    4. Puppeteer: Screenshots PhantomJS Alternative
      Marty56 @foxriver76 last edited by
      @foxriver76 Danke. Damit hat es funktioniert.
        jojo182 last edited by
        ich bekomme leider den Adapter auch nicht grün. Hat jemand eine Idee was es sein könnte?
        Folgende Fehlermeldung erscheint im Log:
        2022-08-22 10:43:07.164 - info: host.raspberrypi instance system.adapter.puppeteer.0 started with pid 18342
        2022-08-22 10:43:09.637 - error: puppeteer.0 (18342) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2022-08-22 10:43:09.640 - error: puppeteer.0 (18342) unhandled promise rejection: Failed to launch the browser process!
        /opt/iobroker/node_modules/iobroker.puppeteer/node_modules/puppeteer/.local-chromium/linux-982053/chrome-linux/chrome: 16: /opt/iobroker/node_modules/iobroker.puppeteer/node_modules/puppeteer/.local-chromium/linux-982053/chrome-linux/chrome: Syntax error: ")" unexpected
        TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
        2022-08-22 10:43:09.643 - error: puppeteer.0 (18342) Error: Failed to launch the browser process!
        at onClose (/opt/iobroker/node_modules/iobroker.puppeteer/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:241:20)
        at Interface. (/opt/iobroker/node_modules/iobroker.puppeteer/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:231:68)
        at Interface.emit (node:events:525:35)
        at Interface.close (node:readline:590:8)
        at Socket.onend (node:readline:280:10)
        at Socket.emit (node:events:525:35)
        at endReadableNT (node:internal/streams/readable:1358:12)
        at processTicksAndRejections (node:internal/process/task_queues:83:21)
        2022-08-22 10:43:09.644 - error: puppeteer.0 (18342) Failed to launch the browser process!
        2022-08-22 10:43:09.664 - warn: puppeteer.0 (18342) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2022-08-22 10:43:10.363 - error: host.raspberrypi instance system.adapter.puppeteer.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2022-08-22 10:43:10.363 - info: host.raspberrypi Restart adapter system.adapter.puppeteer.0 because enabled
        • foxriver76
          Es ist sehr wichtig, den Adapter klassisch zu installieren, nicht via Katze oder ähnliches. Falls anders geschehen bitte Adapter löschen und normal über Admin installieren. Dann werden die nötigen Pakete mit installiert.
            liv-in-sky @foxriver76 last edited by
            @foxriver76
            hast du das mitbekommen - war ursprünglich hier im thread gepostet - wurde aber verschoben
            https://forum.iobroker.net/post/845827
            • foxriver76
              foxriver76 Developer @liv-in-sky last edited by
              @liv-in-sky Ja, sollte nicht gelöscht werden wie von Thomas vermutet. Dort liegt meines Wissens der Browser der von Puppeteer selbst mitgebracht wird.
                liv-in-sky @jojo182 last edited by liv-in-sky
                @jojo182
                hast du das ausgeführt ? https://forum.iobroker.net/post/845727
                soll nicht heißen, du sollst das ausführen !!!!
                • Negalein
                  Negalein Global Moderator @foxriver76 last edited by
                  @foxriver76 sagte in Puppeteer: Screenshots PhantomJS Alternative:
                  seh gerade, dass es mich da auch erwischt hat.
                  Also Puppeteer wieder deinstallieren und wieder installieren?
                  • foxriver76
                    foxriver76 Developer @Negalein last edited by
                    @negalein Ja, ist die sauberste Lösung.
                      @foxriver76 Also ich hab den ganzen Adapter gelöscht, dann manuell die Reste in node_modules auch.
                      Dann über Admin Oberfläche den Adapter neu installiert, leider das gleiche Ergebnis.
                      @liv-in-sky Tatsächlich hatte ich das ausgeführt, danach meckerte dann der Adapter das er chromium gar nicht finden kann wegen dem "." Hatte dann nochmal alles deinstalliert und neu installiert und dann kam wieder der oben genannte Fehler.
                      Ich muss dazu sagen, dass ich normalerweiße im Javascript immer direkt puppeteer aufgerufen hatte. Seit einer Woche ca. geht das nicht mehr. Wahrscheinlich dann das gleiche Problem, nur zeigt er mir im Log nichts an, deshalb hatte ich gehofft ich bekomm es mit dem puppeteer Adapter wieder ans laufen.
                      • foxriver76
                        foxriver76 Developer @jojo182 last edited by
                        @jojo182 Kannst du was zu deinem System sagen. Zeige mal alle Ausgaben:
                        node -v
                        nodejs -v
                        cd /opt/iobroker
                        npm ls
                          jojo182 @foxriver76 last edited by
                          @foxriver76
                          Ist ein Raspberry Pi 4 mit (noch) buster.
                          node -v
                          v16.17.0
                          nodejs -v
                          v16.17.0
                          cd /opt/iobroker
                          npm ls
                          iobroker.inst@3.0.0 /opt/iobroker
                          ├── canvas@2.9.3
                          ├── iobroker.admin@6.2.17
                          ├── iobroker.backitup@2.4.12
                          ├── iobroker.daswetter@3.1.4
                          ├── iobroker.discovery@3.0.5
                          ├── iobroker.echarts@1.0.12
                          ├── iobroker.email@1.1.3
                          ├── iobroker.energiefluss@1.0.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#0a734637f65acccbe761f460d06ecd1cb0731a96)
                          ├── iobroker.flot@1.11.0
                          ├── iobroker.fritzdect@2.2.3
                          ├── iobroker.history@2.2.1
                          ├── iobroker.homeconnect@1.0.1
                          ├── iobroker.husq-automower@1.1.2 (git+ssh://git@github.com/truegreyhound/ioBroker.husq-automower.git#7a8ed7031d6e945544c0adbb05d82cc0f322f954)
                          ├── iobroker.info@1.9.19
                          ├── iobroker.jarvis@3.0.13
                          ├── iobroker.javascript@6.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.javascript.git#9f30d43e14ff8e86d89860be50d1a4f4e15e2905)
                          ├── iobroker.js-controller@4.0.23
                          ├── iobroker.knx@1.0.45
                          ├── iobroker.mihome-vacuum@3.6.0
                          ├── iobroker.modbus@5.0.5
                          ├── iobroker.mqtt@4.0.7
                          ├── iobroker.node-red@3.3.1
                          ├── iobroker.openknx@0.2.6
                          ├── iobroker.openweathermap@0.3.0
                          ├── iobroker.puppeteer@0.2.6
                          ├── iobroker.pvforecast@2.3.0
                          ├── iobroker.shuttercontrol@1.4.14
                          ├── iobroker.simple-api@2.7.0
                          ├── iobroker.smartmeter@3.3.4
                          ├── iobroker.socketio@6.1.8
                          ├── iobroker.sonoff@2.5.1
                          ├── iobroker.sql@2.1.8
                          ├── iobroker.stiebel-isg@1.7.5
                          ├── iobroker.telegram@1.14.1
                          ├── iobroker.text2command@2.2.2
                          ├── iobroker.tr-064@4.2.16
                          ├── iobroker.vis@1.4.15
                          ├── iobroker.web@5.2.4
                          ├── iobroker.ws@2.1.3
                          ├── iobroker.yr@5.3.0
                          ├── iobroker.zigbee@1.7.6
                          └── puppeteer@16.2.0
                          Javascript Adapter ist übrigens nur über github installiert weil ich gehofft hatte das Task Cancel Problem ist damit behoben.
                          • foxriver76
                            foxriver76 Developer @jojo182 last edited by foxriver76
                            @jojo182 Bitte noch
                            Edit: sehe schon die Version all good
                            Ich vermute es liegt an puppeteer@16.2.0, der Adapter installiert eigentlich ^13.7.0 und 16 ist nicht kompatibel. Lösche die Version bitte manuell und dann reinstall des Adapters. Evtl. hast du puppeteer im Javascript Adapter hinterlegt, dann dort zusätzlich entfernen.
                            • Negalein
                              läuft wieder 🙂
                                jojo182 last edited by jojo182
                                @foxriver76 Hat leider nichts geholfen. Hab puppeteer@16.2.0 deinstalliert, Im JS Adapter das zusätzliche puppeteer modul entfernt und JS neu gestartet und dann deinen Adapter einmal komplett entfernt und neu installiert. Trotzdem die gleiche Fehlermeldung wie oben gepostet.
