    4. [Neuer Adapter] EuSec
      lustig29 @e-i-k-e last edited by
      @e-i-k-e Genau an dem Problem hängt es bei mir auch. Ich hoffe es kann uns jemand helfen
        lustig29 @lustig29 last edited by lustig29
        Ich bekomme folgende Fehlermeldung im Log.
        eusec.0
        2022-07-17 10:53:39.239	error	Station: T8010P23220312FE Device: T8210P64220333A9 - Error - Stopping livestream... [{}]
        eusec.0
        2022-07-17 10:53:39.231	error	ffmpegStreamToHls(): ffmpeg stderr:ffmpeg version 4.4.1-static https://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2021 the FFmpeg developers built with gcc 6.3.0 (Debian 6.3.0-18+deb9u1) 20170516 configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --disable-ffplay --disable-indev=sndio --disable-outdev=sndio --cc=gcc --enable-fontconfig --enable-frei0r --enable-gnutls --enable-gmp --enable-libgme --enable-gray --enable-libfribidi --enable-libass --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-librubberband --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libvorbis --enable-libopus --enable-libtheora --enable-libvidstab --enable-libvo-amrwbenc --enable-libvpx --enable-libwebp --enable-libx264 --enable-libxml2 --enable-libxvid --enable-libzimg libavutil 56. 70.100 / 56. 70.100 libavcodec 58.134.100 / 58.134.100 libavformat 58. 76.100 / 58. 76.100 libavdevice 58. 13.100 / 58. 13.100 libavfilter 7.110.100 / 7.110.100 libswscale 5. 9.100 / 5. 9.100 libswresample 3. 9.100 / 3. 9.100 libpostproc 55. 9.100 / 55. 9.100Input #0, hevc, from 'unix:/tmp/eusec.0.1.sock': Duration: N/A, bitrate: N/A Stream #0:0: Video: hevc (Main), yuvj420p(pc, bt709), 2048x1536, 15 fps, 15 tbr, 1200k tbn, 15 tbcInput #1, aac, from 'unix:/tmp/eusec.0.2.sock': Duration: N/A, bitrate: 24 kb/s Stream #1:0: Audio: aac (LC), 16000 Hz, mono, fltp, 24 kb/s[hls @ 0x2e98eb0] Stream HEVC is not hvc1, you should use tag:v hvc1 to set it.Output #0, hls, to '/opt/iobroker/iobroker-data/eusec.0/T8010P23220312FE/live/T8210P64220333A9.m3u8': Metadata: encoder : Lavf58.76.100 Stream #0:0: Video: hevc (Main), yuvj420p(pc, bt709), 2048x1536, q=2-31, 15 fps, 15 tbr, 90k tbn, 15 tbc Stream #0:1: Audio: aac (LC), 16000 Hz, mono, fltp, 24 kb/sStream mapping: Stream #0:0 -> #0:0 (copy) Stream #1:0 -> #0:1 (copy)Press [q] to stop, [?] for help[hls @ 0x2e98eb0] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properlyframe= 1 fps=0.0 q=-1.0 size=N/A time=00:00:00.00 bitrate=N/A speed= 0x [mpegts @ 0x2e9be40] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly[mpegts @ 0x2e9be40] first pts and dts value must be setav_interleaved_write_frame(): Invalid data found when processing input[mpegts @ 0x2e9be40] AAC bitstream not in ADTS format and extradata missing[hls @ 0x2e98eb0] Opening '/opt/iobroker/iobroker-data/eusec.0/T8010P23220312FE/live/T8210P64220333A90.ts' for writing[hls @ 0x2e98eb0] Opening '/opt/iobroker/iobroker-data/eusec.0/T8010P23220312FE/live/T8210P64220333A9.m3u8.tmp' for writingframe= 1 fps=0.0 q=-1.0 Lsize=N/A time=00:00:00.00 bitrate=N/A speed= 0x video:104kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknownConversion failed!
        eusec.0
        2022-07-17 10:53:39.231	error	ffmpegStreamToHls(): ffmpeg output:
        eusec.0
        2022-07-17 10:53:39.207	error	ffmpegStreamToHls(): An error occurred: ffmpeg exited with code 1: frame= 1 fps=0.0 q=-1.0 Lsize=N/A time=00:00:00.00 bitrate=N/A speed= 0x video:104kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknownConversion failed!
          Stormbringer @Uli977 last edited by Stormbringer
          @uli977 Hallo, weiß nicht ob ihr noch immer sucht aber hier mal ein Export von meinem VIS Widget für Eufy.
