    4. [gelöst] Admin nach Update (6.2.17) weg
    • Hant0r
      Hant0r @Glasfaser last edited by Hant0r
      @glasfaser sagte in Admin nach Update (6.2.17) weg:
      iob install admin@6.2.17 --debug
      root@ioBroker:/opt/iobroker# rm -rf  /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
      root@ioBroker:/opt/iobroker# iob install admin@6.2.17 --debug
      NPM version: 8.15.0
      Installing iobroker.admin@6.2.17... (System call)
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/busboy
      npm ERR! dest /opt/iobroker/node_modules/.busboy-A5FsP0CS
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/busboy' -> '/opt/iobroker/node_modules/.busboy-A5FsP0CS'
      npm ERR!     /opt/iobroker/.npm/_logs/2022-08-23T22_20_31_569Z-debug-0.log
      host.ioBroker Cannot install iobroker.admin@6.2.17: 217
      Den auch löschen?
      • Glasfaser
        Glasfaser @Hant0r last edited by Glasfaser
        @hant0r
        cd /opt/iobroker/node_modules
        for i in $(find -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
        dann nochmal
        Hant0r 1 Reply Last reply Reply Quote 0
        • Hant0r
          @glasfaser
          Da gab es wirklich noch drei weitere ... sind nun weg
          Installation sieht besser aus, aber komme noch nicht auf die Webseite
          NPM version: 8.15.0
          added 3 packages, removed 89 packages, and changed 12 packages in 20s
          175 packages are looking for funding
            run `npm fund` for details
          host.ioBroker install adapter admin@6.2.17
          upload [51] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
          upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
          upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
          upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js application/javascript
          upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js application/javascript
          upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
          upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
          upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
          upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
          upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
          upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
          upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
          upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
          upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
          upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
          upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
          upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
          upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
          upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
          upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
          upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
          host.ioBroker object system.adapter.admin created/updated
          Update "system.adapter.admin.0"
          • Glasfaser
            @hant0r sagte in Admin nach Update (6.2.17) weg:
            Wie hast du die gelöscht !?
            mit rm -rf
            Warum nicht mit dem anderen angegebeben code
            iobroker start admin
            • Hant0r
              @glasfaser
              Doch habe es über dein Script gemacht 😉
              Wollte nur wissen wie viele es noch gab 👼
              Das war es .... D A N K E 🙂
              Das war mal echt eine schnelle Hilfe.
              Wieso es aber dazu kam, weißt du auch nicht oder?
              Glasfaser 3 Replies Last reply Reply Quote 0
              • Glasfaser
                Doch schon lange 😉 !
                Du hast ein Update mal gemacht auf Nodejs16 mit NPM8 !
                Da gibt es einige Thread dazu .
                z.b 217 / Error 25
                • Glasfaser
                  @hant0r
                  Beispiel :
                  https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
                  https://forum.iobroker.net/topic/57238/error-25-npm-err-code-enotempty?_=1661294007594
                  usw ..
                  Hant0r 1 Reply Last reply Reply Quote 1
                  • Hant0r
                    @glasfaser Aaaah ...
                    Da ich den Fehler 217 und nicht 25 hatte, habe ich den Thread wahrscheinlich nicht über die Suche gefunden.
                    Auf jedenfall danke das du so schnell geholfen hast 🙂
                    Glasfaser 1 Reply Last reply Reply Quote 1
                    • Glasfaser
                      ist von Thomas !!
                      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2
                      • Glasfaser
                        Sehr gerne ..
                        Dann setze den Thread auf [gelöst]
                        draexler 1 Reply Last reply Reply Quote 1
                        • draexler
                          draexler @Glasfaser last edited by
                          @glasfaser Hatte das gleiche Problem. Danke 🙂
                          Da ich keine Linux Profi bin.
                          Ich habe den Befehl
                          im Verzeichnis:
                          ausgeführt.