                                Edit: Was mir noch aufgefallen ist: Wenn ich im JS Adapter wieder puppeteer reinnehme und den Adapter neu starte, erscheint im Log folgendes:
                                javascript.0
                                	2022-08-22 12:33:04.583	error	WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                javascript.0
                                	2022-08-22 12:33:04.580	error	npm
                                javascript.0
                                	2022-08-22 12:33:04.496	error	WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
                                javascript.0
                                	2022-08-22 12:33:04.494	error	npm
                                javascript.0
                                	2022-08-22 12:33:04.325	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                javascript.0
                                	2022-08-22 12:33:04.322	error	npm
                                javascript.0
                                	2022-08-22 12:33:04.069	error	WARN deprecated har-validator@5.1.5: this library is no longer supported
                                javascript.0
                                	2022-08-22 12:33:04.067	error	npm
                                javascript.0
                                	2022-08-22 12:32:58.082	info	npm install puppeteer --omit=dev (System call)
                                Das erscheint nur mit aktiviertem puppeteer modul. Keine Ahnung ob das was damit zu tun hat.
                                mikeal created this issue in request/request
                                open Request’s Past, Present and Future #3142
                                • foxriver76
                                  @jojo182 zeig jetzt mal
                                  cd /opt/iobroker
                                  npm ls -la
                                    @foxriver76
                                    $ cd /opt/iobroker
                                    $ npm ls -la
                                    npm ERR! Cannot read properties of undefined (reading 'description')
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-08-22T11_13_22_947Z-debug-0.log
                                    $ cat /home/iobroker/.npm/_logs/2022-08-22T11_13_22_947Z-debug-0.log
                                    0 verbose cli /usr/bin/node /usr/bin/npm
                                    1 info using npm@8.15.0
                                    2 info using node@v16.17.0
                                    3 timing npm:load:whichnode Completed in 1ms
                                    4 timing config:load:defaults Completed in 6ms
                                    5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
                                    6 timing config:load:builtin Completed in 4ms
                                    7 timing config:load:cli Completed in 16ms
                                    8 timing config:load:env Completed in 1ms
                                    9 timing config:load:file:/opt/iobroker/.npmrc Completed in 3ms
                                    10 timing config:load:project Completed in 6ms
                                    11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
                                    12 timing config:load:user Completed in 1ms
                                    13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                                    14 timing config:load:global Completed in 0ms
                                    15 timing config:load:validate Completed in 1ms
                                    16 timing config:load:credentials Completed in 3ms
                                    17 timing config:load:setEnvs Completed in 3ms
                                    18 timing config:load Completed in 43ms
                                    19 timing npm:load:configload Completed in 44ms
                                    20 timing npm:load:mkdirpcache Completed in 10ms
                                    21 timing npm:load:mkdirplogs Completed in 2ms
                                    22 verbose title npm ls
                                    23 verbose argv "ls" "--long" "--all"
                                    24 timing npm:load:setTitle Completed in 4ms
                                    25 timing config:load:flatten Completed in 11ms
                                    26 timing npm:load:display Completed in 16ms
                                    27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
                                    28 verbose logfile /home/iobroker/.npm/_logs/2022-08-22T11_13_22_947Z-debug-0.log
                                    29 timing npm:load:logFile Completed in 17ms
                                    30 timing npm:load:timers Completed in 1ms
                                    31 timing npm:load:configScope Completed in 1ms
                                    32 timing npm:load Completed in 96ms
                                    33 timing arborist:ctor Completed in 3ms
                                    34 silly logfile start cleaning logs, removing 1 files
                                    35 silly logfile done cleaning log files
                                    36 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.puppeteer
                                    37 timing command:ls Completed in 5787ms
                                    38 verbose stack TypeError: Cannot read properties of undefined (reading 'description')
                                    38 verbose stack     at getHumanOutputItem (/usr/lib/node_modules/npm/lib/commands/ls.js:334:35)
                                    38 verbose stack     at visit (/usr/lib/node_modules/npm/lib/commands/ls.js:160:15)
                                    38 verbose stack     at visitNode (/usr/lib/node_modules/npm/node_modules/treeverse/lib/breadth.js:37:25)
                                    38 verbose stack     at next (/usr/lib/node_modules/npm/node_modules/treeverse/lib/breadth.js:23:19)
                                    38 verbose stack     at /usr/lib/node_modules/npm/node_modules/treeverse/lib/breadth.js:25:31
                                    38 verbose stack     at processTicksAndRejections (node:internal/process/task_queues:96:5)
                                    38 verbose stack     at async LS.exec (/usr/lib/node_modules/npm/lib/commands/ls.js:122:20)
                                    38 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:78:5)
                                    39 verbose cwd /opt/iobroker
                                    40 verbose Linux 5.10.103-v7l+
                                    41 verbose node v16.17.0
                                    42 verbose npm  v8.15.0
                                    43 error Cannot read properties of undefined (reading 'description')
                                    44 verbose exit 1
                                    45 timing npm Completed in 6097ms
                                    46 verbose code 1
                                    47 error A complete log of this run can be found in:
                                    47 error     /home/iobroker/.npm/_logs/2022-08-22T11_13_22_947Z-debug-0.log
                                      Thomas Braun Most Active @jojo182 last edited by
                                      @jojo182
                                      cd /opt/iobroker
                                      npm ls
                                      war vermutlich gemeint.
                                        jojo182 @Thomas Braun last edited by Negalein
                                        $ npm ls
                                        ├── @types/caseless@0.12.2 extraneous
                                        ├── @types/request@2.48.8 extraneous
                                        ├── @types/tough-cookie@4.0.2 extraneous
                                        ├── canvas@2.9.3
                                        ├── coffeescript@1.12.7 extraneous
                                        ├── node-inspect@2.0.0 extraneous
                                        ├── picocolors@1.0.0 extraneous
                                        ├── setimmediate@1.0.5 extraneous
                                        ├── virtual-tsc@0.6.2 extraneous
                                        └── wake_on_lan@1.0.0 extraneous
                                        • foxriver76
                                          @jojo182 Komisch, dass er nur top level zeigt
                                          cd /opt/iobroker
                                          npm ls --depth=4
                                          J Thomas Braun 2 Replies Last reply Reply Quote 0
                                            @foxriver76 Jetzt kommt ein haufen Zeugs:
                                            $ npm ls --depth=4
                                            ├─┬ @types/request@2.48.8 extraneous
                                            │ ├── @types/caseless@0.12.2 deduped
                                            │ ├── @types/node@18.6.3
                                            │ ├── @types/tough-cookie@4.0.2 deduped
                                            │ └─┬ form-data@2.5.1 extraneous
                                            │   ├── asynckit@0.4.0
                                            │   ├─┬ combined-stream@1.0.8
                                            │   │ └── delayed-stream@1.0.0
                                            │   └─┬ mime-types@2.1.30
                                            │     └── mime-db@1.47.0
                                            ├─┬ canvas@2.9.3
                                            │ ├─┬ @mapbox/node-pre-gyp@1.0.9
                                            │ │ ├── detect-libc@2.0.1
                                            │ │ ├─┬ https-proxy-agent@5.0.0
                                            │ │ │ ├─┬ agent-base@6.0.2
                                            │ │ │ │ └── debug@4.3.1
                                            │ │ │ └─┬ debug@4.3.1
                                            │ │ │   └── ms@2.1.2
                                            │ │ ├─┬ make-dir@3.1.0
                                            │ │ │ └── semver@6.3.0
                                            │ │ ├─┬ node-fetch@2.6.7
                                            │ │ │ ├─┬ encoding@0.1.13