          [{"tpl":"tplValueStringRaw","data":{"hm_id":"80101","digits":"","factor":1,"min":0,"max":1,"step":0.01,"oid":"eusec.0.T8010P2320280268.cameras.T8213P1122140AD8.last_event_pic_html","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_visibility":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"663px","top":"26px","width":"302px","height":"302px","border":"2px solid rgb(255, 255, 255)","border-radius":"5px","z-index":"0","color":"","background":"#ffffff"},"widgetSet":"basic"}]
          Man muß den DP "Last Event Picture HTML Image verwenden und eine Basic-String Widget ;o)
          Für die, die Probleme haben, dass immer das alte Bild kommt die könnten mal versuchen ob es besser wird wenn man vor den DP Wert noch Speicherpfad mit angibt. Also quasi so:
           <variables>
             <variable id="zDj_NjzC@n9EX4!!A^hc">INT_Pfad_Eufy_Adapter</variable>
           </variables>
           <block type="variables_set" id="4yJzU.[Q/8`~_e?JT;y%" x="413" y="463">
             <field name="VAR" id="zDj_NjzC@n9EX4!!A^hc">INT_Pfad_Eufy_Adapter</field>
               <block type="text" id="R`SKA|wbaU-8oeU9@qc3">
                 <field name="TEXT">/opt/iobroker/iobroker-data/</field>
               <block type="telegram" id="7G$U|Br3/N`snbzK-ix%">
                 <field name="INSTANCE">.2</field>
                 <field name="LOG"></field>
                 <field name="SILENT">TRUE</field>
                 <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
                 <value name="MESSAGE">
                   <shadow type="text">
                     <field name="TEXT"></field>
                   <block type="text_join" id="eX/TSIgLUE?LAZVCMsQE">
                     <value name="ADD0">
                       <block type="variables_get" id="ffVp(7[2OyY+Y46$:RlZ">
                     <value name="ADD1">
                       <block type="get_value_var" id="{2;;~A+aiAw4,Y+NsMH3">
                         <value name="OID">
                           <block type="field_oid" id="#fyGX+AmY!IG)QFJW@~F">
                             <field name="oid">eusec.0.T8010P2320280268.cameras.T8213P1122140AD8.last_event_pic_url</field>
          @e-i-k-e Mit Synology kenn ich mich nicht aus. Bei Motioneye wird der Link verwendet, den die App ausgibt. GGf. muss man Benutzer und Kennwort aus den Link rauslöschen und separat in ein Feld eintragen. So ist es zumindest bei Motioneye. Dein Link wirkt irgendwie eher wie wenn du einen Wert vom Adapter genommen hättest? Der Adapter hat damit eigentlich nichts zu tun, er startet und stopt nur den Stream. VIS kann mit dem Stream direkt nichts anfangen. Daher der Umweg über Motioneye. Dafür gibts aber Anleitungen im Forum. VLC kann den Link von der App glaube ich direkt verarbeiten.
          Uli977 E 3 Replies Last reply Reply Quote 0
          • Uli977
            Uli977 @Stormbringer last edited by
            @stormbringer Danke dir für deinen Input!
            Leider wird bei mir immer noch ein altes Bild angezeigt.
            Welcher Pfad muss hier denn genau rein?
              e-i-k-e @Stormbringer last edited by e-i-k-e
              @stormbringer
              Wo finde ich denn den Link in der App?
                johannes1702 last edited by
                leider scheitere ich an der Installation des Adapters. Ich starte die Installation direkt von Github und nach ca. 5 Min kommt dann diese Fehlermeldung(en):
                $ iobroker url https://github.com/bropat/ioBroker.eusec --host ioBroker --debug
                install bropat/ioBroker.eusec#f6e0490293154eba6f42f94be13bd74dc49d4d6a
                NPM version: 6.14.16Installing bropat/ioBroker.eusec#f6e0490293154eba6f42f94be13bd74dc49d4d6a... (System call)
                npm ERR! code ENOTSUP
                npm ERR! notsup Unsupported engine for iobroker.eusec@0.9.4: wanted: {"node":">=14.17.0"} (current: {"node":"12.22.12","npm":"6.14.16"})
                npm ERR! notsup Not compatible with your version of node/npm: iobroker.eusec@0.9.4
                npm ERR! notsup Required: {"node":">=14.17.0"}
                npm ERR! notsup Actual: {"npm":"6.14.16","node":"12.22.12"}
                npm ERR! /home/iobroker/.npm/_logs/2022-08-11T16_58_28_606Z-debug.log
                host.ioBroker Cannot install bropat/ioBroker.eusec#f6e0490293154eba6f42f94be13bd74dc49d4d6a: 1
                ERROR: Process exited with code 25
                Es scheint als wäre es ein Problem mit der Node Version. Mein System ist aktuell, sowohl ioBroker als auch das darunterliegende Ubuntu.
