    4. [gelöst] Admin nach Update (6.2.17) weg
    • Glasfaser
      Glasfaser @Hant0r last edited by
      @hant0r
      rm -rf  /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
      dann nochmal
      iob install admin@6.2.17 --debug
      Hant0r 1 Reply Last reply Reply Quote 0
      • Hant0r
        Hant0r @Glasfaser last edited by Hant0r
        @glasfaser sagte in Admin nach Update (6.2.17) weg:
        root@ioBroker:/opt/iobroker# rm -rf  /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
        root@ioBroker:/opt/iobroker# iob install admin@6.2.17 --debug
        NPM version: 8.15.0
        Installing iobroker.admin@6.2.17... (System call)
        npm ERR! code ENOTEMPTY
        npm ERR! syscall rename
        npm ERR! path /opt/iobroker/node_modules/busboy
        npm ERR! dest /opt/iobroker/node_modules/.busboy-A5FsP0CS
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/busboy' -> '/opt/iobroker/node_modules/.busboy-A5FsP0CS'
        npm ERR!     /opt/iobroker/.npm/_logs/2022-08-23T22_20_31_569Z-debug-0.log
        host.ioBroker Cannot install iobroker.admin@6.2.17: 217
        Den auch löschen?
        • Glasfaser
          Glasfaser @Hant0r last edited by Glasfaser
          @hant0r
          cd /opt/iobroker/node_modules
          for i in $(find -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
          dann nochmal
          • Hant0r
            @glasfaser
            Da gab es wirklich noch drei weitere ... sind nun weg
            Installation sieht besser aus, aber komme noch nicht auf die Webseite
            NPM version: 8.15.0
            added 3 packages, removed 89 packages, and changed 12 packages in 20s
            175 packages are looking for funding
              run `npm fund` for details
            host.ioBroker install adapter admin@6.2.17
            upload [51] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
            upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
            upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
            upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js application/javascript
            upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js application/javascript
            upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
            upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
            upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
            upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
            upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
            upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
            upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
            upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
            upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
            upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
            host.ioBroker object system.adapter.admin created/updated
            Update "system.adapter.admin.0"
            • Glasfaser
              @hant0r sagte in Admin nach Update (6.2.17) weg:
              Wie hast du die gelöscht !?
              mit rm -rf
              Warum nicht mit dem anderen angegebeben code
              iobroker start admin
              • Hant0r
                @glasfaser
                Doch habe es über dein Script gemacht 😉
                Wollte nur wissen wie viele es noch gab 👼
                Das war es .... D A N K E 🙂
                Das war mal echt eine schnelle Hilfe.
                Wieso es aber dazu kam, weißt du auch nicht oder?
                Glasfaser 3 Replies Last reply Reply Quote 0
                • Glasfaser
                  Doch schon lange 😉 !
                  Du hast ein Update mal gemacht auf Nodejs16 mit NPM8 !
                  Da gibt es einige Thread dazu .
                  z.b 217 / Error 25
                  • Glasfaser
                    @hant0r
                    Beispiel :
                    https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
                    https://forum.iobroker.net/topic/57238/error-25-npm-err-code-enotempty?_=1661294007594
                    usw ..
                    Hant0r 1 Reply Last reply Reply Quote 1
                    • Hant0r
                      @glasfaser Aaaah ...
                      Da ich den Fehler 217 und nicht 25 hatte, habe ich den Thread wahrscheinlich nicht über die Suche gefunden.
                      Auf jedenfall danke das du so schnell geholfen hast 🙂
                      Glasfaser 1 Reply Last reply Reply Quote 1
                      • Glasfaser
                        ist von Thomas !!
                        https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2
                        • Glasfaser
                          Sehr gerne ..
                          Dann setze den Thread auf [gelöst]
                          draexler 1 Reply Last reply Reply Quote 1
                          • draexler
                            draexler @Glasfaser last edited by
                            @glasfaser Hatte das gleiche Problem. Danke 🙂
                            Da ich keine Linux Profi bin.
                            Ich habe den Befehl
                            im Verzeichnis:
                            ausgeführt.
