    4. Unbestätigten Wert schreiben lassen
      fir3drag0n @Homoran last edited by fir3drag0n
      24.8.2022, 09:19:36.836	[info ]: javascript.0 (6488) Stop script script.js.common.Sodastream-Counter
      24.8.2022, 09:19:37.396	[info ]: javascript.0 (6488) Start javascript script.js.common.Sodastream-Counter
      24.8.2022, 09:19:37.415	[info ]: javascript.0 (6488) script.js.common.Sodastream-Counter: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      24.8.2022, 09:19:51.103	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
      24.8.2022, 09:20:30.202	[info ]: javascript.0 (6488) Stop script script.js.common.Sodastream-Counter
      24.8.2022, 09:20:30.212	[info ]: javascript.0 (6488) Start javascript script.js.common.Sodastream-Counter
      24.8.2022, 09:20:30.219	[info ]: javascript.0 (6488) script.js.common.Sodastream-Counter: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      24.8.2022, 09:20:38.000	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
      24.8.2022, 09:20:53.528	[info ]: javascript.0 (6488) Stop script script.js.common.Sodastream-Counter
      24.8.2022, 09:20:53.544	[info ]: javascript.0 (6488) Start javascript script.js.common.Sodastream-Counter
      24.8.2022, 09:20:53.550	[info ]: javascript.0 (6488) script.js.common.Sodastream-Counter: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      24.8.2022, 09:42:48.165	[info ]: javascript.0 (6488) Stop script script.js.common.Sodastream-Counter
      24.8.2022, 09:42:48.175	[info ]: javascript.0 (6488) Start javascript script.js.common.Sodastream-Counter
      24.8.2022, 09:42:48.196	[info ]: javascript.0 (6488) script.js.common.Sodastream-Counter: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      24.8.2022, 09:43:13.042	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
      24.8.2022, 09:43:49.091	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
      24.8.2022, 09:43:49.179	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
      24.8.2022, 09:43:51.030	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
      24.8.2022, 09:45:28.984	[info ]: javascript.0 (6488) Stop script script.js.common.Sodastream-Counter
      24.8.2022, 09:45:28.999	[info ]: javascript.0 (6488) Start javascript script.js.common.Sodastream-Counter
      24.8.2022, 09:45:29.018	[info ]: javascript.0 (6488) script.js.common.Sodastream-Counter: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      24.8.2022, 09:45:38.776	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
      24.8.2022, 09:46:18.909	[info ]: javascript.0 (6488) Stop script script.js.common.Sodastream-Counter
      24.8.2022, 09:46:21.031	[info ]: javascript.0 (6488) Stop script script.js.common.Sodastream-Counter
      24.8.2022, 09:46:21.229	[info ]: javascript.0 (6488) Start javascript script.js.common.Sodastream-Counter
      24.8.2022, 09:46:21.237	[info ]: javascript.0 (6488) script.js.common.Sodastream-Counter: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      24.8.2022, 09:46:21.387	[info ]: javascript.0 (6488) Start javascript script.js.common.Sodastream-Counter
      24.8.2022, 09:46:21.393	[info ]: javascript.0 (6488) script.js.common.Sodastream-Counter: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      24.8.2022, 09:46:28.939	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
      24.8.2022, 09:46:28.940	[warn ]: javascript.0 (6488) script.js.common.Sodastream-Counter: setForeignState(id=0_userdata.0.Sodastream.Sodastream-Counter, state={"val":"9","ack":true,"ts":1661327188939,"q":0,"from":"system.adapter.javascript.0","lc":1661327188932,"c":"script.js.common.Sodastream-Counter"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
      24.8.2022, 09:46:28.942	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
      24.8.2022, 09:46:28.943	[warn ]: javascript.0 (6488) script.js.common.Sodastream-Counter: setForeignState(id=0_userdata.0.Sodastream.Sodastream-Counter, state={"val":"9","ack":true,"ts":1661327188942,"q":0,"from":"system.adapter.javascript.0","lc":1661327188932,"c":"script.js.common.Sodastream-Counter"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
      24.8.2022, 09:47:18.664	[info ]: javascript.0 (6488) Stop script script.js.common.Sodastream-Counter
      24.8.2022, 09:47:18.677	[info ]: javascript.0 (6488) Start javascript script.js.common.Sodastream-Counter
      24.8.2022, 09:47:18.685	[info ]: javascript.0 (6488) script.js.common.Sodastream-Counter: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      24.8.2022, 09:47:26.344	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
      24.8.2022, 09:47:26.344	[warn ]: javascript.0 (6488) script.js.common.Sodastream-Counter: setForeignState(id=0_userdata.0.Sodastream.Sodastream-Counter, state={"val":"11","ack":false,"ts":1661327246344,"q":0,"from":"system.adapter.javascript.0","lc":1661327246333,"c":"script.js.common.Sodastream-Counter"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
      Einmal geht es darum den Wert manuell über Jarvis zu ändern und einmal soll er sich jeweils um 1 erhöhen, wenn der Fensterkontakt auslöst.
