    4. Test Withings v0.0.x
    • ESP8266
      ESP8266 @tombox last edited by ESP8266
      @tombox , Adapter Restart:
      withings.0
      	2022-08-12 10:58:12.871	info	starting. Version 0.0.10 in /opt/iobroker/node_modules/iobroker.withings, node: v14.20.0, js-controller: 4.0.23
      withings.0
      	2022-08-12 10:58:06.643	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
      withings.0
      	2022-08-12 10:58:06.536	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      withings.0
      	2022-08-12 10:58:06.533	info	terminating
      Die Meldung kommt alle 3 Stunden.
      v6.2.14
      18
      Log-Größe: 3.1 KB
      Zeit
      Nachricht
      withings.0
      withings.0
      withings.0
      withings.0
      withings.0
      	2022-08-12 10:58:06.530	info	Got terminate signal TERMINATE_YOURSELF
      withings.0
      	2022-08-12 10:45:56.899	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
      withings.0
      	2022-08-12 10:45:56.491	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
      backitup.0
      	2022-08-12 09:52:54.409	info	[iobroker] backup was activated at 02:00 every 1 day(s)
      backitup.0
      	2022-08-12 09:52:54.260	info	starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.20.0, js-controller: 4.0.23
      backitup.0
      	2022-08-12 09:52:14.165	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      backitup.0
      	2022-08-12 09:52:14.163	info	terminating
      backitup.0
      	2022-08-12 09:52:14.161	info	cleaned everything up...
      backitup.0
      	2022-08-12 09:52:14.145	info	Got terminate signal TERMINATE_YOURSELF
      admin.0
      	2022-08-12 09:49:33.864	info	==> Connected system.user.admin from ::ffff:192.XXXXXXXXX
      withings.0
      	2022-08-12 07:45:56.661	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
      withings.0
      	2022-08-12 07:45:56.421	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
      admin.0
      	2022-08-12 06:04:49.702	info	Repository received successfully.
      admin.0
      	2022-08-12 06:04:42.068	info	Request actual repository...
      admin.0
      	2022-08-12 06:04:14.748	info	Adapter rating updated
      withings.0
      	2022-08-12 04:45:56.549	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
      withings.0
      	2022-08-12 04:45:56.351	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
      iot.0
      	2022-08-12 04:29:26.686	error	Error by device connection: "read ECONNRESET"
      withings.0
      	2022-08-12 01:45:56.641	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
      • Marc Berg
        Marc Berg Most Active @ESP8266 last edited by
        @esp8266 sagte in Test Withings v0.0.x:
        Diese Fehlermeldungen hatte ich auch, erst nach dem zweiten Adapter-Restart wurde der Datenpunkt angelegt und die Meldungen sind nun weg. Etwas seltsam.
        Marc
        • ESP8266
          ESP8266 @Marc Berg last edited by ESP8266
          @marc-berg ,muss irgenwas sein, wass nach 180 Min etwas anschiebt.
          Ich habe den Adapter nur geupgradet. Nichts neu angelegt etc.
          • Marc Berg
            Ja, genau wie bei mir. Gestern den Adapter auf die Version 0.0.10 gebracht, heute früh die "...connection..."-Meldungen gesehen, die alle 3h erschienen sind, danach den Adapter neu gestartet. Daraufhin erschien die Fehlermeldung wieder. Erst nach einem zweiten Neustart sind die Meldungen nun weg.
            • ESP8266
              @tombox , Meldungen scheinen weg zu sein. 10:58 Uhr was die letzte.
              • MassiveAttack
                MassiveAttack last edited by
                hallo!
                jedes mal wenn ich den adapter starten möchte, bekomme ich ein mail mit einem temporären login code. was mache ich falsch? mein login in der app funktioniert ja mit user/pw.
                  tombox @MassiveAttack last edited by
                  @massiveattack Ist leider ein Manko den man so hinnehmen muss
                  MassiveAttack 1 Reply Last reply Reply Quote 0
                  • MassiveAttack
                    MassiveAttack @tombox last edited by MassiveAttack
                    @tombox
                    würde ich, wenn der adapter starten würde 🙂
                    withings.0
                    	1346	2022-08-18 13:09:56.349	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    withings.0
                    	1346	2022-08-18 13:09:56.347	info	terminating
                    withings.0
                    	1346	2022-08-18 13:09:56.322	error	resultArray is not iterable
                    withings.0
                    	1346	2022-08-18 13:09:56.321	error	TypeError: resultArray is not iterable at Withings.login (/opt/iobroker/node_modules/iobroker.withings/main.js:226:26) at processTicksAndRejections (node:internal/process/task_queues:96:5) at Withings.onReady (/opt/iobroker/node_modules/iobroker.withings/main.js:69:5)
                    withings.0
                    	1346	2022-08-18 13:09:56.315	error	unhandled promise rejection: resultArray is not iterable
                    withings.0
                    	1346	2022-08-18 13:09:56.314	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    withings.0
                    	1346	2022-08-18 13:09:56.311	error	{"errors":[{"message":"redirect_uri_mismatch: The redirect URI provided is missing or does not match partner callback url"}]}
                    withings.0
                    	1346	2022-08-18 13:09:53.479	info	starting. Version 0.0.10 in /opt/iobroker/node_modules/iobroker.withings, node: v16.17.0, js-controller: 4.0.23
                      @massiveattack callback url stimmt anscheinend nicht hast du wie vorgegeben Callback URI: http://localhost
                      • MassiveAttack
                        @tombox said in Test Withings v0.0.x:
                        http://localhost
                        peinlich, hatte wohl https geschrieben 🙄
                        danke, funktioniert jetzt
                        • Pr3mut05
                          Pr3mut05 last edited by Pr3mut05
                          Ich bekomme ständig E-Mails mit dem temporären Passwort
                          Wie kann ich denn das abschalten 😕
                          OK - Wurde zwei Kommentare davor beantwortet 😉
                          • ESP8266
                            ESP8266 @Pr3mut05 last edited by ESP8266
                            @tombox , es fängt wieder an.