                            Macht das was? Momentan läuft alles 🙂
                              Thomas Braun Most Active last edited by
                              @draexler
                              iobroker update
                              zeigen
                              draexler 1 Reply Last reply Reply Quote 0
                              • draexler
                                draexler @Thomas Braun last edited by
                                Used repository: Stable (default)
                                Adapter    "admin"        : 6.2.17   , installed 6.2.17
                                Adapter    "alarm"        : 3.1.1    , installed 3.1.1
                                Adapter    "alexa2"       : 3.11.2   , installed 3.12.0
                                Adapter    "alias-manager": 1.2.4    , installed 1.2.4
                                Adapter    "backitup"     : 2.4.10   , installed 2.4.10
                                Adapter    "bring"        : 1.8.1    , installed 1.8.1
                                Adapter    "cloud"        : 4.2.1    , installed 4.2.1
                                Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                                Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
                                Adapter    "devices"      : 1.0.12   , installed 1.0.12
                                Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                                Adapter    "ecovacs-deebot": 1.4.4   , installed 1.4.4
                                Adapter    "email"        : 1.1.3    , installed 1.1.3
                                Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                                Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                Adapter    "ham"          : 4.0.2    , installed 5.0.1
                                Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                                Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                                Adapter    "history"      : 2.2.0    , installed 2.2.0
                                Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                Adapter    "hue"          : 3.7.1    , installed 3.7.1
                                Adapter    "ical"         : 1.13.1   , installed 1.13.1
                                Adapter    "info"         : 1.9.19   , installed 1.9.19
                                Adapter    "iot"          : 1.11.8   , installed 1.11.8
                                Adapter    "javascript"   : 6.0.0    , installed 6.0.0
                                Adapter    "linux-control": 1.1.3    , installed 1.1.3
                                Adapter    "meteoalarm"   : 2.1.3    , installed 2.1.3
                                Adapter    "mqtt"         : 3.0.6    , installed 3.0.6
                                Adapter    "netatmo"      : 1.7.1    , installed 1.7.1
                                Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
                                Adapter    "oilfox"       : 4.1.2    , installed 4.1.2
                                Adapter    "parcel"       : 0.0.20   , installed 0.0.20
                                Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
                                Adapter    "ping"         : 1.5.3    , installed 1.5.3
                                Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
                                Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                Adapter    "pushover"     : 3.0.2    , installed 3.0.2
                                Adapter    "shelly"       : 6.0.0    , installed 6.0.0
                                Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                                Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
                                Adapter    "sql"          : 2.1.7    , installed 2.1.7
                                Adapter    "synology"     : 2.1.9    , installed 2.1.9
                                Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                                Adapter    "telegram"     : 1.13.0   , installed 1.13.0
                                Adapter    "terminal"     : 0.2.6    , installed 0.2.6
                                Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                                Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
                                Adapter    "unifi"        : 0.5.10   , installed 0.5.10
                                Adapter    "vis"          : 1.4.15   , installed 1.4.15
                                Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
                                Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                Adapter    "wolf"         : 1.5.0    , installed 1.5.0
                                Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                                • Glasfaser
                                  Glasfaser @draexler last edited by
                                  @draexler sagte in [gelöst] Admin nach Update (6.2.17) weg:
                                  im Verzeichnis:
                                  Mit iobroker / iob vorraus Befehle , kannst du auch z.B. im home Verzeichniss durchführen.
                                    daniello @Glasfaser last edited by
                                    Hallo allerseits, ich habe bei jedem Admin-Update die Panik, ob die Webseite dann wohl erreichbar sein wird. Grad bin ich nach einem Upate wieder nicht an die GUI gekommen.
                                    Nach lesen dieses Threads hab ich mal:
                                    eingegeben und siehe da .. es geht 🙂
                                    Vielleicht kann ich mir in Zukunft so immer weiter helfen. Aber warum startet der Admin-Adapter nach einem Update nicht mehr? Auch ein Neustart hilft nicht?!
                                      Diamand2k22 @daniello last edited by
                                      @Thomas-Braun
                                      Hallo Thomas, nach update auf neusten admin Adapter Version ist dieser unter den installierten Adaptern verschwunden.
                                      Ich komme auch nicht mehr ins Webinterface.
