    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Tiger @Homoran last edited by
      No problem Now that I'd understood Filezilla 🙂
      I'm going to have all working, and after we'll see to the update.
      After Node-red.. that if I understand well I've to reprogram... for alexa
      I've to check VIS
      RFXCOM it seems that I've to pair everything as I've the devices but seems not connected
      Zigbee, probably same, I've to pair everything
        crunchip Forum Testing Most Active @Tiger last edited by
        @tiger sagte in Update System iobroker failed:
        don't remember if socketio is used but it was installed.
        Not currently, you can switch and test it or use pure web sockets
        • mickym
          mickym Most Active @Tiger last edited by
          @mickym
          So... if I'm understanding well...
          I've to let like that without copy the directory...
          install the new node of Alexa...
          and made a new programmation?
          as i wanted to have an installation up to date... if it's your recommandation... i'll do like that...
          Yes my recommendation is to do not copy the old stuff. Edit your package.json and delete the line in the dependencies section which refers to the old- alexa node. Run npm install hopefully without errors. Activate in the node red adapter configuration that you use the pallet manager and install a different node. Then you need to rework all alexa flows
            Homoran Global Moderator Administrators @Tiger last edited by
            i don't use zigbee and therefore I'm very sorry if there is a pitfall too.
            But @Thomas-Braun may know wether there will be a solution.
              Tiger @mickym last edited by
              @mickym said in Update System iobroker failed:
              package.json
              ok I'll do it...
              but, how do you edit the package.json?
                No it seems everything is working well...
                Zigbee and Rfxcom... good news...
                  Tiger @crunchip last edited by
                  @crunchip
                  it seems it's due to my version of iobroker.admin...
                  I thing we'll be able to solve it after upgrading system...
                  2022-08-16 18:10:28.357	error	startInstance system.adapter.web.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "4.0.10", required ">=5.1.0"!
                    @tiger I do not understand all the problems, that was a backup with the backitup adapter? Why admin 4
                      Homoran Global Moderator Administrators @crunchip last edited by
                      @crunchip sagte in Update System iobroker failed:
                      no manually by iobroker backup
                      the admin had been downgraded by the restore
                        crunchip Forum Testing Most Active @Homoran last edited by crunchip
                        Vis installed
                        Backup with --force done...
                        ADmin version has beenn downgrade to 4.0 as before...
                        Why
                        itself or through backup
                        then do the upgrade
                        • mickym
                          package.json
                          ok I'll do it...
                          Goto directory
                          cd /opt/iobroker/iobroker-data/node-red
                          nano package.json
                          If a message occurs that file is write protected then use
                          sudo nano package.json
                          Search for the reference of the alexa node. CTRL + k should delete line. I’m typing on my mobile so you need to look at the bottom describing the short-cuts. CTRL + x to
                          exit and confirm to write.
                          Ensure that you run npm install in the directory /opt/iobroker/iobroker-data/node-red. After you started the Node Red Adapter using the pallet manager, remove all alexa nodes from your flows and update your nodes within the pallet manager, if updates are available. This should be done on a regular base. Keep your system up to date to avoid surprises like this.
                          T 3 Replies Last reply Reply Quote 0
                            through backup
                            as I understood
                              @mickym
                              I made by another way as i've not a lot of node to install and needed.
                              I installed node manually,
                              Now I'm trying to find the correct alexa node...
                              moreover The boolean-logic that was installed don't work now... I had a AND node, that works good... now don't work...
                              So I'm truing to find these two solution.
                              node-red is correctly connect to My LOGO !8 from siemens
                              Regards
                                Tiger @mickym last edited by Tiger
                                @mickym
                                Alexa works... and boolean now too...
                                So I'm going to made all as before with the new node...
                                See you all after that to upgrade my system !
                                  @mickym
                                  Don't know why,
                                  Was trying to add other functionnality that doesn't work with node amazon
                                  and connexion lost
                                  message in the log file are like that
                                  node-red.0	2022-08-16 21:00:26.108	info	(8145) node-red exited with 1
                                  node-red.0	2022-08-16 21:00:25.642	warn	(8145) 16 Aug 21:00:25 - [warn] Projects disabled : editorTheme.projects.enabled=false
                                  node-red.0	2022-08-16 21:00:21.074	warn	(8145) (node:8183) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/node_modules/@node-red/editor-client/package.json' of './lib/index.js'. Please either fix that or report it to t
                                  node-red.0	2022-08-16 21:00:21.067	warn	(8145) 16 Aug 21:00:21 - [warn] server.httpadminauth-deprecated
                                  node-red.0	2022-08-16 21:00:19.544	info	(8145) Starting node-red: --max-old-space-size=2048 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                                  • mickym
                                    mickym Most Active @Tiger last edited by mickym
                                    @tiger I cant help you with alexa - as I personally do not use it. The only node - which I help for support was this node:
                                    node-red-contrib-virtual-smart-home. The message which you log are specific to nodes that you have installed.
                                      @mickym
                                      how can i solved it?
                                      as i can't access to node-red now...
                                      when trying to open node-red message appear
                                      This site is not accessible
                                      192.168.1.16 don't allow the connexion
                                      • mickym
                                        @tiger Try to start node-red in secure mode - then the flows do not start and you can delete all alexa stuff.
                                          @mickym
                                          ok now.
                                          With your node-red-contrib-virtual-smart-home, it works with alexa?
                                          • mickym
                                            @tiger As I said - I have no alexa - however when users used it they had good experience .
                                            https://flows.nodered.org/node/node-red-contrib-virtual-smart-home
                                            You need to register it.
                                            But to be honest - if there are only problems with alexa and the other flows work - you may should ask for help from users who work with alexa. So if all your other nodes work - then you should open a separate thread to solve your alexa issues.
                                            update iobroker
                                            18261
