    4. Test Withings v0.0.x
    • ESP8266
      ESP8266 @tombox last edited by
      @tombox , ich bekomme neuerdings mit der Version 0.0.10 folgende Warnmeldung:
      withings.0
      	2022-08-12 07:45:56.661	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
      withings.0
      	2022-08-12 07:45:56.421	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
        tombox @ESP8266 last edited by
        @esp8266 Sollte nur beim ersten start passieren
        • ESP8266
          ESP8266 @tombox last edited by ESP8266
          @tombox , hier die Abstände, gerade erst um 10:45 wieder:
          17
          Log-Größe: 2.4 KB
          Zeit
          Nachricht
          withings.0
          	2022-08-12 10:45:56.899	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
          withings.0
          	2022-08-12 10:45:56.491	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
          backitup.0
          	2022-08-12 09:52:54.409	info	[iobroker] backup was activated at 02:00 every 1 day(s)
          backitup.0
          	2022-08-12 09:52:54.260	info	starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.20.0, js-controller: 4.0.23
          backitup.0
          	2022-08-12 09:52:14.165	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          backitup.0
          	2022-08-12 09:52:14.163	info	terminating
          backitup.0
          	2022-08-12 09:52:14.161	info	cleaned everything up...
          backitup.0
          	2022-08-12 09:52:14.145	info	Got terminate signal TERMINATE_YOURSELF
          admin.0
          	2022-08-12 09:49:33.864	info	==> Connected system.user.admin from ::ffff:192.XXXXXXXX
          withings.0
          withings.0
          admin.0
          	2022-08-12 06:04:49.702	info	Repository received successfully.
            @esp8266 auch nach einem adapter Neustart
            ESP8266 2 Replies Last reply Reply Quote 0
            • ESP8266
              @tombox , Adapter Restart:
              withings.0
              	2022-08-12 10:58:12.871	info	starting. Version 0.0.10 in /opt/iobroker/node_modules/iobroker.withings, node: v14.20.0, js-controller: 4.0.23
              withings.0
              	2022-08-12 10:58:06.643	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
              withings.0
              	2022-08-12 10:58:06.536	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              withings.0
              	2022-08-12 10:58:06.533	info	terminating
              Die Meldung kommt alle 3 Stunden.
              v6.2.14
              18
              Log-Größe: 3.1 KB
              Zeit
              Nachricht
              withings.0
              withings.0
              withings.0
              withings.0
              withings.0
              	2022-08-12 10:58:06.530	info	Got terminate signal TERMINATE_YOURSELF
              withings.0
              withings.0
              backitup.0
              backitup.0
              backitup.0
              backitup.0
              backitup.0
              backitup.0
              admin.0
              	2022-08-12 09:49:33.864	info	==> Connected system.user.admin from ::ffff:192.XXXXXXXXX
              withings.0
              withings.0
              admin.0
              admin.0
              	2022-08-12 06:04:42.068	info	Request actual repository...
              admin.0
              	2022-08-12 06:04:14.748	info	Adapter rating updated
              withings.0
              	2022-08-12 04:45:56.549	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
              withings.0
              	2022-08-12 04:45:56.351	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
              iot.0
              	2022-08-12 04:29:26.686	error	Error by device connection: "read ECONNRESET"
              withings.0
              	2022-08-12 01:45:56.641	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
              • Marc Berg
                Marc Berg Most Active @ESP8266 last edited by
                @esp8266 sagte in Test Withings v0.0.x:
                Diese Fehlermeldungen hatte ich auch, erst nach dem zweiten Adapter-Restart wurde der Datenpunkt angelegt und die Meldungen sind nun weg. Etwas seltsam.
                Marc
                • ESP8266
                  ESP8266 @Marc Berg last edited by ESP8266
                  @marc-berg ,muss irgenwas sein, wass nach 180 Min etwas anschiebt.
                  Ich habe den Adapter nur geupgradet. Nichts neu angelegt etc.
