    4. VIS Anzeige "gevierteilt"
      kgw @kgw last edited by kgw
      @kgw
      [{"tpl":"tplCGradialGauge","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","factor":"1","valueOffset":"0","hCount":"0","needle":"true","needleShadow":"true","needleType":"arrow","borders":true,"borderOuterWidth":"8","borderMiddleWidth":"8","borderInnerWidth":"0","borderShadowWidth":"0","valueBox":true,"ticksAngle":"270","startAngle":"45","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"parser.0.PV_GridPower","units":"Watt","title":"pv_GridPower","minValue":"0","maxValue":"5000","valueBoxStroke":"0","valueInt":"4","needleStart":"","needleEnd":"","g_ticks":false,"minorTicks":"4","g_animation":false,"animation":"true","g_fonts":false,"valueDec":"0","g_highlights_§0":false,"g_colorsGauge":false,"needleCircleSize":"10","needleCircleInner":true,"needleCircleOuter":false,"g_colorsRadial":true,"name":"LeistungGesamt","locked":false},"style":{"left":"595px","top":"14px","width":"187px","height":"226px"},"widgetSet":"canvas-gauges"}]
      dann liegts wohl an Firefox für win11!
      OliverIO Glasfaser 2 Replies Last reply Reply Quote 0
        kgw @DJMarc75 last edited by
        @djmarc75
        Dass hier 3,75 und nicht vier Gigabyte angezeigt werden liegt an der Kilobyte vs. Kibibyte problematik. Während die Software binär mit 1024 bytes = 1 Kibibyte rechnet, rechnen die Hardwarehersteller dezimal 1000 bytes = 1 Kilobyte.
        DJMarc75 BananaJoe 2 Replies Last reply Reply Quote 0
        • DJMarc75
          DJMarc75 @kgw last edited by
          @kgw sagte in VIS Anzeige "gevierteilt":
          OK... danke für die Mathestunde 👍
          und ist das viertel jetzt halbiert oder gar gelöst?
          • BananaJoe
            BananaJoe Most Active @kgw last edited by
            @kgw öhm, nö, das ist so nicht richtig ... Der Raspi hat sehr wohl echte 4GiB RAM.
            Das er dort nur 3,75 anzeigt liegt daran das sich der Grafikchip keinen eigenen RAM hat sondern sich diesen mit dem System teilt. In raspi-config kann man einstellen wieviel RAM die Grafikeinheit nutzt.
            Der Rest wird als RAM ausgewiesen.
            Ist bei einigen PC mit integrierter Grafik genauso.
              kgw @BananaJoe last edited by kgw
              @bananajoe
              jo, danke für die Aufklärung, dann bleib ich lieber bei der Z900🏍
              • OliverIO
                OliverIO @kgw last edited by
                @kgw
                wenn ihr mir jetzt noch erzählt aus welchem adapter dieses widget ist?
                ich wollte da nicht selbst auf die suche gehen?
                installiert habe ich es nicht, nach import erscheint undefined, also ist es nicht Standard-Umfang von vis
                • Glasfaser
                  Glasfaser @kgw last edited by Glasfaser
                  @OliverIO
                  https://github.com/ioBroker/ioBroker.vis-canvas-gauges
                  ich finde auch kein Anzeigefehler !
                  EDIT :
                  Er hat nur das Problem bei :
                  @kgw mal der Browser Cache gelöscht ,
                  Teste mal im "Neuer Privater Tab "
                  • OliverIO
                    @kgw
                    hab jetzt mit firefox auch kein problem feststellen können
                    evtl kannst du mal noch erzählen, was zur "zerstörung" führt.
                    war das nach einer gewissen zeit? oder so und so viel Änderungen?
                      kgw @OliverIO last edited by
                      @oliverio
                      folgendes ist für vis installiert:
                      wie bekomme ich denn heraus aus welchem adapter das widget canva-gauges stammt?
                        kgw @Glasfaser last edited by kgw
                        @glasfaser
                        im privaten tab kommt der Fehler auch
                        Browser Cache löschen hilft auch nicht.
                          Homoran Global Moderator Administrators @kgw last edited by Homoran
                          @oliverio
                          das ist der Adapter 2 über dem markierten
                            @oliverio
                            Erscheinung tritt von alleine (ohne Rechneraktivitäten) nach einer gewissen Zeit auf.
                            Minuten oder so, keine Zeitmessung gemacht!
                            • OliverIO
                              OliverIO @kgw last edited by OliverIO
                              @kgw
                              Ich konnte den Fehler genau so nachvollziehen.
                              Ich habe ein kleines Skript geschrieben, das dauernd neue Werte geschrieben hat.
                              Nach der ca. 28-32 Änderung trat der beschriebene Effekt auf.
                              Bei der verwendeten Bibliothek wurde das schon als Issue gemeldet,
                              leider aber wieder geschlossen, weil es dem Autor zu wenig Informationen war
                              https://github.com/Mikhus/canvas-gauges/issues/205
                              Mittlerweile gibt es eine Version 2.17, bei der aber das Problem ebenso auftritt (habe hier mal lokal die Dateien getauscht)
                              Da das Problem nicht am iobroker liegt, sondern an einer verwendeten Bibliothek, hilft es nur, das Issue dort nochmal zu eröffnen und zu hoffen, das er Lust hat das Problem weiter zu analysieren.
                              JanusHL created this issue in Mikhus/canvas-gauges
                              closed Bug? - broken gauges #205
                                @oliverio
                                hi und danke für die Hilfe!
                                wo und was kann ich nun melden?
                                • OliverIO
                                  @kgw
                                  bei dem verlinkten issue in github nochmal ergänzend schreiben.
                                  Allerdings hat das jemand in 2021 auch schon gemacht.
                                  ich fürchte, das wird nicht mehr gefixt,
                                  leider gibt es davon auch keine forks mit aktuellerem code
                                    kgw @OliverIO last edited by kgw
                                    @oliverio
                                    OK, werd ich dann (erst) morgen formulieren.
                                    ich nehme dann ein anderes widget!
                                    OK, habs in github vermerkt.
                                    OliverIO Homoran 2 Replies Last reply Reply Quote 0
                                    • OliverIO
                                      @kgw
                                      ok ich habe dir einen workaround, aufgrund weiterer issue hinweise von hier
                                      https://github.com/Mikhus/canvas-gauges/issues/251
                                      folgende schritte musst du tun und beim nächsten update des canvas-gauges adapters wiederholen, falls das nicht mittlerweile dann eingebaut wird, aber wir testen hier erstmal ob es richtig funktioniert.
                                      1. suche die folgende Datei
                                        /opt/iobroker/node_modules/iobroker.vis-canvas-gauges/widgets/canvas-gauges.html
                                      2. tausche den inhalt komplett mit dem spoiler inhalt unten aus
                                      3. öffne die konsole und geb folgendes ein
                                      iobroker upload vis-canvas-gauges
                                      1. ca 30 sekunden warten
                                      2. mach im vis editor einen reload (am besten schließen und neu öffnen
                                      3. mach in deiner vis-runtime einen reload
                                      4. danach sollte es kein verschieben mehr geben
                                      wer sich für Details interessiert. es wurde die Zeile 408 + die dazugehörende Funktion padValue hinzugefügt.
