    4. [HowTo] ioBroker unter Docker auf Synology DiskStation
      tscheinik last edited by
      Hallo bin ganz neu hier.
      habe auf der 415+ mit docker iobroker zum laufen bekommen. da in den nächsten tagen ein z-wave usb stick kommt wollt eich schon mal den z-wave adapter installieren.
      klappt aber nicht.
      hat einer ahnung was der fehler ist ?
      $ ./iobroker add zwave
      npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call)
      /bin/sh: 1: sudo: not found
      /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e;
      ! Error: Command failed: sudo apt-get install libudev-dev -y
      ! at checkExecSyncError (child_process.js:481:13)
      at Object.execSync (child_process.js:521:13)
      at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15)
      at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:25:7)
      at Module._compile (module.js:570:32)
      at Object.Module._extensions..js (module.js:579:10)
      at Module.load (module.js:487:32)
      at tryModuleLoad (module.js:446:12)
      at Function.Module._load (module.js:438:3)
      at Module.runMain (module.js:604:10)
      ! npm
      ERR! Linux 3.10.102npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker"
      npm ERR! node v6.11.0
      npm ERR! npm v3.10.10
      npm ERR! code ELIFECYCLE
      ! npm ERR! iobroker.zwave@0.6.0 preinstall: node lib/preinstall.jsnpm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'.
      npm ERR! Make sure you have the latest version of node.js and npm installed.
      npm ERR! If you do, this is most likely a problem with the iobroker.zwave package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR! node lib/preinstall.js
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR! npm bugs iobroker.zwave
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR! npm owner ls iobroker.zwave
      npm ERR! There is likely additional logging output above.
      ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log
      ! host.DS415 install adapter zwave
      ! npm ERR! Linux 3.10.102
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.11.0
      ! npm ERR! npm v3.10.10npm ERR! code ELIFECYCLE
      ! npm ERR! npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'.
      npm
      ERR! If you do, this is most likely a problem with the iobroker.zwave package,npm ERR! not with npm itself.
      npm ERR!
      You can get information on how to open an issue for this project with:npm ERR!
      npm bugs iobroker.zwavenpm ERR! Or if that isn't available, you can get their info via:
      ! npm ERR!
      ! npm
      npm
      ERR! node v6.11.0
      npm ERR!
      ERROR: host.DS415 Cannot install zwave
      ERROR: process exited with code 13</anonymous></anonymous></anonymous>
      • andre
        andre Developer last edited by
        @tscheinik:
        klappt aber nicht.
        ! $ ./iobroker add zwave npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call) /bin/sh: 1: sudo: not found /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e; ^ ! Error: Command failed: sudo apt-get install libudev-dev -y /bin/sh: 1: sudo: not found ! at checkExecSyncError (child_process.js:481:13) at Object.execSync (child_process.js:521:13) at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15) at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:25:7) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) at Function.Module._load (module.js:438:3) at Module.runMain (module.js:604:10) ! npm ERR! Linux 3.10.102npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker" npm ERR! node v6.11.0 npm ERR! npm v3.10.10 npm ERR! code ELIFECYCLE ! npm ERR! iobroker.zwave@0.6.0 preinstall: `node lib/preinstall.js`npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the iobroker.zwave package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node lib/preinstall.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs iobroker.zwave npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls iobroker.zwave npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log ! host.DS415 install adapter zwave npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call) /bin/sh: 1: sudo: not found /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e; ^ ! Error: Command failed: sudo apt-get install libudev-dev -y /bin/sh: 1: sudo: not found ! at checkExecSyncError (child_process.js:481:13) at Object.execSync (child_process.js:521:13) at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15) at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:25:7) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) at Function.Module._load (module.js:438:3) at Module.runMain (module.js:604:10) ! npm ERR! Linux 3.10.102 npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.11.0 ! npm ERR! npm v3.10.10npm ERR! code ELIFECYCLE ! npm ERR! iobroker.zwave@0.6.0 preinstall: `node lib/preinstall.js`npm ERR! Exit status 1 ! npm ERR! npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the iobroker.zwave package,npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node lib/preinstall.js npm ERR! You can get information on how to open an issue for this project with:npm ERR! npm bugs iobroker.zwavenpm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls iobroker.zwave npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log ! host.DS415 install adapter zwave npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call) /bin/sh: 1: sudo: not found /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e; ^ ! Error: Command failed: sudo apt-get install libudev-dev -y /bin/sh: 1: sudo: not found ! at checkExecSyncError (child_process.js:481:13) at Object.execSync (child_process.js:521:13) at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15) at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:25:7) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) at Function.Module._load (module.js:438:3) at Module.runMain (module.js:604:10) ! npm ERR! Linux 3.10.102npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker" npm ERR! node v6.11.0 npm ERR! npm v3.10.10npm ERR! code ELIFECYCLE ! npm ERR! iobroker.zwave@0.6.0 preinstall: `node lib/preinstall.js`npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the iobroker.zwave package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node lib/preinstall.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs iobroker.zwave npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls iobroker.zwave npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request: npm ERR! /opt/npm-debug.log ! host.DS415 install adapter zwave ERROR: host.DS415 Cannot install zwave ERROR: process exited with code 13</anonymous></anonymous></anonymous> `
        die Lösung steht im Log:
        Versuch mal sudo zu installieren. dazu einfach im Terminal des Containers:
        apt-get install sudo
        Und dann nochmal Adapterinstallation versuchen… Allerdings kann ich dir nicht helfen wenn es darum geht den USB-Stick am Container zum Laufen zu bekommen.
        Wäre aber trotzdem nett, wenn du berichtest (auch wenn alles klappt) dann könnte ich ggf. sudo auch mit in das Image mit aufnehmen und damit die Sache für andere User erleichtern... Danke.
