    4. Test Adapter Growatt v3.3.1
      Wildbill last edited by
      @PLCHome-0 Ich hatte heute mehrfach mit der neuesten Version folgende Meldungen im Log, die ich so glaub noch nie hatte. Adapter hat sich dann jedesmal nach einem automatischen Neustart wieder gefangen und für 1-2 Stunden keine Meldungen geworfen, bis es wieder kam. Insgesamt drei oder viermal. Kannst Du damit was anfangen?
      host.iobroker-vlan100
      2022-08-11 13:02:13.074	error	instance system.adapter.growatt.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2022-08-11 13:02:13.074	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
      2022-08-11 13:02:13.073	error	Caught by controller[1]: at runMicrotasks (<anonymous>)
      2022-08-11 13:02:13.073	error	Caught by controller[1]: at /opt/iobroker/node_modules/growatt/lib/growatt.js:252:45
      2022-08-11 13:02:13.073	error	Caught by controller[1]: at JSON.stringify (<anonymous>)
      2022-08-11 13:02:13.073	error	Caught by controller[1]: --- property 'socket' closes the circle
      2022-08-11 13:02:13.073	error	Caught by controller[1]: | property '_httpMessage' -> object with constructor 'ClientRequest'
      2022-08-11 13:02:13.073	error	Caught by controller[1]: --> starting at object with constructor 'TLSSocket'
      2022-08-11 13:02:13.073	error	Caught by controller[1]: TypeError: Converting circular structure to JSON
      2022-08-11 13:02:13.072	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      growatt.0
      2022-08-11 13:02:12.454	error	Converting circular structure to JSON --> starting at object with constructor 'TLSSocket' | property '_httpMessage' -> object with constructor 'ClientRequest' --- property 'socket' closes the circle
      growatt.0
      2022-08-11 13:02:12.453	error	TypeError: Converting circular structure to JSON --> starting at object with constructor 'TLSSocket' | property '_httpMessage' -> object with constructor 'ClientRequest' --- property 'socket' closes the circle at JSON.stringify (<anonymous>) at /opt/iobroker/node_modules/growatt/lib/growatt.js:252:45 at runMicrotasks (<anonymous>) at processTicksAndRejections (node:internal/process/task_queues:96:5)
      growatt.0
      2022-08-11 13:02:12.451	error	unhandled promise rejection: Converting circular structure to JSON --> starting at object with constructor 'TLSSocket' | property '_httpMessage' -> object with constructor 'ClientRequest' --- property 'socket' closes the circle
      growatt.0
      2022-08-11 13:02:12.446	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      Bin nach wie vor auf dem chinesischen Server.
      Gruss, Jürgen
      PLCHome 0 1 Reply Last reply Reply Quote 0
        Garf @PLCHome 0 last edited by
        @plchome-0
        Bei mir sieht es ebenfalls stabil und fehlerfrei aus.
          warp735 last edited by
          @plchome-0
          hab mich grad an Rechner gesetzt und hatte diese Meldung auf m Schirm. Adapter war rot, wurde also gestoppt.
          • PLCHome 0
            PLCHome 0 Developer @Wildbill last edited by PLCHome 0
            @wildbill said in Test Adapter Growatt v1.0.0:
            252:45
            circular structure to JSON --> ... ist gefixed
            Kannst du auf Unstable testen?
            G W 2 Replies Last reply Reply Quote 1
              @plchome-0
              Den oben beschreibenen Fehler hatte ich auch. Jetzt läuft es wieder fehlerfrei.
                Wildbill @PLCHome 0 last edited by
                @plchome-0 sagte in Test Adapter Growatt v1.0.0:
                252:45
                Bin auf 1.1.17 hoch und schaue mal, ob bis morgen noch Meldungen auftauchen. Danke schonmal. 👍
                Gruss, Jürgen
                  @PLCHome-0 So, seit gestern mit der 1.1.17 bleibt das Log endlich ruhig.
