    4. Ersatz für vcgencmd nach Raspberry Kernel Update
    • mickym
      mickym Most Active @Thomas Braun last edited by
      @thomas-braun sagte in Raspberry Kernel Update:
      @mickym sagte in Raspberry Kernel Update:
      um bestimmte Updates zu blockieren.
      apt-hold ist dein Freund.
      OK - Danke - ich probiers mal - und sag obs geklappt hat. 🙂
        Thomas Braun Most Active @mickym last edited by Thomas Braun
        @mickym
        Versuch mal
        vcgencmd display_power 0 0
        echad@chet:~ $ vcgencmd display_power 0 0
        display_power=0
        display_power [0 | 1 | -1] [display]
        Show current display power state, or set the display power state. vcgencmd display_power 0 will turn off power to the current display. vcgencmd display_power 1 will turn on power to the display. If no parameter is set, this will display the current power state. The final parameter is an optional display ID, as returned by tvservice -l or from the table below, which allows a specific display to be turned on or off.
        Note that for the 7" Raspberry Pi Touch Display this simply turns the backlight on and off. The touch functionality continues to operate as normal.
        vcgencmd display_power 0 7 will turn off power to display ID 7, which is HDMI 1 on a Raspberry Pi 4.
        Display         | ID
        > Main LCD      | 0
        > Secondary LCD | 1
        > HDMI 0        | 2
        > Composite     | 3
        > HDMI 1        | 7
        To determine if a specific display ID is on or off, use -1 as the first parameter.
        vcgencmd display_power -1 7 will return 0 if display ID 7 is off, 1 if display ID 7 is on, or -1 if display ID 7 is in an unknown state, for example undetected.
        • mickym
          @mickym
          Versuch mal
          display_power=0
          Ja das hat ich schon probiert - auch mit
          pi@MWHome2:~ $ vcgencmd display_power = 0
          display_power=0
          pi@MWHome2:~ $ vcgencmd display_power 0 0
          display_power=0
          Das meldet zwar display_power=0 zurück, der HDMI Port bleibt aber weiter aktiv.
            @mickym
            Und mit 2 oder 7? Das sind die HDMI-Ports.
            • mickym
              mickym Most Active @Thomas Braun last edited by mickym
              @thomas-braun Also Du meinst
              vcgencmd display_power 2 0
              bzw.
              vcgencmd display_power 7 0
              btw: Das mit dem Zurückhalten der Pakete hat aber schon mal geklappt und Ursache ist definitiv das Kernel Update.
                @mickym Anders herum.
                Die ID steht hinten.
                • mickym
                  @thomas-braun Kein Effekt.
                  Ich hab alles von -2 bis +7 ausprobiert, es kommt mal display_power=-1 oder display_power=0 zurück, aber es schaltet nichts ab.
                    @mickym
                    Hast du xrandr installiert?
                    xrandr --output HDMI-1 --off
                    Wobei ich da die genaue Syntax nicht kenne. Mein RPI läuft ja headless...
                    • mickym
                      @thomas-braun Das Kommando habe ich zwar aber es kommt immer zurück, dass er kein Display öffnen konnte.
                      Can't open display
                      pi@MWHome2:~ $ xrandr --listmonitors
                      Can't open display
                      pi@MWHome2:~ $ xrandr --listproviders
                      Can't open display
                      Wie gesagt das mit dem Kernel auf hold setzen hat geklappt. Es war halt sehr elegant - weil der Bildschirm über Bewegungsmelder gesteuert wurde und nicht über starre Zeiten der Inaktivität - aber noch viel besser - er ist halt automatisch angegangen sobald man das Zimmer betreten hat. Ich finde solche Updates einfach beschi...en. Dann soll man es halt sicher machen oder man nutzt es auf eigenes Risiko.
                      Entweder nehm ich halt den blöden Bildschirmschoner - dann muss man halt immer ne Maus bewegen oder ich hab auch noch einen Shelly über und hänge den Monitor ganz hin - dann wird gar kein Strom mehr gebraucht - wenn niemand im Zimmer ist.
                        Can't open display
                        Möglich das man dafür in der Gruppe 'video' sein muss. Sollte aber eh der Fall sein.
                        xrandr
                        oder
                        sudo xrandr
                        sagt?
                        • mickym
                          Can't open display
                          pi@MWHome2:~ $ sudo xrandr
                          Can't open display
                          pi@MWHome2:~ $
                          pi ist in Gruppe video.
                            mrjeschke @mickym last edited by
                            @mickym
                            Musste gerade feststellen das ich das gleiche Problem habe.
                            Ausschalten kann ich den Monitor über
                            pi@DietPi:~$ export DISPLAY=:0.0
                            pi@DietPi:~$ xrandr --output HDMI-1 --off
                            Einschalten geht über
                            pi@DietPi:~$ xrandr --output HDMI-1 --auto
                            • mickym
                              mickym Most Active @mrjeschke last edited by
                              @maik-0
                              @Thomas-Braun
                              Ja und ich bin soooo blöd.😬 😬 😬
                              Man muss das Kommando tatsächlich auf der Maschine eingeben, an der der Bildschirm hängt. Das war bei dem vcgencmd nicht so, da ging das auch über ssh.
                              Das Ausschalten geht so. - Ich muss nun schauen, ob ich es via NodeRed steuern kann.
                                Das ist klar, X wird nicht (ohne weiteres) über ssh geroutet.
                                Hier kämpfen auch einige damit:
                                https://www.linuxquestions.org/questions/linux-general-1/xrandr-from-remote-through-ssh-869084/
                                • mickym
                                  @thomas-braun Das Ausschalten ging, aber ich habe nun das Problem wie ich das wieder anbekomme.