                                      pi4b@pi4b:~$ iob update
                                      Used repository: beta
                                      Adapter    "adguard"      : 0.0.8    , installed 0.0.8
                                      Adapter    "alarm"        : 3.6.2    , installed 3.6.2
                                      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                      Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                                      Adapter    "bmw"          : 2.8.0    , installed 2.8.0
                                      Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
                                      Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                                      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                                      Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
                                      Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
                                      Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.10
                                      Adapter    "evcc"         : 0.1.1    , installed 0.1.1
                                      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                      Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                                      Adapter    "fronius-solarweb": 0.1.0 , installed 0.1.0
                                      Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
                                      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                                      Adapter    "ham"          : 5.3.1    , installed 5.3.1
                                      Adapter    "ical"         : 1.15.0   , installed 1.15.0
                                      Adapter    "intex"        : 0.1.7    , installed 0.1.7
                                      Adapter    "iot"          : 3.4.0    , installed 3.4.0
                                      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                      Controller "js-controller": 6.0.11   , installed 6.0.11
                                      Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
                                      Adapter    "midea"        : 0.0.7    , installed 0.0.7
                                      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                                      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                                      Adapter    "notification-manager": 1.2.1, installed 1.2.1
                                      Adapter    "oilfox"       : 4.3.0    , installed 4.3.0
                                      Adapter    "opendtu"      : 2.0.0    , installed 2.0.0
                                      Adapter    "parser"       : 2.2.4    , installed 2.2.4
                                      Adapter    "ping"         : 1.7.3    , installed 1.7.3
                                      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                                      Adapter    "rpi2"         : 2.0.0    , installed 2.0.0
                                      Adapter    "shelly"       : 8.1.1    , installed 8.1.1
                                      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                      Adapter    "synology"     : 3.1.0    , installed 3.1.0
                                      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                                      Adapter    "tibberlink"   : 3.4.8    , installed 3.4.8
                                      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                      Adapter    "vis-icontwo"  : 1.6.3    , installed 1.6.3
                                      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                                      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                                      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                                      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                      Adapter    "web"          : 6.3.0    , installed 6.3.0
                                      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                      Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                      Adapter    "zigbee2mqtt"  : 2.13.10  , installed 2.13.10
                                      pi4b@pi4b:~$ iob upgrade
                                      All adapters are up to date
                                      pi4b@pi4b:~$ iob fix
                                      library: loaded
                                      Library version=2024-05-24
                                        Thomas Braun Most Active @Diamand2k22 last edited by
                                        @diamand2k22
                                        Das 'große Ganze' anschauen.
                                        Langfassung von
                                        iob diag
                                        wäre gut.
                                          Diamand2k22 @Thomas Braun last edited by Diamand2k22
                                          @thomas-braun said in [gelöst] Admin nach Update (6.2.17) weg:
                                          iob diag
                                          Skript v.2024-05-22
                                          *** BASE SYSTEM ***
                                           Static hostname: pi4b
                                                 Icon name: computer
                                                    Kernel: Linux 6.1.21-v8+
                                              Architecture: arm64
                                          Model           : Raspberry Pi 4 Model B Rev 1.5
                                          Docker          : false
                                          Virtualization  : none
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                          Systemuptime and Load:
                                           21:42:13 up 81 days,  3:52,  2 users,  load average: 2.60, 2.92, 2.78
                                          CPU threads: 4
                                          *** RASPBERRY THROTTLING ***
                                          Current issues:
                                          Previously detected issues:
                                          *** Time and Time Zones ***
                                                         Local time: Sun 2024-09-15 21:42:14 CEST
                                                     Universal time: Sun 2024-09-15 19:42:14 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          *** Users and Groups ***
                                          User that called 'iob diag':
                                          pi4b
                                          HOME=/home/pi4b
                                          GROUPS=pi4b adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                          iobroker
                                          HOME=/home/iobroker
                                          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                          *** Display-Server-Setup ***
                                          Display-Server: false
                                          Desktop:
                                          Terminal:       tty
                                          Boot Target:    multi-user.target
                                          *** MEMORY ***
                                          Mem:            8.2G        3.7G        1.3G        3.7M        3.3G        4.5G
                                          Swap:           209M        786K        208M
                                          Total:          8.4G        3.7G        1.5G
                                          Active iob-Instances:   49
                                                   7811 M total memory
                                                   3565 M used memory
                                                   3465 M active memory
                                                   2451 M inactive memory
                                                   1244 M free memory
                                                    271 M buffer memory
                                                   2863 M swap cache
                                                    199 M total swap
                                                      0 M used swap
                                                    199 M free swap
                                          top - 21:42:14 up 81 days,  3:52,  2 users,  load average: 2.47, 2.89, 2.77
                                          Tasks: 218 total,   2 running, 216 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s): 63.6 us, 18.2 sy,  0.0 ni, 18.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :   7811.3 total,   1243.8 free,   3565.2 used,   3135.6 buff/cache
                                          MiB Swap:    200.0 total,    199.2 free,      0.8 used.   4246.1 avail Mem
                                          *** FAILED SERVICES ***
                                          0 loaded units listed.