                                         version: "0.1.5"
                                         Copyright 2016 bluefox<dogafox@gmail.com>
                                      <script type="text/javascript" src="widgets/canvas-gauges/js/gauge.min.js"></script>
                                      <script language="javascript">
                                         'use strict';
                                         // Add words for bars
                                         if (vis.editMode) {
                                             $.extend(systemDictionary, {
                                                 "linear":           {"en": "linear",            "de": "linear", "ru": "linear"},
                                                 "quad":             {"en": "quad",              "de": "quad", "ru": "quad"},
                                                 "quint":            {"en": "quint",             "de": "quint", "ru": "quint"},
                                                 "cycle":            {"en": "cycle",             "de": "cycle", "ru": "cycle"},
                                                 "elastic":          {"en": "elastic",           "de": "elastic", "ru": "elastic"},
                                                 "dequad":           {"en": "dequad",            "de": "dequad", "ru": "dequad"},
                                                 "dequint":          {"en": "dequint",           "de": "dequint", "ru": "dequint"},
                                                 "decycle":          {"en": "decycle",           "de": "decycle", "ru": "decycle"},
                                                 "debounce":         {"en": "debounce",          "de": "debounce", "ru": "debounce"},
                                                 "delastic":         {"en": "delastic",          "de": "delastic", "ru": "delastic"},
                                                 "arrow":            {"en": "arrow",             "de": "arrow", "ru": "arrow"},
                                                 "minValue":         {"en": "min",               "de": "min", "ru": "minValue"},
                                                 "maxValue":         {"en": "max",               "de": "max", "ru": "maxValue"},
                                                 "valueOffset":      {"en": "Value offset",      "de": "Wertoffset", "ru": "valueOffset"},
                                                 "hCount":           {"en": "Highlights number", "de": "Anzahl von Sektoren", "ru": "Кол-во секторов"},
                                                 "group_highlights": {"en": "Highlights",        "de": "Sektoren",       "ru": "Сектора"},
                                                 "highlightsFrom":   {"en": "From",              "de": "Von",            "ru": "highlightsFrom"},
                                                 "highlightsTo":     {"en": "To",                "de": "Bis",            "ru": "highlightsTo"},
                                                 "highlightsColor":  {"en": "Color",             "de": "Farbe",          "ru": "highlightsColor"},
                                                 "majorTicks":       {"en": "Major ticks",       "de": "majorTicks",     "ru": "majorTicks"},
                                                 "minorTicks":       {"en": "Minor ticks",       "de": "minorTicks",     "ru": "minorTicks"},
                                                 "strokeTicks":      {"en": "Stroke ticks",      "de": "strokeTicks",        "ru": "strokeTicks"},
                                                 "majorTicksInt":    {"en": "Before comma ",     "de": "majorTicksInt",      "ru": "majorTicksInt"},
                                                 "majorTicksDec":    {"en": "After comma",       "de": "majorTicksDec",      "ru": "majorTicksDec"},
                                                 "group_animation":  {"en": "Animation",         "de": "group_animation",    "ru": "group_animation"},
                                                 "animation":        {"en": "Enabled",           "de": "animation",          "ru": "animation"},
                                                 "animationDuration": {"en": "Duration",         "de": "animationDuration", "ru": "animationDuration"},
                                                 "animationRule":    {"en": "Rule",              "de": "animationRule", "ru": "animationRule"},
                                                 "animatedValue":    {"en": "Value",             "de": "animatedValue", "ru": "animatedValue"},
                                                 "animateOnInit":    {"en": "Animate on start",  "de": "animateOnInit", "ru": "animateOnInit"},
                                                 "group_colorsGauge": {"en": "Colors",           "de": "Farben", "ru": "group_colorsGauge"},
                                                 "colorPlate":       {"en": "Plate",             "de": "Plate", "ru": "colorPlate"},
                                                 "colorPlateEnd":    {"en": "Plate end",         "de": "PlateEnd", "ru": "colorPlateEnd"},
                                                 "colorMajorTicks":  {"en": "Major ticks",       "de": "MajorTicks", "ru": "colorMajorTicks"},
                                                 "colorMinorTicks":  {"en": "Minor ticks",       "de": "MinorTicks", "ru": "colorMinorTicks"},
                                                 "colorTitle":       {"en": "Title",             "de": "Title", "ru": "colorTitle"},
                                                 "colorUnits":       {"en": "Units",             "de": "Units", "ru": "colorUnits"},
                                                 "colorNumbers":     {"en": "Numbers",           "de": "Numbers", "ru": "colorNumbers"},
                                                 "colorNeedle":      {"en": "Needle",            "de": "Needle", "ru": "colorNeedle"},
                                                 "colorNeedleEnd":   {"en": "NeedleEnd",         "de": "NeedleEnd", "ru": "colorNeedleEnd"},
                                                 "colorValueText":   {"en": "ValueText",         "de": "ValueText", "ru": "colorValueText"},
                                                 "colorValueTextShadow":     {"en": "Value text shadow",     "de": "ValueTextShadow", "ru": "colorValueTextShadow"},
                                                 "colorBorderShadow":        {"en": "Border shadow",         "de": "BorderShadow", "ru": "colorBorderShadow"},
                                                 "colorBorderOuter":         {"en": "Border outer",          "de": "BorderOuter", "ru": "colorBorderOuter"},
                                                 "colorBorderOuterEnd":      {"en": "Border outer end",      "de": "BorderOuterEnd", "ru": "colorBorderOuterEnd"},
                                                 "colorBorderMiddle":        {"en": "Border middle",         "de": "BorderMiddle", "ru": "colorBorderMiddle"},
                                                 "colorBorderMiddleEnd":     {"en": "Border middle end",     "de": "BorderMiddleEnd", "ru": "colorBorderMiddleEnd"},
                                                 "colorBorderInner":         {"en": "Border inner",          "de": "BorderInner", "ru": "colorBorderInner"},
                                                 "colorBorderInnerEnd":      {"en": "Border inner end",      "de": "BorderInnerEnd", "ru": "colorBorderInnerEnd"},
                                                 "colorValueBoxRect":        {"en": "Value box rect",        "de": "ValueBoxRect", "ru": "colorValueBoxRect"},
                                                 "colorValueBoxRectEnd":     {"en": "Value box rect end",    "de": "ValueBoxRectEnd", "ru": "colorValueBoxRectEnd"},
                                                 "colorValueBoxBackground":  {"en": "Value box background",  "de": "ValueBoxBackground", "ru": "colorValueBoxBackground"},
                                                 "colorValueBoxShadow":      {"en": "Value box shadow",      "de": "ValueBoxShadow", "ru": "colorValueBoxShadow"},
                                                 "colorNeedleShadowUp":      {"en": "Needle shadow up",      "de": "NeedleShadowUp", "ru": "colorNeedleShadowUp"},
                                                 "colorNeedleShadowDown":    {"en": "Needle shadow down",    "de": "NeedleShadowDown", "ru": "colorNeedleShadowDown"},
                                                 "needle":           {"en": "Needle",            "de": "needle", "ru": "needle"},
                                                 "needleShadow":     {"en": "NeedleShadow",      "de": "needleShadow", "ru": "needleShadow"},
                                                 "needleType":       {"en": "NeedleType",        "de": "needleType", "ru": "needleType"},
                                                 "needleStart":      {"en": "NeedleStart",       "de": "needleStart", "ru": "needleStart"},
                                                 "needleEnd":        {"en": "NeedleEnd",         "de": "needleEnd", "ru": "needleEnd"},