                            Kaum ein Upgrade gefahren, kann er sich nicht wieder einloggen.
                            Auf der Seite habe ich alles bestätigt.
                            Zurück zu 0.0.10 und geht wieder.
                              tombox @ESP8266 last edited by
                              @esp8266 War noch ein Fehler danke für den Hinweis ist mit 0.0.13 behoben
                              ESP8266 1 Reply Last reply Reply Quote 1
                              • ESP8266
                                @tombox , das Problem besteht weiterhin. Auch ein Neustart behebt es nicht.
                                Mom...du schreibst 0.0.13 dann ist installiere ich mal vom Github.
                                Alles gut, lüppt.
                                  MrLee last edited by
                                  Moin!
                                  Bin auf der .13 von Github und habe leider das selbe Problem...mache ich was falsch (erste Installation des Adapters)
                                  withings.0
                                  2022-10-23 16:02:25.302	error	{"status":503,"error":"Invalid Params: Missing [refresh_token]"}
                                  withings.0
                                  2022-10-23 16:02:25.191	warn	Please check username and password
                                  • ESP8266
                                    ESP8266 @MrLee last edited by
                                    @mrlee , Adapter neu starten.
                                      MrLee @ESP8266 last edited by
                                      @esp8266
                                      Moin, dank für die Info...
                                      passiert aber leider genau das Selbe im log und Adapter bleibt gelb.
                                      withings.0
                                      2022-10-24 08:35:28.460	error	{"status":503,"error":"Invalid Params: Missing [refresh_token]"}
                                      withings.0
                                      2022-10-24 08:35:28.349	warn	Please check username and password
                                      withings.0
                                      2022-10-24 08:35:25.260	info	starting. Version 0.0.13 (non-npm: TA2k/ioBroker.withings) in /opt/iobroker/node_modules/iobroker.withings, node: v16.17.1, js-controller: 4.0.23
                                      withings.0
                                      2022-10-24 08:35:24.709	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                      host.iobroker_host-neu
                                      2022-10-24 08:35:21.479	info	instance system.adapter.withings.0 started with pid 15809
                                      2022-10-24 08:35:18.817	info	instance system.adapter.withings.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2022-10-24 08:35:18.197	info	stopInstance system.adapter.withings.0 send kill signal
                                      withings.0
                                      2022-10-24 08:35:18.170	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      withings.0
                                      2022-10-24 08:35:18.167	info	terminating
                                      withings.0
                                      2022-10-24 08:35:18.161	info	Got terminate signal TERMINATE_YOURSELF
                                      2022-10-24 08:35:18.154	info	stopInstance system.adapter.withings.0 (force=false, process=true)
                                      2022-10-24 08:35:08.695	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2022-10-24 08:35:00.051	info	instance system.adapter.dwd.0 started with pid 15780
                                      withings.0 2022-10-24 08:34:09.785	error	{"status":503,"error":"Invalid Params: Missing [refresh_token]"}
                                      withings.0 2022-10-24 08:34:09.673	warn	Please check username and password
                                      Bekomme auch jedesmal wenn ich den Adapter starte eine Mail von withings
                                      Hier ist Ihr vorläufiger Anmeldecode
                                      Habe ich bei Withinhgs was falsch eingestellt?
                                      bis denne
                                      Mr.Lee
                                      stony2k 1 Reply Last reply Reply Quote 0
                                      • stony2k
                                        stony2k @MrLee last edited by stony2k
                                        seit dem Updates des Adapter wird die Zeit von total_sleep_time anders angegeben. Sind das nun Sekunden? Wobei das dann komischerweise nicht mit den Angaben in der App übereinstimmt.
                                        Beispiel: aktuell hat der Datenpunkt den Wert 24300, was 6,7 h sein müssten. Laut der App sind es aber nur 6:45 Min
                                        @mrlee sagte in Test Withings v0.0.x:
                                        bis denne
                                        Mr.Lee
                                        Die Mail bekomme ich auch, ist in meinen Augen einfach zu ignorieren
                                        oberfragger 1 Reply Last reply Reply Quote 0
                                        • oberfragger
                                          oberfragger @stony2k last edited by
                                          @stony2k said in Test Withings v0.0.x:
                                          bis denne
                                          Mr.Lee
                                          die Rechnung stimmt doch!
                                          24300 Sekunden = 405 Minuten = 6,75h
                                          0,75h = 45 Minuten (0,75*60)
                                          -> 6,75h = 6h 45 Minuten
                                          • stony2k
                                            stony2k @oberfragger last edited by
                                            @oberfragger sagte in Test Withings v0.0.x:
                                            bis denne
                                            Mr.Lee
                                            Ok du hast recht. Ich Trottel 😄
                                            Hast du eine Idee, wie ich mir das in ein lesbares Format umwandeln kann? Also per Formel oder Javascript?
                                            516
                                            96148