                                          *** FILESYSTEM ***
                                          /dev/root      ext4      459G   20G  421G   5% /
                                          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                                          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                          tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                                          /dev/sda1      vfat      255M   31M  225M  13% /boot
                                          tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                                          [Wed Jun 26 17:49:34 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A7:70:8D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=1b49eb79-02 rootfstype=ext4 fsck.repair=yes rootwait usbcore.autosuspend=-1
                                          [Wed Jun 26 17:49:37 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                          [Wed Jun 26 17:49:37 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                          [Wed Jun 26 17:49:39 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                          Show mounted filesystems:
                                          TARGET                                                  SOURCE      FSTYPE      OPTIONS
                                          /                                                       /dev/sda2   ext4        rw,noatime
                                          |-/dev                                                  devtmpfs    devtmpfs    rw,relatime,size=3735168k,nr_inodes=933792,mode=755
                                          | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev
                                          | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                          | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                                          |-/proc                                                 proc        proc        rw,relatime
                                          | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                                          |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                                          |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                                          | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                                          | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                                          | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
                                          | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                                          | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                                          | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                                          | |-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                                          | `-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
                                          |-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,size=1599760k,nr_inodes=819200,mode=755
                                          | |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                                          | |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                          | |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                          | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                          | |-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=799876k,nr_inodes=199969,mode=700,uid=1000,gid=1000
                                          | |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
                                          | `-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                          `-/boot                                                 /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          2.3G    /var/
                                          1.7G    /var/log/journal/944391c321c34dc1bb3a49f2128ebf7e
                                          1.7G    /var/log
                                          235M    /var/lib
                                          Archived and active journals take up 1.6G in the file system.
                                          /opt/iobroker/backups:
                                          4.0K    /opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          1.7G    /opt/iobroker/iobroker-data/
                                          923M    /opt/iobroker/iobroker-data/files
                                          618M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
                                          35M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.be60e800.js.map
                                          30M     /opt/iobroker/iobroker-data/objects.jsonl
                                          26M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/blueconnect-poolwerte/.pioenvs/blueconnect-poolwerte/firmware.elf
                                          24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                                          19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
                                          USB-Devices by-id:
                                          /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                          *** NodeJS-Installation ***
                                          /usr/bin/nodejs         v20.17.0
                                          /usr/bin/node           v20.17.0
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          /usr/bin/corepack       0.29.3
                                          nodejs:
                                            Installed: 20.17.0-1nodesource1
                                            Candidate: 20.17.0-1nodesource1
                                            Version table:
                                           *** 20.17.0-1nodesource1 1001
                                                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                                  100 /var/lib/dpkg/status
                                               20.16.0-1nodesource1 1001
                                               20.15.1-1nodesource1 1001
                                               20.15.0-1nodesource1 1001
                                               20.14.0-1nodesource1 1001
                                               20.13.1-1nodesource1 1001
                                               20.13.0-1nodesource1 1001
                                               20.12.2-1nodesource1 1001
                                               20.12.1-1nodesource1 1001
                                               20.12.0-1nodesource1 1001
                                               20.11.1-1nodesource1 1001
                                               20.11.0-1nodesource1 1001
                                               20.10.0-1nodesource1 1001
                                               20.9.0-1nodesource1 1001
                                               20.8.1-1nodesource1 1001
                                               20.8.0-1nodesource1 1001
                                               20.7.0-1nodesource1 1001