                                                 "needleWidth":      {"en": "NeedleWidth",       "de": "needleWidth", "ru": "needleWidth"},
                                                 "group_borders":    {"en": "Borders",           "de": "Rahmen", "ru": "group_borders"},
                                                 "borders":          {"en": "Enabled",           "de": "Aktiviert", "ru": "borders"},
                                                 "borderOuterWidth": {"en": "Outer width",       "de": "borderOuterWidth", "ru": "borderOuterWidth"},
                                                 "borderMiddleWidth": {"en": "Middle width",     "de": "borderMiddleWidth", "ru": "borderMiddleWidth"},
                                                 "borderInnerWidth": {"en": "Inner width",       "de": "borderInnerWidth", "ru": "borderInnerWidth"},
                                                 "borderShadowWidth": {"en": "Shadow width",     "de": "borderShadowWidth", "ru": "borderShadowWidth"},
                                                 "group_valueBox":   {"en": "Value Box",         "de": "Wert-Box", "ru": "group_valueBox"},
                                                 "valueBox":         {"en": "Enabled",           "de": "Aktiviert", "ru": "valueBox"},
                                                 "valueBoxStroke":   {"en": "Box stroke",        "de": "valueBoxStroke", "ru": "valueBoxStroke"},
                                                 "valueText":        {"en": "Text",              "de": "valueText", "ru": "valueText"},
                                                 "valueTextShadow":  {"en": "Text shadow",       "de": "valueTextShadow", "ru": "valueTextShadow"},
                                                 "valueBoxBorderRadius": {"en": "Box border radius", "de": "valueBoxBorderRadius", "ru": "valueBoxBorderRadius"},
                                                 "valueInt":         {"en": "Before comma",      "de": "Vor Komma", "ru": "valueInt"},
                                                 "valueDec":         {"en": "After comma",       "de": "Nach Komma", "ru": "valueDec"},
                                                 "group_fonts":      {"en": "Fonts",             "de": "Schriften", "ru": "group_fonts"},
                                                 "fontNumbers":      {"en": "Numbers",           "de": "Numbers", "ru": "fontNumbers"},
                                                 "fontTitle":        {"en": "Title",             "de": "Title", "ru": "fontTitle"},
                                                 "fontUnits":        {"en": "Units",             "de": "Units", "ru": "fontUnits"},
                                                 "fontValue":        {"en": "Value",             "de": "Value", "ru": "fontValue"},
                                                 "fontNumbersSize":  {"en": "Numbers size",      "de": "Numbers Size", "ru": "fontNumbersSize"},
                                                 "fontTitleSize":    {"en": "Title size",        "de": "Title Size", "ru": "fontTitleSize"},
                                                 "fontUnitsSize":    {"en": "Units size",        "de": "Units Size", "ru": "fontUnitsSize"},
                                                 "fontValueSize":    {"en": "Value size",        "de": "Value Size", "ru": "fontValueSize"},
                                                 "fontNumbersStyle": {"en": "Numbers style",     "de": "Numbers Style", "ru": "fontNumbersStyle"},
                                                 "fontTitleStyle":   {"en": "Title style",       "de": "Title Style", "ru": "fontTitleStyle"},
                                                 "fontUnitsStyle":   {"en": "Units style",       "de": "Units Style", "ru": "fontUnitsStyle"},
                                                 "fontValueStyle":   {"en": "Value style",       "de": "Value Style", "ru": "fontValueStyle"},
                                                 "fontNumbersWeight": {"en": "Numbers weight",   "de": "Numbers Weight", "ru": "fontNumbersWeight"},
                                                 "fontTitleWeight":  {"en": "Title weight",      "de": "Title Weight", "ru": "fontTitleWeight"},
                                                 "fontUnitsWeight":  {"en": "Units weight",      "de": "Units Weight", "ru": "fontUnitsWeight"},
                                                 "fontValueWeight":  {"en": "Value weight",      "de": "Value Weight", "ru": "fontValueWeight"},
                                                 "group_gaugeBar":   {"en": "Gauge bar",         "de": "Gauge Bar", "ru": "group_gaugeBar"},
                                                 "barBeginCircle":   {"en": "Begin circle",      "de": "BeginCircle", "ru": "barBeginCircle"},
                                                 "barWidth":         {"en": "Width",             "de": "Width", "ru": "barWidth"},
                                                 "barLength":        {"en": "Length",            "de": "Length", "ru": "barLength"},
                                                 "barStrokeWidth":   {"en": "Stroke width",      "de": "StrokeWidth", "ru": "barStrokeWidth"},
                                                 "barProgress":      {"en": "Progress",          "de": "Progress", "ru": "barProgress"},
                                                 "group_colorsBar":  {"en": "Bar colors",        "de": "Bar-Farbe", "ru": "group_colorsBar"},
                                                 "colorBarStroke":   {"en": "Bar stroke",        "de": "BarStroke", "ru": "colorBarStroke"},
                                                 "colorBar":         {"en": "Bar",               "de": "Bar", "ru": "colorBar"},
                                                 "colorBarEnd":      {"en": "BarEnd",            "de": "BarEnd", "ru": "colorBarEnd"},
                                                 "colorBarProgress": {"en": "BarProgress",       "de": "BarProgress", "ru": "colorBarProgress"},
                                                 "colorBarProgressEnd": {"en": "BarProgressEnd", "de": "BarProgressEnd", "ru": "colorBarProgressEnd"},
                                                 "group_positions":  {"en": "Positions",         "de": "Position", "ru": "group_positions"},
                                                 "tickSide":         {"en": "Tick's side",       "de": "tick Side", "ru": "tickSide"},
                                                 "needleSide":       {"en": "Needle's side",     "de": "needle Side", "ru": "needleSide"},
                                                 "numberSide":       {"en": "Number's side",     "de": "number Side", "ru": "numberSide"},
                                                 "group_ticksBar":   {"en": "Bar ticks",         "de": "Ticks Bar", "ru": "group_ticksBar"},
                                                 "ticksWidth":       {"en": "Width",             "de": "ticksWidth", "ru": "ticksWidth"},
                                                 "ticksWidthMinor":  {"en": "Width minor",       "de": "ticksWidthMinor", "ru": "ticksWidthMinor"},
                                                 "ticksPadding":     {"en": "Padding",           "de": "ticksPadding", "ru": "ticksPadding"},
                                                 "plate":            {"en": "plate",             "de": "plate", "ru": "plate"},
                                                 "animationTarget":  {"en": "Animation target",  "de": "Animationsziel", "ru": "animationTarget"},
                                                 "group_gaugeRadial": {"en": "Gauge radial",     "de": "Radial", "ru": "group_gaugeRadial"},
                                                 "ticksAngle":       {"en": "Ticks's angle",     "de": "ticksAngle", "ru": "ticksAngle"},
                                                 "startAngle":       {"en": "Start Angle",       "de": "startAngle", "ru": "startAngle"},
                                                 "group_colorsRadial":       {"en": "Colors for radial",         "de": "Farbe (radiall)", "ru": "group_colorsRadial"},
                                                 "colorNeedleCircleOuter":   {"en": "Needle circle outer",       "de": "NeedleCircleOuter", "ru": "colorNeedleCircleOuter"},
                                                 "colorNeedleCircleOuterEnd": {"en": "Needle circle outer end",  "de": "NeedleCircleOuterEnd", "ru": "colorNeedleCircleOuterEnd"},
                                                 "colorNeedleCircleInner":   {"en": "Needle circle inner",       "de": "NeedleCircleInner", "ru": "colorNeedleCircleInner"},
                                                 "colorNeedleCircleInnerEnd": {"en": "Needle circle inner end",  "de": "NeedleCircleInnerEnd", "ru": "colorNeedleCircleInnerEnd"},
                                                 "group_needleRadial":       {"en": "Needle for radial",         "de": "Zeiger (radial)", "ru": "group_needleRadial"},
                                                 "needleCircleSize":         {"en": "Circle size",               "de": "Circle Size", "ru": "needleCircleSize"},
