  T 3 Replies Last reply Reply Quote 0
                                    ok, I've to search how to achieve it... Filezila should be installed on raspberry? or only on y desktop computer?
                                    If you've a website with some tuto or explanation... it should good 🙂
                                    I'm going to work now... will try later.
                                    Thanks a lot.
                                      ok found an explanation...
                                      will try later.
                                        everything done..
                                        try to restore...
                                        but
                                        pi@raspberrypi:~ $ iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz
                                        iobroker controller daemon is not running
                                        host.raspberrypi OK.
                                        The current version of js-controller differs from the version in the backup.
                                        The js-controller version of the backup can not be restored automatically.
                                        To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@3.1.6 --production" inside your ioBroker directory
                                        If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
                                          Homoran Global Moderator Administrators @Tiger last edited by Homoran
                                          but
                                          what a luck!
                                          as @crunchip mentioned you should install vis before restore
                                          so please do it now.
                                          the fialog asks you what controller you wsnt to have.
                                          The actual install also has the actual controller.
                                          Your backup has an ancient one
                                          so please install vis iobroker install vis after that make another try ant choose the
                                          i.e.
                                          iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz --force
                                          (i hope)
                                            Vis installed
                                            Backup with --force done...
                                            ADmin version has beenn downgrade to 4.0 as before...
                                            In the journal log it seems that iobroker is reinstalling all the adapters needed...
                                            as there is all line like that
                                            host.raspberrypi 2022-08-16 15:16:43.415 info iobroker npm-install: 28 packages are looking for funding run npm fund for details
                                            host.raspberrypi 2022-08-16 15:16:43.413 info iobroker npm-install: added 1 package in 5s
                                            host.raspberrypi 2022-08-16 15:16:43.412 info iobroker npm-install:
                                            host.raspberrypi 2022-08-16 15:16:37.347 info iobroker npm-install: Installing iobroker.history@1.9.10... (System call)
                                            host.raspberrypi 2022-08-16 15:16:37.342 info iobroker npm-install: NPM version: 8.11.0
                                            host.raspberrypi 2022-08-16 15:16:34.656 info iobroker install history@1.9.10 using installedFrom
                                            host.raspberrypi 2022-08-16 15:16:34.656 warn startInstance cannot find adapter "history@1.9.10". Try to install it... 1 attempt
                                            update iobroker
                                            20404