        MfG,
        André
          hallo
          habe es installiert. aber bekomme trotzedem einen fehler. aber wohl was anderes
          sudo: unable to send audit message: Operation not permitteddebconf: unable to initialize frontend: Dialog
          debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76, <> line 1.)
          debconf: falling back to frontend: Readline
          debconf: unable to initialize frontend: Readline
          debconf: (This frontend requires a controlling tty.)
          debconf: falling back to frontend: Teletype
          dpkg-preconfigure: unable to re-open stdin:
          ! % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed
          ! 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
          100 125 0 125 0 0 160 0 --:--:-- --:--:-- --:--:-- 160
          ! 100 40742 0 40742 0 0 23720 0 --:--:-- 0:00:01 --:--:-- 23720
          100 1709k 0 1709k 0 0 678k 0 --:--:-- 0:00:02 --:--:-- 2086k
          ! /bin/sh: 1: unzip: not found
          ! Error: Command failed: unzip master.zip && rm master.zip
          at installOpenZwaveFromSource (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:109:3)
          at installOpenZwave (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:103:3)
          at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:26:7)
          ! npm
          ERR! Linux 3.10.102
          npm
          ! npm
          npm ERR!
          npm ERR!
          Make sure you have the latest version of node.js and npm installed.npm ERR!
          ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
          npm ERR!
          100 125 0 125 0 0 259 0 --:--:-- --:--:-- --:--:-- 259
          46 1709k 46 787k 0 0 453k 0 0:00:03 0:00:01 0:00:02 760k
          100 1709k 100 1709k 0 0 876k 0 0:00:01 0:00:01 --:--:-- 1369k
          ! npm
          ! npm
          npm ERR!
          npm ERR!
          ! npm ERR! Or if that isn't available, you can get their info via:npm ERR! npm owner ls iobroker.zwave
          100 125 0 125 0 0 268 0 --:--:-- --:--:-- --:--:-- 268
          ! 8 1709k 8 137k 0 0 104k 0 0:00:16 0:00:01 0:00:15 104k
          100 1709k 100 1709k 0 0 865k 0 0:00:01 0:00:01 --:--:-- 2381k
          ! npm
          npm ERR!
          node v6.11.0npm ERR! npm v3.10.10
          npm ERR!
          habe jetzt mal apt-get install unzip ins terminal eingegeben. versuche jetzt nochmal
          edit:
          es hat geklappt
          • andre
            @tscheinik:
            hallo
            ! $ ./iobroker add zwave npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call) sudo: unable to send audit message: Operation not permitteddebconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76, <> line 1.) debconf: falling back to frontend: Readline debconf: unable to initialize frontend: Readline debconf: (This frontend requires a controlling tty.) debconf: falling back to frontend: Teletype dpkg-preconfigure: unable to re-open stdin: ! % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed ! 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 125 0 125 0 0 160 0 --:--:-- --:--:-- --:--:-- 160 ! 100 40742 0 40742 0 0 23720 0 --:--:-- 0:00:01 --:--:-- 23720 100 1709k 0 1709k 0 0 678k 0 --:--:-- 0:00:02 --:--:-- 2086k ! /bin/sh: 1: unzip: not found /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e; ^ ! Error: Command failed: unzip master.zip && rm master.zip /bin/sh: 1: unzip: not found ! at checkExecSyncError (child_process.js:481:13) at Object.execSync (child_process.js:521:13) at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15) at installOpenZwaveFromSource (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:109:3) at installOpenZwave (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:103:3) at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:26:7) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) ! npm ERR! Linux 3.10.102 npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.11.0 npm ERR! npm v3.10.10 npm ERR! code ELIFECYCLE ! npm ERR! iobroker.zwave@0.6.0 preinstall: `node lib/preinstall.js` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'. npm ERR! Make sure you have the latest version of node.js and npm installed.npm ERR! If you do, this is most likely a problem with the iobroker.zwave package,npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system: npm ERR! node lib/preinstall.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs iobroker.zwave npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls iobroker.zwave npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log ! host.DS415 install adapter zwave npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call) sudo: unable to send audit message: Operation not permitted % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed ! 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 125 0 125 0 0 259 0 --:--:-- --:--:-- --:--:-- 259 ! 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 46 1709k 46 787k 0 0 453k 0 0:00:03 0:00:01 0:00:02 760k 100 1709k 100 1709k 0 0 876k 0 0:00:01 0:00:01 --:--:-- 1369k ! /bin/sh: 1: unzip: not found /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e; ^ ! Error: Command failed: unzip master.zip && rm master.zip /bin/sh: 1: unzip: not found ! at checkExecSyncError (child_process.js:481:13) at Object.execSync (child_process.js:521:13) at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15) at installOpenZwaveFromSource (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:109:3) at installOpenZwave (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:103:3) at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:26:7) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) ! npm ERR! Linux 3.10.102npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker" npm ERR! node v6.11.0 npm ERR! npm v3.10.10 npm ERR! code ELIFECYCLE ! npm ERR! iobroker.zwave@0.6.0 preinstall: `node lib/preinstall.js`npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the iobroker.zwave package, npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system: npm ERR! node lib/preinstall.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs iobroker.zwave ! npm ERR! Or if that isn't available, you can get their info via:npm ERR! npm owner ls iobroker.zwave npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log ! host.DS415 install adapter zwave npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call) sudo: unable to send audit message: Operation not permitted % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed ! 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 125 0 125 0 0 268 0 --:--:-- --:--:-- --:--:-- 268 ! 8 1709k 8 137k 0 0 104k 0 0:00:16 0:00:01 0:00:15 104k 100 1709k 100 1709k 0 0 865k 0 0:00:01 0:00:01 --:--:-- 2381k ! /bin/sh: 1: unzip: not found /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e; ^ ! Error: Command failed: unzip master.zip && rm master.zip /bin/sh: 1: unzip: not found ! at checkExecSyncError (child_process.js:481:13) at Object.execSync (child_process.js:521:13) at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15) at installOpenZwaveFromSource (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:109:3) at installOpenZwave (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:103:3) at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:26:7) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) ! npm ERR! Linux 3.10.102npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker" npm ERR! node v6.11.0npm ERR! npm v3.10.10 npm ERR! code ELIFECYCLE ! npm ERR! iobroker.zwave@0.6.0 preinstall: `node lib/preinstall.js`npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the iobroker.zwave package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node lib/preinstall.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs iobroker.zwave npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls iobroker.zwave npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log ! host.DS415 install adapter zwave ERROR: host.DS415 Cannot install zwave ERROR: process exited with code 13</anonymous></anonymous></anonymous> `
            Du musst das Logfile schon lesen… Oder es zumindest versuchen...
