    2. English
    3. ioBroker general
    4. Update System iobroker failed
    • mickym
      mickym Most Active @Tiger last edited by
      @tiger sagte in Update System iobroker failed:
      @mickym
      So... if I'm understanding well...
      I've to let like that without copy the directory...
      install the new node of Alexa...
      and made a new programmation?
      as i wanted to have an installation up to date... if it's your recommandation... i'll do like that...
      Yes my recommendation is to do not copy the old stuff. Edit your package.json and delete the line in the dependencies section which refers to the old- alexa node. Run npm install hopefully without errors. Activate in the node red adapter configuration that you use the pallet manager and install a different node. Then you need to rework all alexa flows
        Homoran Global Moderator Administrators @Tiger last edited by
        Zigbee, probably same, I've to pair everything
        i don't use zigbee and therefore I'm very sorry if there is a pitfall too.
        But @Thomas-Braun may know wether there will be a solution.
          Tiger @mickym last edited by
          @mickym said in Update System iobroker failed:
          package.json
          ok I'll do it...
          but, how do you edit the package.json?
            Tiger @Homoran last edited by
            No it seems everything is working well...
            Zigbee and Rfxcom... good news...
              Tiger @crunchip last edited by
              @crunchip
              it seems it's due to my version of iobroker.admin...
              I thing we'll be able to solve it after upgrading system...
              2022-08-16 18:10:28.357	error	startInstance system.adapter.web.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "4.0.10", required ">=5.1.0"!
                crunchip Forum Testing Most Active @Tiger last edited by
                @tiger I do not understand all the problems, that was a backup with the backitup adapter? Why admin 4
                  Homoran Global Moderator Administrators @crunchip last edited by
                  @crunchip sagte in Update System iobroker failed:
                  no manually by iobroker backup
                  the admin had been downgraded by the restore
                    crunchip Forum Testing Most Active @Homoran last edited by crunchip
                    Vis installed
                    Backup with --force done...
                    ADmin version has beenn downgrade to 4.0 as before...
                    Why
                    itself or through backup
                    then do the upgrade
                    • mickym
                      package.json
                      ok I'll do it...
                      Goto directory
                      cd /opt/iobroker/iobroker-data/node-red
                      nano package.json
                      If a message occurs that file is write protected then use
                      sudo nano package.json
                      Search for the reference of the alexa node. CTRL + k should delete line. I’m typing on my mobile so you need to look at the bottom describing the short-cuts. CTRL + x to
                      exit and confirm to write.
                      Ensure that you run npm install in the directory /opt/iobroker/iobroker-data/node-red. After you started the Node Red Adapter using the pallet manager, remove all alexa nodes from your flows and update your nodes within the pallet manager, if updates are available. This should be done on a regular base. Keep your system up to date to avoid surprises like this.
                      T 3 Replies Last reply Reply Quote 0
                        through backup
                        as I understood
                          @mickym
                          I made by another way as i've not a lot of node to install and needed.
                          I installed node manually,
                          Now I'm trying to find the correct alexa node...
                          moreover The boolean-logic that was installed don't work now... I had a AND node, that works good... now don't work...
                          So I'm truing to find these two solution.
                          node-red is correctly connect to My LOGO !8 from siemens
                          Regards
                            Tiger @mickym last edited by Tiger
                            @mickym
                            Alexa works... and boolean now too...
                            So I'm going to made all as before with the new node...
                            See you all after that to upgrade my system !
                              @mickym
                              Don't know why,
                              Was trying to add other functionnality that doesn't work with node amazon
                              and connexion lost
                              message in the log file are like that
                              node-red.0	2022-08-16 21:00:26.108	info	(8145) node-red exited with 1
                              node-red.0	2022-08-16 21:00:25.642	warn	(8145) 16 Aug 21:00:25 - [warn] Projects disabled : editorTheme.projects.enabled=false
                              node-red.0	2022-08-16 21:00:21.074	warn	(8145) (node:8183) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/node_modules/@node-red/editor-client/package.json' of './lib/index.js'. Please either fix that or report it to t
                              node-red.0	2022-08-16 21:00:21.067	warn	(8145) 16 Aug 21:00:21 - [warn] server.httpadminauth-deprecated
                              node-red.0	2022-08-16 21:00:19.544	info	(8145) Starting node-red: --max-old-space-size=2048 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                              • mickym
                                mickym Most Active @Tiger last edited by mickym
                                @tiger I cant help you with alexa - as I personally do not use it. The only node - which I help for support was this node:
                                node-red-contrib-virtual-smart-home. The message which you log are specific to nodes that you have installed.
                                  @mickym
                                  how can i solved it?
                                  as i can't access to node-red now...
                                  when trying to open node-red message appear
                                  This site is not accessible
                                  192.168.1.16 don't allow the connexion
                                  • mickym
                                    @tiger Try to start node-red in secure mode - then the flows do not start and you can delete all alexa stuff.
                                      @mickym
                                      ok now.
                                      With your node-red-contrib-virtual-smart-home, it works with alexa?
                                      • mickym
                                        @tiger As I said - I have no alexa - however when users used it they had good experience .
                                        https://flows.nodered.org/node/node-red-contrib-virtual-smart-home
                                        You need to register it.
                                        But to be honest - if there are only problems with alexa and the other flows work - you may should ask for help from users who work with alexa. So if all your other nodes work - then you should open a separate thread to solve your alexa issues.
                                          @mickym
                                          node-red is only for alexa...
                                          all other node are for the programmation of alexa.
                                          I had register, connect...
                                          but you are right, I think we can continue to upgrade and i will solve the problem of node-red after
                                            @mickym
                                            Your node is extremely good and easy...
                                            everything is working now
                                            @Homoran
                                            Everything is good now, not VIS, SOCKETIO and WEB but we've to upgrade 🙂
                                            can you help me to do it in a correct way?
                                            update iobroker
                                            20408