                                                 "needleCircleInner":        {"en": "Circle inner",              "de": "Circle Inner", "ru": "needleCircleInner"},
                                                 "needleCircleOuter":        {"en": "Circle outer",              "de": "Circle Outer", "ru": "needleCircleOuter"}
                                         //jQuery.extend(true, vis.binds, {
                                         vis.binds['canvas-gauges'] = {
                                             version: "0.1.5",
                                             showVersion: function () {
                                                 if (vis.binds['canvas-gauges'].version) {
                                                     console.log('Version vis-canvas-gauges: ' + vis.binds['canvas-gauges'].version);
                                                     vis.binds['canvas-gauges'].version = null;
                                             gaugeDestroy: function (wid, $wid) {
                                                 if ($wid && $wid.length) {
                                                     var bound = $wid.data('bound');
                                                     if (bound) {
                                                         var bindHandler = $wid.data('bindHandler');
                                                         for (var b = 0; b < bound.length; b++) {
                                                             vis.states.unbind(bound[b], bindHandler);
                                                     var gauge = $wid.data('gauge');
                                                     if (gauge) {
                                                         gauge.destroy();
                                                         $wid.data('gauge', null);
                                             padValue: function (val,options) {
                                                 let dec = options.valueDec;
                                                 let int = options.valueInt;
                                                 let i = 0;
                                                 let s, strVal, n;
                                                 val = parseFloat(val);
                                                 n = (val < 0);
                                                 val = Math.abs(val);
                                                 if (dec > 0) {
                                                     strVal = val.toFixed(dec).toString().split('.');
                                                     s = int - strVal[0].length;
                                                     for (; i < s; ++i) {
                                                         strVal[0] = '0' + strVal[0];
                                                     strVal = (n ? '-' : '') + strVal[0] + '.' + strVal[1];
                                                 } else {
                                                     strVal = Math.round(val).toString();
                                                     s = int - strVal.length;
                                                         strVal = '0' + strVal;
                                                     strVal = (n ? '-' : '') + strVal;
                                                 return strVal;
                                             gauge: function (view, data, type) {
                                                 var wid = data.attr('wid');
                                                 var $wid = $('#' + wid).css('overflow', 'visible');
                                                 if (!$wid.length) {
                                                     setTimeout(function () {
                                                         vis.binds['canvas-gauges'].gauge(view, data, type);
                                                     }, 100);
                                                     return;
                                                 if (!$wid.is(':visible')) {
                                                     }, 1000);
                                                     return;
                                                 $wid.css('overflow', 'visible');
                                                 var w = $wid.width();
                                                 var h = $wid.height();
                                                 var options = {
                                                     width:          w,
                                                     height:         h,
                                                     title:          data.attr('title') || '',
                                                     minValue:       parseFloat(data.attr('minValue')) || 0,
                                                     maxValue:       parseFloat(data.attr('maxValue')),
                                                     units:          data.attr('units') || '',
                                                     factor:         parseFloat(data.attr('factor')) || 1,
                                                     offset:         parseFloat(data.attr('valueOffset')) || 0,
                                                     minorTicks:     parseInt(data.attr('minorTicks'), 10) || 1,
                                                     strokeTicks:    data.attr('strokeTicks') === 'true' || data.attr('strokeTicks') === true,
                                                     majorTicksInt:  parseInt(data.attr('majorTicksInt'), 10) || 4,
                                                     majorTicksDec:  parseInt(data.attr('majorTicksDec'), 10) || 2,
                                                     animation:      data.attr('animation') === 'true' || data.attr('animation') === true,
                                                     animationDuration:  parseInt(data.attr('animationDuration')) || 500,
                                                     animationRule:  data.attr('animationRule') || 'linear',
                                                     animatedValue:  data.attr('animatedValue') === 'true' || data.attr('animatedValue') === true,
                                                     animateOnInit:  data.attr('animateOnInit') === 'true' || data.attr('animateOnInit') === true
                                                 if (isNaN(options.maxValue)) options.maxValue = 100;
                                                 if (data.attr('colorPlate'))             options.colorPlate             = data.attr('colorPlate');
                                                 if (data.attr('colorPlateEnd'))          options.colorPlateEnd          = data.attr('colorPlateEnd');
                                                 if (data.attr('colorMajorTicks'))        options.colorMajorTicks        = data.attr('colorMajorTicks');
                                                 if (data.attr('colorMinorTicks'))        options.colorMinorTicks        = data.attr('colorMinorTicks');
                                                 if (data.attr('colorTitle'))             options.colorTitle             = data.attr('colorTitle');
                                                 if (data.attr('colorUnits'))             options.colorUnits             = data.attr('colorUnits');
                                                 if (data.attr('colorNumbers'))           options.colorNumbers           = data.attr('colorNumbers');
                                                 if (data.attr('colorNeedle'))            options.colorNeedle            = data.attr('colorNeedle');
                                                 if (data.attr('colorNeedleEnd'))         options.colorNeedleEnd         = data.attr('colorNeedleEnd');
                                                 if (data.attr('colorValueText'))         options.colorValueText         = data.attr('colorValueText');
                                                 if (data.attr('colorValueTextShadow'))   options.colorValueTextShadow   = data.attr('colorValueTextShadow');
                                                 if (data.attr('colorBorderShadow'))      options.colorBorderShadow      = data.attr('colorBorderShadow');
                                                 if (data.attr('colorBorderOuter'))       options.colorBorderOuter       = data.attr('colorBorderOuter');
                                                 if (data.attr('colorBorderOuterEnd'))    options.colorBorderOuterEnd    = data.attr('colorBorderOuterEnd');
                                                 if (data.attr('colorBorderMiddle'))      options.colorBorderMiddle      = data.attr('colorBorderMiddle');
                                                 if (data.attr('colorBorderMiddleEnd'))   options.colorBorderMiddleEnd   = data.attr('colorBorderMiddleEnd');
                                                 if (data.attr('colorBorderInner'))       options.colorBorderInner       = data.attr('colorBorderInner');
                                                 if (data.attr('colorBorderInnerEnd'))    options.colorBorderInnerEnd    = data.attr('colorBorderInnerEnd');