                                            │ │ │ │ └── iconv-lite@0.6.3
                                            │ │ │ └─┬ whatwg-url@5.0.0
                                            │ │ │   ├── tr46@0.0.3
                                            │ │ │   └── webidl-conversions@3.0.1
                                            │ │ ├─┬ nopt@5.0.0
                                            │ │ │ └── abbrev@1.1.1
                                            │ │ ├─┬ npmlog@5.0.1
                                            │ │ │ ├─┬ are-we-there-yet@2.0.0
                                            │ │ │ │ ├── delegates@1.0.0
                                            │ │ │ │ └── readable-stream@3.6.0
                                            │ │ │ ├── console-control-strings@1.1.0
                                            │ │ │ ├─┬ gauge@3.0.2
                                            │ │ │ │ ├── aproba@1.2.0
                                            │ │ │ │ ├── color-support@1.1.3
                                            │ │ │ │ ├── console-control-strings@1.1.0 deduped
                                            │ │ │ │ ├── has-unicode@2.0.1
                                            │ │ │ │ ├── object-assign@4.1.1 deduped
                                            │ │ │ │ ├── signal-exit@3.0.7
                                            │ │ │ │ ├── string-width@4.2.3
                                            │ │ │ │ ├── strip-ansi@6.0.1
                                            │ │ │ │ └── wide-align@1.1.5
                                            │ │ │ └── set-blocking@2.0.0
                                            │ │ ├─┬ rimraf@3.0.2
                                            │ │ │ └─┬ glob@7.1.6
                                            │ │ │   ├── fs.realpath@1.0.0
                                            │ │ │   ├── inflight@1.0.6
                                            │ │ │   ├── inherits@2.0.3 deduped
                                            │ │ │   ├── minimatch@3.0.4
                                            │ │ │   ├── once@1.4.0 deduped
                                            │ │ │   └── path-is-absolute@1.0.1
                                            │ │ ├── semver@7.3.5 deduped
                                            │ │ └── tar@6.1.11 deduped
                                            │ ├── nan@2.16.0
                                            │ └─┬ simple-get@3.1.0
                                            │   ├─┬ decompress-response@4.2.1
                                            │   │ └── mimic-response@2.1.0
                                            │   ├─┬ once@1.4.0
                                            │   │ └── wrappy@1.0.2
                                            │   └── simple-concat@1.0.1
                                            ├─┬ iobroker.admin@6.2.17
                                            │ ├─┬ @iobroker/adapter-core@2.6.0
                                            │ │ └─┬ @types/iobroker@4.0.2
                                            │ │   └── @types/node@18.6.3 deduped
                                            │ ├─┬ @iobroker/socket-classes@0.5.2
                                            │ │ ├── axios@0.27.2 deduped
                                            │ │ ├── cookie-parser@1.4.6 deduped
                                            │ │ └── passport@0.6.0 deduped
                                            │ ├─┬ @iobroker/ws-server@2.1.0
                                            │ │ └── ws@8.8.1 deduped
                                            │ ├─┬ axios@0.27.2
                                            │ │ ├── follow-redirects@1.14.9
                                            │ │ └─┬ form-data@4.0.0
                                            │ │   ├── asynckit@0.4.0 deduped
                                            │ │   ├── combined-stream@1.0.8 deduped
                                            │ │   └── mime-types@2.1.30 deduped
                                            │ ├─┬ body-parser@1.20.0
                                            │ │ ├── bytes@3.1.2
                                            │ │ ├── content-type@1.0.4
                                            │ │ ├─┬ debug@2.6.9
                                            │ │ │ └── ms@2.0.0
                                            │ │ ├── depd@2.0.0
                                            │ │ ├── destroy@1.2.0
                                            │ │ ├─┬ http-errors@2.0.0
                                            │ │ │ ├── depd@2.0.0 deduped
                                            │ │ │ ├── inherits@2.0.4
                                            │ │ │ ├── setprototypeof@1.2.0 deduped
                                            │ │ │ ├── statuses@2.0.1 deduped
                                            │ │ │ └── toidentifier@1.0.1
                                            │ │ ├─┬ iconv-lite@0.4.24
                                            │ │ │ └── safer-buffer@2.1.2
                                            │ │ ├─┬ on-finished@2.4.1
                                            │ │ │ └── ee-first@1.1.1
                                            │ │ ├── qs@6.10.3 deduped
                                            │ │ ├─┬ raw-body@2.5.1
                                            │ │ │ ├── bytes@3.1.2 deduped
                                            │ │ │ ├── http-errors@2.0.0 deduped
                                            │ │ │ ├── iconv-lite@0.4.24 deduped
                                            │ │ │ └── unpipe@1.0.0 deduped
                                            │ │ ├─┬ type-is@1.6.18
                                            │ │ │ ├── media-typer@0.3.0
                                            │ │ │ └── mime-types@2.1.30 deduped
                                            │ ├─┬ compression@1.7.4
                                            │ │ ├─┬ accepts@1.3.7
                                            │ │ │ ├── mime-types@2.1.30 deduped
                                            │ │ │ └── negotiator@0.6.2
                                            │ │ ├── bytes@3.0.0
                                            │ │ ├─┬ compressible@2.0.18
                                            │ │ │ └── mime-db@1.47.0 deduped
                                            │ │ ├── debug@2.6.9 deduped
                                            │ │ ├── on-headers@1.0.2
                                            │ │ ├── safe-buffer@5.1.2
                                            │ │ └── vary@1.1.2
                                            │ ├── connect-flash@0.1.1
                                            │ ├─┬ cookie-parser@1.4.6
                                            │ │ ├── cookie-signature@1.0.6
                                            │ │ └── cookie@0.4.1
                                            │ ├─┬ express-fileupload@1.4.0
                                            │ │ └─┬ busboy@1.6.0
                                            │ │   └── streamsearch@1.1.0
                                            │ ├─┬ express-session@1.17.3
                                            │ │ ├── cookie-signature@1.0.6 deduped
                                            │ │ ├── cookie@0.4.2
                                            │ │ ├── on-headers@1.0.2 deduped
                                            │ │ ├── parseurl@1.3.3
                                            │ │ ├── safe-buffer@5.2.1
                                            │ │ └─┬ uid-safe@2.1.5
                                            │ │   └── random-bytes@1.0.0
                                            │ ├─┬ express@4.18.1
                                            │ │ ├─┬ accepts@1.3.8
                                            │ │ │ ├─┬ mime-types@2.1.35
                                            │ │ │ │ └── mime-db@1.52.0
                                            │ │ │ └── negotiator@0.6.3
                                            │ │ ├── array-flatten@1.1.1
                                            │ │ ├── body-parser@1.20.0 deduped
                                            │ │ ├─┬ content-disposition@0.5.4
                                            │ │ │ └── safe-buffer@5.2.1
                                            │ │ ├── content-type@1.0.4 deduped
                                            │ │ ├── cookie@0.5.0
                                            │ │ ├── encodeurl@1.0.2
                                            │ │ ├── escape-html@1.0.3
                                            │ │ ├── etag@1.8.1
                                            │ │ ├─┬ finalhandler@1.2.0
                                            │ │ │ ├── debug@2.6.9 deduped
                                            │ │ │ ├── encodeurl@1.0.2 deduped
                                            │ │ │ ├── escape-html@1.0.3 deduped
                                            │ │ │ ├── on-finished@2.4.1 deduped
                                            │ │ │ ├── parseurl@1.3.3 deduped
                                            │ │ ├── fresh@0.5.2
                                            │ │ ├── merge-descriptors@1.0.1
                                            │ │ ├── methods@1.1.2
                                            │ │ ├── path-to-regexp@0.1.7
                                            │ │ ├─┬ proxy-addr@2.0.7
                                            │ │ │ ├── forwarded@0.2.0
                                            │ │ │ └── ipaddr.js@1.9.1
                                            │ │ ├── range-parser@1.2.1
                                            │ │ ├── safe-buffer@5.2.1 deduped
                                            │ │ ├─┬ send@0.18.0
                                            │ │ │ ├── destroy@1.2.0 deduped
                                            │ │ │ ├── etag@1.8.1 deduped
                                            │ │ │ ├── fresh@0.5.2 deduped
                                            │ │ │ ├── mime@1.6.0
                                            │ │ │ ├── ms@2.1.3
                                            │ │ │ ├── range-parser@1.2.1 deduped
                                            │ │ │ └── statuses@2.0.1 deduped
                                            │ │ ├─┬ serve-static@1.15.0
                                            │ │ │ └── send@0.18.0 deduped