            Nehme meinen letzte Beitrag und ersetze sudo mit unzip...
            MfG,
            André
            Gesendet mit Tapatalk
              haben uns überschnitten. darauf bin ich schon gekommen.
              es hat jetzt geklappt.
              • andre
                @tscheinik:
                es hat jetzt geklappt. `
                🙂 Du hattest jetzt nur sudo und unzip nachinstalliert, richtig?
                Lass es mich bitte wissen ob das Einbinden des USB sticks gelingt, dann würde ich die Pakete mit in das Image aufnehmen.
                MfG,
                André
                  ja sobald ich den stick bekomme werde ich es testen.
                  habe diesen stick Aeotec AEOEZW090-C Aeon Labs USB Stick
                  ja genau einmal sudo und einmal unzip
                    gingo79 last edited by
                    @andre:
                    Jetzt habe ich zwei Möglichkeiten: Entweder ich fange diese Meldung, dass ioBroker schon läuft irgendwie im Startup Script ab und reagiere darauf, oder ich identifiziere die Ursache und beseitige sie. Letzteres ist mein Favorit 😉
                    Momentan warte ich darauf, dass es bei mir wieder passiert. Allerdings startet meine DiskStation ja nicht so häufig wie bei dir. 🙂
                    Ich bleibe dran.
                    MfG,
                    André
                    Gesendet mit Tapatalk `
                    Vielen Dank dafür!
                    Gingo79
                      @andre:
                      @tscheinik:
                      MfG,
                      André
                      ich habe es einmal geschafft bei z-wave einen usb port auszuwhälen. war aber kurz danach weg. ich kann nichtmal einen usb port aussuchen.
                      bei domoticz wird der stick erkannt.
                        Artem82 last edited by
                        Please add to default to iob container 'cifs-utils'
                        I want mount folder.
                        Thx!!!
                        • andre
                          @tscheinik:
                          @andre:
                          @tscheinik:
                          MfG,
                          André
                          bei domoticz wird der stick erkannt. `
                          Versuch mal den Container mit erweiterten Berechtigungen laufen zu lassen. (https://forum.synology.com/enu/viewtopic.php?t=127019)
                          Container stoppen, Container bearbeiten, Allgemeine Einstellungen: "Container mit hoher Priorität ausführen". Vielleicht hast du dann Zugriff auf die USB-Geräte.
                          Falls nicht kenne ich nur den Weg wie man USB-Devices beim Start des Containers per Kommandozeile durch reicht… Habe es selbst aber noch nicht praktiziert...
                          MfG,
                          André
                          • andre
                            @Artem82:
                            Please add to iob container 'cifs-utils'
                            Thx!!! `
                            I'm sorry. As long as no Adapter requires this package, I will not add this to the image.
                            But you can install it manually as you want using "apt-get install" at the commandline of the container.
                            If you wannt to mount folders between the container and diskstation there is a described way using the docker webinterface of the synology diskstation. Maybe it is also possible to share the mounted diskstation folder to access it from the network…
                            regards,
                            André
                              @andre:
                              @Artem82:
                              Thx!!! `
                              regards,
                              André `
                              ~~![](</s><URL url=)http://prntscr.com/fllf8w" />
                              After this command:
                              Unable to apply new capability set.~~
                              • andre
                                @Artem82:
                                @andre:
                                @Artem82:
                                Thx!!! `
                                regards,
                                André `
                                After this command:
                                Unable to apply new capability set.~~ ` ~~I'm sorry, can't help u with that.
                                Try to find something at google. It gives me a lot of results when i use:````
                                unable to apply new capability set cifs docker
                                regards,
                                André~~
                                  afunk last edited by
                                  wollte einfach mal DANKE für dieses coole Docker-Paket sagen 🙂
                                  afunk
                                  • andre
                                    @afunk:
                                    afunk `
                                    Das freut mich. 🙂 Hat sich die Arbeit ja gelohnt.
                                    MfG,
                                    André
                                      ehome last edited by
                                      Hallo Andre,
                                      habe gestern mal eine Test-Migration meiner iobroker Installation auf Docker gemacht. Deine Anleitung hat mir
                                      sehr geholfen - auch wenn ich es auf meiner QNAP gemacht habe.
                                      Der Adapter "phantomjs" lässt sich zwar installieren, funktioniert aber nicht richtig. Die Fehlermeldung findest du weiter unten.
                                      So richtig schlau werde ich nicht aus den Fehlermeldungen - aber vielleicht kannst du damit was anzufangen.