      Bei der Änderung über den Fensterkontakt übernimmt er dann immer den alten Wert und nicht den, wenn man ihn über Jarvis geändert hat.
      L Homoran 2 Replies Last reply Reply Quote 0
        lessthanmore @fir3drag0n last edited by
        @fir3drag0n Das ist doch eine Endlosschleife oder?
          Homoran Global Moderator Administrators @fir3drag0n last edited by
          @fir3drag0n bitte Texte wie hier fie Log Meldung immer als Text in code-tags posten
          ist sonst am Handy nicht zu entziffern.
            Homoran Global Moderator Administrators @Homoran last edited by
            @homoran sagte in Unbestätigten Wert schreiben lassen:
            wenn ich das extrem vergrößere
            scheinst du rechts oben den debug modus aktiviert zu haben.
            Ausschalten!
              @homoran ja, da habe ich dann eine Schleife
              24.8.2022, 09:57:22.472	[info ]: javascript.0 (6488) Stop script script.js.common.Sodastream-Counter
              24.8.2022, 09:57:22.488	[info ]: javascript.0 (6488) Start javascript script.js.common.Sodastream-Counter
              24.8.2022, 09:57:22.494	[info ]: javascript.0 (6488) script.js.common.Sodastream-Counter: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
              24.8.2022, 10:04:49.109	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
              24.8.2022, 10:04:49.292	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
              24.8.2022, 10:04:49.440	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
              24.8.2022, 10:04:49.465	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
              24.8.2022, 10:04:49.521	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
              24.8.2022, 10:04:49.539	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
              24.8.2022, 10:04:49.555	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
              24.8.2022, 10:04:49.573	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
              24.8.2022, 10:04:49.595	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
              24.8.2022, 10:04:49.612	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
              24.8.2022, 10:04:49.629	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                paul53 @fir3drag0n last edited by paul53
                @fir3drag0n sagte: ist der Wert logischerweise noch unbestätigt und ich brauche dafür ein Skript.
                Weshalb muss der Wert bestätigt werden?
                Eine Bestätigung erzeugt man mit "aktualisiere" - nicht mit "steuere".
                Ein Trigger auf "wurde aktualisiert" erzeugt eine Trigger-Endlosschleife. Ändere den Trigger auf "wurde geändert" und "Auslösung durch unbestätigte Änderung":
                  fir3drag0n @paul53 last edited by
                  @paul53 also ich setze z.B. manuell den Wert "20".
