    4. Admin 6.2 jetzt im Stable
    • Horst Böttcher
      Horst Böttcher last edited by
      Vielen Dank an euch, Update hat bestens geklappt.
      • Feuersturm
        Feuersturm @nerg last edited by
        @nerg bei mir kann ich auf dem Handy im Samsung Browser auf die Desktop Ansicht umschalten. Das ist erstmal ein workaround
        • Michael Schmitt
          Michael Schmitt @apollon77 last edited by
          wenn ich durch die einzelnen Rubriken ( Info, Adapter, Instanzen usw. ) schauen kommt mit fast jedem Klick =
          admin.0
          2022-08-23 17:25:12.765	info	==> Connected system.user.admin from ::ffff:192.168.178.40
          admin.0
          2022-08-23 17:25:01.149	info	==> Connected system.user.admin from ::ffff:192.168.178.40
          web.0
          2022-08-23 17:24:40.567	info	<== Disconnect system.user.admin from ::ffff:192.168.178.40 material.0
          admin.0
          2022-08-23 17:24:24.966	info	<== Disconnect system.user.admin from ::ffff:192.168.178.40
          host.raspberrypi
          2022-08-23 17:24:18.945	info	Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
          admin.0
          2022-08-23 17:24:15.857	info	==> Connected system.user.admin from ::ffff:192.168.178.40
          admin.0
          2022-08-23 17:18:00.201	info	<== Disconnect system.user.admin from ::ffff:192.168.178.40
          host.raspberrypi
          2022-08-23 17:17:49.336	info	Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
          admin.0
          2022-08-23 17:17:46.619	info	==> Connected system.user.admin from ::ffff:192.168.178.40
          admin.0
          2022-08-23 17:13:15.610	info	<== Disconnect system.user.admin from ::ffff:192.168.178.40 javascript
          admin.0
          2022-08-23 17:13:07.865	info	==> Connected system.user.admin from ::ffff:192.168.178.40
          admin.0
          2022-08-23 17:12:53.738	info	<== Disconnect system.user.admin from ::ffff:192.168.178.40
          host.raspberrypi
          2022-08-23 17:12:48.316	info	Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
          admin.0
          2022-08-23 17:12:45.458	info	==> Connected system.user.admin from ::ffff:192.168.178.40
          Wie kann ich das beheben ?
          • Feuersturm
            Feuersturm @Michael Schmitt last edited by
            @michael-schmitt meinst du die Meldung Connected system.user.admin?
            Das ist eine reine Info, da musst und kannst du nichts beheben.
            Michael Schmitt 1 Reply Last reply Reply Quote 0
            • Michael Schmitt
              Michael Schmitt @Feuersturm last edited by
              @feuersturm sagte in Admin 6.1 jetzt im Stable:
              OK, hab mich nur gewundert weil das vor dem Admin update nicht war.
              • bahnuhr
                bahnuhr Forum Testing Most Active last edited by bahnuhr
                Wenn admin 4 nicht mehr erreichbar ist, dann kann man nicht die whitelist im Adapter Cloud eingeben.
                siehe issue hier:
                https://github.com/ioBroker/ioBroker.cloud/issues/319
                mcuiobroker created this issue in ioBroker/ioBroker.cloud
                closed WhiteList for Services not shown under Admin 5 #319
                • Thomas Jansen
                  Thomas Jansen @stenmic last edited by
                  @stenmic Kann man das nicht oben über die 3 Balken?
                    ferzbeidel last edited by
                    Hallo, ich habe gestern das Update gemacht und seit dem komm ich nicht mehr auf die Iobroker Oberfläche übers Heimnetz. Über IoBroker Pro komme ich darauf.
                      stenmic @Thomas Jansen last edited by stenmic
                      @thomas-jansen leider nicht mehr!
                        ferzbeidel @ferzbeidel last edited by
                        @ferzbeidel Jetzt im Moment geht es wieder.🤷‍♂️
                          apollon77 @bahnuhr last edited by
                          @bahnuhr habe ich nochmal weitergegeben
                            apollon77 @ferzbeidel last edited by
                            @ferzbeidel ohne weitere Infos unmöglich zu bewerten… wenn es mal wieder Nicht tut. Browser fehlerkonsole schauen und auch logfile von iobroker.