                                                 if (data.attr('colorValueBoxRect'))      options.colorValueBoxRect      = data.attr('colorValueBoxRect');
                                                 if (data.attr('colorValueBoxRectEnd'))   options.colorValueBoxRectEnd   = data.attr('colorValueBoxRectEnd');
                                                 if (data.attr('colorValueBoxBackground'))options.colorValueBoxBackground = data.attr('colorValueBoxBackground');
                                                 if (data.attr('colorValueBoxShadow'))    options.colorValueBoxShadow    = data.attr('colorValueBoxShadow');
                                                 if (data.attr('colorNeedleShadowUp'))    options.colorNeedleShadowUp    = data.attr('colorNeedleShadowUp');
                                                 if (data.attr('colorNeedleShadowDown'))  options.colorNeedleShadowDown  = data.attr('colorNeedleShadowDown');
                                                 if (data.attr('needle')       !== undefined && data.attr('needle')       !== '')  options.needle       = data.attr('needle') === 'true' || data.attr('needle') === true;
                                                 if (data.attr('needleShadow') !== undefined && data.attr('needleShadow') !== '')  options.needleShadow = data.attr('needleShadow') === 'true' || data.attr('needleShadow') === true;
                                                 if (data.attr('needleType')   !== undefined && data.attr('needleType')   !== '')  options.needleType   = data.attr('needleType');
                                                 if (data.attr('needleStart')  !== undefined && data.attr('needleStart')  !== '')  options.needleStart  = parseFloat(data.attr('needleStart'));
                                                 if (data.attr('needleEnd')    !== undefined && data.attr('needleEnd')    !== '')  options.needleEnd    = parseFloat(data.attr('needleEnd'));
                                                 if (data.attr('needleWidth')  !== undefined && data.attr('needleWidth')  !== '')  options.needleWidth  = parseFloat(data.attr('needleWidth'));
                                                 if (data.attr('borders')           !== undefined && data.attr('borders')           !== '')  options.borders = data.attr('borders') === 'true' || data.attr('borders') === true;
                                                 if (data.attr('borderOuterWidth')  !== undefined && data.attr('borderOuterWidth')  !== '')  options.borderOuterWidth  = parseFloat(data.attr('borderOuterWidth'));
                                                 if (data.attr('borderMiddleWidth') !== undefined && data.attr('borderMiddleWidth') !== '')  options.borderMiddleWidth = parseFloat(data.attr('borderMiddleWidth'));
                                                 if (data.attr('borderInnerWidth')  !== undefined && data.attr('borderInnerWidth')  !== '')  options.borderInnerWidth  = parseFloat(data.attr('borderInnerWidth'));
                                                 if (data.attr('borderShadowWidth') !== undefined && data.attr('borderShadowWidth') !== '')  options.borderShadowWidth = parseFloat(data.attr('borderShadowWidth'));
                                                 if (data.attr('valueBox')              !== undefined && data.attr('valueBox') !== '')       options.valueBox = data.attr('valueBox') === 'true' || data.attr('valueBox') === true;
                                                 if (data.attr('valueText')             !== undefined && data.attr('valueText') !== '')      options.valueText = data.attr('valueText');
                                                 if (data.attr('valueBoxStroke')        !== undefined && data.attr('valueBoxStroke') !== '') options.valueBoxStroke  = parseFloat(data.attr('valueBoxStroke'));
                                                 if (data.attr('valueTextShadow')       !== undefined)                                       options.valueTextShadow = data.attr('valueTextShadow');
                                                 if (data.attr('valueBoxBorderRadius')  !== undefined && data.attr('valueBoxBorderRadius') !== '')  options.valueBoxBorderRadius  = parseFloat(data.attr('valueBoxBorderRadius'));
                                                 if (data.attr('valueInt')              !== undefined && data.attr('valueInt') !== '')       options.valueInt = parseInt(data.attr('valueInt'), 10);
                                                 if (data.attr('valueDec')              !== undefined && data.attr('valueDec') !== '')       options.valueDec = parseInt(data.attr('valueDec'), 10);
                                                 if (data.attr('fontNumbers') !== undefined && data.attr('fontNumbers') !== '')  options.fontNumbers = data.attr('fontNumbers');
                                                 if (data.attr('fontTitle')   !== undefined && data.attr('fontTitle')   !== '')  options.fontTitle   = data.attr('fontTitle');
                                                 if (data.attr('fontUnits')   !== undefined && data.attr('fontUnits')   !== '')  options.fontUnits   = data.attr('fontUnits');
                                                 if (data.attr('fontValue')   !== undefined && data.attr('fontValue')   !== '')  options.fontValue   = data.attr('fontValue');
                                                 if (data.attr('fontNumbersSize') !== undefined && data.attr('fontNumbersSize') !== '')  options.fontNumbersSize = parseInt(data.attr('fontNumbersSize'), 10);
                                                 if (data.attr('fontTitleSize')   !== undefined && data.attr('fontTitleSize')   !== '')  options.fontTitleSize   = parseInt(data.attr('fontTitleSize'), 10);
                                                 if (data.attr('fontUnitsSize')   !== undefined && data.attr('fontUnitsSize')   !== '')  options.fontUnitsSize   = parseInt(data.attr('fontUnitsSize'), 10);
                                                 if (data.attr('fontValueSize')   !== undefined && data.attr('fontValueSize')   !== '')  options.fontValueSize   = parseInt(data.attr('fontValueSize'), 10);
                                                 if (data.attr('fontNumbersStyle') !== undefined && data.attr('fontNumbersStyle')    !== '')  options.fontNumbersStyle = data.attr('fontNumbersStyle');
                                                 if (data.attr('fontTitleStyle') !== undefined && data.attr('fontTitleStyle')        !== '')  options.fontTitleStyle = data.attr('fontTitleStyle');
                                                 if (data.attr('fontUnitsStyle') !== undefined && data.attr('fontUnitsStyle')        !== '')  options.fontUnitsStyle = data.attr('fontUnitsStyle');
                                                 if (data.attr('fontValueStyle') !== undefined && data.attr('fontValueStyle')        !== '')  options.fontValueStyle = data.attr('fontValueStyle');
                                                 if (data.attr('fontNumbersWeight') !== undefined && data.attr('fontNumbersWeight')  !== '')  options.fontNumbersWeight = data.attr('fontNumbersWeight');
                                                 if (data.attr('fontTitleWeight') !== undefined && data.attr('fontTitleWeight')      !== '')  options.fontTitleWeight = data.attr('fontTitleWeight');
                                                 if (data.attr('fontUnitsWeight') !== undefined && data.attr('fontUnitsWeight')      !== '')  options.fontUnitsWeight = data.attr('fontUnitsWeight');
                                                 if (data.attr('fontValueWeight') !== undefined && data.attr('fontValueWeight')      !== '')  options.fontNumbers = data.attr('fontValueWeight');
                                                 var hCount = parseInt(data.attr('hCount'), 10) || 0;
                                                 if (hCount) {
                                                     options.highlights = [];
                                                     for (var u = 1; u <= hCount; u++) {
                                                         if (data.attr('highlightsFrom' + u) === undefined || data.attr('highlightsFrom' + u) === '') continue;
                                                         if (type === 'radial') {
                                                             options.highlights.push({
        from:   (parseFloat(data.attr('highlightsFrom' + u)) || 0),
        to:     parseFloat(data.attr('highlightsTo' + u)),
        color:  data.attr('highlightsColor' + u)
                                                         } else {
        from:   (parseFloat(data.attr('highlightsFrom' + u)) || 0) - options.minValue,
        to:     parseFloat(data.attr('highlightsTo' + u)) - options.minValue,
                                                 } else {
                                                     options.highlights = false;
                                                 // convert majorTicks
                                                 var majorTicks = data.attr('majorTicks');
                                                 if (typeof majorTicks === 'string' && majorTicks.indexOf(',') !== -1) {
                                                     majorTicks = majorTicks.split(',');
