    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Tiger @Thomas Braun last edited by
      Sorry, I didn't found up to know how to copy text from PuTTY
        Thomas Braun Most Active @Tiger last edited by
        @tiger
        Copy the backupfile from your Desktop computer over to the Raspberry with FileZilla. Target directroy /opt/iobroker/backups
        T 3 Replies Last reply Reply Quote 0
          ok, I've to search how to achieve it... Filezila should be installed on raspberry? or only on y desktop computer?
          If you've a website with some tuto or explanation... it should good 🙂
          I'm going to work now... will try later.
          Thanks a lot.
            ok found an explanation...
            will try later.
              everything done..
              try to restore...
              but
              pi@raspberrypi:~ $ iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz
              iobroker controller daemon is not running
              host.raspberrypi OK.
              The current version of js-controller differs from the version in the backup.
              The js-controller version of the backup can not be restored automatically.
              To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@3.1.6 --production" inside your ioBroker directory
              If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
                Homoran Global Moderator Administrators @Tiger last edited by Homoran
                @tiger sagte in Update System iobroker failed:
                but
                what a luck!
                as @crunchip mentioned you should install vis before restore
                so please do it now.
                the fialog asks you what controller you wsnt to have.
                The actual install also has the actual controller.
                Your backup has an ancient one
                so please install vis iobroker install vis after that make another try ant choose the
                i.e.
                iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz --force
                (i hope)
                  Tiger @Homoran last edited by Tiger
                  Vis installed
                  Backup with --force done...
                  ADmin version has beenn downgrade to 4.0 as before...
                  In the journal log it seems that iobroker is reinstalling all the adapters needed...
                  as there is all line like that
                  host.raspberrypi 2022-08-16 15:16:43.415 info iobroker npm-install: 28 packages are looking for funding run npm fund for details
                  host.raspberrypi 2022-08-16 15:16:43.413 info iobroker npm-install: added 1 package in 5s
                  host.raspberrypi 2022-08-16 15:16:43.412 info iobroker npm-install:
                  host.raspberrypi 2022-08-16 15:16:37.347 info iobroker npm-install: Installing iobroker.history@1.9.10... (System call)
                  host.raspberrypi 2022-08-16 15:16:37.342 info iobroker npm-install: NPM version: 8.11.0
                  host.raspberrypi 2022-08-16 15:16:34.656 info iobroker install history@1.9.10 using installedFrom
                  host.raspberrypi 2022-08-16 15:16:34.656 warn startInstance cannot find adapter "history@1.9.10". Try to install it... 1 attempt
                    @tiger at this moment the restore itself is finished and all adapters were built.
                    this will last a time
                      @homoran said in Update System iobroker failed:
                      It can take is time:)
                      after that, supposed that all adapters will be installed with the last versions...
                      and the last thing will be to update the iobroker.admin... and perhaps js-controller depending of the version.
                        no!
                        they will stay in their versions of the backup.
                        but now your controller is in a living version and all updates should work
                        it has to be the next thing, and then the others
                          everything came back as before.
                          But, Things I forgot to do...
                          Node-red doens't work as all node has to be reinstall ...
                          So, what is your recommandation? trying to have all working as before and after made the update?
                          Or I search before how to have the backup of Node-red and other things... before continue?
                          same for VIS, not possible to connect to vis from browser
                          Homoran mickym crunchip 3 Replies Last reply Reply Quote 0
                            ohhhh, I didn't work with node red for years now.
                            let's try to call @mickym , i guess he can help. I've read there are different possibilities to install the nodes not supplied with the adapter.
                            • mickym
                              mickym Most Active @Tiger last edited by
                              @tiger You can try - the following.
                              Restore from your former image the package.json file into /opt/iobroker/iobroker-data/node-red directory. replace the existing one or rename it. Run npm install.
                              Change to that directory:
                              cd /opt/iobroker/iobroker-data/node-red
                              npm install
                                Tiger @mickym last edited by
                                @mickym
                                thanks for your answer,
                                To be sure what I've to do... (to avoid problem... I'm newbee 🙂 )
                                I've juste to replace the package.json file in the actual directory /opt/iobroker/iobroker-data/node-red by the old one my old sdcard?
                                and after that run npm install, correct?
                                stupid question, to have access to the file on my old SDcard, is it possible to place the SDcard on my windows desktop pc and save it? or I've to place the old SDcard in the raspberry Pi to pick up file with filezilla?
                                Homoran mickym 2 Replies Last reply Reply Quote 0
                                  I'm pretty sure windows won't see it 😞
                                    crunchip Forum Testing Most Active @Tiger last edited by
                                    show the settings for vis and web. You use the socketio?
                                    • mickym
                                      @mickym
                                      correct. I doubt that you can directly access the files on your SD card , because you have no drivers in windows. for the ext4 file system. In your case - I would boot with the old SD card and copy the whole directory /opt/iobroker/iobroker-data/node-red to your USB stick. When you boot with the new card - you should have access to all files wherever you mounted your USB stick. You should even be able to replace the complete new directory in the /opt/iobroker-dat with the old one. Rename the exiting one and replace it with the new one. If you want to know what the files in your /opt/iobroker/iobroker-data/node-red data mean you can have a look to my extensive description here: https://github.com/ioBroker/ioBroker.node-red/issues/320
                                      mickym2 created this issue in ioBroker/ioBroker.node-red
                                      closed No restore for NodeRed instances with activated project function #320
                                        Tiger @mickym last edited by Tiger
                                        @mickym
                                        Sorry, didn't see your post before doing it...
                                        So I took the package.json and replace in the node-red and made npm install in the directory
                                        Error with alexa node, seems that the node used before doesn't exist now
                                        pi@raspberrypi:/opt/iobroker/iobroker-data/node-red $ npm install
                                        npm ERR! code ENOVERSIONS
                                        npm ERR! No versions available for node-red-node-alexa
                                        npm ERR!     /home/iobroker/.npm/_logs/2022-08-16T14_59_56_194Z-debug-0.log
                                        log file 2022-08-16T14_59_56_194Z-debug-0.log
                                        Do you want that I tryed with copy af all the directory? there is a lot of files... more than 60.000
                                        • mickym
                                          mickym Most Active @Tiger last edited by mickym
                                          node-red-node-alexa
                                          So this node is no longer supported. As said you can rename the existing directory and copy the whole directory to the original place - but I do not recommend this. So better is to look for an replacement.
                                          If you want to try if the old one is running copying the old directory in total - you should first rename the exiting one before you copy the old one. But better is to remove the alexa node. If this is the only error then you should have all except the alexa node.
                                          to test if the old one will run. you can do
                                          mv node-red node-red.new
                                          and then copy the old directory into the iobroker-data directory. But I am not sure if this old alexa node will work at all.
                                            @mickym
                                            I'm Trying to understand 🙂
                                            1 I've to test with your command
                                            once made, (depending of the result)
                                            • change the name of the directory to have backup I supposed
                                            • Copy all the directory from the old SD Card (lots of files... more than 60.000....) to the new SD Card at same place
                                            and after?
                                            update iobroker
                                            20397