                            draexler 1 Reply Last reply Reply Quote -1
                            • draexler
                              draexler @apollon77 last edited by
                              Ich habe auch versucht das Update zu machen. Jetzt ist der Admin nicht mehr erreichbar.
                              Wenn ich versuche den Admin über die Konsole zu starten
                              pi@SmartHomePi:~ $ iobroker start admin
                              The adapter "admin.0" was started.
                              Sagt er auch das er gestartet hat. Aber der Admin geht dann wieder auf disabled.
                              pi@SmartHomePi:~ $ iobroker list adapters
                              system.adapter.admin                   : admin          - v5.3.8
                              system.adapter.alarm                   : alarm          - v3.1.1
                              system.adapter.alexa2                  : alexa2         - v3.12.0
                              system.adapter.alias-manager           : alias-manager  - v1.2.4
                              system.adapter.backitup                : backitup       - v2.4.10
                              system.adapter.bring                   : bring          - v1.8.1
                              system.adapter.cloud                   : cloud          - v4.2.1
                              system.adapter.coronavirus-statistics  : coronavirus-statistics - v0.8.7
                              system.adapter.daswetter               : daswetter      - v3.1.2
                              system.adapter.devices                 : devices        - v1.0.12
                              system.adapter.discovery               : discovery      - v3.0.5
                              system.adapter.ecovacs-deebot          : ecovacs-deebot - v1.4.4
                              system.adapter.email                   : email          - v1.1.3
                              system.adapter.esphome                 : esphome        - v0.2.4
                              system.adapter.feiertage               : feiertage      - v1.1.0
                              system.adapter.flot                    : flot           - v1.11.0
                              system.adapter.ham                     : ham            - v5.0.1
                              system.adapter.harmony                 : harmony        - v1.2.2
                              system.adapter.heizoel                 : heizoel        - v1.0.3
                              system.adapter.history                 : history        - v2.2.0
                              system.adapter.hm-rega                 : hm-rega        - v3.0.40
                              system.adapter.hm-rpc                  : hm-rpc         - v1.15.12
                              system.adapter.hue                     : hue            - v3.7.1
                              system.adapter.ical                    : ical           - v1.13.1
                              system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.1.0
                              system.adapter.info                    : info           - v1.9.19
                              system.adapter.iot                     : iot            - v1.11.8
                              system.adapter.javascript              : javascript     - v6.0.0
                              system.adapter.linux-control           : linux-control  - v1.1.3
                              system.adapter.meteoalarm              : meteoalarm     - v2.1.3
                              system.adapter.mqtt                    : mqtt           - v3.0.6
                              system.adapter.netatmo                 : netatmo        - v1.7.1
                              system.adapter.octoprint               : octoprint      - v4.0.0
                              system.adapter.oilfox                  : oilfox         - v4.1.2
                              system.adapter.parcel                  : parcel         - v0.0.20
                              system.adapter.pi-hole                 : pi-hole        - v1.3.4
                              system.adapter.ping                    : ping           - v1.5.3
                              system.adapter.plenticore              : plenticore     - v2.2.0
                              system.adapter.pollenflug              : pollenflug     - v1.0.6
                              system.adapter.pushover                : pushover       - v3.0.2
                              system.adapter.rpi2                    : rpi2           - v1.3.2
                              system.adapter.shelly                  : shelly         - v6.0.0
                              system.adapter.simple-api              : simple-api     - v2.7.0
                              system.adapter.smartgarden             : smartgarden    - v2.0.0
                              system.adapter.socketio                : socketio       - v4.2.0
                              system.adapter.sql                     : sql            - v2.1.7
                              system.adapter.synology                : synology       - v2.1.9
                              system.adapter.tankerkoenig            : tankerkoenig   - v2.1.1
                              system.adapter.telegram                : telegram       - v1.13.0
                              system.adapter.terminal                : terminal       - v0.2.6
                              system.adapter.trashschedule           : trashschedule  - v2.0.3
                              system.adapter.tvprogram               : tvprogram      - v1.1.2
                              system.adapter.unifi                   : unifi          - v0.5.10
                              system.adapter.vis                     : vis            - v1.4.15
                              system.adapter.vis-history             : vis-history    - v1.0.0
                              system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.2.0
                              system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                              system.adapter.vis-keyboard            : vis-keyboard   - v0.0.2
                              system.adapter.vis-material-advanced   : vis-material-advanced - v1.7.2
                              system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.9
                              system.adapter.vis-players             : vis-players    - v0.1.6
                              system.adapter.vis-timeandweather      : vis-timeandweather - v1.2.2
                              system.adapter.web                     : web            - v4.3.0