                                                     for (var m = majorTicks.length - 1; m >= 0; m--) {
                                                         majorTicks[m] = majorTicks[m].trim();
                                                 } else {
                                                     majorTicks = parseFloat(majorTicks);
                                                     if (majorTicks) {
                                                         var start = options.minValue;
                                                         var step = (options.maxValue - options.minValue) / (majorTicks - 1);
                                                         majorTicks = [];
                                                         while(start <= options.maxValue) {
                                                             majorTicks.push(start);
                                                             start += step;
                                                     } else {
                                                         majorTicks = undefined;
                                                 if (!majorTicks) {
                                                     majorTicks = [];
                                                     var step = (options.maxValue - options.minValue) / 5;
                                                         start += step;
                                                 options.majorTicks = majorTicks;
                                                     vis.binds['canvas-gauges'].radialGauge(view, data, options, $wid);
                                                 } else {
                                                     vis.binds['canvas-gauges'].linearGauge(view, data, options, $wid);
                                                 if (gauge) {
                                                     gauge.update(options);
                                                 } else {
                                                     options.value = options.minValue || 0;
                                                     $wid.html('<canvas class="vis-canvas-gauges"></canvas>');
                                                     options.renderTo = $wid.find('.vis-canvas-gauges')[0];
                                                         gauge = new RadialGauge(options);
                                                     } else {
                                                         gauge = new LinearGauge(options);
                                                     $wid.data('gauge', gauge);
                                                     gauge.draw();
                                                     if (vis.editMode && vis.activeWidgets.indexOf(wid) !== -1) {
                                                         $wid.resizable('destroy');
                                                         vis.resizable($wid);
                                                 var oid = data.attr('oid');
                                                 if ((oid || oid === 0) && oid !== 'nothing_selected') {
                                                     var val = vis.states.attr(oid + '.val');
                                                     if (val === undefined || val === null) {
                                                     } else {
                                                         var updateGauge = function (e, newVal /* , oldVal*/) {
                                                             gauge.value = parseFloat(newVal) * gauge.options.factor + gauge.options.offset;
                                                             gauge.update({ valueText: vis.binds['canvas-gauges'].padValue(gauge.value,options) })
                                                         // remember all ids, that bound
                                                         $wid.data('bound', [oid + '.val']);
                                                         // remember bind handler
                                                         $wid.data('bindHandler', updateGauge);
                                                         vis.states.bind(oid + '.val', updateGauge);
                                                     gauge.value = val * gauge.options.factor + gauge.options.offset;
                                                 // register destroy handler
                                                 $wid.data('destroy', vis.binds['canvas-gauges'].gaugeDestroy);
                                             linearGauge: function (view, data, options, $wid) {
                                                 options.borderRadius = parseFloat($wid.css('border-radius'));
                                                 if (data.attr('barBeginCircle') !== undefined && data.attr('barBeginCircle')    !== '')  options.barBeginCircle = parseFloat(data.attr('barBeginCircle'));
                                                 if (data.attr('barWidth')       !== undefined && data.attr('barWidth')          !== '')  options.barWidth       = parseFloat(data.attr('barWidth'));
                                                 if (data.attr('barLength')      !== undefined && data.attr('barLength')         !== '')  options.barLength      = parseFloat(data.attr('barLength'));
                                                 if (data.attr('barStrokeWidth') !== undefined && data.attr('barStrokeWidth')    !== '')  options.barStrokeWidth = parseFloat(data.attr('barStrokeWidth'));
                                                 if (data.attr('barProgress')    !== undefined && data.attr('barProgress')       !== '')  options.barProgress    = data.attr('barProgress') === 'true' || data.attr('barProgress') === true;
                                                 if (data.attr('colorBarStroke')     !== undefined && data.attr('colorBarStroke')    !== '')  options.colorBarStroke     = data.attr('colorBarStroke');
                                                 if (data.attr('colorBar')           !== undefined && data.attr('colorBar')          !== '')  options.colorBar           = data.attr('colorBar');
                                                 if (data.attr('colorBarEnd')        !== undefined && data.attr('colorBarEnd')       !== '')  options.colorBarEnd        = data.attr('colorBarEnd');
                                                 if (data.attr('colorBarProgress')   !== undefined && data.attr('colorBarProgress')  !== '')  options.colorBarProgress   = data.attr('colorBarProgress');
                                                 if (data.attr('colorBarProgressEnd') !== undefined && data.attr('colorBarProgressEnd') !== '')  options.colorBarProgressEnd = data.attr('colorBarProgressEnd');
                                                 if (data.attr('tickSide')       !== undefined && data.attr('tickSide')      !== '')  options.tickSide       = data.attr('tickSide');
                                                 if (data.attr('needleSide')     !== undefined && data.attr('needleSide')    !== '')  options.needleSide     = data.attr('needleSide');
                                                 if (data.attr('numberSide')     !== undefined && data.attr('numberSide')    !== '')  options.numberSide     = data.attr('numberSide');
                                                 if (data.attr('ticksWidth')      !== undefined && data.attr('ticksWidth')      !== '')  options.ticksWidth      = parseFloat(data.attr('ticksWidth'));
                                                 if (data.attr('ticksWidthMinor') !== undefined && data.attr('ticksWidthMinor') !== '')  options.ticksWidthMinor = parseFloat(data.attr('ticksWidthMinor'));
                                                 if (data.attr('ticksPadding')    !== undefined && data.attr('ticksPadding')    !== '')  options.barBeginCircle  = parseFloat(data.attr('ticksPadding'));
                                             radialGauge: function (view, data, options, $wid) {
                                                 if (data.attr('ticksAngle') !== undefined && data.attr('ticksAngle')    !== '')  options.ticksAngle = parseFloat(data.attr('ticksAngle'));
                                                 if (data.attr('startAngle')       !== undefined && data.attr('startAngle')          !== '')  options.startAngle       = parseFloat(data.attr('startAngle'));
                                                 if (data.attr('colorNeedleCircleOuter')     !== undefined && data.attr('colorNeedleCircleOuter')    !== '')  options.colorNeedleCircleOuter     = data.attr('colorNeedleCircleOuter');
                                                 if (data.attr('colorNeedleCircleOuterEnd')           !== undefined && data.attr('colorNeedleCircleOuterEnd')          !== '')  options.colorNeedleCircleOuterEnd           = data.attr('colorNeedleCircleOuterEnd');
                                                 if (data.attr('colorNeedleCircleInner')        !== undefined && data.attr('colorNeedleCircleInner')       !== '')  options.colorNeedleCircleInner        = data.attr('colorNeedleCircleInner');