                          Macht das was? Momentan läuft alles 🙂
                            Thomas Braun Most Active last edited by
                            @draexler
                            iobroker update
                            zeigen
                            draexler 1 Reply Last reply Reply Quote 0
                            • draexler
                              draexler @Thomas Braun last edited by
                              Used repository: Stable (default)
                              Adapter    "admin"        : 6.2.17   , installed 6.2.17
                              Adapter    "alarm"        : 3.1.1    , installed 3.1.1
                              Adapter    "alexa2"       : 3.11.2   , installed 3.12.0
                              Adapter    "alias-manager": 1.2.4    , installed 1.2.4
                              Adapter    "backitup"     : 2.4.10   , installed 2.4.10
                              Adapter    "bring"        : 1.8.1    , installed 1.8.1
                              Adapter    "cloud"        : 4.2.1    , installed 4.2.1
                              Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                              Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
                              Adapter    "devices"      : 1.0.12   , installed 1.0.12
                              Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                              Adapter    "ecovacs-deebot": 1.4.4   , installed 1.4.4
                              Adapter    "email"        : 1.1.3    , installed 1.1.3
                              Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                              Adapter    "flot"         : 1.11.0   , installed 1.11.0
                              Adapter    "ham"          : 4.0.2    , installed 5.0.1
                              Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                              Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                              Adapter    "history"      : 2.2.0    , installed 2.2.0
                              Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                              Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                              Adapter    "hue"          : 3.7.1    , installed 3.7.1
                              Adapter    "ical"         : 1.13.1   , installed 1.13.1
                              Adapter    "info"         : 1.9.19   , installed 1.9.19
                              Adapter    "iot"          : 1.11.8   , installed 1.11.8
                              Adapter    "javascript"   : 6.0.0    , installed 6.0.0
                              Adapter    "linux-control": 1.1.3    , installed 1.1.3
                              Adapter    "meteoalarm"   : 2.1.3    , installed 2.1.3
                              Adapter    "mqtt"         : 3.0.6    , installed 3.0.6
                              Adapter    "netatmo"      : 1.7.1    , installed 1.7.1
                              Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
                              Adapter    "oilfox"       : 4.1.2    , installed 4.1.2
                              Adapter    "parcel"       : 0.0.20   , installed 0.0.20
                              Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
                              Adapter    "ping"         : 1.5.3    , installed 1.5.3
                              Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
                              Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                              Adapter    "pushover"     : 3.0.2    , installed 3.0.2
                              Adapter    "shelly"       : 6.0.0    , installed 6.0.0
                              Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                              Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
                              Adapter    "sql"          : 2.1.7    , installed 2.1.7
                              Adapter    "synology"     : 2.1.9    , installed 2.1.9
                              Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                              Adapter    "telegram"     : 1.13.0   , installed 1.13.0
                              Adapter    "terminal"     : 0.2.6    , installed 0.2.6
                              Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                              Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
                              Adapter    "unifi"        : 0.5.10   , installed 0.5.10
                              Adapter    "vis"          : 1.4.15   , installed 1.4.15
                              Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
                              Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                              Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                              Adapter    "wolf"         : 1.5.0    , installed 1.5.0
                              Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                              • Glasfaser
                                Glasfaser @draexler last edited by
                                @draexler sagte in [gelöst] Admin nach Update (6.2.17) weg:
                                im Verzeichnis:
                                Mit iobroker / iob vorraus Befehle , kannst du auch z.B. im home Verzeichniss durchführen.
                                  daniello @Glasfaser last edited by
                                  Hallo allerseits, ich habe bei jedem Admin-Update die Panik, ob die Webseite dann wohl erreichbar sein wird. Grad bin ich nach einem Upate wieder nicht an die GUI gekommen.
                                  Nach lesen dieses Threads hab ich mal:
                                  eingegeben und siehe da .. es geht 🙂
                                  Vielleicht kann ich mir in Zukunft so immer weiter helfen. Aber warum startet der Admin-Adapter nach einem Update nicht mehr? Auch ein Neustart hilft nicht?!
                                    Diamand2k22 @daniello last edited by
                                    @Thomas-Braun
                                    Hallo Thomas, nach update auf neusten admin Adapter Version ist dieser unter den installierten Adaptern verschwunden.
                                    Ich komme auch nicht mehr ins Webinterface.