                                            │ │ ├── type-is@1.6.18 deduped
                                            │ │ ├── utils-merge@1.0.1
                                            │ │ └── vary@1.1.2 deduped
                                            │ ├── mime@3.0.0
                                            │ ├─┬ passport-local@1.0.0
                                            │ │ └── passport-strategy@1.0.0
                                            │ ├─┬ passport@0.6.0
                                            │ │ ├── passport-strategy@1.0.0 deduped
                                            │ │ ├── pause@0.0.1
                                            │ │ └── utils-merge@1.0.1 deduped
                                            │ ├─┬ semver@7.3.7
                                            │ │ └─┬ lru-cache@6.0.0
                                            │ │   └── yallist@4.0.0 deduped
                                            │ └─┬ ws@8.8.1
                                            │   ├── UNMET OPTIONAL DEPENDENCY bufferutil@^4.0.1
                                            │   └── UNMET OPTIONAL DEPENDENCY utf-8-validate@^5.0.2
                                            ├─┬ iobroker.backitup@2.4.12
                                            │ ├─┬ @googleapis/drive@3.0.1
                                            │ │ └─┬ googleapis-common@5.1.0
                                            │ │   ├── extend@3.0.2 deduped
                                            │ │   ├─┬ gaxios@4.3.3
                                            │ │   │ ├── abort-controller@3.0.0
                                            │ │   │ ├── extend@3.0.2 deduped
                                            │ │   │ ├── https-proxy-agent@5.0.0 deduped
                                            │ │   │ ├── is-stream@2.0.0 deduped
                                            │ │   │ └── node-fetch@2.6.7 deduped
                                            │ │   ├─┬ google-auth-library@7.14.1
                                            │ │   │ ├── arrify@2.0.1 deduped
                                            │ │   │ ├── base64-js@1.5.1 deduped
                                            │ │   │ ├── ecdsa-sig-formatter@1.0.11 deduped
                                            │ │   │ ├── fast-text-encoding@1.0.3 deduped
                                            │ │   │ ├── gaxios@4.3.3 deduped
                                            │ │   │ ├── gcp-metadata@4.3.1
                                            │ │   │ ├── gtoken@5.3.2
                                            │ │   │ ├── jws@4.0.0 deduped
                                            │ │   │ └── lru-cache@6.0.0 deduped
                                            │ │   ├── url-template@2.0.8
                                            │ │   └── uuid@8.3.2
                                            │ ├── @iobroker/adapter-core@2.6.0 deduped
                                            │ ├─┬ axios@0.27.2
                                            │ │ ├── follow-redirects@1.14.9 deduped
                                            │ ├─┬ dropbox-v2-api@2.5.4
                                            │ │ └── request@2.88.2 deduped
                                            │ │ ├── array-flatten@1.1.1 deduped
                                            │ │ ├─┬ body-parser@1.20.0
                                            │ │ │ ├── content-type@1.0.4 deduped
                                            │ │ │ ├── qs@6.10.3 deduped
                                            │ │ │ ├─┬ raw-body@2.5.1
                                            │ │ │ │ ├── bytes@3.1.2 deduped
                                            │ │ │ │ ├── http-errors@2.0.0 deduped
                                            │ │ │ │ ├── iconv-lite@0.4.24 deduped
                                            │ │ │ │ └── unpipe@1.0.0 deduped
                                            │ │ │ ├── type-is@1.6.18 deduped
                                            │ │ ├── content-disposition@0.5.4 deduped
                                            │ │ ├── depd@2.0.0
                                            │ │ │ └── toidentifier@1.0.1 deduped
                                            │ │ ├── merge-descriptors@1.0.1 deduped
                                            │ │ ├── methods@1.1.2 deduped
                                            │ │ │ └── ee-first@1.1.1 deduped
                                            │ │ ├── path-to-regexp@0.1.7 deduped
                                            │ │ ├── proxy-addr@2.0.7 deduped
                                            │ │ ├─┬ send@0.18.0
                                            │ │ │ ├── mime@1.6.0 deduped
                                            │ │ │ ├── ms@2.1.3
                                            │ │ ├── utils-merge@1.0.1 deduped
                                            │ ├─┬ fs-extra@10.1.0
                                            │ │ ├── graceful-fs@4.2.6
                                            │ │ ├─┬ jsonfile@6.1.0
                                            │ │ │ ├── graceful-fs@4.2.6 deduped
                                            │ │ │ └── universalify@2.0.0 deduped
                                            │ ├─┬ ftp@0.3.10
                                            │ │ ├─┬ readable-stream@1.1.14
                                            │ │ │ ├── core-util-is@1.0.2
                                            │ │ │ ├── isarray@0.0.1
                                            │ │ │ └── string_decoder@0.10.31
                                            │ │ └── xregexp@2.0.0
                                            │ ├─┬ google-auth-library@8.1.1
                                            │ │ ├─┬ ecdsa-sig-formatter@1.0.11
                                            │ │ │ └── safe-buffer@5.1.2 deduped
                                            │ │ ├─┬ gaxios@5.0.1
                                            │ │ ├─┬ gcp-metadata@5.0.0
                                            │ │ │ ├── gaxios@5.0.1 deduped
                                            │ │ │ └─┬ json-bigint@1.0.0
                                            │ │ │   └── bignumber.js@9.0.2
                                            │ │ ├─┬ gtoken@6.1.0
                                            │ │ │ ├─┬ gaxios@4.3.3
                                            │ │ │ │ ├── abort-controller@3.0.0 deduped
                                            │ │ │ │ ├── extend@3.0.2 deduped
                                            │ │ │ │ ├── https-proxy-agent@5.0.0 deduped
                                            │ │ │ │ ├── is-stream@2.0.0 deduped
                                            │ │ │ │ └── node-fetch@2.6.7 deduped
                                            │ │ │ ├─┬ google-p12-pem@4.0.0
                                            │ │ │ │ └── node-forge@1.3.1 deduped
                                            │ │ │ └── jws@4.0.0 deduped
                                            │ │ ├─┬ jws@4.0.0
                                            │ │ │ ├─┬ jwa@2.0.0
                                            │ │ │ │ ├── buffer-equal-constant-time@1.0.1
                                            │ │ │ │ ├── ecdsa-sig-formatter@1.0.11 deduped
                                            │ │ │ │ └── safe-buffer@5.1.2 deduped
                                            │ ├─┬ node-schedule@2.1.0
                                            │ │ ├─┬ cron-parser@3.5.0
                                            │ │ │ ├─┬ is-nan@1.3.2
                                            │ │ │ │ ├── call-bind@1.0.2 deduped
                                            │ │ │ │ └── define-properties@1.1.3 deduped
                                            │ │ │ └── luxon@1.27.0 deduped
                                            │ │ ├── long-timeout@0.1.1
                                            │ │ └── sorted-array-functions@1.3.0
                                            │ ├── node-wol@0.1.1
                                            │ ├─┬ request@2.88.2
                                            │ │ ├── aws-sign2@0.7.0
                                            │ │ ├── aws4@1.11.0
                                            │ │ ├── caseless@0.12.0
                                            │ │ ├── forever-agent@0.6.1
                                            │ │ ├─┬ form-data@2.3.3
                                            │ │ │ ├── asynckit@0.4.0 deduped
                                            │ │ │ ├── combined-stream@1.0.8 deduped
                                            │ │ ├─┬ har-validator@5.1.5
                                            │ │ │ ├─┬ ajv@6.12.6
                                            │ │ │ │ ├── fast-deep-equal@3.1.3 deduped
                                            │ │ │ │ ├── fast-json-stable-stringify@2.1.0
                                            │ │ │ │ ├── json-schema-traverse@0.4.1
                                            │ │ │ │ └── uri-js@4.4.1
                                            │ │ │ └── har-schema@2.0.0
                                            │ │ ├─┬ http-signature@1.2.0
                                            │ │ │ ├── assert-plus@1.0.0
                                            │ │ │ ├─┬ jsprim@1.4.1
                                            │ │ │ │ ├── assert-plus@1.0.0 deduped
                                            │ │ │ │ ├── extsprintf@1.3.0
                                            │ │ │ │ ├── json-schema@0.2.3
                                            │ │ │ │ └── verror@1.10.0
                                            │ │ │ └─┬ sshpk@1.16.1
                                            │ │ │   ├── asn1@0.2.4
                                            │ │ │   ├── bcrypt-pbkdf@1.0.2
                                            │ │ │   ├── dashdash@1.14.1
                                            │ │ │   ├── ecc-jsbn@0.1.2
                                            │ │ │   ├── getpass@0.1.7
                                            │ │ │   ├── jsbn@0.1.1
                                            │ │ │   ├── safer-buffer@2.1.2 deduped
                                            │ │ │   └── tweetnacl@0.14.5
                                            │ │ ├── is-typedarray@1.0.0
                                            │ │ ├── isstream@0.1.2