                                               20.6.1-1nodesource1 1001
                                               20.6.0-1nodesource1 1001
                                               20.5.1-1nodesource1 1001
                                               20.5.0-1nodesource1 1001
                                               20.4.0-1nodesource1 1001
                                               20.3.1-1nodesource1 1001
                                               20.3.0-1nodesource1 1001
                                               20.2.0-1nodesource1 1001
                                               20.1.0-1nodesource1 1001
                                               20.0.0-1nodesource1 1001
                                               18.19.0+dfsg-6~deb12u2 500
                                               18.19.0+dfsg-6~deb12u1 500
                                                  500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
                                          No problems detected
                                          Errors in npm tree:
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Core adapters versions
                                          js-controller:  6.0.11
                                          admin:          7.1.0
                                          javascript:     8.8.3
                                          nodejs modules from github:     4
                                          +-- iobroker.blueconnect@0.0.6 (git+ssh://git@github.com/kopierschnitte/ioBroker.blueconnect.git#6d92d3de8f3e303fa3cf3f94d4ef5070b7656eb4)
                                          +-- iobroker.energiefluss-erweitert@0.4.1 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#f724bf54ab9a69bc6d4533b59f560462e1bb2993)
                                          +-- iobroker.esphome@0.5.0-beta.10 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#d60377cc7c7d3092a8bcb1cf945ed256cba6e96f)
                                          | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                                          Adapter State
                                          + system.adapter.adguard.0                : adguard               : pi4b                                     -  enabled
                                            system.adapter.admin.0                  : admin                 : pi4b                                     - disabled, port: ****, bind: 0.0.0.0, run as: admin
                                          + system.adapter.alarm.0                  : alarm                 : pi4b                                     -  enabled
                                          + system.adapter.alexa2.0                 : alexa2                : pi4b                                     -  enabled
                                            system.adapter.alias-manager.0          : alias-manager         : pi4b                                     - disabled
                                          + system.adapter.backitup.0               : backitup              : pi4b                                     -  enabled
                                            system.adapter.blueconnect.0            : blueconnect           : pi4b                                     -  enabled
                                          + system.adapter.bmw.0                    : bmw                   : pi4b                                     -  enabled
                                          + system.adapter.bydhvs.0                 : bydhvs                : pi4b                                     -  enabled
                                            system.adapter.daswetter.0              : daswetter             : pi4b                                     -  enabled
                                          + system.adapter.device-reminder.0        : device-reminder       : pi4b                                     -  enabled
                                          + system.adapter.device-watcher.0         : device-watcher        : pi4b                                     -  enabled
                                          + system.adapter.discovery.0              : discovery             : pi4b                                     -  enabled
                                            system.adapter.dwd.0                    : dwd                   : pi4b                                     -  enabled
                                          + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : pi4b                                     -  enabled
                                          + system.adapter.ecovacs-deebot.1         : ecovacs-deebot        : pi4b                                     -  enabled
                                          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: pi4b                                     -  enabled
                                          + system.adapter.esphome.0                : esphome               : pi4b                                     -  enabled
                                          + system.adapter.evcc.0                   : evcc                  : pi4b                                     -  enabled, port: ****
                                          + system.adapter.fritzdect.0              : fritzdect             : pi4b                                     -  enabled
                                          + system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : pi4b                                     -  enabled
                                          + system.adapter.fronius.0                : fronius               : pi4b                                     -  enabled
                                          + system.adapter.fronius.1                : fronius               : pi4b                                     -  enabled
                                          + system.adapter.fronius.2                : fronius               : pi4b                                     -  enabled
                                          + system.adapter.fullybrowser.0           : fullybrowser          : pi4b                                     -  enabled
                                          + system.adapter.ham.0                    : ham                   : pi4b                                     -  enabled
                                          + system.adapter.heizoel.0                : heizoel               : pi4b                                     -  enabled
                                            system.adapter.ical.0                   : ical                  : pi4b                                     -  enabled
                                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : pi4b                                     - disabled
                                          + system.adapter.influxdb.0               : influxdb              : pi4b                                     -  enabled, port: ****
                                          + system.adapter.intex.0                  : intex                 : pi4b                                     -  enabled, port: *****
                                          + system.adapter.iot.0                    : iot                   : pi4b                                     -  enabled
                                          + system.adapter.javascript.0             : javascript            : pi4b                                     -  enabled