                                      Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
                                      phantomjs.0	2017-08-09 11:18:01.078	debug	inMem message phantomjs.0.* phantomjs.0.working val=false, ack=true, ts=1502270281067, q=0, from=system.adapter.phantomjs.0, lc=1502270281067
                                      phantomjs.0	2017-08-09 11:18:01.074	debug	inMem message phantomjs.0.* phantomjs.0.working val=true, ack=true, ts=1502270281066, q=0, from=system.adapter.phantomjs.0, lc=1502270281066
                                      phantomjs.0	2017-08-09 11:18:01.058	debug	inMem message phantomjs.0.* phantomjs.0.working val=false, ack=true, ts=1502270281054, q=0, from=system.adapter.phantomjs.0, lc=1502270281007
                                      phantomjs.0	2017-08-09 11:18:01.049	debug	inMem message phantomjs.0.* phantomjs.0.working val=false, ack=true, ts=1502270281046, q=0, from=system.adapter.phantomjs.0, lc=1502270281007
                                      phantomjs.0	2017-08-09 11:18:01.046	debug	inMem message phantomjs.0.* phantomjs.0.working val=false, ack=true, ts=1502270281041, q=0, from=system.adapter.phantomjs.0, lc=1502270281007
                                      phantomjs.0	2017-08-09 11:18:01.034	debug	inMem message phantomjs.0.* phantomjs.0.working val=false, ack=true, ts=1502270281030, q=0, from=system.adapter.phantomjs.0, lc=1502270281007
                                      phantomjs.0	2017-08-09 11:18:01.022	debug	inMem message phantomjs.0.* phantomjs.0.working val=false, ack=true, ts=1502270281016, q=0, from=system.adapter.phantomjs.0, lc=1502270281007
                                      phantomjs.0	2017-08-09 11:18:01.012	debug	inMem message phantomjs.0.* phantomjs.0.working val=false, ack=true, ts=1502270281007, q=0, from=system.adapter.phantomjs.0, lc=1502270281007
                                      phantomjs.0	2017-08-09 11:18:01.010	debug	sendTo 'send' to system.adapter.javascript.0 from system.adapter.phantomjs.0
                                      phantomjs.0	2017-08-09 11:18:01.010	error	/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs: error while loading shared libraries: libfontconfig.so.1: cannot open shared object file: No such file or directory
                                      phantomjs.0	2017-08-09 11:18:01.010	error	Error: Command failed: /opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js http://iobroker:8082/flot/index.html?relativeEnd=now&range=2880&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=300&noBorder=noborder&titlePos=bottom%3A5%3Bleft%3A65&timeFormat=%25H%3A%25M&useComma=false&l%5B0%5D%5Bid%5D=wrapper.0.Strom.power_hausanschluss&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23ff0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5Bname%5D=Hausanschluss+gesamt&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Byaxe%5D=leftColor&l%5B0%5D%5BchartType%5D=line&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5Bsmoothing%5D=1&l%5B0%5D%5Bfill%5D=0.3&l%5B1%5D%5Bid%5D=wrapper.0.Strom.power_waschmaschine&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%239d9d9d&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bname%5D=Waschmaschine&l%5B1%5D%5Byaxe%5D=rightColor&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=0&l%5B2%5D%5Bid%5D=wrapper.0.Strom.power_it-schrank&l%5B2%5D%5Binstance%5D=sql.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%230000FF&l%5B2%5D%5Bmin%5D=0&l%5B2%5D%5Bthickness%5D=3&l%5B2%5D%5Bshadowsize%5D=3&l%5B2%5D%5Bname%5D=IT-Schrank&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BcommonYAxis%5D=2&l%5B2%5D%5BafterComma%5D=0&l%5B2%5D%5Bpoints%5D=false&l%5B3%5D%5Bid%5D=wrapper.0.Strom.power_schreibtisch-olli&l%5B3%5D%5Binstance%5D=sql.0&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%23FFFF00&l%5B3%5D%5Bmin%5D=0&l%5B3%5D%5Bthickness%5D=3&l%5B3%5D%5Bshadowsize%5D=3&l%5B3%5D%5Bname%5D=Schreibtisch+Olli&l%5B3%5D%5Byaxe%5D=off&l%5B3%5D%5Bxaxe%5D=off&l%5B3%5D%5BcommonYAxis%5D=2&l%5B3%5D%5BafterComma%5D=0&l%5B4%5D%5Bid%5D=wrapper.0.Strom.power_trockner&l%5B4%5D%5Binstance%5D=sql.0&l%5B4%5D%5Boffset%5D=0&l%5B4%5D%5Baggregate%5D=minmax&l%5B4%5D%5Bcolor%5D=%23FF00FF&l%5B4%5D%5Bmin%5D=0&l%5B4%5D%5Bthickness%5D=3&l%5B4%5D%5Bshadowsize%5D=3&l%5B4%5D%5Bname%5D=Trockner&l%5B4%5D%5Byaxe%5D=off&l%5B4%5D%5Bxaxe%5D=off&l%5B4%5D%5BcommonYAxis%5D=2&l%5B4%5D%5BafterComma%5D=0&timeType=relative&legend=nw&hoverDetail=true&zoom=true&noedit=false&animation=0&live=300&_vis_refts=1492630530729&grid_color=%23ffffff /opt/iobroker/node_modules/iobroker.phantomjs/stromverbrauch_woche.png 1010px*315px 90000ms
                                      phantomjs.0	2017-08-09 11:18:01.007	info	and save to '/opt/iobroker/node_modules/iobroker.phantomjs/stromverbrauch_woche.png'