                                            │ │ ├── json-stringify-safe@5.0.1
                                            │ │ ├── oauth-sign@0.9.0
                                            │ │ ├── performance-now@2.1.0
                                            │ │ ├── qs@6.5.2
                                            │ │ ├── safe-buffer@5.1.2 deduped
                                            │ │ ├─┬ tough-cookie@2.5.0
                                            │ │ │ ├── psl@1.8.0 deduped
                                            │ │ │ └── punycode@2.1.1 deduped
                                            │ │ ├─┬ tunnel-agent@0.6.0
                                            │ │ └── uuid@3.4.0
                                            │ ├─┬ tar-fs@2.1.1
                                            │ │ ├── chownr@1.1.4
                                            │ │ ├── mkdirp-classic@0.5.3
                                            │ │ ├─┬ pump@3.0.0
                                            │ │ │ ├─┬ end-of-stream@1.4.4
                                            │ │ │ │ └── once@1.4.0 deduped
                                            │ │ └─┬ tar-stream@2.2.0
                                            │ │   ├─┬ bl@4.1.0
                                            │ │   │ ├── buffer@5.7.1
                                            │ │   ├── end-of-stream@1.4.4 deduped
                                            │ │   ├── fs-constants@1.0.0
                                            │ │   └─┬ readable-stream@3.6.0
                                            │ │     ├── string_decoder@1.3.0
                                            │ │     └── util-deprecate@1.0.2 deduped
                                            │ └─┬ webdav@4.10.0
                                            │   ├─┬ axios@0.27.2
                                            │   ├── base-64@1.0.0
                                            │   ├── byte-length@1.0.2
                                            │   ├─┬ fast-xml-parser@3.21.1
                                            │   │ └── strnum@1.0.5
                                            │   ├── he@1.2.0
                                            │   ├── hot-patcher@0.5.0
                                            │   ├── layerr@0.1.2
                                            │   ├─┬ md5@2.3.0
                                            │   │ ├── charenc@0.0.2
                                            │   │ ├── crypt@0.0.2
                                            │   │ └── is-buffer@1.1.6
                                            │   ├─┬ minimatch@5.1.0
                                            │   │ └─┬ brace-expansion@2.0.1
                                            │   │   └── balanced-match@1.0.2
                                            │   ├── nested-property@4.0.0
                                            │   ├── path-posix@1.0.0
                                            │   ├── url-join@4.0.1
                                            │   └─┬ url-parse@1.5.10
                                            │     ├── querystringify@2.2.0
                                            │     └── requires-port@1.0.0
                                            ├─┬ iobroker.daswetter@3.1.4
                                            │ ├─┬ axios@0.27.2
                                            │ └── xml2json-light@1.0.6
                                            ├─┬ iobroker.discovery@3.0.5
                                            │ ├─┬ mdns-discovery@0.2.6
                                            │ │ ├─┬ debug@2.2.0
                                            │ │ │ └── ms@0.7.1
                                            │ │ ├── dgram@1.0.1
                                            │ │ └─┬ dns-packet@1.3.4
                                            │ │   ├── ip@1.1.5 deduped
                                            │ ├── netmask@2.0.2
                                            │ ├── node-mndp@0.0.3
                                            │ ├─┬ node-ssdp@4.0.1
                                            │ │ ├─┬ async@2.6.4
                                            │ │ │ └── lodash@4.17.21
                                            │ │ ├── bluebird@3.7.2
                                            │ │ ├─┬ debug@3.2.7
                                            │ │ │ └── ms@2.1.3
                                            │ │ └── ip@1.1.5 deduped
                                            │ └─┬ serialport@10.4.0
                                            │   ├─┬ @serialport/binding-mock@10.2.2
                                            │   │ ├── @serialport/bindings-interface@1.2.1
                                            │   │ └── debug@4.3.3 deduped
                                            │   ├─┬ @serialport/bindings-cpp@10.7.0
                                            │   │ ├── @serialport/bindings-interface@1.2.1 deduped
                                            │   │ ├─┬ @serialport/parser-readline@10.3.0
                                            │   │ │ └── @serialport/parser-delimiter@10.3.0
                                            │   │ ├─┬ debug@4.3.3
                                            │   │ │ └── ms@2.1.2
                                            │   │ ├── node-addon-api@4.3.0 deduped
                                            │   │ └── node-gyp-build@4.3.0
                                            │   ├── @serialport/parser-byte-length@10.3.0
                                            │   ├── @serialport/parser-cctalk@10.3.0
                                            │   ├── @serialport/parser-delimiter@10.3.0
                                            │   ├── @serialport/parser-inter-byte-timeout@10.3.0
                                            │   ├── @serialport/parser-packet-length@10.3.0
                                            │   │ └── @serialport/parser-delimiter@10.3.0 deduped
                                            │   ├── @serialport/parser-ready@10.3.0
                                            │   ├── @serialport/parser-regex@10.3.0
                                            │   ├── @serialport/parser-slip-encoder@10.3.0
                                            │   ├── @serialport/parser-spacepacket@10.3.0
                                            │   ├─┬ @serialport/stream@10.3.0
                                            │   └─┬ debug@4.3.3
                                            │     └── ms@2.1.2
                                            ├─┬ iobroker.echarts@1.0.12
                                            │ ├── canvas@2.9.3 deduped
                                            │ ├─┬ echarts@5.3.3
                                            │ │ ├── tslib@2.3.0
                                            │ │ └─┬ zrender@5.3.2
                                            │ │   └── tslib@2.3.0
                                            │ ├─┬ jsdom@19.0.0
                                            │ │ ├── abab@2.0.6
                                            │ │ ├─┬ acorn-globals@6.0.0
                                            │ │ │ ├── acorn-walk@7.2.0
                                            │ │ │ └── acorn@7.4.1
                                            │ │ ├── acorn@8.7.1
                                            │ │ ├── canvas@2.9.3 deduped
                                            │ │ ├── cssom@0.5.0
                                            │ │ ├─┬ cssstyle@2.3.0
                                            │ │ │ └── cssom@0.3.8
                                            │ │ ├─┬ data-urls@3.0.2
                                            │ │ │ ├── abab@2.0.6 deduped
                                            │ │ │ ├── whatwg-mimetype@3.0.0 deduped
                                            │ │ │ └─┬ whatwg-url@11.0.0
                                            │ │ │   ├── tr46@3.0.0 deduped
                                            │ │ │   └── webidl-conversions@7.0.0 deduped
                                            │ │ ├── decimal.js@10.3.1
                                            │ │ ├─┬ domexception@4.0.0
                                            │ │ ├─┬ escodegen@2.0.0
                                            │ │ │ ├── esprima@4.0.1
                                            │ │ │ ├── estraverse@5.3.0
                                            │ │ │ ├── esutils@2.0.3
                                            │ │ │ ├─┬ optionator@0.8.3
                                            │ │ │ │ ├── deep-is@0.1.4
                                            │ │ │ │ ├── fast-levenshtein@2.0.6
                                            │ │ │ │ ├── levn@0.3.0
                                            │ │ │ │ ├── prelude-ls@1.1.2
                                            │ │ │ │ ├── type-check@0.3.2
                                            │ │ │ │ └── word-wrap@1.2.3
                                            │ │ │ └── source-map@0.6.1 deduped
                                            │ │ ├─┬ form-data@4.0.0
                                            │ │ ├─┬ html-encoding-sniffer@3.0.0
                                            │ │ │ └── whatwg-encoding@2.0.0 deduped
                                            │ │ ├─┬ http-proxy-agent@5.0.0
                                            │ │ │ ├── @tootallnate/once@2.0.0
                                            │ │ │ ├── agent-base@6.0.2 deduped
                                            │ │ │ └─┬ debug@4.3.4
                                            │ │ │   └── ms@2.1.2
                                            │ │ ├── is-potential-custom-element-name@1.0.1
                                            │ │ ├── nwsapi@2.2.0
                                            │ │ ├── parse5@6.0.1
                                            │ │ ├─┬ saxes@5.0.1
                                            │ │ │ └── xmlchars@2.2.0
                                            │ │ ├── symbol-tree@3.2.4
                                            │ │ ├─┬ tough-cookie@4.0.0
                                            │ │ │ ├── punycode@2.1.1 deduped
                                            │ │ │ └── universalify@0.1.2
                                            │ │ ├─┬ w3c-hr-time@1.0.2
                                            │ │ │ └── browser-process-hrtime@1.0.0
                                            │ │ ├─┬ w3c-xmlserializer@3.0.0