                                                 if (data.attr('colorNeedleCircleInnerEnd')   !== undefined && data.attr('colorNeedleCircleInnerEnd')  !== '')  options.colorNeedleCircleInnerEnd   = data.attr('colorNeedleCircleInnerEnd');
                                                 if (data.attr('needleCircleSize')       !== undefined && data.attr('needleCircleSize')      !== '')  options.needleCircleSize       = parseFloat(data.attr('needleCircleSize'));
                                                 if (data.attr('needleCircleInner')    !== undefined && data.attr('needleCircleInner')       !== '')  options.needleCircleInner    = data.attr('needleCircleInner') === 'true' || data.attr('needleCircleInner') === true;
                                                 if (data.attr('needleCircleOuter')    !== undefined && data.attr('needleCircleOuter')       !== '')  options.needleCircleOuter    = data.attr('needleCircleOuter') === 'true' || data.attr('needleCircleOuter') === true;
                                                 if (data.attr('animationTarget')     !== undefined && data.attr('animationTarget')    !== '')  options.animationTarget     = data.attr('animationTarget');
                                         if (vis.editMode) {
                                             vis.binds['canvas-gauges'].changedId = function (widgetID, view, newId/*, fields*/) {
                                                 var obj = vis.objects[newId];
                                                 var changed = [];
                                                 var wData = vis.views[view].widgets[widgetID].data;
                                                 var wwData = vis.widgets[widgetID].data;
                                                 if (obj && obj.common && obj.type === 'state') {
                                                     if (obj.common.min !== undefined && (wData.minValue === undefined || wData.minValue === '')) {
                                                         wData.minValue = obj.common.min;
                                                         wwData.minValue = obj.common.min;
                                                         changed.push('minValue');
                                                     if (obj.common.max !== undefined && (wData.maxValue === undefined || wData.maxValue === '')) {
                                                         wData.maxValue = obj.common.max;
                                                         wwData.maxValue = obj.common.max;
                                                         changed.push('maxValue');
                                                     if (obj.common.unit !== undefined && (wData.units === undefined || wData.units === '')) {
                                                         wData.units = obj.common.unit;
                                                         wwData.units = obj.common.unit;
                                                         changed.push('units');
                                                     if (obj.common.name && (wData.title === undefined || wData.title === '')) {
                                                         wData.title = obj.common.name;
                                                         wwData.title = obj.common.name;
                                                         changed.push('title');
                                                 return changed.length ? changed : null;
                                         vis.binds['canvas-gauges'].showVersion();
                                      </script>
                                      <!--script id="tplCGlinearGauge"
                                             type="text/ejs"
                                             class="vis-tpl"
                                             data-vis-type="temperature,number"
                                             data-vis-set="canvas-gauges"
                                             data-vis-name="Linear"
                                             data-vis-update-style="true"
                                             data-vis-prev='<img src="widgets/canvas-gauges/img/prev/Prev_cgLinear.png"></img>'
                                             data-vis-attrs="oid/id/changedId;minValue;maxValue;units;title;factor[1];valueOffset[0];hCount[1]/slider,0,20,1;"
                                             data-vis-attrs0="group.highlights/byindex;highlightsFrom(1-hCount);highlightsTo(1-hCount);highlightsColor(1-hCount)/color;"
                                             data-vis-attrs1="group.ticks;majorTicks/slider,0,20,1;minorTicks/slider,0,20,1;strokeTicks/checkbox;majorTicksInt/slider,0,10,1;majorTicksDec/slider,0,10,1;"
                                             data-vis-attrs2="group.animation;animation[true]/checkbox;animationDuration/slider,0,2000,50;animationRule/select,linear,quad,quint,cycle,bounce,elastic,dequad,dequint,decycle,debounce,delastic;animatedValue/checkbox;animateOnInit/checkbox;"
                                             data-vis-attrs3="group.colorsGauge;colorPlate/color;colorPlateEnd/color;colorMajorTicks/color;colorMinorTicks/color;colorTitle/color;colorUnits/color;colorNumbers/color;colorNeedle/color;colorNeedleEnd/color;colorValueText/color;colorValueTextShadow/color;colorBorderShadow/color;colorBorderOuter/color;colorBorderOuterEnd/color;colorBorderMiddle/color;colorBorderMiddleEnd/color;colorBorderInner/color;colorBorderInnerEnd/color;colorValueBoxRect/color;colorValueBoxRectEnd/color;colorValueBoxBackground/color;colorValueBoxShadow/color;colorNeedleShadowUp/color;colorNeedleShadowDown/color;"
                                             data-vis-attrs4="group.needle;needle/checkbox;needleShadow/checkbox;needleType/select,arrow,line;needleStart/slider,0,20,1;needleEnd/slider,0,20,1;needleWidth/slider,0,20,1;"
                                             data-vis-attrs5="group.borders;borders[true]/checkbox;borderOuterWidth/slider,0,20,1;borderMiddleWidth/slider,0,20,1;borderInnerWidth/slider,0,20,1;borderShadowWidth/slider,0,20,1;;"
                                             data-vis-attrs6="group.valueBox;valueBox[false]/checkbox;valueBoxStroke/slider,0,20,1;valueText;valueTextShadow/checkbox;valueBoxBorderRadius/slider,0,20,1;valueInt/slider,0,20,1;valueDec/slider,0,20,1;"
                                             data-vis-attrs7="group.fonts;fontNumbers/fontname;fontTitle/fontname;fontUnits/fontname;fontValue/fontname;"
                                             data-vis-attrs8="fontNumbersSize/slider,0,100,1;fontTitleSize/slider,0,100,1;fontUnitsSize/slider,0,100,1;fontValueSize/slider,0,100,1;"
                                             data-vis-attrs9="fontNumbersStyle/nselect,normal,italic,oblique;fontTitleStyle/nselect,normal,italic,oblique;fontUnitsStyle/nselect,normal,italic,oblique;fontValueStyle/nselect,normal,italic,oblique;"
                                             data-vis-attrs10="fontNumbersWeight/auto,normal,bold,bolder,lighter;fontTitleWeight/auto,normal,bold,bolder,lighter;fontUnitsWeight/auto,normal,bold,bolder,lighter;fontValueWeight/auto,normal,bold,bolder,lighter;"
                                         <div class="vis-widget <%== this.data.attr('class') %>" style="overflow: visible; width: 150px; height: 250px; border-radius: 10px" id="<%= this.data.attr('wid') %>"></div>
                                         <% vis.binds['canvas-gauges'].gauge(this.view, this.data, 'linear'); %>
                                      </script-->
                                      <script id="tplCGlinearGauge"
                                             type="text/ejs"
                                             class="vis-tpl"
                                             data-vis-attrs1="group.ticks;majorTicks/slider,0,20,1;minorTicks[5]/slider,0,20,1;strokeTicks/checkbox;majorTicksInt/slider,0,10,1;majorTicksDec/slider,0,10,1;"
                                             data-vis-attrs4="group.needle;needle/checkbox;needleShadow/checkbox;needleType/select,arrow,line;needleStart/slider,0,100,1;needleEnd/slider,0,100,1;needleWidth/slider,0,50,1;"
                                             data-vis-attrs5="group.borders;borders[true]/checkbox;borderOuterWidth/slider,0,20,1;borderMiddleWidth/slider,0,20,1;borderInnerWidth/slider,0,20,1;borderShadowWidth/slider,0,20,1;"
                                             data-vis-attrs11="group.gaugeBar;barBeginCircle/slider,0,360,1;barWidth/slider,0,50,1;barLength/slider,0,100,1;barStrokeWidth/slider,0,50,0;barProgress[true]/checkbox;"
                                             data-vis-attrs12="group.colorsBar;colorBarStroke/color;colorBar/color;colorBarEnd/color;colorBarProgress/color;colorBarProgressEnd/color;"
                                             data-vis-attrs13="group.positions;tickSide/select,both,left,right;needleSide/select,both,left,right;numberSide/select,both,left,right;"
                                             data-vis-attrs14="group.ticksBar;ticksWidth/slider,0,50,1;ticksWidthMinor/slider,0,50,1;ticksPadding/slider,0,50,1;"
                                      </script>
                                      <script id="tplCGradialGauge"