                Jemand eine Lösung? 🙂
                LG Jo
                  johannes1702 @johannes1702 last edited by
                  @johannes1702 Hat sich erledigt, habe node manuell aktualisiert 🙂
                    @stormbringer sagte in [Neuer Adapter] EuSec:
                    Wo finde ich den Link in der App?
                      Mike Hellracer @bropat last edited by
                      ich habe den Adapter in der Version 0.7.5 auf einem IObroker Pi am Laufen. ffmpeg ist auch in der aktuellen Version installiert.
                      Im Log bekomme ich leider noch:
                      ffmpegStreamToHls(): Not support audio codec or unknown audio codec (NONE)
                      Kann mir einer von euch sagen, wwelches der passende Audo Codec ist? bzw. was ich noch tun muss?
                        chiroptera last edited by
                        Also ich habe immer noch das Problem, dass meine Station und die Cams nicht gefunden werden.
                        Bin jetzt auf 0.9.4 - Instanz neu installiert, Adapter Versionen schon x-mal hin und her installiert. Mit der 0.8.4 wurde die Station noch gefunden, nach dem Update nicht mehr. Jetzt leider auch nicht mehr mit der 0.8.4
                        2FA ist nicht aktiviert, war es auch noch nie. Smartphone App deinstalliert und wieder neu installiert - Region ist Germany und ist auch nicht änderbar. Instanz ist grün - sonst keine Fehlermeldungen.
                        Jemand noch eine Idee, was ich noch versuchen kann?
                          lustig29 @chiroptera last edited by
                          Gibt es denn keine Möglichkeit, das Live Bild abzugreifen?
                            worxweis @lustig29 last edited by
                            @lustig29
                            Hallo Lustig!
                            Bis jetzt hat mir auch noch keiner erklären können wie er ein live view ins Vis bringt! Ich weis zwar, das es das Objekt Livestream gibt, indem nach dem Klingeln bzw. auch nach dem selberstarten ein link drinnen steht, aber was ich mit diesem in vis machen soll, ist mir immer noch ein rätsel!
                              lustig29 @worxweis last edited by
                              @worxweis Na dann wollen wir mal hoffen, dass wir bald Hilfe bekommen
                                Gonzokalle @lustig29 last edited by
                                Kann mir bitte jemand helfen wie ich die Meldungen weg bekomme?
                                Das kommt so zwei bis drei mal am Tag. Benutze die 0.9.4
                                Fabio 2 Replies Last reply Reply Quote 0
                                • Fabio
                                  Fabio @Gonzokalle last edited by Fabio
                                  @gonzokalle hab ich auch. Habe ein issuses auf gemacht @bropat weiss Bescheid und wird das fixen.
                                  Grüße Fabio
                                    Gonzokalle @Fabio last edited by
                                    @fa-bio
                                    Ich dachte es lag an mir.
                                    Danke für die Info. 👍
                                      chiroptera last edited by chiroptera
                                      Hallo @bropat,
                                      was kann ich noch versuchen - meine Station will einfach nicht erkannt werden.
                                      Edit: Hat sich erledigt. In den iobroker Settings war das Land nicht definiert ... warum auch immer. Geht jetzt 🙂
                                        bug77 last edited by
                                        ich möchte den m3u8 livestream der Doorbell in der VIS anzeigen lassen, gibt es da eine Lösung wie man das hinbekommt?
                                        Außerdem habe ich immer wieder in der Log diese Fehler:
                                        	P2PClientProtocol.lookup(): station: T8020P1021344260 - All address lookup tentatives failed.
                                        weiß jemand warum das kommt?
                                        nukleuz B 2 Replies Last reply Reply Quote 0
                                        • nukleuz
                                          nukleuz @bug77 last edited by
                                          @bug77
                                          Mit dem Stream in den UIs habe ich noch nicht hinbekommen - da scheint wirklich MotionEye nur zu helfen…
                                          Der Log weißt darauf hin, dass keine Station gefunden wurde - hast du denn eine?
                                          Wenn nicht, einfach ignorieren!?
                                            mem @nukleuz last edited by
                                            Hallo @bropat ,
                                            Respekt für Deine Arbeit an diesem Adapter. Echt klasse und hilfreich. Habe v0.9.4 und bin im Umstieg von der Homebase2(T8010) auf die Homebase3 (S380) mit den eufyCam3(S330). Diese werden ja nicht unterstützt. Die Homebase3 wird zwar erkannt, aber die eufyCam3s erscheinen nicht im iobroker. Besteht die Möglichkeit den Adapter für die Devices fit zu machen ?
                                            adapter cameras doorbell eufy eufycam security
                                            160
                                            1173
                                            456246
