Update auf Nodejs 16 scheitert an grafana
Hier der ganze Text:
root@CT201:/opt/iobroker# curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash - ## Installing the NodeSource Node.js 16.x repo... ## Populating apt-get cache... + apt-get update Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease Get:2 https://deb.nodesource.com/node_14.x bionic InRelease [4584 B] Get:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB] Get:4 https://repos.influxdata.com/ubuntu bionic InRelease [4737 B] Get:5 http://archive.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB] Err:6 https://packagecloud.io/grafana/stable/debian stretch InRelease 402 Payment Required [IP: 52.8.238.184 443] Get:7 https://repos.influxdata.com/ubuntu bionic/stable amd64 Packages [1267 B] Get:8 https://deb.nodesource.com/node_14.x bionic/main amd64 Packages [769 B] Get:9 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages [2707 kB] Get:10 http://archive.ubuntu.com/ubuntu bionic-updates/main Translation-en [500 kB] Get:11 http://archive.ubuntu.com/ubuntu bionic-updates/restricted amd64 Packages [889 kB] Get:12 http://archive.ubuntu.com/ubuntu bionic-updates/restricted Translation-en [123 kB] Get:13 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages [1837 kB] Get:14 http://archive.ubuntu.com/ubuntu bionic-updates/universe Translation-en [398 kB] Get:15 http://archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 Packages [24.9 kB] Get:16 http://archive.ubuntu.com/ubuntu bionic-security/main amd64 Packages [2366 kB] Get:17 http://archive.ubuntu.com/ubuntu bionic-security/main Translation-en [410 kB] Get:18 http://archive.ubuntu.com/ubuntu bionic-security/restricted amd64 Packages [859 kB] Get:19 http://archive.ubuntu.com/ubuntu bionic-security/restricted Translation-en [118 kB] Get:20 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages [1223 kB] Get:21 http://archive.ubuntu.com/ubuntu bionic-security/universe Translation-en [282 kB] Get:22 http://archive.ubuntu.com/ubuntu bionic-security/multiverse amd64 Packages [19.0 kB] Reading package lists... Done E: Failed to fetch https://packagecloud.io/grafana/stable/debian/dists/stretch/InRelease 402 Payment Required [IP: 52.8.238.184 443] E: The repository 'https://packagecloud.io/grafana/stable/debian stretch InRelease' is not signed. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. Error executing command, exiting root@CT201:/opt/iobroker# sudo apt install -y nodejs Reading package lists... Done Building dependency tree Reading state information... Done The following packages will be upgraded: nodejs 1 upgraded, 0 newly installed, 0 to remove and 149 not upgraded. Need to get 25.5 MB of archives. After this operation, 2564 kB of additional disk space will be used. Get:1 https://deb.nodesource.com/node_14.x bionic/main amd64 nodejs amd64 14.20.0-1nodesource1 [25.5 MB] Fetched 25.5 MB in 3s (7467 kB/s) (Reading database ... 37036 files and directories currently installed.) Preparing to unpack .../nodejs_14.20.0-1nodesource1_amd64.deb ... Detected old npm client, removing... Unpacking nodejs (14.20.0-1nodesource1) over (14.17.6-1nodesource1) ... Setting up nodejs (14.20.0-1nodesource1) ... Processing triggers for man-db (2.8.3-2ubuntu0.1) ... root@CT201:/opt/iobroker# node -v v14.20.0 -
Punkt 1: Nicht als root rumeimern. Leg dir einen user an, falls da noch keiner ist:
adduser deinusername usermod -aG sudo deinusername usermod -aG iobroker deinusername exitUnd dann niemehr als root anmelden, nur noch mit dem user.
Punkt 2:
Jetzt als user:sudo apt-get install -y apt-transport-https sudo apt-get install -y software-properties-common wget sudo wget -q -O /usr/share/keyrings/grafana.key https://packages.grafana.com/gpg.key echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://packages.grafana.com/oss/deb stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list -
Habe das nach OffTopic verschoben.
Grafana ist kein Bestandteil von ioBroker -
@ed210 sagte in Update auf Nodejs 16 scheitert an grafana:
root@CT201:
@ed210
steht das für ConTainer? -
@thomas-braun Vielen Dank für die ausführliche Beschreibung! Der User ist angelegt und das Update wird gerade ausgeführt. Soweit hat alles geklappt bisher.
