    4. JavaScript
    5. ID of type boolean or number is not supported.
      myssv last edited by
      Ich bekomme massenhaft diese Fehlermeldungen:
      javascript.0
      	2022-08-21 11:23:45.042	error	script.js.common.Aqara_Sensoren.Batterie_72:_Temperatur_Terrasse Error by subscription: ID of type boolean or number is not supported.
      javascript.0
      	2022-08-21 11:23:45.010	error	script.js.common.Aqara_Sensoren.Batterie_09:_Wassersensor_Hobbyraum Error by subscription: ID of type boolean or number is not supported.
      javascript.0
      	2022-08-21 11:23:45.005	error	script.js.common.Aqara_Sensoren.Batterie_69:_Temperatur_Kinderzimmer Error by subscription: ID of type boolean or number is not supported.
      javascript.0
      	2022-08-21 11:23:44.995	error	script.js.common.Aqara_Sensoren.Batterie_66:_Temperatur_Wohnzimmer Error by subscription: ID of type boolean or number is not supported.
      javascript.0
      	2022-08-21 11:23:44.990	error	script.js.common.Aqara_Sensoren.Batterie_63:_Temperatur_Tiefkühlschrank Error by subscription: ID of type boolean or number is not supported.
      javascript.0
      	2022-08-21 11:23:44.985	error	script.js.common.Aqara_Sensoren.Batterie_60:_Temperatur_Büro_Sonja Error by subscription: ID of type boolean or number is not supported.
      javascript.0
      	2022-08-21 11:23:44.961	error	script.js.common.Aqara_Sensoren.Batterie_08:_Wassersensor_HWR Error by subscription: ID of type boolean or number is not supported.
      javascript.0
      	2022-08-21 11:23:44.956	error	script.js.common.Aqara_Sensoren.Batterie_57:_Temperatur_Kühlschrank1 Error by subscription: ID of type boolean or number is not supported.
      javascript.0
      	2022-08-21 11:23:44.951	error	script.js.common.Aqara_Sensoren.Batterie_54:_Temperatur_Garage Error by subscription: ID of type boolean or number is not supported.
      javascript.0
      	2022-08-21 11:23:44.946	error	script.js.common.Aqara_Sensoren.Batterie_51:_Temperatur_Kühlschrank2 Error by subscription: ID of type boolean or number is not supported.
      javascript.0
      	2022-08-21 11:23:44.941	error	script.js.common.Aqara_Sensoren.Batterie_48:_Temperatur_Gäste_WC Error by subscription: ID of type boolean or number is not supported.
      javascript.0
      	2022-08-21 11:23:44.937	error	script.js.common.Aqara_Sensoren.Batterie_45:_Temperatur_Büro_Volker Error by subscription: ID of type boolean or number is not supported.
      javascript.0
      	2022-08-21 11:23:44.932	error	script.js.common.Aqara_Sensoren.Batterie_42:_Temperatur_Dachboden Error by subscription: ID of type boolean or number is not supported.
      javascript.0
      	2022-08-21 11:23:44.926	error	script.js.common.Aqara_Sensoren.Batterie_39:_Temperatur_Büro_Sonja Error by subscription: ID of type boolean or number is not supported.
      javascript.0
      	2022-08-21 11:23:44.922	error	script.js.common.Aqara_Sensoren.Batterie_36:_Temperatur_Schlafzimmer Error by subscription: ID of type boolean or number is not supported.
      javascript.0
      	2022-08-21 11:23:44.916	error	script.js.common.Aqara_Sensoren.Batterie_32:_OpenClose_Garagentor Error by subscription: ID of type boolean or number is not supported.
      javascript.0
      	2022-08-21 11:23:44.911	error	script.js.common.Aqara_Sensoren.Batterie_31:_Wassersensor_Badezimmer Error by subscription: ID of type boolean or number is not supported.
      Die Scripte sind alle identisch (bis auf die Datenpunkte) und sollen vor leerer Batterie warnen:
      Hat jemand eine Idee?
        Homoran Global Moderator Administrators @myssv last edited by
        @myssv sagte in ID of type boolean or number is not supported.:
        ich denke da kommt nur ein true/false und kein Wert
          paul53 @myssv last edited by
          @myssv sagte: Hat jemand eine Idee?
