    2. English
    3. ioBroker general
    4. Update System iobroker failed
    • mickym
      mickym Most Active @Tiger last edited by mickym
      @tiger sagte in Update System iobroker failed:
      node-red-node-alexa
      So this node is no longer supported. As said you can rename the existing directory and copy the whole directory to the original place - but I do not recommend this. So better is to look for an replacement.
      If you want to try if the old one is running copying the old directory in total - you should first rename the exiting one before you copy the old one. But better is to remove the alexa node. If this is the only error then you should have all except the alexa node.
      to test if the old one will run. you can do
      cd /opt/iobroker/iobroker-data
      mv node-red node-red.new
      and then copy the old directory into the iobroker-data directory. But I am not sure if this old alexa node will work at all.
        Tiger @mickym last edited by Tiger
        @mickym
        I'm Trying to understand 🙂
        1 I've to test with your command
        once made, (depending of the result)
        • change the name of the directory to have backup I supposed
        • Copy all the directory from the old SD Card (lots of files... more than 60.000....) to the new SD Card at same place
        and after?
          Tiger @crunchip last edited by
          @crunchip
          don't remember if socketio is used but it was installed.
          Web.0 is not configured, And I didn't reached to change the Ip adress.
          Configuration of VIS, nothing, lincence key is show and when checking licence it's OK
          Configuration of Web.0
          No ip Adress, supposed is the reason
          • mickym
            @mickym
            and after?
            after you copied the old directory under /opt/iobroker/iobroker-data make sure that the rights are adapted.
            go to the /opt/iobroker/iobroker-data directory and execute:
            sudo chown -R iobroker:iobroker node-red
            this will ensure that user iobroker has access to all files and you can try to start the adapter. If this will not work - you have to use again the backup (node-red.new) and delete the reference of the old alexa node in the package.json file. However I guess all other nodes should have been installed.
            I have to go off now and can only support you on my mobile. But this is very limited. But these are standard procedures all others should be familiar with. 😉
              @mickym said in Update System iobroker failed:
              What do you mean by that?
              • mickym
                @tiger If you copy with user pi - all files are owned by this user. As iobroker runs under user iobroker you need to change the owner of the files and directories.
                  @mickym
                  ok I've same user name as before
                  • mickym
                    @tiger So but I am not sure if the old node will work at all with the new node version. You should better think about a replacement.
                      @mickym
                      So... if I'm understanding well...
                      I've to let like that without copy the directory...
                      install the new node of Alexa...
                      and made a new programmation?
                      as i wanted to have an installation up to date... if it's your recommandation... i'll do like that...
                        Tiger @Homoran last edited by
                        No problem Now that I'd understood Filezilla 🙂
                        I'm going to have all working, and after we'll see to the update.
                        After Node-red.. that if I understand well I've to reprogram... for alexa
                        I've to check VIS
                        RFXCOM it seems that I've to pair everything as I've the devices but seems not connected
                        Zigbee, probably same, I've to pair everything
                          crunchip Forum Testing Most Active @Tiger last edited by
                          Not currently, you can switch and test it or use pure web sockets
                          • mickym
                            @mickym
                            Yes my recommendation is to do not copy the old stuff. Edit your package.json and delete the line in the dependencies section which refers to the old- alexa node. Run npm install hopefully without errors. Activate in the node red adapter configuration that you use the pallet manager and install a different node. Then you need to rework all alexa flows
                              Homoran Global Moderator Administrators @Tiger last edited by
                              i don't use zigbee and therefore I'm very sorry if there is a pitfall too.
                              But @Thomas-Braun may know wether there will be a solution.
                                package.json
                                ok I'll do it...
                                but, how do you edit the package.json?
                                  No it seems everything is working well...
                                  Zigbee and Rfxcom... good news...
                                    @crunchip
                                    it seems it's due to my version of iobroker.admin...
                                    I thing we'll be able to solve it after upgrading system...
                                    2022-08-16 18:10:28.357	error	startInstance system.adapter.web.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "4.0.10", required ">=5.1.0"!
                                      @tiger I do not understand all the problems, that was a backup with the backitup adapter? Why admin 4
                                        Homoran Global Moderator Administrators @crunchip last edited by
                                        @crunchip sagte in Update System iobroker failed:
                                        no manually by iobroker backup
                                        the admin had been downgraded by the restore
                                          crunchip Forum Testing Most Active @Homoran last edited by crunchip
                                          Vis installed
                                          Backup with --force done...
                                          ADmin version has beenn downgrade to 4.0 as before...
                                          Why
                                          itself or through backup
                                          then do the upgrade
                                          • mickym
                                            package.json
                                            ok I'll do it...
                                            Goto directory
                                            cd /opt/iobroker/iobroker-data/node-red
                                            nano package.json
                                            If a message occurs that file is write protected then use
                                            sudo nano package.json
                                            Search for the reference of the alexa node. CTRL + k should delete line. I’m typing on my mobile so you need to look at the bottom describing the short-cuts. CTRL + x to
                                            exit and confirm to write.
                                            Ensure that you run npm install in the directory /opt/iobroker/iobroker-data/node-red. After you started the Node Red Adapter using the pallet manager, remove all alexa nodes from your flows and update your nodes within the pallet manager, if updates are available. This should be done on a regular base. Keep your system up to date to avoid surprises like this.
                                            T 3 Replies Last reply Reply Quote 0
                                            update iobroker
                                            18325