                                            │ │ │ └── xml-name-validator@4.0.0 deduped
                                            │ │ ├── webidl-conversions@7.0.0
                                            │ │ ├─┬ whatwg-encoding@2.0.0
                                            │ │ │ └─┬ iconv-lite@0.6.3
                                            │ │ │   └── safer-buffer@2.1.2 deduped
                                            │ │ ├─┬ whatwg-url@10.0.0
                                            │ │ │ ├─┬ tr46@3.0.0
                                            │ │ │ │ └── punycode@2.1.1 deduped
                                            │ │ ├── ws@8.8.1 deduped
                                            │ └── moment@2.29.3
                                            ├─┬ iobroker.email@1.1.3
                                            │ └── nodemailer@6.7.5
                                            ├─┬ iobroker.energiefluss@1.0.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#0a734637f65acccbe761f460d06ecd1cb0731a96)
                                            │ └── canvas@2.9.3 deduped
                                            ├─┬ iobroker.flot@1.11.0
                                            │ └── @iobroker/adapter-core@2.6.0 deduped
                                            ├─┬ iobroker.fritzdect@2.2.3
                                            │ ├─┬ @iobroker/adapter-core@2.5.1
                                            │ │ └─┬ @types/iobroker@3.3.4
                                            │ ├─┬ command-line-args@5.2.0
                                            │ │ ├── array-back@3.1.0
                                            │ │ ├─┬ find-replace@3.0.0
                                            │ │ │ └── array-back@3.1.0 deduped
                                            │ │ ├── lodash.camelcase@4.3.0
                                            │ │ └── typical@4.0.0
                                            │ ├─┬ command-line-usage@6.1.1
                                            │ │ ├── array-back@4.0.2
                                            │ │ ├─┬ chalk@2.4.2
                                            │ │ │ ├─┬ ansi-styles@3.2.1
                                            │ │ │ │ └── color-convert@1.9.3
                                            │ │ │ ├── escape-string-regexp@1.0.5
                                            │ │ │ └─┬ supports-color@5.5.0
                                            │ │ │   └── has-flag@3.0.0
                                            │ │ ├─┬ table-layout@1.0.2
                                            │ │ │ ├── array-back@4.0.2
                                            │ │ │ ├── deep-extend@0.6.0
                                            │ │ │ ├── typical@5.2.0
                                            │ │ │ └─┬ wordwrapjs@4.0.1
                                            │ │ │   ├── reduce-flatten@2.0.0
                                            │ │ │   └── typical@5.2.0
                                            │ └── xml2json-light@1.0.6 deduped
                                            ├─┬ iobroker.history@2.2.1
                                            ├─┬ iobroker.homeconnect@1.0.1
                                            │ ├─┬ axios-rate-limit@1.3.0
                                            │ │ └── axios@0.24.0 deduped
                                            │ ├─┬ axios@0.26.1
                                            │ │ └── follow-redirects@1.14.9
                                            │ ├── eventsource@2.0.0
                                            │ └─┬ qs@6.10.3
                                            │   └─┬ side-channel@1.0.4
                                            │     ├─┬ call-bind@1.0.2
                                            │     │ ├── function-bind@1.1.1
                                            │     │ └── get-intrinsic@1.1.1 deduped
                                            │     ├─┬ get-intrinsic@1.1.1
                                            │     │ ├── function-bind@1.1.1 deduped
                                            │     │ ├── has-symbols@1.0.2
                                            │     │ └── has@1.0.3 deduped
                                            │     └── object-inspect@1.12.0
                                            ├─┬ iobroker.husq-automower@1.1.2 (git+ssh://git@github.com/truegreyhound/ioBroker.husq-automower.git#7a8ed7031d6e945544c0adbb05d82cc0f322f954)
                                            │ ├─┬ node-schedule@1.3.3
                                            │ │ ├─┬ cron-parser@2.18.0
                                            │ │ │ ├── is-nan@1.3.2 deduped
                                            │ │ │ └─┬ moment-timezone@0.5.33
                                            │ │ │   └── moment@2.29.1
                                            │ │ ├── long-timeout@0.1.1 deduped
                                            │ │ └── sorted-array-functions@1.3.0 deduped
                                            ├─┬ iobroker.info@1.9.19
                                            │ │ └─┬ @types/iobroker@4.0.1
                                            │ ├─┬ axios@0.26.0
                                            │ ├── jshashes@1.0.8
                                            │ ├── UNMET OPTIONAL DEPENDENCY osx-temperature-sensor@^1.0.7
                                            │ ├─┬ semver@7.3.5
                                            │ └── systeminformation@5.11.6
                                            ├─┬ iobroker.jarvis@3.0.13
                                            │ ├─┬ got@11.8.5
                                            │ │ ├── @sindresorhus/is@4.0.1
                                            │ │ ├─┬ @szmarczak/http-timer@4.0.5
                                            │ │ │ └── defer-to-connect@2.0.1
                                            │ │ ├─┬ @types/cacheable-request@6.0.1
                                            │ │ │ ├── @types/http-cache-semantics@4.0.0
                                            │ │ │ ├─┬ @types/keyv@3.1.1
                                            │ │ │ │ └── @types/node@18.6.3 deduped
                                            │ │ │ ├── @types/node@18.6.3 deduped
                                            │ │ │ └── @types/responselike@1.0.0 deduped
                                            │ │ ├─┬ @types/responselike@1.0.0
                                            │ │ ├── cacheable-lookup@5.0.4
                                            │ │ ├─┬ cacheable-request@7.0.2
                                            │ │ │ ├─┬ clone-response@1.0.2
                                            │ │ │ │ └── mimic-response@1.0.1
                                            │ │ │ ├─┬ get-stream@5.2.0
                                            │ │ │ │ └── pump@3.0.0 deduped
                                            │ │ │ ├── http-cache-semantics@4.1.0
                                            │ │ │ ├─┬ keyv@4.0.3
                                            │ │ │ │ └── json-buffer@3.0.1
                                            │ │ │ ├── lowercase-keys@2.0.0 deduped
                                            │ │ │ ├── normalize-url@6.1.0
                                            │ │ │ └── responselike@2.0.0 deduped
                                            │ │ ├─┬ decompress-response@6.0.0
                                            │ │ │ └── mimic-response@3.1.0
                                            │ │ ├─┬ http2-wrapper@1.0.3
                                            │ │ │ ├── quick-lru@5.1.1
                                            │ │ │ └── resolve-alpn@1.1.2
                                            │ │ ├── p-cancelable@2.1.1
                                            │ │ └─┬ responselike@2.0.0
                                            │ │   └── lowercase-keys@2.0.0 deduped
                                            │ ├── ip@1.1.5
                                            │ ├── object-hash@2.2.0
                                            │ ├── platform@1.3.6
                                            │ ├─┬ socket.io@4.5.1
                                            │ │ ├── accepts@1.3.7 deduped
                                            │ │ ├── base64id@2.0.0
                                            │ │ ├─┬ debug@4.3.4
                                            │ │ │ └── ms@2.1.2
                                            │ │ ├─┬ engine.io@6.2.0
                                            │ │ │ ├── @types/cookie@0.4.1
                                            │ │ │ ├── @types/cors@2.8.12
                                            │ │ │ ├── accepts@1.3.7 deduped
                                            │ │ │ ├── base64id@2.0.0 deduped
                                            │ │ │ ├── cookie@0.4.1 deduped
                                            │ │ │ ├─┬ cors@2.8.5
                                            │ │ │ │ └── vary@1.1.2 deduped
                                            │ │ │ ├── debug@4.3.4 deduped
                                            │ │ │ ├── engine.io-parser@5.0.4
                                            │ │ │ └─┬ ws@8.2.3
                                            │ │ │   ├── UNMET OPTIONAL DEPENDENCY bufferutil@^4.0.1
                                            │ │ │   └── UNMET OPTIONAL DEPENDENCY utf-8-validate@^5.0.2
                                            │ │ ├── socket.io-adapter@2.4.0
                                            │ │ └─┬ socket.io-parser@4.0.5
                                            │ │   ├── @types/component-emitter@1.2.11
                                            │ │   ├── component-emitter@1.3.0
                                            │ │   └── debug@4.3.4 deduped
                                            │ └── uuid@8.3.2
                                            ├─┬ iobroker.javascript@6.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.javascript.git#9f30d43e14ff8e86d89860be50d1a4f4e15e2905)
                                            │ │ └─┬ @types/iobroker@4.0.4
                                            │ │   └── @types/node@16.11.52 deduped
                                            │ ├── @types/node@16.11.52
                                            │ ├─┬ @types/request@2.48.8
                                            │ │ ├── @types/caseless@0.12.2