                              system.adapter.wolf                    : wolf           - v1.5.0
                              system.adapter.yahka                   : yahka          - v0.13.1
                              pi@SmartHomePi:~ $ iobroker list instances
                                system.adapter.admin.0                  : admin                 : SmartHomePi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                                system.adapter.alarm.0                  : alarm                 : SmartHomePi                              - disabled
                              + system.adapter.alexa2.0                 : alexa2                : SmartHomePi                              -  enabled
                                system.adapter.alias-manager.0          : alias-manager         : SmartHomePi                              -  enabled
                              + system.adapter.backitup.0               : backitup              : SmartHomePi                              -  enabled
                              + system.adapter.bring.0                  : bring                 : SmartHomePi                              -  enabled
                              + system.adapter.cloud.0                  : cloud                 : SmartHomePi                              -  enabled
                                system.adapter.coronavirus-statistics.0 : coronavirus-statistics: SmartHomePi                              -  enabled
                                system.adapter.daswetter.0              : daswetter             : SmartHomePi                              -  enabled
                              + system.adapter.discovery.0              : discovery             : SmartHomePi                              -  enabled
                              + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : SmartHomePi                              -  enabled
                              + system.adapter.email.0                  : email                 : SmartHomePi                              -  enabled
                              + system.adapter.esphome.0                : esphome               : SmartHomePi                              -  enabled
                                system.adapter.flot.0                   : flot                  : SmartHomePi                              - disabled
                              + system.adapter.ham.0                    : ham                   : SmartHomePi                              -  enabled
                              + system.adapter.harmony.0                : harmony               : SmartHomePi                              -  enabled
                              + system.adapter.heizoel.0                : heizoel               : SmartHomePi                              -  enabled
                              + system.adapter.history.0                : history               : SmartHomePi                              -  enabled
                              + system.adapter.hm-rega.0                : hm-rega               : SmartHomePi                              -  enabled
                              + system.adapter.hm-rpc.0                 : hm-rpc                : SmartHomePi                              -  enabled, port: 0
                              + system.adapter.hm-rpc.1                 : hm-rpc                : SmartHomePi                              -  enabled, port: 0
                              + system.adapter.hm-rpc.2                 : hm-rpc                : SmartHomePi                              -  enabled, port: 0
                              + system.adapter.hue.0                    : hue                   : SmartHomePi                              -  enabled, port: 443
                              + system.adapter.hue.1                    : hue                   : SmartHomePi                              -  enabled, port: 443
                              + system.adapter.hue.2                    : hue                   : SmartHomePi                              -  enabled, port: 443
                                system.adapter.ical.0                   : ical                  : SmartHomePi                              -  enabled
                                system.adapter.ical.1                   : ical                  : SmartHomePi                              -  enabled
                                system.adapter.ical.2                   : ical                  : SmartHomePi                              -  enabled
                                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : SmartHomePi                              - disabled
                              + system.adapter.info.0                   : info                  : SmartHomePi                              -  enabled
                              + system.adapter.iot.0                    : iot                   : SmartHomePi                              -  enabled
                              + system.adapter.javascript.0             : javascript            : SmartHomePi                              -  enabled
                              + system.adapter.linux-control.0          : linux-control         : SmartHomePi                              -  enabled
                                system.adapter.meteoalarm.0             : meteoalarm            : SmartHomePi                              -  enabled
                              + system.adapter.mqtt.0                   : mqtt                  : SmartHomePi                              -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.netatmo.0                : netatmo               : SmartHomePi                              -  enabled
                              + system.adapter.octoprint.0              : octoprint             : SmartHomePi                              -  enabled
                                system.adapter.oilfox.0                 : oilfox                : SmartHomePi                              -  enabled
                              + system.adapter.parcel.0                 : parcel                : SmartHomePi                              -  enabled
                              + system.adapter.pi-hole.0                : pi-hole               : SmartHomePi                              -  enabled
                              + system.adapter.ping.0                   : ping                  : SmartHomePi                              -  enabled
                              + system.adapter.plenticore.0             : plenticore            : SmartHomePi                              -  enabled, port: 80