                                    pi4b@pi4b:~$ iob update
                                    Used repository: beta
                                    Adapter    "adguard"      : 0.0.8    , installed 0.0.8
                                    Adapter    "alarm"        : 3.6.2    , installed 3.6.2
                                    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                    Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                                    Adapter    "bmw"          : 2.8.0    , installed 2.8.0
                                    Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
                                    Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                                    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                                    Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
                                    Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
                                    Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.10
                                    Adapter    "evcc"         : 0.1.1    , installed 0.1.1
                                    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                    Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                                    Adapter    "fronius-solarweb": 0.1.0 , installed 0.1.0
                                    Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
                                    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                                    Adapter    "ham"          : 5.3.1    , installed 5.3.1
                                    Adapter    "ical"         : 1.15.0   , installed 1.15.0
                                    Adapter    "intex"        : 0.1.7    , installed 0.1.7
                                    Adapter    "iot"          : 3.4.0    , installed 3.4.0
                                    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                    Controller "js-controller": 6.0.11   , installed 6.0.11
                                    Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
                                    Adapter    "midea"        : 0.0.7    , installed 0.0.7
                                    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                                    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                                    Adapter    "notification-manager": 1.2.1, installed 1.2.1
                                    Adapter    "oilfox"       : 4.3.0    , installed 4.3.0
                                    Adapter    "opendtu"      : 2.0.0    , installed 2.0.0
                                    Adapter    "parser"       : 2.2.4    , installed 2.2.4
                                    Adapter    "ping"         : 1.7.3    , installed 1.7.3
                                    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                                    Adapter    "rpi2"         : 2.0.0    , installed 2.0.0
                                    Adapter    "shelly"       : 8.1.1    , installed 8.1.1
                                    Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                    Adapter    "synology"     : 3.1.0    , installed 3.1.0
                                    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                                    Adapter    "tibberlink"   : 3.4.8    , installed 3.4.8
                                    Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                    Adapter    "vis-icontwo"  : 1.6.3    , installed 1.6.3
                                    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                                    Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                                    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                                    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                    Adapter    "web"          : 6.3.0    , installed 6.3.0
                                    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                    Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                    Adapter    "zigbee2mqtt"  : 2.13.10  , installed 2.13.10
                                    pi4b@pi4b:~$ iob upgrade
                                    All adapters are up to date
                                    pi4b@pi4b:~$ iob fix
                                    library: loaded
                                    Library version=2024-05-24
                                      Thomas Braun Most Active @Diamand2k22 last edited by
                                      @diamand2k22
                                      Das 'große Ganze' anschauen.
                                      Langfassung von
                                      iob diag
                                      wäre gut.
                                        Diamand2k22 @Thomas Braun last edited by Diamand2k22
                                        @thomas-braun said in [gelöst] Admin nach Update (6.2.17) weg:
                                        iob diag
                                        Skript v.2024-05-22
                                        *** BASE SYSTEM ***
                                         Static hostname: pi4b
                                               Icon name: computer
                                                  Kernel: Linux 6.1.21-v8+
                                            Architecture: arm64
                                        Model           : Raspberry Pi 4 Model B Rev 1.5
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : aarch64
                                        Userland        : 64 bit
                                        Systemuptime and Load:
                                         21:42:13 up 81 days,  3:52,  2 users,  load average: 2.60, 2.92, 2.78
                                        CPU threads: 4
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        Previously detected issues:
                                        *** Time and Time Zones ***
                                                       Local time: Sun 2024-09-15 21:42:14 CEST
                                                   Universal time: Sun 2024-09-15 19:42:14 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** Users and Groups ***
                                        User that called 'iob diag':
                                        pi4b
                                        HOME=/home/pi4b
                                        GROUPS=pi4b adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                        iobroker
                                        HOME=/home/iobroker
                                        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                        *** Display-Server-Setup ***
                                        Display-Server: false
                                        Desktop:
                                        Terminal:       tty
                                        Boot Target:    multi-user.target
                                        *** MEMORY ***
                                        Mem:            8.2G        3.7G        1.3G        3.7M        3.3G        4.5G
                                        Swap:           209M        786K        208M
                                        Total:          8.4G        3.7G        1.5G
                                        Active iob-Instances:   49
                                                 7811 M total memory
                                                 3565 M used memory
                                                 3465 M active memory
                                                 2451 M inactive memory
                                                 1244 M free memory
                                                  271 M buffer memory
                                                 2863 M swap cache
                                                  199 M total swap
                                                    0 M used swap
                                                  199 M free swap
                                        top - 21:42:14 up 81 days,  3:52,  2 users,  load average: 2.47, 2.89, 2.77
                                        Tasks: 218 total,   2 running, 216 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s): 63.6 us, 18.2 sy,  0.0 ni, 18.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :   7811.3 total,   1243.8 free,   3565.2 used,   3135.6 buff/cache
                                        MiB Swap:    200.0 total,    199.2 free,      0.8 used.   4246.1 avail Mem
                                        *** FAILED SERVICES ***
                                        0 loaded units listed.