                                      phantomjs.0	2017-08-09 11:18:01.000	info	Create 1010px*315px in 90000ms - 'http://iobroker:8082/flot/index.html?relativeEnd=now&range=2880&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=300&noBorder=noborder&titlePos=bottom%3A5%3Bleft%3A65&timeFormat=%25H%3A%25M&useComma=false&l%5B0%5D%5Bid%5D=wrapper.0.Strom.power_hausanschluss&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23ff0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5Bname%5D=Hausanschluss+gesamt&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Byaxe%5D=leftColor&l%5B0%5D%5BchartType%5D=line&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5Bsmoothing%5D=1&l%5B0%5D%5Bfill%5D=0.3&l%5B1%5D%5Bid%5D=wrapper.0.Strom.power_waschmaschine&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%239d9d9d&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bname%5D=Waschmaschine&l%5B1%5D%5Byaxe%5D=rightColor&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=0&l%5B2%5D%5Bid%5D=wrapper.0.Strom.power_it-schrank&l%5B2%5D%5Binstance%5D=sql.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%230000FF&l%5B2%5D%5Bmin%5D=0&l%5B2%5D%5Bthickness%5D=3&l%5B2%5D%5Bshadowsize%5D=3&l%5B2%5D%5Bname%5D=IT-Schrank&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BcommonYAxis%5D=2&l%5B2%5D%5BafterComma%5D=0&l%5B2%5D%5Bpoints%5D=false&l%5B3%5D%5Bid%5D=wrapper.0.Strom.power_schreibtisch-olli&l%5B3%5D%5Binstance%5D=sql.0&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%23FFFF00&l%5B3%5D%5Bmin%5D=0&l%5B3%5D%5Bthickness%5D=3&l%5B3%5D%5Bshadowsize%5D=3&l%5B3%5D%5Bname%5D=Schreibtisch+Olli&l%5B3%5D%5Byaxe%5D=off&l%5B3%5D%5Bxaxe%5D=off&l%5B3%5D%5BcommonYAxis%5D=2&l%5B3%5D%5BafterComma%5D=0&l%5B4%5D%5Bid%5D=wrapper.0.Strom.power_trockner&l%5B4%5D%5Binstance%5D=sql.0&l%5B4%5D%5Boffset%5D=0&l%5B4%5D%5Baggregate%5D=minmax&l%5B4%5D%5Bcolor%5D=%23FF00FF&l%5B4%5D%5Bmin%5D=0&l%5B4%5D%5Bthickness%5D=3&l%5B4%5D%5Bshadowsize%5D=3&l%5B4%5D%5Bname%5D=Trockner&l%5B4%5D%5Byaxe%5D=off&l%5B4%5D%5Bxaxe%5D=off&l%5B4%5D%5BcommonYAxis%5D=2&l%5B4%5D%5BafterComma%5D=0&timeType=relative&legend=nw&hoverDetail=true&zoom=true&noedit=false&animation=0&live=300&_vis_refts=1492630530729&grid_color=%23ffffff'
                                      phantomjs.0	2017-08-09 11:18:00.998	debug	inMem message phantomjs.0.* phantomjs.0.working val=true, ack=true, ts=1502270280939, q=0, from=system.adapter.phantomjs.0, lc=1502270280874
                                      phantomjs.0	2017-08-09 11:18:00.997	debug	inMem message phantomjs.0.* phantomjs.0.working val=true, ack=true, ts=1502270280930, q=0, from=system.adapter.phantomjs.0, lc=1502270280874
                                      phantomjs.0	2017-08-09 11:18:00.996	debug	inMem message phantomjs.0.* phantomjs.0.working val=true, ack=true, ts=1502270280917, q=0, from=system.adapter.phantomjs.0, lc=1502270280874
                                      phantomjs.0	2017-08-09 11:18:00.995	debug	inMem message phantomjs.0.* phantomjs.0.working val=true, ack=true, ts=1502270280907, q=0, from=system.adapter.phantomjs.0, lc=1502270280874
                                      phantomjs.0	2017-08-09 11:18:00.994	debug	inMem message phantomjs.0.* phantomjs.0.working val=true, ack=true, ts=1502270280887, q=0, from=system.adapter.phantomjs.0, lc=1502270280874
                                      phantomjs.0	2017-08-09 11:18:00.992	debug	inMem message phantomjs.0.* phantomjs.0.working val=true, ack=true, ts=1502270280874, q=0, from=system.adapter.phantomjs.0, lc=1502270280874
                                      phantomjs.0	2017-08-09 11:18:00.990	debug	inMem message messagebox.system.adapter.phantomjs.0 messagebox.system.adapter.phantomjs.0 command=send, url=http://iobroker:8082/flot/index.html?relativeEnd=now&range=2880&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=300&noBorder=noborder&titlePos=bottom%3A5%3Bleft%3A65&timeFormat=%25H%3A%25M&useComma=false&l%5B0%5D%5Bid%5D=wrapper.0.Strom.power_hausanschluss&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23ff0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5Bname%5D=Hausanschluss+gesamt&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Byaxe%5D=leftColor&l%5B0%5D%5BchartType%5D=line&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5Bsmoothing%5D=1&l%5B0%5D%5Bfill%5D=0.3&l%5B1%5D%5Bid%5D=wrapper.0.Strom.power_waschmaschine&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%239d9d9d&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bname%5D=Waschmaschine&l%5B1%5D%5Byaxe%5D=rightColor&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=0&l%5B2%5D%5Bid%5D=wrapper.0.Strom.power_it-schrank&l%5B2%5D%5Binstance%5D=sql.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%230000FF&l%5B2%5D%5Bmin%5D=0&l%5B2%5D%5Bthickness%5D=3&l%5B2%5D%5Bshadowsize%5D=3&l%5B2%5D%5Bname%5D=IT-Schrank&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BcommonYAxis%5D=2&l%5B2%5D%5BafterComma%5D=0&l%5B2%5D%5Bpoints%5D=false&l%5B3%5D%5Bid%5D=wrapper.0.Strom.power_schreibtisch-olli&l%5B3%5D%5Binstance%5D=sql.0&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%23FFFF00&l%5B3%5D%5Bmin%5D=0&l%5B3%5D%5Bthickness%5D=3&l%5B3%5D%5Bshadowsize%5D=3&l%5B3%5D%5Bname%5D=Schreibtisch+Olli&l%5B3%5D%5Byaxe%5D=off&l%5B3%5D%5Bxaxe%5D=off&l%5B3%5D%5BcommonYAxis%5D=2&l%5B3%5D%5BafterComma%5D=0&l%5B4%5D%5Bid%5D=wrapper.0.Strom.power_trockner&l%5B4%5D%5Binstance%5D=sql.0&l%5B4%5D%5Boffset%5D=0&l%5B4%5D%5Baggregate%5D=minmax&l%5B4%5D%5Bcolor%5D=%23FF00FF&l%5B4%5D%5Bmin%5D=0&l%5B4%5D%5Bthickness%5D=3&l%5B4%5D%5Bshadowsize%5D=3&l%5B4%5D%5Bname%5D=Trockner&l%5B4%5D%5Byaxe%5D=off&l%5B4%5D%5Bxaxe%5D=off&l%5B4%5D%5BcommonYAxis%5D=2&l%5B4%5D%5BafterComma%5D=0&timeType=relative&legend=nw&hoverDetail=true&zoom=true&noedit=false&animation=0&live=300&_vis_refts=1492630530729&grid_color=%23ffffff, output=stromverbrauch_woche.png, width=1010, height=315, renderTime=90000, online=true, from=system.adapter.javascript.0, url=http://iobroker:8082/flot/index.html?relativeEnd=now&range=2880&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=300&noBorder=noborder&titlePos=bottom%3A5%3Bleft%3A65&timeFormat=%25H%3A%25M&useComma=false&l%5B0%5D%5Bid%5D=wrapper.0.Strom.power_hausanschluss&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23ff0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5Bname%5D=Hausanschluss+gesamt&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Byaxe%5D=leftColor&l%5B0%5D%5BchartType%5D=line&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5Bsmoothing%5D=1&l%5B0%5D%5Bfill%5D=0.3&l%5B1%5D%5Bid%5D=wrapper.0.Strom.power_waschmaschine&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%239d9d9d&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bname%5D=Waschmaschine&l%5B1%5D%5Byaxe%5D=rightColor&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=0&l%5B2%5D%5Bid%5D=wrapper.0.Strom.power_it-schrank&l%5B2%5D%5Binstance%5D=sql.