                  Dann soll bei Schließen der Fensterkontakt der Counter hochzählen (z.B. 21), irgendwie scheint dies aber noch nicht zu funktionieren und er beginnt immer bei "0":
                  24.8.2022, 10:04:49.647	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:49.664	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:49.681	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:49.698	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:49.715	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:49.732	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:49.749	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:49.766	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:49.784	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:49.801	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:49.818	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:49.835	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:49.852	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:49.870	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:49.887	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:49.904	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:49.951	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:49.990	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.011	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.091	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.141	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.158	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.175	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.193	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.210	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.229	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.246	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.263	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.280	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.298	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.315	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.339	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.356	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.377	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.399	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.428	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.445	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.462	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.480	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.502	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.520	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.579	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.600	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.622	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.642	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.668	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.694	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.714	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.730	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.784	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.801	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.819	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.839	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.857	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.874	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.891	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.908	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.941	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:50.963	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.009	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.031	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.052	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.069	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.086	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.103	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.120	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.137	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.154	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.171	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.189	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.206	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.223	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.240	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.257	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.274	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.290	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.307	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.324	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.342	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.359	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.376	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.393	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.410	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.427	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.444	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.460	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.477	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.494	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.511	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.529	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.545	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.563	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.580	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.596	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.613	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.631	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.648	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.674	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.701	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.720	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.749	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.771	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.789	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.810	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.845	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.926	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:51.949	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.014	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.035	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.055	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.088	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.106	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.123	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.139	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.157	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.177	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.193	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.210	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.229	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.247	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.264	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.280	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.296	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.312	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.328	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.343	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.359	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.376	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.393	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.409	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.426	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.442	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.458	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.483	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.516	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.550	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.581	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.612	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.645	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.661	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.677	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.693	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.712	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.729	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.751	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.768	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.784	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.805	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.821	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.844	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.861	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.877	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.893	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.910	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.925	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.941	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.957	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.973	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:52.989	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.004	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.021	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.037	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.094	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.159	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.176	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.192	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.208	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.260	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.285	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.301	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.318	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.334	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.354	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.370	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.386	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.402	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.417	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.433	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.452	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.513	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.539	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.568	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.593	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.611	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.628	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.646	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.662	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.679	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.696	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.713	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.730	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.747	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.764	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.781	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.799	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.852	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.868	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.885	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.902	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.918	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.935	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.952	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.968	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:53.985	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.002	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.024	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.049	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.068	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.084	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.101	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.119	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.145	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.161	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.178	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.195	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.211	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.230	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.247	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.263	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.279	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.296	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.313	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.331	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.351	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.400	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.417	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.434	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.451	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.467	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.483	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.500	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.519	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.536	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.552	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.569	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.586	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.602	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.618	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.636	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.652	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.669	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.686	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.702	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.719	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.735	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.752	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.768	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.786	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.803	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.821	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.837	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.853	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.870	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.887	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.904	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.920	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.937	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.955	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.971	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:54.989	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.005	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.022	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.039	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.056	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.073	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.088	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.105	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.121	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.139	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.155	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.172	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.188	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.204	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.221	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.238	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.255	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.272	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.288	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.305	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.322	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.338	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.354	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.371	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.387	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.405	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.421	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.438	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.455	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.472	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.489	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.505	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.522	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.539	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.557	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.573	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.589	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.606	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.623	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.642	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.659	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.675	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.691	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.709	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.763	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.779	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.795	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.847	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.864	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.881	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.898	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.915	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.931	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.948	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.965	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.982	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:55.999	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.016	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.034	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.062	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.086	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.110	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.131	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.148	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.164	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.180	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.195	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.212	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.228	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.243	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.261	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.277	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.293	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.308	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.323	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.339	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.357	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.373	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.388	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.410	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.425	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.441	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.457	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.472	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.488	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.504	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.519	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.535	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.562	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.577	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.593	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.608	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.625	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.640	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.655	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.671	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.688	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.738	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.753	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.806	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.823	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.838	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.854	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.869	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.885	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.901	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.916	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.934	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.949	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.968	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:56.984	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.001	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.016	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.033	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.053	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.069	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.086	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.103	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.123	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.139	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.155	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.171	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.187	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.203	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.220	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.237	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.252	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.272	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.294	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.310	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.325	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.341	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.393	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.415	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.432	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.454	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.472	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.487	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.503	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.519	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.535	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.551	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.568	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.584	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.600	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.616	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.636	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.651	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.666	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.680	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.695	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.709	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.725	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.751	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.766	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.780	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.798	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.814	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.829	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.848	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.863	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.881	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.899	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                  24.8.2022, 10:04:57.911	[info ]: javascript.0 (6488) Stop script script.js.common.Sodastream-Counter
                  24.8.2022, 10:59:15.635	[info ]: javascript.0 (6488) Stop script script.js.common.Sodastream-Counter
                  24.8.2022, 10:59:23.155	[info ]: javascript.0 (6488) Start javascript script.js.common.Sodastream-Counter
                  24.8.2022, 10:59:23.176	[info ]: javascript.0 (6488) script.js.common.Sodastream-Counter: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  24.8.2022, 11:01:07.529	[warn ]: javascript.0 (6488)     at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                    @fir3drag0n sagte: scheint dies aber noch nicht zu funktionieren und er beginnt immer bei "0":
                    Wie sieht das Skript jetzt aus?
                    Im Tab "Protokolle" finden sich zur Warnung um 11:01:07 sicherlich weitere Informationen.