                  Einzig heute Nacht gab es eine Meldung vom Adapter:
                  growatt.0
                  2022-08-13 03:57:31.230	error	Growatt exception: AxiosError: Request failed with status code 500
                  Da ich mich aber meine zu erinnern, dass ich sowas immer wieder mal nachs zwischen 3 und 4 hatte wird das wohl der China-Server sein, der neu gebootet und kurz nicht erreichbar ist. 😊
                  Also von meiner Seite sieht es jetzt sehr gut aus. Danke
                  Gruss, Jürgen
                  • PLCHome 0
                    @wildbill Zwischen 3 und 4 trennen auch manche DSL-Router, vielleicht kommt die Meldung bei dir daher.
                    W 2 Replies Last reply Reply Quote 0
                      @plchome-0 Nein, bei mir erfolgt die Trennung nur alle paar Monate mal, daran liegt es nicht.
                      Die Meldung kommt aber wirklich täglich exakt um 3:57 Uhr. Skript oder geplanten Adapter-Neustart kann ich ausschliessen.
                      Gruss, Jürgen
                        moonsorrox @Wildbill last edited by
                        This post is deleted!
                          moonsorrox @moonsorrox last edited by
                            Wildbill @moonsorrox last edited by
                              moonsorrox @Wildbill last edited by moonsorrox
                                Wildbill @moonsorrox last edited by Wildbill
                                  meine Frage wäre aber eine andere zu meinem Growatt 1500S der läuft mit diesem Modul bisher super, aber was ich garnicht heraus bekomme ist der Ertrag der Anlage für ein Jahr.
                                  Ich bekomme alle Werte die ich brauche Tag, Monat und Gesamt, aber eben für 1Jahr nicht ist das bei allen Growatt so?
                                    @moonsorrox Bin mir gar nicht sicher, ob Du die Daten des Jahresertrags direkt auf der Growatt-Seite findest. Ich sehe da auch nur maximal den Monatsertrag und dann Total, aber nicht für das gesamte Jahr.
                                    Für derartige Auswertungen würde ich Dir aber eh den Sourceanalytix-Adapter empfehlen. Natürlich nicht nur für den Growatt, sondern für Zähler sämtlicher Art. Damit lässt sich sowas viel besser und granularer auswerten und Du bekommst auch Montas- und Wochendaten im Verlauf, so dass Du die gesamte Vergangenheit jederzeit sehen kannst.
                                    Gruss, Jürgen
                                      @wildbill
                                      naja ich sehe bei Growatt eingeloggt schon die Jahre, also die 3 Jahre 2020, 2021, 2022 bis jetzt August jetzt als Balkendiagram, aber im ioBroker gibt es diesen Wert eben nicht.
                                        @plchome-0 Da der Adapter heute mal wieder einen Haufen Fehler schmeisst, habe ich mal direkt server.growatt.com aufgerufen. Abgesehen davon, dass die Bedienung auf der Site gerade sehr sehr langsam war, zeigte mir der Browser (Safari) dort soeben auch einen Serverfehler 500 an. Also scheint es doch am Server direkt zu liegen. Warum da wohl manche (wie ich) mehr betroffen sind und andere anscheinend nicht (oder nicht so sehr), ist mir zwar unklar, aber damit muss ich wohl leben.
                                        Gruss, Jürgen
                                          @wildbill
                                          ja ich habe es schon bemerkt das einige viele Fehler haben, andere eben nicht - ich habe aktuell keine Fehler
                                          Habe grad mal geschaut, aber ein Fehler habe auch gehabt
                                          2022-08-26 14:14:59.812 error Growatt exception: AxiosError: Request failed with status code 502
                                          W S 2 Replies Last reply Reply Quote 0
                                            @moonsorrox Wenn ich schaue, welche Objekte sich im Gowatt-Adapter auswählen lassen, so sehe ich da auch nur eMonth und eTotal. Von Jahren ist da nix, also kommt das wohl auch nicht mit. Aber wie gesagt, mit dem sourceanalytix hast Du alls (und mehr) was Du brauchst.
                                            Gruss, Jürgen
                                            adapter growatt pv-anlage shine solar test tester
                                            71
                                            800
                                            311780