                                          + system.adapter.lovelace.0               : lovelace              : pi4b                                     -  enabled, port: ****, bind: 0.0.0.0, run as: admin
                                          + system.adapter.midea.0                  : midea                 : pi4b                                     -  enabled
                                          + system.adapter.modbus.0                 : modbus                : pi4b                                     -  enabled
                                          + system.adapter.node-red.0               : node-red              : pi4b                                     -  enabled, port: *****, bind: 192.168.178.36
                                          + system.adapter.notification-manager.0   : notification-manager  : pi4b                                     -  enabled
                                            system.adapter.oilfox.0                 : oilfox                : pi4b                                     -  enabled
                                          + system.adapter.opendtu.0                : opendtu               : pi4b                                     -  enabled
                                          + system.adapter.parser.0                 : parser                : pi4b                                     -  enabled
                                          + system.adapter.ping.0                   : ping                  : pi4b                                     -  enabled
                                          + system.adapter.pushover.0               : pushover              : pi4b                                     -  enabled
                                          + system.adapter.rpi2.0                   : rpi2                  : pi4b                                     -  enabled
                                          + system.adapter.shelly.0                 : shelly                : pi4b                                     -  enabled, port: ****, bind: 0.0.0.0
                                          + system.adapter.synology.0               : synology              : pi4b                                     -  enabled, port: *******
                                          + system.adapter.tibberlink.0             : tibberlink            : pi4b                                     -  enabled
                                          + system.adapter.tr-064.0                 : tr-064                : pi4b                                     -  enabled
                                          + system.adapter.trashschedule.0          : trashschedule         : pi4b                                     -  enabled
                                          + system.adapter.tuya.0                   : tuya                  : pi4b                                     -  enabled
                                            system.adapter.vis-bars.0               : vis-bars              : pi4b                                     -  enabled
                                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : pi4b                                     -  enabled
                                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : pi4b                                     -  enabled
                                            system.adapter.vis-history.0            : vis-history           : pi4b                                     -  enabled
                                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : pi4b                                     -  enabled
                                            system.adapter.vis-icontwo.0            : vis-icontwo           : pi4b                                     -  enabled
                                          + system.adapter.vis-inventwo.0           : vis-inventwo          : pi4b                                     -  enabled
                                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : pi4b                                     -  enabled
                                            system.adapter.vis-justgage.0           : vis-justgage          : pi4b                                     -  enabled
                                            system.adapter.vis-material.0           : vis-material          : pi4b                                     -  enabled
                                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : pi4b                                     -  enabled
                                            system.adapter.vis-metro.0              : vis-metro             : pi4b                                     -  enabled
                                            system.adapter.vis-plumb.0              : vis-plumb             : pi4b                                     -  enabled
                                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : pi4b                                     -  enabled
                                            system.adapter.vis.0                    : vis                   : pi4b                                     -  enabled
                                          + system.adapter.web.0                    : web                   : pi4b                                     -  enabled, port: *****, bind: 0.0.0.0, run as: admin
                                          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : pi4b                                     -  enabled
                                          + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : pi4b                                     -  enabled
                                          + system.adapter.whatsapp-cmb.2           : whatsapp-cmb          : pi4b                                     -  enabled
                                          + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : pi4b                                     -  enabled
                                          ioBroker-Repositories
                                          Active repo(s): beta
                                          Upgrade policy: none
                                          Installed ioBroker-Instances
                                          Adapter    "admin"        : 7.1.1    , installed 7.1.0  [Updatable]
                                          Objects and States
                                          Objects:        26958
                                          States:         23279
                                          Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                                          Hit:2 http://deb.debian.org/debian bookworm InRelease
                                          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                          Hit:4 http://archive.raspberrypi.org/debian bookworm InRelease
                                          Hit:5 https://apt.grafana.com stable InRelease
                                          Hit:6 https://repos.influxdata.com/debian stable InRelease
                                          Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                          Reading package lists...
                                          Pending Updates: 0
                                            Homoran Global Moderator Administrators @Diamand2k22 last edited by
                                            @diamand2k22 iob start admin.0
                                            2264