                                        *** FILESYSTEM ***
                                        /dev/root      ext4      459G   20G  421G   5% /
                                        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                                        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                        tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                                        /dev/sda1      vfat      255M   31M  225M  13% /boot
                                        tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                                        [Wed Jun 26 17:49:34 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A7:70:8D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=1b49eb79-02 rootfstype=ext4 fsck.repair=yes rootwait usbcore.autosuspend=-1
                                        [Wed Jun 26 17:49:37 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Wed Jun 26 17:49:37 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                        [Wed Jun 26 17:49:39 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                        Show mounted filesystems:
                                        TARGET                                                  SOURCE      FSTYPE      OPTIONS
                                        /                                                       /dev/sda2   ext4        rw,noatime
                                        |-/dev                                                  devtmpfs    devtmpfs    rw,relatime,size=3735168k,nr_inodes=933792,mode=755
                                        | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev
                                        | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                        | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                                        |-/proc                                                 proc        proc        rw,relatime
                                        | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                                        |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                                        |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                                        | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                                        | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                                        | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
                                        | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                                        | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                                        | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                                        | |-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                                        | `-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
                                        |-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,size=1599760k,nr_inodes=819200,mode=755
                                        | |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                                        | |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                        | |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                        | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                        | |-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=799876k,nr_inodes=199969,mode=700,uid=1000,gid=1000
                                        | |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
                                        | `-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                        `-/boot                                                 /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                        /var:
                                        2.3G    /var/
                                        1.7G    /var/log/journal/944391c321c34dc1bb3a49f2128ebf7e
                                        1.7G    /var/log
                                        235M    /var/lib
                                        Archived and active journals take up 1.6G in the file system.
                                        /opt/iobroker/backups:
                                        4.0K    /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        1.7G    /opt/iobroker/iobroker-data/
                                        923M    /opt/iobroker/iobroker-data/files
                                        618M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
                                        35M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.be60e800.js.map
                                        30M     /opt/iobroker/iobroker-data/objects.jsonl
                                        26M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/blueconnect-poolwerte/.pioenvs/blueconnect-poolwerte/firmware.elf
                                        24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                                        19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
                                        USB-Devices by-id:
                                        /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                        *** NodeJS-Installation ***
                                        /usr/bin/nodejs         v20.17.0
                                        /usr/bin/node           v20.17.0
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        /usr/bin/corepack       0.29.3
                                        nodejs:
                                          Installed: 20.17.0-1nodesource1
                                          Candidate: 20.17.0-1nodesource1
                                          Version table:
                                         *** 20.17.0-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                                100 /var/lib/dpkg/status
                                             20.16.0-1nodesource1 1001
                                             20.15.1-1nodesource1 1001
                                             20.15.0-1nodesource1 1001
                                             20.14.0-1nodesource1 1001
                                             20.13.1-1nodesource1 1001
                                             20.13.0-1nodesource1 1001
                                             20.12.2-1nodesource1 1001
                                             20.12.1-1nodesource1 1001
                                             20.12.0-1nodesource1 1001
                                             20.11.1-1nodesource1 1001
                                             20.11.0-1nodesource1 1001
                                             20.10.0-1nodesource1 1001
                                             20.9.0-1nodesource1 1001
                                             20.8.1-1nodesource1 1001
                                             20.8.0-1nodesource1 1001
                                             20.7.0-1nodesource1 1001
                                             20.6.1-1nodesource1 1001
                                             20.6.0-1nodesource1 1001