                              + system.adapter.pollenflug.0             : pollenflug            : SmartHomePi                              -  enabled
                              + system.adapter.pushover.0               : pushover              : SmartHomePi                              -  enabled
                              + system.adapter.pushover.1               : pushover              : SmartHomePi                              -  enabled
                              + system.adapter.pushover.2               : pushover              : SmartHomePi                              -  enabled
                              + system.adapter.rpi2.0                   : rpi2                  : SmartHomePi                              -  enabled
                                system.adapter.shelly.0                 : shelly                : SmartHomePi                              - disabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.smartgarden.0            : smartgarden           : SmartHomePi                              -  enabled
                              + system.adapter.sql.0                    : sql                   : SmartHomePi                              -  enabled
                              + system.adapter.synology.0               : synology              : SmartHomePi                              -  enabled, port: 5000
                              + system.adapter.tankerkoenig.0           : tankerkoenig          : SmartHomePi                              -  enabled
                              + system.adapter.telegram.0               : telegram              : SmartHomePi                              -  enabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.terminal.0               : terminal              : SmartHomePi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                              + system.adapter.trashschedule.0          : trashschedule         : SmartHomePi                              -  enabled
                              + system.adapter.tvprogram.0              : tvprogram             : SmartHomePi                              -  enabled
                              + system.adapter.unifi.0                  : unifi                 : SmartHomePi                              -  enabled
                                system.adapter.vis-history.0            : vis-history           : SmartHomePi                              -  enabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : SmartHomePi                              - disabled
                                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : SmartHomePi                              -  enabled
                                system.adapter.vis-keyboard.0           : vis-keyboard          : SmartHomePi                              - disabled
                                system.adapter.vis-material-advanced.0  : vis-material-advanced : SmartHomePi                              - disabled
                                system.adapter.vis-materialdesign.0     : vis-materialdesign    : SmartHomePi                              - disabled
                                system.adapter.vis-players.0            : vis-players           : SmartHomePi                              -  enabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : SmartHomePi                              - disabled
                                system.adapter.vis.0                    : vis                   : SmartHomePi                              -  enabled
                              + system.adapter.web.0                    : web                   : SmartHomePi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                system.adapter.wolf.0                   : wolf                  : SmartHomePi                              - disabled, port: 12004, bind: 0.0.0.0
                              + system.adapter.yahka.0                  : yahka                 : SmartHomePi                              -  enabled
                              + system.adapter.yahka.1                  : yahka                 : SmartHomePi                              -  enabled
                              + system.adapter.yahka.2                  : yahka                 : SmartHomePi                              -  enabled
                              Was kann ich machen?
                              Ein Reboot habe ich schon gemacht. Es läuft dann im Hintergrund auch alles schön, aber der Admin bleibt nicht erreichbar.
                              iobroker fix
                              wurde auch schon gemacht.
                                Thomas Braun Most Active @draexler last edited by
                                @draexler
                                iobroker update
                                iobroker upgrade admin --debug
                                draexler 1 Reply Last reply Reply Quote 1
                                • draexler
                                  draexler @Thomas Braun last edited by
                                  @thomas-braun Gelöst mit diesen Topic. Aber trotzdem danke dir für die schnelle Reaktion 🙂
                                    saeft_2003 Most Active last edited by saeft_2003
                                    Gibt es auf dem iphone die Möglichkeit sich unter Objekte die Namen und die Werte anzeigen zu lassen?
                                    • Glasfaser
                                      Glasfaser @saeft_2003 last edited by Glasfaser
                                      @saeft_2003
                                      siehe ... und dann folgend
                                      https://forum.iobroker.net/topic/57378/admin-6-2-jetzt-im-stable/10
                                        saeft_2003 Most Active @Glasfaser last edited by
                                        @glasfaser
                                        Auf github habe ich das so verstanden als wäre das
                                        gefixt. Hab ich das falsch verstanden?
                                        • Krisiun
                                          Krisiun last edited by
                                          Hallo, ich habe auch ein kleines Problem mit der neue Grafik. Wie kann ich da die Spalten verschieben? iobroker.Spalten.png
                                          • Dr. Bakterius
                                            Dr. Bakterius Most Active @Krisiun last edited by
                                            @krisiun Geht leider nur bei den Spalten 'ID' und 'Wert'.
                                            Krisiun 1 Reply Last reply Reply Quote 0
                                            185
                                            21218