Ja, das Linux läuft in einem Proxmox Container.
Zeigen...
Nach dem reboot:sudo apt update apt policy grafana apt policy nodejs -
Ich bin jetzt alle Punkte durchgegangen. Der grafana-Fehler bleibt leider bestehen:
ed210@CT201:/opt/iobroker$ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash - ## Installing the NodeSource Node.js 16.x repo... ## Populating apt-get cache... + apt-get update Hit:1 https://repos.influxdata.com/ubuntu bionic InRelease Hit:2 https://deb.nodesource.com/node_14.x bionic InRelease Hit:3 https://packages.grafana.com/oss/deb stable InRelease Hit:4 http://archive.ubuntu.com/ubuntu bionic InRelease Hit:5 http://archive.ubuntu.com/ubuntu bionic-updates InRelease Hit:6 http://archive.ubuntu.com/ubuntu bionic-security InRelease Err:7 https://packagecloud.io/grafana/stable/debian stretch InRelease 402 Payment Required [IP: 52.8.238.184 443] Reading package lists... Done E: Failed to fetch https://packagecloud.io/grafana/stable/debian/dists/stretch/InRelease 402 Payment Required [IP: 52.8.238.184 443] E: The repository 'https://packagecloud.io/grafana/stable/debian stretch InRelease' is not signed. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. Error executing command, exiting ed210@CT201:/opt/iobroker$ -
Hab das "Nach dem Reboot" übersehen, sorry.
@thomas-braun said in Update auf Nodejs 16 scheitert an grafana:
apt policy nodejs
ed210@CT201:/opt/iobroker$ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash - ## Installing the NodeSource Node.js 16.x repo... ## Populating apt-get cache... + apt-get update Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease Hit:2 https://repos.influxdata.com/ubuntu bionic InRelease Hit:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease Hit:4 https://deb.nodesource.com/node_14.x bionic InRelease Hit:5 http://archive.ubuntu.com/ubuntu bionic-security InRelease Hit:6 https://packages.grafana.com/oss/deb stable InRelease Err:7 https://packagecloud.io/grafana/stable/debian stretch InRelease 402 Payment Required [IP: 52.8.238.184 443] Reading package lists... Done E: Failed to fetch https://packagecloud.io/grafana/stable/debian/dists/stretch/InRelease 402 Payment Required [IP: 52.8.238.184 443] E: The repository 'https://packagecloud.io/grafana/stable/debian stretch InRelease' is not signed. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. Error executing command, exiting ed210@CT201:/opt/iobroker$Der Fehler ist leider immer noch da, auch nach den 3 Zeilen bei "Nach dem reboot"
Es muss noch eine *.list Datei geben, die "packagecloud" enthält.
grep -r "packagecloud" /etc/apt/Diese Datei löschen.
sudo rm /pfad/zur/datei.list -
Der erste Befehl wird gerade ausgeführt. Er scheint ne Weile dafür zu brauchen.
Sollte eigentlich nicht. So viele Dateien sollten in dem Pfad nicht liegen.
> ed210@CT201:/opt/iobroker$ grep -r "packagecloud" /etc/apt/ >Ich vermute das er was tut, weil ich nach der Eingabe keinen promt mehr bekomme.
ed210@CT201:/opt/iobroker$ grep -r "grafana" /etc/apt/ /etc/apt/sources.list:deb https://packagecloud.io/grafana/stable/debian/ stretch main /etc/apt/sources.list.d/grafana.list:deb [signed-by=/usr/share/keyrings/grafana.key] https://packages.grafana.com/oss/deb stable main ed210@CT201:/opt/iobroker$ -
STOP!
Nicht löschen!
Nur die eine Zeile mit dem Eintragdeb https://packagecloud.io/grafana/stable/debian/ stretch mainlöschen.
Geht mit nano.
sudo nano /etc/apt/sources.listDatei speichern: STRG-X, Nachfrage bestätigen.
sudo apt update -
So weit erledigt.
Nach dem STRG + X bestätige ich die Nachfrage mit "y"Danach kommt eine weitere Frage: File Name to Write: /etc/apt/sources.list
DOS Format Append Backup File
Mac Format Prepend To FilesWas soll ich da auswählen?