                                             20.5.1-1nodesource1 1001
                                             20.5.0-1nodesource1 1001
                                             20.4.0-1nodesource1 1001
                                             20.3.1-1nodesource1 1001
                                             20.3.0-1nodesource1 1001
                                             20.2.0-1nodesource1 1001
                                             20.1.0-1nodesource1 1001
                                             20.0.0-1nodesource1 1001
                                             18.19.0+dfsg-6~deb12u2 500
                                             18.19.0+dfsg-6~deb12u1 500
                                                500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
                                        No problems detected
                                        Errors in npm tree:
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Core adapters versions
                                        js-controller:  6.0.11
                                        admin:          7.1.0
                                        javascript:     8.8.3
                                        nodejs modules from github:     4
                                        +-- iobroker.blueconnect@0.0.6 (git+ssh://git@github.com/kopierschnitte/ioBroker.blueconnect.git#6d92d3de8f3e303fa3cf3f94d4ef5070b7656eb4)
                                        +-- iobroker.energiefluss-erweitert@0.4.1 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#f724bf54ab9a69bc6d4533b59f560462e1bb2993)
                                        +-- iobroker.esphome@0.5.0-beta.10 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#d60377cc7c7d3092a8bcb1cf945ed256cba6e96f)
                                        | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                                        Adapter State
                                        + system.adapter.adguard.0                : adguard               : pi4b                                     -  enabled
                                          system.adapter.admin.0                  : admin                 : pi4b                                     - disabled, port: ****, bind: 0.0.0.0, run as: admin
                                        + system.adapter.alarm.0                  : alarm                 : pi4b                                     -  enabled
                                        + system.adapter.alexa2.0                 : alexa2                : pi4b                                     -  enabled
                                          system.adapter.alias-manager.0          : alias-manager         : pi4b                                     - disabled
                                        + system.adapter.backitup.0               : backitup              : pi4b                                     -  enabled
                                          system.adapter.blueconnect.0            : blueconnect           : pi4b                                     -  enabled
                                        + system.adapter.bmw.0                    : bmw                   : pi4b                                     -  enabled
                                        + system.adapter.bydhvs.0                 : bydhvs                : pi4b                                     -  enabled
                                          system.adapter.daswetter.0              : daswetter             : pi4b                                     -  enabled
                                        + system.adapter.device-reminder.0        : device-reminder       : pi4b                                     -  enabled
                                        + system.adapter.device-watcher.0         : device-watcher        : pi4b                                     -  enabled
                                        + system.adapter.discovery.0              : discovery             : pi4b                                     -  enabled
                                          system.adapter.dwd.0                    : dwd                   : pi4b                                     -  enabled
                                        + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : pi4b                                     -  enabled
                                        + system.adapter.ecovacs-deebot.1         : ecovacs-deebot        : pi4b                                     -  enabled
                                        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: pi4b                                     -  enabled
                                        + system.adapter.esphome.0                : esphome               : pi4b                                     -  enabled
                                        + system.adapter.evcc.0                   : evcc                  : pi4b                                     -  enabled, port: ****
                                        + system.adapter.fritzdect.0              : fritzdect             : pi4b                                     -  enabled
                                        + system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : pi4b                                     -  enabled
                                        + system.adapter.fronius.0                : fronius               : pi4b                                     -  enabled
                                        + system.adapter.fronius.1                : fronius               : pi4b                                     -  enabled
                                        + system.adapter.fronius.2                : fronius               : pi4b                                     -  enabled
                                        + system.adapter.fullybrowser.0           : fullybrowser          : pi4b                                     -  enabled
                                        + system.adapter.ham.0                    : ham                   : pi4b                                     -  enabled
                                        + system.adapter.heizoel.0                : heizoel               : pi4b                                     -  enabled
                                          system.adapter.ical.0                   : ical                  : pi4b                                     -  enabled
                                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : pi4b                                     - disabled
                                        + system.adapter.influxdb.0               : influxdb              : pi4b                                     -  enabled, port: ****
                                        + system.adapter.intex.0                  : intex                 : pi4b                                     -  enabled, port: *****
                                        + system.adapter.iot.0                    : iot                   : pi4b                                     -  enabled
                                        + system.adapter.javascript.0             : javascript            : pi4b                                     -  enabled
                                        + system.adapter.lovelace.0               : lovelace              : pi4b                                     -  enabled, port: ****, bind: 0.0.0.0, run as: admin