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%230000FF&l%5B2%5D%5Bmin%5D=0&l%5B2%5D%5Bthickness%5D=3&l%5B2%5D%5Bshadowsize%5D=3&l%5B2%5D%5Bname%5D=IT-Schrank&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BcommonYAxis%5D=2&l%5B2%5D%5BafterComma%5D=0&l%5B2%5D%5Bpoints%5D=false&l%5B3%5D%5Bid%5D=wrapper.0.Strom.power_schreibtisch-olli&l%5B3%5D%5Binstance%5D=sql.0&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%23FFFF00&l%5B3%5D%5Bmin%5D=0&l%5B3%5D%5Bthickness%5D=3&l%5B3%5D%5Bshadowsize%5D=3&l%5B3%5D%5Bname%5D=Schreibtisch+Olli&l%5B3%5D%5Byaxe%5D=off&l%5B3%5D%5Bxaxe%5D=off&l%5B3%5D%5BcommonYAxis%5D=2&l%5B3%5D%5BafterComma%5D=0&l%5B4%5D%5Bid%5D=wrapper.0.Strom.power_trockner&l%5B4%5D%5Binstance%5D=sql.0&l%5B4%5D%5Boffset%5D=0&l%5B4%5D%5Baggregate%5D=minmax&l%5B4%5D%5Bcolor%5D=%23FF00FF&l%5B4%5D%5Bmin%5D=0&l%5B4%5D%5Bthickness%5D=3&l%5B4%5D%5Bshadowsize%5D=3&l%5B4%5D%5Bname%5D=Trockner&l%5B4%5D%5Byaxe%5D=off&l%5B4%5D%5Bxaxe%5D=off&l%5B4%5D%5BcommonYAxis%5D=2&l%5B4%5D%5BafterComma%5D=0&timeType=relative&legend=nw&hoverDetail=true&zoom=true&noedit=false&animation=0&live=300&_vis_refts=1492630530729&grid_color=%23ffffff, output=stromverbrauch_woche.png, width=1010, height=315, renderTime=90000, online=true, id=8, ack=false, time=1502270280785, _id=36062398
                                      phantomjs.0	2017-08-09 11:18:00.980	debug	sendTo 'send' to system.adapter.javascript.0 from system.adapter.phantomjs.0
                                      phantomjs.0	2017-08-09 11:18:00.979	error	/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs: error while loading shared libraries: libfontconfig.so.1: cannot open shared object file: No such file or directory
                                      phantomjs.0	2017-08-09 11:18:00.979	error	Error: Command failed: /opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js http://iobroker:8082/flot/index.html?relativeEnd=now&range=10080&live=900&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=3600&noBorder=noborder&hoverDetail=false&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m&useComma=true&l%5B0%5D%5Bid%5D=wrapper.0.Temperatur.temp_za&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5Baggregate%5D=average&l%5B0%5D%5Bmin%5D=15&l%5B0%5D%5BafterComma%5D=1&l%5B0%5D%5Bpoints%5D=false&l%5B1%5D%5Bid%5D=wrapper.0.Temperatur.temp_zj&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=average&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bmin%5D=15&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=1&l%5B2%5D%5Bid%5D=wrapper.0.Temperatur.temp_zl&l%5B2%5D%5Binstance%5D=sql.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=average&l%5B2%5D%5Bcolor%5D=%230000FF&l%5B2%5D%5Bmin%5D=15&l%5B2%5D%5Bthickness%5D=3&l%5B2%5D%5Bshadowsize%5D=3&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BcommonYAxis%5D=1&l%5B2%5D%5BafterComma%5D=1&timeType=relative&zoom=false&noedit=true&animation=0&x_labels_color=%23ffffff&y_labels_color=%23ffffff&_vis_refts=1500482247515 /opt/iobroker/node_modules/iobroker.phantomjs/kinder_woche.png 414px*249px 90000ms
                                      phantomjs.0	2017-08-09 11:18:00.978	info	and save to '/opt/iobroker/node_modules/iobroker.phantomjs/kinder_woche.png'
                                      phantomjs.0	2017-08-09 11:18:00.976	debug	sendTo 'send' to system.adapter.javascript.0 from system.adapter.phantomjs.0
                                      phantomjs.0	2017-08-09 11:18:00.976	error	/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs: error while loading shared libraries: libfontconfig.so.1: cannot open shared object file: No such file or directory
                                      phantomjs.0	2017-08-09 11:18:00.976	error	Error: Command failed: /opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js http://iobroker:8082/flot/index.html?relativeEnd=now&range=2y&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=count&aggregateSpan=3600&noBorder=noborder&titlePos=bottom%3A5%3Bleft%3A65&timeFormat=%25d.%25m.%25y&useComma=false&l%5B0%5D%5Bid%5D=wrapper.0.ManuelleDaten.strom-verbrauch-monat&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Bcolor%5D=%233B3DA5&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bmax%5D=900&l%5B0%5D%5Bthickness%5D=4&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5Bunit%5D=kWh&l%5B0%5D%5BchartType%5D=line&l%5B0%5D%5Baggregate%5D=average&l%5B0%5D%5BignoreNull%5D=true&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Byaxe%5D=right&l%5B0%5D%5Bname%5D=Strom+in+kWh&l%5B0%5D%5Bfill%5D=30&l%5B0%5D%5Bpoints%5D=true&l%5B0%5D%5BafterComma%5D=2&l%5B1%5D%5Bid%5D=wrapper.0.ManuelleDaten.gas-verbrauch-monat&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=average&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bmax%5D=1100&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bunit%5D=m%C2%B3&l%5B1%5D%5Bname%5D=Gas+in+m%C2%B3&l%5B1%5D%5BchartType%5D=line&l%5B1%5D%5BignoreNull%5D=true&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5Byaxe%5D=left&l%5B1%5D%5Bfill%5D=30&l%5B1%5D%5Bpoints%5D=true&timeType=relative&legend=nw&hoverDetail=true&zoom=true&noedit=false&animation=0&x_labels_color=%23ffffff&y_labels_color=%23ffffff&grid_color=%23ffffff&barFontColor=%23ffffff&titleColor=%23ffffff /opt/iobroker/node_modules/iobroker.phantomjs/energie_gas_strom.png 1010px*300px 90000ms