                  • Marc Berg
                    Ja, genau wie bei mir. Gestern den Adapter auf die Version 0.0.10 gebracht, heute früh die "...connection..."-Meldungen gesehen, die alle 3h erschienen sind, danach den Adapter neu gestartet. Daraufhin erschien die Fehlermeldung wieder. Erst nach einem zweiten Neustart sind die Meldungen nun weg.
                    • ESP8266
                      @tombox , Meldungen scheinen weg zu sein. 10:58 Uhr was die letzte.
                      • MassiveAttack
                        MassiveAttack last edited by
                        hallo!
                        jedes mal wenn ich den adapter starten möchte, bekomme ich ein mail mit einem temporären login code. was mache ich falsch? mein login in der app funktioniert ja mit user/pw.
                          tombox @MassiveAttack last edited by
                          @massiveattack Ist leider ein Manko den man so hinnehmen muss
                          MassiveAttack 1 Reply Last reply Reply Quote 0
                          • MassiveAttack
                            MassiveAttack @tombox last edited by MassiveAttack
                            @tombox
                            würde ich, wenn der adapter starten würde 🙂
                            withings.0
                            	1346	2022-08-18 13:09:56.349	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                            withings.0
                            	1346	2022-08-18 13:09:56.347	info	terminating
                            withings.0
                            	1346	2022-08-18 13:09:56.322	error	resultArray is not iterable
                            withings.0
                            	1346	2022-08-18 13:09:56.321	error	TypeError: resultArray is not iterable at Withings.login (/opt/iobroker/node_modules/iobroker.withings/main.js:226:26) at processTicksAndRejections (node:internal/process/task_queues:96:5) at Withings.onReady (/opt/iobroker/node_modules/iobroker.withings/main.js:69:5)
                            withings.0
                            	1346	2022-08-18 13:09:56.315	error	unhandled promise rejection: resultArray is not iterable
                            withings.0
                            	1346	2022-08-18 13:09:56.314	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            withings.0
                            	1346	2022-08-18 13:09:56.311	error	{"errors":[{"message":"redirect_uri_mismatch: The redirect URI provided is missing or does not match partner callback url"}]}
                            withings.0
                            	1346	2022-08-18 13:09:53.479	info	starting. Version 0.0.10 in /opt/iobroker/node_modules/iobroker.withings, node: v16.17.0, js-controller: 4.0.23
                              @massiveattack callback url stimmt anscheinend nicht hast du wie vorgegeben Callback URI: http://localhost
                              • MassiveAttack
                                @tombox said in Test Withings v0.0.x:
                                http://localhost
                                peinlich, hatte wohl https geschrieben 🙄
                                danke, funktioniert jetzt
                                • Pr3mut05
                                  Pr3mut05 last edited by Pr3mut05
                                  Ich bekomme ständig E-Mails mit dem temporären Passwort
                                  Wie kann ich denn das abschalten 😕
                                  OK - Wurde zwei Kommentare davor beantwortet 😉
                                  • ESP8266
                                    ESP8266 @Pr3mut05 last edited by ESP8266
                                    @tombox , es fängt wieder an.
                                    Kaum ein Upgrade gefahren, kann er sich nicht wieder einloggen.
                                    Auf der Seite habe ich alles bestätigt.
                                    Zurück zu 0.0.10 und geht wieder.
                                      @esp8266 War noch ein Fehler danke für den Hinweis ist mit 0.0.13 behoben
                                      ESP8266 1 Reply Last reply Reply Quote 1
                                      • ESP8266
                                        @tombox , das Problem besteht weiterhin. Auch ein Neustart behebt es nicht.
                                        Mom...du schreibst 0.0.13 dann ist installiere ich mal vom Github.
                                        Alles gut, lüppt.
                                          MrLee last edited by
                                          Moin!
                                          Bin auf der .13 von Github und habe leider das selbe Problem...mache ich was falsch (erste Installation des Adapters)
                                          withings.0
                                          2022-10-23 16:02:25.302	error	{"status":503,"error":"Invalid Params: Missing [refresh_token]"}
                                          withings.0
                                          2022-10-23 16:02:25.191	warn	Please check username and password
                                          • ESP8266
                                            ESP8266 @MrLee last edited by
                                            @mrlee , Adapter neu starten.
                                            516
                                            89669
