    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Thomas Braun Most Active @Tiger last edited by
      @tiger
      But in Linux all files are in a path.
      Usually usb sticks are mounted in /media/
        Tiger @Thomas Braun last edited by
        I understand, but As I said... as I don't know Linux... difficult to know the path 🙂
          @tiger
          But where is the stick now plugged? In your Desktop computer? In your Raspberry?
            plug on the raspberry, and i've install without desktop... as recommended
              @tiger
              I don't get it...
              ls -la /media
                Sorry, I didn't found up to know how to copy text from PuTTY
                  @tiger
                  Copy the backupfile from your Desktop computer over to the Raspberry with FileZilla. Target directroy /opt/iobroker/backups
                  T 3 Replies Last reply Reply Quote 0
                    ok, I've to search how to achieve it... Filezila should be installed on raspberry? or only on y desktop computer?
                    If you've a website with some tuto or explanation... it should good 🙂
                    I'm going to work now... will try later.
                    Thanks a lot.
                      ok found an explanation...
                      will try later.
                        everything done..
                        try to restore...
                        but
                        pi@raspberrypi:~ $ iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz
                        iobroker controller daemon is not running
                        host.raspberrypi OK.
                        The current version of js-controller differs from the version in the backup.
                        The js-controller version of the backup can not be restored automatically.
                        To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@3.1.6 --production" inside your ioBroker directory
                        If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
                          Homoran Global Moderator Administrators @Tiger last edited by Homoran
                          @tiger sagte in Update System iobroker failed:
                          but
                          what a luck!
                          as @crunchip mentioned you should install vis before restore
                          so please do it now.
                          the fialog asks you what controller you wsnt to have.
                          The actual install also has the actual controller.
                          Your backup has an ancient one
                          so please install vis iobroker install vis after that make another try ant choose the
                          i.e.
                          iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz --force
                          (i hope)
                            Tiger @Homoran last edited by Tiger
                            Vis installed
                            Backup with --force done...
                            ADmin version has beenn downgrade to 4.0 as before...
                            In the journal log it seems that iobroker is reinstalling all the adapters needed...
                            as there is all line like that
                            host.raspberrypi 2022-08-16 15:16:43.415 info iobroker npm-install: 28 packages are looking for funding run npm fund for details
                            host.raspberrypi 2022-08-16 15:16:43.413 info iobroker npm-install: added 1 package in 5s
                            host.raspberrypi 2022-08-16 15:16:43.412 info iobroker npm-install:
                            host.raspberrypi 2022-08-16 15:16:37.347 info iobroker npm-install: Installing iobroker.history@1.9.10... (System call)
                            host.raspberrypi 2022-08-16 15:16:37.342 info iobroker npm-install: NPM version: 8.11.0
                            host.raspberrypi 2022-08-16 15:16:34.656 info iobroker install history@1.9.10 using installedFrom
                            host.raspberrypi 2022-08-16 15:16:34.656 warn startInstance cannot find adapter "history@1.9.10". Try to install it... 1 attempt
                              @tiger at this moment the restore itself is finished and all adapters were built.
                              this will last a time
                                @homoran said in Update System iobroker failed:
                                It can take is time:)
                                after that, supposed that all adapters will be installed with the last versions...
                                and the last thing will be to update the iobroker.admin... and perhaps js-controller depending of the version.
                                  no!
                                  they will stay in their versions of the backup.
                                  but now your controller is in a living version and all updates should work
                                  it has to be the next thing, and then the others
                                    everything came back as before.
                                    But, Things I forgot to do...
                                    Node-red doens't work as all node has to be reinstall ...
                                    So, what is your recommandation? trying to have all working as before and after made the update?
                                    Or I search before how to have the backup of Node-red and other things... before continue?
                                    same for VIS, not possible to connect to vis from browser
                                    Homoran mickym crunchip 3 Replies Last reply Reply Quote 0
                                      ohhhh, I didn't work with node red for years now.
                                      let's try to call @mickym , i guess he can help. I've read there are different possibilities to install the nodes not supplied with the adapter.
                                      • mickym
                                        mickym Most Active @Tiger last edited by
                                        @tiger You can try - the following.
                                        Restore from your former image the package.json file into /opt/iobroker/iobroker-data/node-red directory. replace the existing one or rename it. Run npm install.
                                        Change to that directory:
                                        cd /opt/iobroker/iobroker-data/node-red
                                        npm install
                                          Tiger @mickym last edited by
                                          @mickym
                                          thanks for your answer,
                                          To be sure what I've to do... (to avoid problem... I'm newbee 🙂 )
                                          I've juste to replace the package.json file in the actual directory /opt/iobroker/iobroker-data/node-red by the old one my old sdcard?
                                          and after that run npm install, correct?
                                          stupid question, to have access to the file on my old SDcard, is it possible to place the SDcard on my windows desktop pc and save it? or I've to place the old SDcard in the raspberry Pi to pick up file with filezilla?
                                          Homoran mickym 2 Replies Last reply Reply Quote 0
                                            I'm pretty sure windows won't see it 😞
                                            update iobroker
                                            20403