          An den Trigger muss eine ID übergeben werden - kein Wert.
          M Homoran 2 Replies Last reply Reply Quote 2
            myssv @paul53 last edited by
            @paul53 ah verstehe. Also so:
            Vielen Dank!
              @paul53 schon wieder 👓 😞
                myssv @Homoran last edited by
                @homoran ??? Meinst Du mich?
                  nöö, mich!
                    @homoran OK, dann bin ich beruhigt 😏
                    nochmals vielen Dank Euch beiden!
                    • haus-automatisierung
                      haus-automatisierung Developer Most Active last edited by
                      Yeah, genau so habe ich mir das vorgestellt 🙂 In der Vergangenheit gab es viel zu viele Scripts mit Wert als Trigger. Daher die Warnung.
                      https://github.com/ioBroker/ioBroker.javascript/issues/1050
                        Homoran Global Moderator Administrators @haus-automatisierung last edited by
                        @haus-automatisierung sagte in ID of type boolean or number is not supported.:
                        Daher die Warnung.
                        war aber nicht die optimale Formulierung für mich 😞
                          haus-automatisierung Developer Most Active @Homoran last edited by
                          @homoran sagte in ID of type boolean or number is not supported.:
                          Das zu ändern ist ja super einfach - Vorschlag?
                            Vorschlag
                            menno - jetzt dachte ich, ich könnte mich mal zurücklehnen....
                            Auf die Gefahr dass das so nicht stimmt:
                            Trigger may only refer to IDs
                            oder so
                              @homoran Das Problem ist, dass aktuell nur der Typ geprüft werden kann.
                              Theoretisch könnte man auch noch schauen, ob es wirklich eine gültige Objekt-ID ist, aber (je nach Reihenfolge) in den User-Scripts könnte das zu Problemen führen.
                              Daher aktuell die Meldung, dass number oder boolean nicht erlaubt ist - weil: Das ist garantiert keine gültige Objekt-ID. Also wenn man einen String oder einen regulären Ausdruck zu einer ID übergibt, welche es gar nicht gibt (z.B. 'käsekuchen'). Dann wird sich der Adapter nicht beschweren.
                              Wäre also der Datenpunkt vom Typ "string" und man nimmt als Trigger "Wert von Objekt-ID", dann gibt es keine Beschwerde. Der Wert im State könnte ja auch eine gültige ID zu einem anderen Objekt sein.
                              Ist leider nicht 100% wasserdicht alles. Daher aktuell nur eine kleine Hilfestellung für die User.
                                paul53 @haus-automatisierung last edited by paul53
                                @haus-automatisierung sagte: eine kleine Hilfestellung für die User.
                                Die ich etwas massiver formulieren würde:
                                Error by subscription (trigger): Wrong ID of type boolean or number
                                  Homoran Global Moderator Administrators @haus-automatisierung last edited by Homoran
                                  mir fehlte hauptsächlich der deutliche Bezug zum Trigger!
                                  Als normaler Blockly-User kann ich Subscription nicht zuordnen
                                  haus-automatisierung paul53 2 Replies Last reply Reply Quote 0
                                    Beim Wording habe ich mich an den anderen (bereits existierenden) Fehlermeldungen orientiert. Die Funktion heißt halt subscribe (on ist ja nur ein alias dafür).
                                    Aber ich bin ganz bei Dir: Den Blockly-Nutzern wird das nicht klar. Nehme ich mal mit auf ToDo.
                                      @homoran sagte: Als normaler Blockly-User kann ich Subscription nicht zuordnen
                                      So besser?
                                        @paul53 sagte:
                                        So besser?
                                        Super!
                                        da wird es allen gerecht!
                                          @homoran sagte: da wird es allen gerecht!
                                          PR ist erstellt.
                                          haus-automatisierung 1 Reply Last reply Reply Quote 2
                                            haus-automatisierung Developer Most Active @paul53 last edited by
                                            @paul53 Danke 🙂 Die Meldung ein paar Zeilen da drüber könntest Du ja analog dazu auch noch anpassen.
                                            2849