                                      phantomjs.0	2017-08-09 11:18:00.975	info	and save to '/opt/iobroker/node_modules/iobroker.phantomjs/energie_gas_strom.png'
                                      phantomjs.0	2017-08-09 11:18:00.967	debug	sendTo 'send' to system.adapter.javascript.0 from system.adapter.phantomjs.0
                                      phantomjs.0	2017-08-09 11:18:00.966	error	/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs: error while loading shared libraries: libfontconfig.so.1: cannot open shared object file: No such file or directory
                                      phantomjs.0	2017-08-09 11:18:00.966	error	Error: Command failed: /opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js http://iobroker:8082/flot/index.html?relativeEnd=now&range=10080&live=900&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=3600&noBorder=noborder&hoverDetail=false&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m&useComma=true&l%5B0%5D%5Bid%5D=wrapper.0.Temperatur.temp_bo&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5Baggregate%5D=average&l%5B0%5D%5Bmin%5D=15&l%5B0%5D%5BafterComma%5D=1&l%5B0%5D%5Bpoints%5D=false&l%5B1%5D%5Bid%5D=wrapper.0.Temperatur.temp_fo&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=average&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bmin%5D=15&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=1&timeType=relative&zoom=false&noedit=true&animation=0&x_labels_color=%23ffffff&y_labels_color=%23ffffff&_vis_refts=1500482247515 /opt/iobroker/node_modules/iobroker.phantomjs/flure_woche.png 976px*334px 90000ms
                                      phantomjs.0	2017-08-09 11:18:00.965	info	and save to '/opt/iobroker/node_modules/iobroker.phantomjs/flure_woche.png'
                                      phantomjs.0	2017-08-09 11:18:00.965	debug	sendTo 'send' to system.adapter.javascript.0 from system.adapter.phantomjs.0
                                      phantomjs.0	2017-08-09 11:18:00.964	error	/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs: error while loading shared libraries: libfontconfig.so.1: cannot open shared object file: No such file or directory
                                      phantomjs.0	2017-08-09 11:18:00.964	error	Error: Command failed: /opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js http://iobroker:8082/flot/index.html?relativeEnd=now&range=10080&live=900&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=3600&noBorder=noborder&hoverDetail=false&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m&useComma=true&l%5B0%5D%5Bid%5D=wrapper.0.Temperatur.temp_wk&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5Baggregate%5D=average&l%5B0%5D%5Bmin%5D=15&l%5B0%5D%5BafterComma%5D=1&l%5B0%5D%5Bpoints%5D=false&l%5B1%5D%5Bid%5D=wrapper.0.Temperatur.temp_fu&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=average&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bmin%5D=15&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=1&timeType=relative&zoom=false&noedit=true&animation=0&x_labels_color=%23ffffff&y_labels_color=%23ffffff&_vis_refts=1500482247515 /opt/iobroker/node_modules/iobroker.phantomjs/erdgeschoss_woche.png 674px*301px 90000ms
                                      phantomjs.0	2017-08-09 11:18:00.964	info	and save to '/opt/iobroker/node_modules/iobroker.phantomjs/erdgeschoss_woche.png'
                                      phantomjs.0	2017-08-09 11:18:00.963	debug	sendTo 'send' to system.adapter.javascript.0 from system.adapter.phantomjs.0
                                      phantomjs.0	2017-08-09 11:18:00.962	error	/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs: error while loading shared libraries: libfontconfig.so.1: cannot open shared object file: No such file or directory
                                      phantomjs.0	2017-08-09 11:18:00.962	error	Error: Command failed: /opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js http://iobroker:8082/flot/index.html?relativeEnd=now&range=10080&live=900&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=3600&noBorder=noborder&hoverDetail=false&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m&useComma=true&l%5B0%5D%5Bid%5D=wrapper.0.Temperatur.temp_bo&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5Baggregate%5D=average&l%5B0%5D%5Bmin%5D=15&l%5B0%5D%5BafterComma%5D=1&l%5B0%5D%5Bpoints%5D=false&l%5B1%5D%5Bid%5D=wrapper.0.Temperatur.temp_wz&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=average&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bmin%5D=15&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=1&timeType=relative&zoom=false&noedit=true&animation=0&x_labels_color=%23ffffff&y_labels_color=%23ffffff&_vis_refts=1500482247515 /opt/iobroker/node_modules/iobroker.phantomjs/dachgeschoss_woche.png 941px*334px 90000ms
