    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Tiger @Thomas Braun last edited by
      yes it is
      and USB key is inserted
      file name is
        Thomas Braun Most Active @Tiger last edited by Thomas Braun
        @tiger sagte in Update System iobroker failed:
        file name is
        Which path?
        Is that FileZilla that you are using as a filemanager?
          file is directly on the usb key, not in a folder
            Tiger @Thomas Braun last edited by Tiger
            I've nothing installed on the raspberry
            only iobroker and the OS lite
              @tiger
              But in Linux all files are in a path.
              Usually usb sticks are mounted in /media/
                I understand, but As I said... as I don't know Linux... difficult to know the path 🙂
                  @tiger
                  But where is the stick now plugged? In your Desktop computer? In your Raspberry?
                    plug on the raspberry, and i've install without desktop... as recommended
                      @tiger
                      I don't get it...
                      ls -la /media
                        Sorry, I didn't found up to know how to copy text from PuTTY
                          @tiger
                          Copy the backupfile from your Desktop computer over to the Raspberry with FileZilla. Target directroy /opt/iobroker/backups
                          T 3 Replies Last reply Reply Quote 0
                            ok, I've to search how to achieve it... Filezila should be installed on raspberry? or only on y desktop computer?
                            If you've a website with some tuto or explanation... it should good 🙂
                            I'm going to work now... will try later.
                            Thanks a lot.
                              ok found an explanation...
                              will try later.
                                everything done..
                                try to restore...
                                but
                                pi@raspberrypi:~ $ iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz
                                iobroker controller daemon is not running
                                host.raspberrypi OK.
                                The current version of js-controller differs from the version in the backup.
                                The js-controller version of the backup can not be restored automatically.
                                To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@3.1.6 --production" inside your ioBroker directory
                                If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
                                  Homoran Global Moderator Administrators @Tiger last edited by Homoran
                                  but
                                  what a luck!
                                  as @crunchip mentioned you should install vis before restore
                                  so please do it now.
                                  the fialog asks you what controller you wsnt to have.
                                  The actual install also has the actual controller.
                                  Your backup has an ancient one
                                  so please install vis iobroker install vis after that make another try ant choose the
                                  i.e.
                                  iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz --force
                                  (i hope)
                                    Tiger @Homoran last edited by Tiger
                                    Vis installed
                                    Backup with --force done...
                                    ADmin version has beenn downgrade to 4.0 as before...
                                    In the journal log it seems that iobroker is reinstalling all the adapters needed...
                                    as there is all line like that
                                    host.raspberrypi 2022-08-16 15:16:43.415 info iobroker npm-install: 28 packages are looking for funding run npm fund for details
                                    host.raspberrypi 2022-08-16 15:16:43.413 info iobroker npm-install: added 1 package in 5s
                                    host.raspberrypi 2022-08-16 15:16:43.412 info iobroker npm-install:
                                    host.raspberrypi 2022-08-16 15:16:37.347 info iobroker npm-install: Installing iobroker.history@1.9.10... (System call)
                                    host.raspberrypi 2022-08-16 15:16:37.342 info iobroker npm-install: NPM version: 8.11.0
                                    host.raspberrypi 2022-08-16 15:16:34.656 info iobroker install history@1.9.10 using installedFrom
                                    host.raspberrypi 2022-08-16 15:16:34.656 warn startInstance cannot find adapter "history@1.9.10". Try to install it... 1 attempt
                                      @tiger at this moment the restore itself is finished and all adapters were built.
                                      this will last a time
                                        @homoran said in Update System iobroker failed:
                                        It can take is time:)
                                        after that, supposed that all adapters will be installed with the last versions...
                                        and the last thing will be to update the iobroker.admin... and perhaps js-controller depending of the version.
                                          no!
                                          they will stay in their versions of the backup.
                                          but now your controller is in a living version and all updates should work
                                          it has to be the next thing, and then the others
                                            everything came back as before.
                                            But, Things I forgot to do...
                                            Node-red doens't work as all node has to be reinstall ...
                                            So, what is your recommandation? trying to have all working as before and after made the update?
                                            Or I search before how to have the backup of Node-red and other things... before continue?
                                            same for VIS, not possible to connect to vis from browser
                                            Homoran mickym crunchip 3 Replies Last reply Reply Quote 0
                                            update iobroker
                                            20401