                    Du hast die Frage nicht beantwortet:
                    @paul53 sagte in Unbestätigten Wert schreiben lassen:
                      fir3drag0n @paul53 last edited by fir3drag0n
                      @paul53 also offensichtlich schient der DP ein string zu sein:
                      javascript.0
                      2022-08-24 11:04:00.327	info	State value to set for "0_userdata.0.Sodastream.Sodastream-Counter" has to be type "number" but received type "string"
                      javascript.0
                      2022-08-24 11:04:00.283	warn	at processImmediate (node:internal/timers:466:21)
                      javascript.0
                      2022-08-24 11:04:00.283	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
                      javascript.0
                      2022-08-24 11:04:00.283	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:596:29)
                      javascript.0
                      2022-08-24 11:04:00.282	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1212:38)
                      javascript.0
                      2022-08-24 11:04:00.282	warn	at Object.<anonymous> (script.js.common.Sodastream-Counter:7:3)
                      javascript.0
                      2022-08-24 11:04:00.281	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1687:20)
                      javascript.0
                      2022-08-24 11:04:00.279	warn	You are assigning a string to the state "0_userdata.0.Sodastream.Sodastream-Counter" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
                        "common": {
                          "name": "Sodastream-Counter",
                          "desc": "Manuell erzeugt",
                          "role": "state",
                          "type": "number",
                          "read": true,
                          "write": true,
                          "def": 0
                        "type": "state",
                        "native": {},
                        "user": "system.user.admin",
                        "ts": 1661321877340,
                        "_id": "0_userdata.0.Sodastream.Sodastream-Counter",
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                        @paul53 ich dachte, der Wert muss bestätigt werden, wenn man ihn manuell in Jarvis ändert?
                          @fir3drag0n sagte: offensichtlich schient der DP ein string zu sein:
                          Nein, es wird ein String geschrieben (Javascript-Ansicht, Zeile 7). Was zu sehen ist, ist nicht das vollständige Skript:
                          Wo sind die weiteren 2 Trigger?
                            @fir3drag0n sagte: ich dachte, der Wert muss bestätigt werden, wenn man ihn manuell in Jarvis ändert?
                            Muss er normalerweise nicht.
                              @paul53 das ist das Skript:
                              var sodastream_counter;
                              on({id: [].concat(['0_userdata.0.Sodastream.Sodastream-Counter']), change: "any", ack: false}, async function (obj) {
                                var value = obj.state.val;
                                setState("0_userdata.0.Sodastream.Sodastream-Counter"/*Sodastream-Counter*/, (obj.state ? obj.state.val : ""), true);
                              on({id: [].concat(['zigbee.0.00158d0007c57b0b.opened']), change: "ne"}, async function (obj) {
                                if (getState("zigbee.0.00158d0007c57b0b.opened").val == false) {
                                  sodastream_counter = getState("0_userdata.0.Sodastream.Sodastream-Counter").val;
                                  sodastream_counter = (typeof sodastream_counter == 'number' ? sodastream_counter : 0) + 1;
                                  setState("0_userdata.0.Sodastream.Sodastream-Counter"/*Sodastream-Counter*/, sodastream_counter, true);
                                @fir3drag0n sagte: das ist das Skript:
                                Dann wundert mich der Log mit "4 subcriptions".
                                Lass den oberen Trigger weg und konvertiere den Wert beim Einlesen nach Zahl.
                                Anscheinend schreibt Jarvis einen String in den Datenpunkt. Das erklärt auch, warum mit 0 begonnen wird. Ändere mal die Rolle von "state" in "level".
                                Trigger "ist kleiner als letztes" reagiert nur auf Änderung true --> false des Kontaktes.
                                  @paul53 ja, das war es - danke!
                                    @paul53 said in Unbestätigten Wert schreiben lassen:
                                    Anscheinend schreibt Jarvis einen String in den Datenpunkt. Das erklärt auch, warum mit 0 begonnen wird. Ändere mal die Rolle von "state" in "value".
                                    was bewirkt die Änderung der Rolle?
                                      @fir3drag0n sagte: was bewirkt die Änderung der Rolle?
                                      Jarvis schreibt dann vielleicht eine Zahl in den Datenpunkt? Ich habe gelesen, dass Visualisierungen die Rolle auswerten.
                                      Da es ein r/w Datenpunkt ist, nimm die Rolle "level".
                                      671