                                            │ │ ├── @types/node@16.11.52 deduped
                                            │ │ ├── @types/tough-cookie@4.0.2
                                            │ │ └─┬ form-data@2.5.1
                                            │ │   └── mime-types@2.1.35 deduped
                                            │ ├── coffeescript@1.12.7
                                            │ ├── jsonata@1.8.6
                                            │ ├─┬ jszip@3.10.0
                                            │ │ ├─┬ lie@3.3.0
                                            │ │ │ └── immediate@3.0.6
                                            │ │ ├── pako@1.0.11
                                            │ │ ├─┬ readable-stream@2.3.7
                                            │ │ │ ├── core-util-is@1.0.3
                                            │ │ │ ├── isarray@1.0.0
                                            │ │ │ ├── process-nextick-args@2.0.1
                                            │ │ │ ├── safe-buffer@5.1.2 deduped
                                            │ │ │ ├─┬ string_decoder@1.1.1
                                            │ │ │ └── util-deprecate@1.0.2
                                            │ │ └── setimmediate@1.0.5
                                            │ ├── node-inspect@2.0.0
                                            │ │ │ │ └── define-properties@1.1.4
                                            │ │ │ └── luxon@1.28.0
                                            │ ├─┬ puppeteer@16.2.0
                                            │ │ ├─┬ cross-fetch@3.1.5
                                            │ │ │ └─┬ node-fetch@2.6.7
                                            │ │ │   ├── encoding@0.1.13 deduped
                                            │ │ │   └── whatwg-url@5.0.0
                                            │ │ ├─┬ debug@4.3.4
                                            │ │ │ └── ms@2.1.2
                                            │ │ ├── devtools-protocol@0.0.1019158
                                            │ │ ├─┬ extract-zip@2.0.1
                                            │ │ │ ├─┬ @types/yauzl@2.10.0
                                            │ │ │ │ └── @types/node@16.11.52 deduped
                                            │ │ │ └─┬ yauzl@2.10.0
                                            │ │ │   ├── buffer-crc32@0.2.13
                                            │ │ │   └── fd-slicer@1.1.0
                                            │ │ ├─┬ https-proxy-agent@5.0.1
                                            │ │ │ │ └── debug@4.3.4 deduped
                                            │ │ ├── progress@2.0.3
                                            │ │ ├── proxy-from-env@1.1.0
                                            │ │ │ └─┬ glob@7.2.0
                                            │ │ │   ├── inherits@2.0.4 deduped
                                            │ │ │   ├── minimatch@3.1.2
                                            │ │ ├─┬ tar-fs@2.1.1
                                            │ │ │ ├── chownr@1.1.4
                                            │ │ │ ├── mkdirp-classic@0.5.3
                                            │ │ │ ├─┬ pump@3.0.0
                                            │ │ │ │ ├── end-of-stream@1.4.4
                                            │ │ │ └─┬ tar-stream@2.2.0
                                            │ │ │   ├── bl@4.1.0
                                            │ │ │   ├── end-of-stream@1.4.4 deduped
                                            │ │ │   ├── fs-constants@1.0.0
                                            │ │ ├─┬ unbzip2-stream@1.4.3
                                            │ │ │ ├─┬ buffer@5.7.1
                                            │ │ │ │ ├── base64-js@1.5.1
                                            │ │ │ │ └── ieee754@1.2.1
                                            │ │ │ └── through@2.3.8
                                            │ │ └─┬ ws@8.8.1
                                            │ │ ├── aws4@1.11.0
                                            │ │ ├─┬ combined-stream@1.0.8
                                            │ │ │ └── delayed-stream@1.0.0
                                            │ │ │ └── mime-types@2.1.35 deduped
                                            │ │ │ ├─┬ jsprim@1.4.2
                                            │ │ │ │ ├── json-schema@0.4.0
                                            │ │ │ └─┬ sshpk@1.17.0
                                            │ │ │   ├── asn1@0.2.6
                                            │ │ ├── qs@6.5.3
                                            │ │ │ ├── psl@1.9.0
                                            │ │ └── uuid@3.4.0
                                            │ ├─┬ semver@7.3.7
                                            │ ├── suncalc2@1.8.1
                                            │ ├── typescript@4.7.4
                                            │ ├─┬ virtual-tsc@0.6.2
                                            │ │ ├── picocolors@1.0.0
                                            │ │ └── typescript@4.7.4 deduped
                                            │ └─┬ wake_on_lan@1.0.0
                                            │   └── minimist@1.2.6
                                            ├─┬ iobroker.js-controller@4.0.23
                                            │ ├─┬ @alcalzone/esbuild-register@2.5.1-1
                                            │ │ ├── esbuild@0.11.23
                                            │ │ └── jsonc-parser@3.0.0
                                            │ ├─┬ @iobroker/db-objects-file@4.0.23
                                            │ │ ├─┬ @iobroker/db-base@4.0.23
                                            │ │ │ ├── @iobroker/js-controller-common@4.0.23 deduped
                                            │ │ │ ├── deep-clone@3.0.3 deduped
                                            │ │ │ ├── fs-extra@10.0.0 deduped
                                            │ │ │ └── respjs@4.2.0
                                            │ │ ├── @iobroker/db-objects-redis@4.0.23 deduped
                                            │ │ └── fs-extra@10.0.0 deduped
                                            │ ├─┬ @iobroker/db-objects-jsonl@4.0.23
                                            │ │ ├─┬ @alcalzone/jsonl-db@2.5.1
                                            │ │ │ ├─┬ alcalzone-shared@4.0.1
                                            │ │ │ └─┬ proper-lockfile@4.1.2
                                            │ │ │   ├── retry@0.12.0
                                            │ │ │   └── signal-exit@3.0.7 deduped
                                            │ │ ├── @iobroker/db-base@4.0.23 deduped
                                            │ │ ├── @iobroker/db-objects-file@4.0.23 deduped
                                            │ ├─┬ @iobroker/db-objects-redis@4.0.23
                                            │ │ ├─┬ ioredis@4.28.5
                                            │ │ │ ├── cluster-key-slot@1.1.0
                                            │ │ │ ├─┬ debug@4.3.4
                                            │ │ │ │ └── ms@2.1.2
                                            │ │ │ ├── denque@1.5.1
                                            │ │ │ ├── lodash.defaults@4.2.0
                                            │ │ │ ├── lodash.flatten@4.4.0
                                            │ │ │ ├── lodash.isarguments@3.1.0
                                            │ │ │ ├── p-map@2.1.0
                                            │ │ │ ├── redis-commands@1.7.0
                                            │ │ │ ├── redis-errors@1.2.0
                                            │ │ │ ├─┬ redis-parser@3.0.0
                                            │ │ │ │ └── redis-errors@1.2.0 deduped
                                            │ │ │ └── standard-as-callback@2.1.0
                                            │ │ ├─┬ node.extend@2.0.2
                                            │ │ │ ├─┬ has@1.0.3
                                            │ │ │ │ └── function-bind@1.1.1 deduped
                                            │ │ │ └── is@3.3.0
                                            │ │ └── semver@7.3.5 deduped
                                            │ ├─┬ @iobroker/db-states-file@4.0.23
                                            │ │ └── @iobroker/db-states-redis@4.0.23 deduped
                                            │ ├─┬ @iobroker/db-states-jsonl@4.0.23
                                            │ │ ├── @alcalzone/jsonl-db@2.5.1 deduped
                                            │ │ ├── @iobroker/db-states-file@4.0.23 deduped
                                            │ ├─┬ @iobroker/db-states-redis@4.0.23
                                            │ │ └── ioredis@4.28.5 deduped
                                            │ ├─┬ @iobroker/js-controller-adapter@4.0.23
                                            │ │ ├─┬ @alcalzone/pak@0.7.0
                                            │ │ │ ├─┬ axios@0.21.4
                                            │ │ │ │ └── follow-redirects@1.14.9 deduped
                                            │ │ │ ├─┬ execa@5.1.1
                                            │ │ │ │ ├── cross-spawn@7.0.3
                                            │ │ │ │ ├── get-stream@6.0.1
                                            │ │ │ │ ├── human-signals@2.1.0
                                            │ │ │ │ ├── merge-stream@2.0.0
                                            │ │ │ │ ├── npm-run-path@4.0.1
                                            │ │ │ │ ├── onetime@5.1.2
                                            │ │ │ │ ├── signal-exit@3.0.7 deduped
                                            │ │ │ │ └── strip-final-newline@2.0.0
                                            │ │ │ └─┬ fs-extra@9.1.0
                                            │ │ │   ├── at-least-node@1.0.0
                                            │ │ │   ├── jsonfile@6.1.0 deduped
                                            │ │ ├── @iobroker/db-objects-jsonl@4.0.23 deduped
                                            │ │ ├── @iobroker/db-states-jsonl@4.0.23 deduped
                                            │ │ ├── @iobroker/db-states-redis@4.0.23 deduped
