    4. (Gelöst)Pegelalarm zeigt angelegte Stationen nicht an
    • Damrak2022
      Damrak2022 last edited by Damrak2022
      Bei mir habe ich das Problem, das Pegelalarm mir von den 4 angelegten Stationen nur eine anzeigt.
      Anbei der Debug Log
      host.homebridge
      2022-08-15 18:53:24.955	info	instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
      pegelalarm.0
      2022-08-15 18:53:24.351	info	Terminated (NO_ERROR): Without reason
      pegelalarm.0
      2022-08-15 18:53:24.350	debug	Plugin sentry destroyed
      pegelalarm.0
      2022-08-15 18:53:24.341	debug	cleaned everything up...
      pegelalarm.0
      2022-08-15 18:53:24.176	debug	Check for deleting old states is started
      pegelalarm.0
      2022-08-15 18:53:24.175	debug	Pegelalarm Request is completed
      pegelalarm.0
      2022-08-15 18:53:23.174	debug	Pegelalarm request for measuring station 4 is finish ...
      pegelalarm.0
      2022-08-15 18:53:23.173	debug	Pegelalarm request done
      mihome-vacuum.0
      2022-08-15 18:53:22.820	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/blob/master/lib/canvaserror.md
      pegelalarm.0
      2022-08-15 18:53:20.906	debug	Pegelalarm API is available ... Status: 200
      pegelalarm.0
      2022-08-15 18:53:20.807	debug	https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Trave&qWater=Trave&qStationName=Travem%C3%BCnde
      pegelalarm.0
      2022-08-15 18:53:20.806	debug	Pegelalarm request for measuring station 4 is started ...
      pegelalarm.0
      2022-08-15 18:53:19.804	debug	Pegelalarm request for measuring station 3 is finish ...
      pegelalarm.0
      2022-08-15 18:53:19.803	debug	Pegelalarm request done
      pegelalarm.0
      2022-08-15 18:53:19.678	debug	Pegelalarm API is available ... Status: 200
      pegelalarm.0
      2022-08-15 18:53:19.589	debug	https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Trave&qWater=Trave&qStationName=L%C3%BCbeck-Moisling
      pegelalarm.0
      2022-08-15 18:53:19.588	debug	Pegelalarm request for measuring station 3 is started ...
      pegelalarm.0
      2022-08-15 18:53:18.588	debug	Pegelalarm request for measuring station 2 is finish ...
      pegelalarm.0
      2022-08-15 18:53:18.586	debug	Pegelalarm request done
      pegelalarm.0
      2022-08-15 18:53:18.375	debug	Pegelalarm API is available ... Status: 200
      pegelalarm.0
      2022-08-15 18:53:18.286	debug	https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Rhein&qWater=Rhein%20(Rhin,%20Rijn)&qStationName=Bingen
      pegelalarm.0
      2022-08-15 18:53:18.286	debug	Pegelalarm request for measuring station 2 is started ...
      Hat jemand eine Idee wie ich das behebe?
      arteck Negalein 2 Replies Last reply Reply Quote 0
        arteck Developer Most Active @Damrak2022 last edited by arteck
        @damrak2022 sagte in Pegelalarm zeigt angelegte Stationen nicht an:
        https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Rhein&qWater=Rhein (Rhin, Rijn)&qStationName=Bingen
        ruf doch den link selber auf und schaue was da rauskommt..
        jier bei dem kommt nix.. da wird nix geliefert
        bei dem hier
        https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Trave&qWater=Trave&qStationName=Travemünde
        schon
        • Negalein
          Negalein Global Moderator @Damrak2022 last edited by
          zeig mal Screenshots deiner Konfig.
          • Damrak2022
            Damrak2022 @Negalein last edited by
            @negalein Welche Konfiguration meinstDu, die des Adapters?
            So sehen auf jeden Fall meine Objekte aus, obwohl ich 4 Stationen angelegt habe, wird ir unter den Objekten nur eine angezeigt.
            Angelegt habe ich:
            Region Main - Wasser Main - Stationsname Frankfurt Osthafen
            Region Rhein - Wasser Rhein - Stationsname Bingen
            Region Trave - Wasser Trave - Stationsname Lübeck-Moisling
            Region Trave - Wasser Trave - Stationsname Travemünde
            Selbst wenn Bingen keine Daten liefert, wie Du schreibst, so müssten doch zumindest die Stationsnamen unter Objekten angelegt werden, oder?
            • DJMarc75
              DJMarc75 @Damrak2022 last edited by
              @damrak2022 Der Adapter holt sich die Daten von den Stationen.
              @arteck sagte in Pegelalarm zeigt angelegte Stationen nicht an:
              Warum ? Der Adapter wird so programmiert sein dass nur wenn Daten kommen auch Ordner und DPs angelegt werden ?
              • Damrak2022
                Damrak2022 @DJMarc75 last edited by
                @djmarc75 Ja, das könnte natürlich sein. Ich wusste nicht das man das so machen kann.
                • DJMarc75
                  • Damrak2022
                    @djmarc75 so programmieren kann
                    • Damrak2022
                      @djmarc75 Weißt Du zufällig was beim Main die Bezeichnung Griesheim_op und Griesheim_up bedeutet.
                      • DJMarc75
                        Na ich schätze dass das 2 verschiedene Stationen sind?!
                        Ich kenne den Adapter nicht.
                          Tontechniker last edited by
                          Ich habe seit einiger Zeit Probleme mit der Anzeige von zwei Stationen.
                          Habe den Adapter gelöscht und neu installiert mit dem gleichen Ergebnis.
                          Das Problem trat nach einem Versionswechsel auf. Früher habe ich als Region "Hessen" eingegeben. Wenn ich das jetzt tue ist der Fluss Fulda nicht mehr aufgelistet. Meine jetzige Version ist V1.3.2.
                          Kann mir jemand sagen, woran das liegt?
                          461