                                      phantomjs.0	2017-08-09 11:18:00.962	info	and save to '/opt/iobroker/node_modules/iobroker.phantomjs/dachgeschoss_woche.png'
                                      phantomjs.0	2017-08-09 11:18:00.960	debug	sendTo 'send' to system.adapter.javascript.0 from system.adapter.phantomjs.0
                                      phantomjs.0	2017-08-09 11:18:00.958	error	/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs: error while loading shared libraries: libfontconfig.so.1: cannot open shared object file: No such file or directory
                                      phantomjs.0	2017-08-09 11:18:00.958	error	Error: Command failed: /opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js http://iobroker:8082/flot/index.html?relativeEnd=now&range=1440&live=900&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=3600&noBorder=noborder&hoverDetail=false&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m&useComma=true&l%5B0%5D%5Bid%5D=wrapper.0.Temperatur.temp_ab&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5Baggregate%5D=max&timeType=relative&zoom=false&noedit=false&animation=0&x_labels_color=%23ffffff&y_labels_color=%23ffffff /opt/iobroker/node_modules/iobroker.phantomjs/aussen_tag.png 720px*401px 90000ms
                                      phantomjs.0	2017-08-09 11:18:00.957	info	and save to '/opt/iobroker/node_modules/iobroker.phantomjs/aussen_tag.png'
                                      phantomjs.0	2017-08-09 11:18:00.932	info	Create 1010px*300px in 90000ms - 'http://iobroker:8082/flot/index.html?relativeEnd=now&range=2y&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=count&aggregateSpan=3600&noBorder=noborder&titlePos=bottom%3A5%3Bleft%3A65&timeFormat=%25d.%25m.%25y&useComma=false&l%5B0%5D%5Bid%5D=wrapper.0.ManuelleDaten.strom-verbrauch-monat&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Bcolor%5D=%233B3DA5&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bmax%5D=900&l%5B0%5D%5Bthickness%5D=4&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5Bunit%5D=kWh&l%5B0%5D%5BchartType%5D=line&l%5B0%5D%5Baggregate%5D=average&l%5B0%5D%5BignoreNull%5D=true&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Byaxe%5D=right&l%5B0%5D%5Bname%5D=Strom+in+kWh&l%5B0%5D%5Bfill%5D=30&l%5B0%5D%5Bpoints%5D=true&l%5B0%5D%5BafterComma%5D=2&l%5B1%5D%5Bid%5D=wrapper.0.ManuelleDaten.gas-verbrauch-monat&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=average&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bmax%5D=1100&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bunit%5D=m%C2%B3&l%5B1%5D%5Bname%5D=Gas+in+m%C2%B3&l%5B1%5D%5BchartType%5D=line&l%5B1%5D%5BignoreNull%5D=true&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5Byaxe%5D=left&l%5B1%5D%5Bfill%5D=30&l%5B1%5D%5Bpoints%5D=true&timeType=relative&legend=nw&hoverDetail=true&zoom=true&noedit=false&animation=0&x_labels_color=%23ffffff&y_labels_color=%23ffffff&grid_color=%23ffffff&barFontColor=%23ffffff&titleColor=%23ffffff'
                                      Olli
                                      • andre
                                        @ehome:
                                        Hallo Andre,
                                        Olli ` Hallo,
                                        danke für das Feedback. Sieht aus alsob libfontconfig im Container fehlt. Mach mal im Container ein "apt-get install libfontconfig"
                                        Dann sollte der Adapter funktionieren.
                                        Schau mir das mal an wenn ich wieder daheim bin.
                                        MfG,
                                        André
                                        Gesendet von Unterwegs mit Tapatalk
                                          RalfR72 last edited by
                                          Habe den Beitrag mit der Advanced Docker Installation nun mehrmals gelesen. Das meiste ist mir auch klar. Nur wie bekomme ich das ioBroker Verzeichniss aus meinem Container raus? Wie komm ich da ran?
                                          Seh nirgends in meiner Diskstation das Biobroker Verzeichnis.
                                          Geht das mit einem Terminal Befehl? Wenn ja wie lautet der Befehl?
                                          Würd mich über Hilfe freuen.
                                          • andre
                                            @RalfR72:
                                            Würd mich über Hilfe freuen. `
                                            Hallo Ralf,
                                            sorry, dass ich dir auf deine pn noch nicht geantwortet hab. 🙂
                                            Du kannst von deinem Container aus über ein gemountetes Verzeichnis auf Ordner der DS zugreifen. Ich bin aktuell gerade dabei ein ausführliches Tutorial zum ganzen Synology und iobroker Thema zu schreiben. Gestern habe ich genau dein Thema beschrieben 🙂 Ist leider noch nicht veröffentlicht. Wenn ich es morgen an den PC schaffe, schicke ich dir schonmal meinen Entwurf per pn. Das sollte deine Frage dann beantworten.
                                            MfG,
                                            André
                                            Gesendet von iPad mit Tapatalk
                                            buanet diskstation docker iobroker synology
                                            248
                                            2854
                                            1526753