                                            │ │ ├── @iobroker/plugin-base@1.2.1 deduped
                                            │ │ ├── @iobroker/plugin-sentry@1.2.0 deduped
                                            │ │ ├── jsonwebtoken@8.5.1 deduped
                                            │ │ ├── node-schedule@2.1.0 deduped
                                            │ │ ├── node.extend@2.0.2 deduped
                                            │ │ ├── pidusage@3.0.0 deduped
                                            │ │ ├── readline@1.3.0
                                            │ ├─┬ @iobroker/js-controller-cli@4.0.23
                                            │ │ ├── @iobroker/js-controller-common-db@4.0.23 deduped
                                            │ │ ├─┬ chokidar@3.5.3
                                            │ │ │ ├─┬ anymatch@3.1.2
                                            │ │ │ │ ├── normalize-path@3.0.0 deduped
                                            │ │ │ │ └── picomatch@2.3.1
                                            │ │ │ ├─┬ braces@3.0.2
                                            │ │ │ │ └── fill-range@7.0.1
                                            │ │ │ ├── UNMET OPTIONAL DEPENDENCY fsevents@~2.3.2
                                            │ │ │ ├─┬ glob-parent@5.1.2
                                            │ │ │ │ └── is-glob@4.0.3 deduped
                                            │ │ │ ├─┬ is-binary-path@2.1.0
                                            │ │ │ │ └── binary-extensions@2.2.0
                                            │ │ │ ├─┬ is-glob@4.0.3
                                            │ │ │ │ └── is-extglob@2.1.1
                                            │ │ │ └─┬ readdirp@3.6.0
                                            │ │ │   └── picomatch@2.3.1 deduped
                                            │ │ ├── daemonize2@0.4.2 deduped
                                            │ │ ├─┬ debug@4.3.4
                                            │ │ │ └── ms@2.1.2
                                            │ │ ├─┬ event-stream@4.0.1
                                            │ │ │ ├── duplexer@0.1.2
                                            │ │ │ ├── from@0.1.7
                                            │ │ │ ├── map-stream@0.0.7
                                            │ │ │ ├─┬ pause-stream@0.0.11
                                            │ │ │ │ └── through@2.3.8 deduped
                                            │ │ │ ├─┬ split@1.0.1
                                            │ │ │ ├─┬ stream-combiner@0.2.2
                                            │ │ │ │ ├── duplexer@0.1.2 deduped
                                            │ │ └── readline-sync@1.4.10 deduped
                                            │ ├─┬ @iobroker/js-controller-common-db@4.0.23
                                            │ │ ├─┬ winston-seq-updated@1.0.4
                                            │ │ │ ├── seq-logging@0.4.6
                                            │ │ │ └─┬ winston-transport@4.5.0
                                            │ │ │   ├── logform@2.4.0 deduped
                                            │ │ │   ├── readable-stream@3.6.0
                                            │ │ │   └── triple-beam@1.3.0 deduped
                                            │ │ └─┬ winston-syslog@2.5.0
                                            │ │   ├── glossy@0.1.7
                                            │ │   ├─┬ unix-dgram@2.0.4
                                            │ │   │ ├── bindings@1.5.0
                                            │ │   │ └── nan@2.16.0 deduped
                                            │ │   └── winston@3.7.2 deduped
                                            │ ├─┬ @iobroker/js-controller-common@4.0.23
                                            │ │ ├── @alcalzone/pak@0.7.0 deduped
                                            │ │ ├─┬ @datalust/winston-seq@1.0.2
                                            │ │ │ ├── seq-logging@1.1.1
                                            │ │ │ ├── winston-transport@4.5.0 deduped
                                            │ │ │ └── winston@3.7.2 deduped
                                            │ │ ├─┬ axios@0.26.1
                                            │ │ ├── ci-info@3.3.0
                                            │ │ ├── event-stream@4.0.1 deduped
                                            │ │ ├── node-forge@1.3.1
                                            │ │ ├── promisify-child-process@4.1.1 deduped
                                            │ │ ├── readline@1.3.0 deduped
                                            │ │ ├── request@2.88.2 deduped
                                            │ │ ├─┬ winston-daily-rotate-file@4.6.1
                                            │ │ │ ├─┬ file-stream-rotator@0.6.1
                                            │ │ │ │ └── moment@2.29.1 deduped
                                            │ │ │ ├── object-hash@2.2.0 deduped
                                            │ │ │ ├── triple-beam@1.3.0
                                            │ │ ├── winston-syslog@2.5.0 deduped
                                            │ │ └─┬ winston@3.7.2
                                            │ │   ├─┬ @dabh/diagnostics@2.0.3
                                            │ │   │ ├── colorspace@1.1.4
                                            │ │   │ ├── enabled@2.0.0
                                            │ │   │ └── kuler@2.0.0
                                            │ │   ├── async@3.2.3
                                            │ │   ├─┬ logform@2.4.0
                                            │ │   │ ├── @colors/colors@1.5.0 deduped
                                            │ │   │ ├── fecha@4.2.3
                                            │ │   │ ├── ms@2.1.3
                                            │ │   │ ├── safe-stable-stringify@2.3.1 deduped
                                            │ │   ├─┬ one-time@1.0.0
                                            │ │   │ └── fn.name@1.1.0
                                            │ │   ├─┬ readable-stream@3.6.0
                                            │ │   │ ├── string_decoder@1.3.0
                                            │ │   │ └── util-deprecate@1.0.2 deduped
                                            │ │   ├── stack-trace@0.0.10
                                            │ │   ├── triple-beam@1.3.0 deduped
                                            │ │   └── winston-transport@4.5.0 deduped
                                            │ ├─┬ @iobroker/plugin-sentry@1.2.0
                                            │ │ ├─┬ @sentry/integrations@6.19.7
                                            │ │ │ ├── @sentry/types@6.19.7
                                            │ │ │ ├─┬ @sentry/utils@6.19.7
                                            │ │ │ │ ├── @sentry/types@6.19.7 deduped
                                            │ │ │ │ └── tslib@1.14.1 deduped
                                            │ │ │ ├── localforage@1.10.0 deduped
                                            │ │ ├─┬ @sentry/node@6.18.2
                                            │ │ │ ├─┬ @sentry/core@6.18.2
                                            │ │ │ │ ├── @sentry/hub@6.18.2 deduped
                                            │ │ │ │ ├── @sentry/minimal@6.18.2
                                            │ │ │ │ ├── @sentry/types@6.18.2 deduped
                                            │ │ │ │ ├── @sentry/utils@6.18.2 deduped
                                            │ │ │ ├─┬ @sentry/hub@6.18.2
                                            │ │ │ ├─┬ @sentry/utils@6.18.2
                                            │ │ │ ├── cookie@0.4.2
                                            │ │ │ ├── lru_map@0.3.3 deduped
                                            │ │ └── source-map-support@0.5.21 deduped
                                            │ ├─┬ axios@0.24.0
                                            │ ├─┬ debug@4.3.4
                                            │ │ └── ms@2.1.2
                                            │ ├─┬ decache@4.6.1
                                            │ │ └── callsite@1.0.0
                                            │ ├─┬ diskusage@1.1.3
                                            │ │ ├── es6-promise@4.2.8
                                            │ ├─┬ fs-extra@10.0.0
                                            │ ├─┬ greenlock-express@4.0.3
                                            │ │ ├─┬ @root/greenlock-express@4.0.4
                                            │ │ │ ├── @root/greenlock@4.0.5 deduped
                                            │ │ │ └── redirect-https@1.3.1 deduped
                                            │ │ ├─┬ @root/greenlock@4.0.5
                                            │ │ │ ├── @greenlock/manager@3.1.0 deduped
                                            │ │ │ ├── @root/acme@3.1.0 deduped
                                            │ │ │ ├── @root/csr@0.8.1 deduped
                                            │ │ │ ├─┬ @root/keypairs@0.10.3
                                            │ │ │ │ ├── @root/encoding@1.0.1 deduped
                                            │ │ │ │ ├── @root/pem@1.0.4 deduped
                                            │ │ │ │ └── @root/x509@0.7.2 deduped
                                            │ │ │ ├── @root/mkdirp@1.0.0 deduped
                                            │ │ │ ├── @root/request@1.8.1 deduped
                                            │ │ │ ├── acme-http-01-standalone@3.0.5 deduped
                                            │ │ │ ├── cert-info@1.5.1 deduped
                                            │ │ │ ├── greenlock-store-fs@3.2.2 deduped
                                            │ │ │ └── safe-replace@1.1.0 deduped
                                            │ │ └─┬ redirect-https@1.3.1
                                            │ │   └── escape-html@1.0.3 deduped
                                            31.7k
                                            79.8k
                                            browser headless phantomjs puppeteer screenshot screenshots website
                                            23
                                            245
                                            25724