                                        + system.adapter.midea.0                  : midea                 : pi4b                                     -  enabled
                                        + system.adapter.modbus.0                 : modbus                : pi4b                                     -  enabled
                                        + system.adapter.node-red.0               : node-red              : pi4b                                     -  enabled, port: *****, bind: 192.168.178.36
                                        + system.adapter.notification-manager.0   : notification-manager  : pi4b                                     -  enabled
                                          system.adapter.oilfox.0                 : oilfox                : pi4b                                     -  enabled
                                        + system.adapter.opendtu.0                : opendtu               : pi4b                                     -  enabled
                                        + system.adapter.parser.0                 : parser                : pi4b                                     -  enabled
                                        + system.adapter.ping.0                   : ping                  : pi4b                                     -  enabled
                                        + system.adapter.pushover.0               : pushover              : pi4b                                     -  enabled
                                        + system.adapter.rpi2.0                   : rpi2                  : pi4b                                     -  enabled
                                        + system.adapter.shelly.0                 : shelly                : pi4b                                     -  enabled, port: ****, bind: 0.0.0.0
                                        + system.adapter.synology.0               : synology              : pi4b                                     -  enabled, port: *******
                                        + system.adapter.tibberlink.0             : tibberlink            : pi4b                                     -  enabled
                                        + system.adapter.tr-064.0                 : tr-064                : pi4b                                     -  enabled
                                        + system.adapter.trashschedule.0          : trashschedule         : pi4b                                     -  enabled
                                        + system.adapter.tuya.0                   : tuya                  : pi4b                                     -  enabled
                                          system.adapter.vis-bars.0               : vis-bars              : pi4b                                     -  enabled
                                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : pi4b                                     -  enabled
                                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : pi4b                                     -  enabled
                                          system.adapter.vis-history.0            : vis-history           : pi4b                                     -  enabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : pi4b                                     -  enabled
                                          system.adapter.vis-icontwo.0            : vis-icontwo           : pi4b                                     -  enabled
                                        + system.adapter.vis-inventwo.0           : vis-inventwo          : pi4b                                     -  enabled
                                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : pi4b                                     -  enabled
                                          system.adapter.vis-justgage.0           : vis-justgage          : pi4b                                     -  enabled
                                          system.adapter.vis-material.0           : vis-material          : pi4b                                     -  enabled
                                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : pi4b                                     -  enabled
                                          system.adapter.vis-metro.0              : vis-metro             : pi4b                                     -  enabled
                                          system.adapter.vis-plumb.0              : vis-plumb             : pi4b                                     -  enabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : pi4b                                     -  enabled
                                          system.adapter.vis.0                    : vis                   : pi4b                                     -  enabled
                                        + system.adapter.web.0                    : web                   : pi4b                                     -  enabled, port: *****, bind: 0.0.0.0, run as: admin
                                        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : pi4b                                     -  enabled
                                        + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : pi4b                                     -  enabled
                                        + system.adapter.whatsapp-cmb.2           : whatsapp-cmb          : pi4b                                     -  enabled
                                        + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : pi4b                                     -  enabled
                                        ioBroker-Repositories
                                        Active repo(s): beta
                                        Upgrade policy: none
                                        Installed ioBroker-Instances
                                        Adapter    "admin"        : 7.1.1    , installed 7.1.0  [Updatable]
                                        Objects and States
                                        Objects:        26958
                                        States:         23279
                                        Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                                        Hit:2 http://deb.debian.org/debian bookworm InRelease
                                        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                        Hit:4 http://archive.raspberrypi.org/debian bookworm InRelease
                                        Hit:5 https://apt.grafana.com stable InRelease
                                        Hit:6 https://repos.influxdata.com/debian stable InRelease
                                        Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                        Reading package lists...
                                        Pending Updates: 0
                                          Homoran Global Moderator Administrators @Diamand2k22 last edited by
                                          @diamand2k22 iob start admin.0
                                            @diamand2k22 sagte in [gelöst] Admin nach Update (6.2.17) weg:
                                            iob update
                                            iob upgrade
                                            iob start admin
                                            2259