                                             type="text/ejs"
                                             class="vis-tpl"
                                             data-vis-type="number"
                                             data-vis-name="Radial"
                                             data-vis-prev='<img src="widgets/canvas-gauges/img/prev/Prev_cgRadial.png"></img>'
                                             data-vis-attrs1="group.ticks;majorTicks/slider,0,20,1;minorTicks[4]/slider,0,20,1;strokeTicks/checkbox;majorTicksInt/slider,0,10,1;majorTicksDec/slider,0,10,1;"
                                             data-vis-attrs2="group.animation;animation[true]/checkbox;animationDuration/slider,0,2000,50;animationRule/select,linear,quad,quint,cycle,bounce,elastic,dequad,dequint,decycle,debounce,delastic;animatedValue/checkbox;animateOnInit/checkbox;animationTarget/select,needle,plate;"
                                             data-vis-attrs4="group.needle;needle[true]/checkbox;needleShadow[true]/checkbox;needleType[select]/select,arrow,line;needleStart/slider,0,100,1;needleEnd/slider,0,100,1;needleWidth/slider,0,50,1;"
                                             data-vis-attrs5="group.borders;borders[true]/checkbox;borderOuterWidth[2]/slider,0,20,1;borderMiddleWidth[2]/slider,0,20,1;borderInnerWidth[2]/slider,0,20,1;borderShadowWidth[2]/slider,0,20,1;"
                                             data-vis-attrs11="group.gaugeRadial;ticksAngle[270]/slider,0,360,1;startAngle[45]/slider,0,360,1;"
                                             data-vis-attrs12="group.colorsRadial;colorNeedleCircleOuter/color;colorNeedleCircleOuterEnd/color;colorNeedleCircleInner/color;colorNeedleCircleInnerEnd/color;"
                                             data-vis-attrs13="group.needleRadial;needleCircleSize/slider,0,200,1;needleCircleInner/checkbox;needleCircleInner/checkbox;needleCircleOuter/checkbox;"
                                         <div class="vis-widget <%== this.data.attr('class') %>" style="overflow: visible; width: 200px; height: 200px;" id="<%= this.data.attr('wid') %>"></div>
                                         <% vis.binds['canvas-gauges'].gauge(this.view, this.data, 'radial'); %>
                                      </script>
                                      <script id="tplCGCompas"
                                             type="text/ejs"
                                             class="vis-tpl"
                                             data-vis-name="Compas"
                                             data-vis-prev='<img src="widgets/canvas-gauges/img/prev/Prev_cgCompas.png"></img>'
                                             data-vis-attrs="oid/id/changedId;minValue[0];maxValue[360];units;title;factor[1];valueOffset[0];hCount[1]/slider,0,20,1;"
                                             data-vis-attrs1="group.ticks;majorTicks[N,NE,E,SE,S,SW,W,NW,N];minorTicks[22]/slider,0,20,1;strokeTicks[false]/checkbox;majorTicksInt/slider,0,10,1;majorTicksDec/slider,0,10,1;"
                                             data-vis-attrs2="group.animation;animation[true]/checkbox;animationDuration[1000]/slider,0,2000,50;animationRule/select,linear,quad,quint,cycle,bounce,elastic,dequad,dequint,decycle,debounce,delastic;animatedValue/checkbox;animateOnInit/checkbox;animationTarget/select,needle,plate;"
                                             data-vis-attrs3="group.colorsGauge;colorPlate[#222]/color;colorPlateEnd/color;colorMajorTicks[#f5f5f5]/color;colorMinorTicks[#ddd]/color;colorTitle/color;colorUnits/color;colorNumbers[#ccc]/color;colorNeedle[rgba(240,128,128,1)]/color;colorNeedleEnd[rgba(255,160,122,.9)]/color;colorValueText/color;colorValueTextShadow/color;colorBorderShadow/color;colorBorderOuter[#ccc]/color;colorBorderOuterEnd[#ccc]/color;colorBorderMiddle/color;colorBorderMiddleEnd/color;colorBorderInner/color;colorBorderInnerEnd/color;colorValueBoxRect/color;colorValueBoxRectEnd/color;colorValueBoxBackground/color;colorValueBoxShadow/color;colorNeedleShadowUp/color;colorNeedleShadowDown[#222]/color;"
                                             data-vis-attrs4="group.needle;needle/checkbox;needleShadow/checkbox;needleType[line]/select,arrow,line;needleStart[75]/slider,0,100,1;needleEnd[99]/slider,0,100,1;needleWidth[3]/slider,0,50,1;"
                                             data-vis-attrs5="group.borders;borders[true]/checkbox;borderOuterWidth[10]/slider,0,20,1;borderMiddleWidth[0]/slider,0,20,1;borderInnerWidth[0]/slider,0,20,1;borderShadowWidth[0]/slider,0,20,1;"
                                             data-vis-attrs6="group.valueBox;valueBox[false]/checkbox;valueBoxStroke/slider,0,20,1;valueText;valueTextShadow[false]/checkbox;valueBoxBorderRadius/slider,0,20,1;valueInt/slider,0,20,1;valueDec/slider,0,20,1;"
                                             data-vis-attrs11="group.gaugeRadial;ticksAngle[360]/slider,0,360,1;startAngle[180]/slider,0,360,1;"
                                             data-vis-attrs12="group.colorsRadial;colorNeedleCircleOuter[#ccc]/color;colorNeedleCircleOuterEnd/color;colorNeedleCircleInner/color;colorNeedleCircleInnerEnd/color;"
                                             data-vis-attrs13="group.needleRadial;needleCircleSize[15]/slider,0,200,1;needleCircleInner/checkbox;needleCircleInner/checkbox;needleCircleOuter[false]/checkbox;"
                                      </script>
                                      <script id="tplCGflatGauge"
                                             type="text/ejs"
                                             class="vis-tpl"
                                             data-vis-name="Flat"
                                             data-vis-prev='<img src="widgets/canvas-gauges/img/prev/Prev_cgFlat.png"></img>'
                                             data-vis-attrs1="group.ticks;majorTicks/slider,0,20,1;minorTicks[10]/slider,0,20,1;strokeTicks[true]/checkbox;majorTicksInt/slider,0,10,1;majorTicksDec/slider,0,10,1;"
                                             data-vis-attrs3="group.colorsGauge;colorPlate[#fff]/color;colorPlateEnd/color;colorMajorTicks/color;colorMinorTicks/color;colorTitle/color;colorUnits/color;colorNumbers/color;colorNeedle[red]/color;colorNeedleEnd[rgba(255,0,0,0.7)]/color;colorValueText/color;colorValueTextShadow/color;colorBorderShadow/color;colorBorderOuter/color;colorBorderOuterEnd/color;colorBorderMiddle/color;colorBorderMiddleEnd/color;colorBorderInner/color;colorBorderInnerEnd/color;colorValueBoxRect/color;colorValueBoxRectEnd/color;colorValueBoxBackground/color;colorValueBoxShadow/color;colorNeedleShadowUp/color;colorNeedleShadowDown/color;"
                                             data-vis-attrs4="group.needle;needle/checkbox;needleShadow/checkbox;needleType[line]/select,arrow,line;needleStart/slider,0,100,1;needleEnd/slider,0,100,1;needleWidth[3]/slider,0,50,1;"
                                             data-vis-attrs5="group.borders;borders[false]/checkbox;borderOuterWidth[0]/slider,0,20,1;borderMiddleWidth[0]/slider,0,20,1;borderInnerWidth[0]/slider,0,20,1;borderShadowWidth[0]/slider,0,20,1;;"
                                             data-vis-attrs11="group.gaugeBar;barBeginCircle[0]/slider,0,360,1;barWidth[5]/slider,0,50,1;barLength/slider,0,100,1;barStrokeWidth/slider,0,50,0;barProgress[true]/checkbox;"
                                             data-vis-attrs12="group.colorsBar;colorBarStroke/color;colorBar/color;colorBarEnd/color;colorBarProgress[#db9994]/color;colorBarProgressEnd/color;"
                                             data-vis-attrs13="group.positions;tickSide[left]/select,both,left,right;needleSide[left]/select,both,left,right;numberSide[left]/select,both,left,right;"
                                             data-vis-attrs14="group.ticksBar;ticksWidth[50]/slider,0,50,1;ticksWidthMinor[15]/slider,0,50,1;ticksPadding/slider,0,50,1;"
                                         <div class="vis-widget <%== this.data.attr('class') %>" style="overflow: visible; width: 360px; height: 100px;" id="<%= this.data.attr('wid') %>"></div>
                                      </script>
                                      rouggio created this issue in Mikhus/canvas-gauges
                                      open Firefox - Most gauges layout breaking after a few seconds #251
                                      K 1 Reply Last reply Reply Quote 3
                                        Alternativ vielleicht die rgraph gauge
                                          @oliverio
                                          moin und THX, läuft, seit heute morgen fehlerfrei!
                                          Gute Vorgabe der einzelnen Schritte.
                                          thomas
                                            kgw @Homoran last edited by
                                            @homoran sagte in VIS Anzeige "gevierteilt":
                                            rgraph gauge
                                            thx,
                                            Anzeige ist auch OK, und wäre ein Ersatz für das Fehlerwidget.
                                            1791