                                  • mickym
                                    mickym Most Active @mrjeschke last edited by mickym
                                    @mrjeschke
                                    @Thomas-Braun
                                    So vielen Dank an Euch beide. Wichtig war noch der Export dieser Umgebungsvariable DISPLAY=0.0 - damit ist es dann auch möglich remote und über SSH den Bildschirm wieder zu schalten. Außerdem muss man noch Berechtigungen vergeben, damit das ganze auch für andere Benutzer funktioniert. Für NodeRed muss man dann noch ein paar Verrenkungen machen. Da muss ich wohl @apollon77 bitten wieder eine Variable für die settings.js bereitzustellen, damit man in der Laufzeitumgebung des NodeRed Prozesses Umgebungsvariablen definieren kann.
                                    Als erstes damit der Benutzer iobroker das Ganze auch ausführen darf, muss man die Zugriffsrechte anpassen und zwar muss das wohl bei jedem Neustart des Systems neu erfolgen, kann man wohl nicht konfigurieren. Ich habe diesen Zugriffscheck abgeschaltet mit xhost +.
                                    Es langt wenn man es für den Benutzer pi ins Anmeldeprofil schreibt, da sich dieser ja eh automatisch anmeldet.
                                    Die beiden Befehle habe ich also in die .profile im Homeverzeichnis des pi angehängt:
                                    export DISPLAY=:0.0
                                    xhost +
                                    Dann war die Herausforderung diese DISPLAY Umgebungsvariable in dem Prozess, in dem node-red läuft zugänglich zu machen, wie oben bereits erwähnt.
                                    Man kann folgendenen Eintrag in die settings.js machen bevor die module.export section beginnt - also entweder ganz am Anfang oder ganz am Ende.
                                    process.env.DISPLAY=':0.0';
                                    Wenn man es nicht macht - dann bekommt man immer als RC=1 zurück, wenn man die xrandr Befehle ausführen will.
                                    Ansonsten kann man dann prüfen, dass der Returncode 0 ist - also alles in Ordnung ist. Und kann dann an bzw. true in auto und false bzw, aus in off übersetzen und an den Befehlsrumpf angehängt.
                                    xrandr --output HDMI-1 <--off|--auto>
                                    Danke an alle die mir geholfen haben. 🙂
                                    mickym Sminter 2 Replies Last reply Reply Quote 0
                                    • mickym
                                      mickym Most Active @mickym last edited by
                                      Das Einzige - was etwas offen ist - das ich bisher nichts gefunden habe, wie bei dem vcgencmd Befehl, das mir den aktuellen Status zurückliefert. Das ist nicht ganz so schlimm, wenn man eh nur an einer Stelle schaltet und halt sobald die Maschine hochgefahren ist, einen definierten Status schaltet.
                                      • Sminter
                                        Sminter @mickym last edited by
                                        @mickym Danke, genau das habe ich gesucht: Die Steuerung des Bildschirms per NodeRed. Kannst du mir noch den Export deines Flows zukommen lassen?
                                        Da ich mich noch nicht lange mit dem Pi beschäftige. Wo finde ich die zwei anzupassenden Dateien auf dem Pi 4?
                                        • mickym
                                          mickym Most Active @Sminter last edited by mickym
                                          @sminter Na wenn du all das gemacht hast, was ich unten beschrieben habe - der Flow ist quasi nur der Aufruf der Befehle:
                                          Mit true und false schalte ich den Monitor an und aus:
                                          Hier der Flow:
                                                 "id": "226756a3.c3f79a",
                                                 "type": "exec",
                                                 "z": "2364426f.ac30ce",
                                                 "command": "xrandr --output HDMI-1 ",
                                                 "addpay": "payload",
                                                 "append": "",
                                                 "useSpawn": "true",
                                                 "timer": "10",
                                                 "winHide": false,
                                                 "oldrc": false,
                                                 "name": "",
                                                 "x": 770,
                                                 "y": 1840,
                                                 "wires": [
                                                         "7220811b.4bd39"
                                                         "7220811b.4bd39"
                                                         "830e8b336da27104"
                                                 "id": "3b699dd31190819f",
                                                 "type": "change",
                                                 "name": "translate",
                                                 "rules": [
                                                         "t": "change",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "from": "true",
                                                         "fromt": "bool",
                                                         "to": "--auto",
                                                         "tot": "str"
                                                         "t": "change",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "from": "false",
                                                         "fromt": "bool",
                                                         "to": "--off",
                                                         "tot": "str"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 560,
                                                 "y": 1840,
                                                 "wires": [
                                                         "226756a3.c3f79a"
                                          Die anderen Dateien habe ich in dem Post beschrieben. Die .profile im Homeverzeichnis des pi.
                                          Den export der Variablen, wie gesagt in der settings.js - da musst Du das template editieren. Leider - da es nicht in die Adapterkonfiguration übernommen wird, bei jedem Update erneut ändern:
                                          Die template settings.js findest Du unter dem Verzeichnis:
                                          /opt/iobroker/node_modules/iobroker.node-red
                                          Sminter 1 Reply Last reply Reply Quote 0
                                          • Sminter
                                            @mickym Thx, für die Screenshots. Hatte anfänglich Schwierigkeiten. Vielleicht liegt es an der OS-Version oder dem Pi4. Kann es sein, das meine Settings-Datei wo anders liegt?
                                            Und die .profile finde ich auch über die Dateisuche nicht.
                                            Der NodeRed-Befehl ist kein Problem, nur greift er natürlich noch nicht... Weißt du wo ich die Datei noch suchen könnte?
                                            6442
