    4. JavaScript
    5. Benötige Programmierhilfe Javascript
      Rushmed Most Active @OliverIO last edited by Rushmed
      @oliverio Ich habe jetzt für jeden Befehl deine Vorschläge für Funktion und Logik zusammengesetzt.
      Hattest du dir das so gedacht?
      Bspw.:
      var net = require('net');
      function sendMessage(host, port, message) {
       var timeout = 1000;
       return new Promise((resolve, reject) => {
         var client = new net.Socket();
         client.connect(port, host, function() {
           //console.log('Connected');
           client.setTimeout(timeout);
           client.write(message);
         client.on('data', function(data) {
           console.log('Received: ' + data);
           resolve(data.toString());
         client.on("error",(err)=>{
           resolve(err);
         client.on("timeout",()=>{
           resolve("timeout");
      sendMessage('192.168.178.149', 2785, 'C;Garagentor;open')
        var dp1 = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor";
        var dp2 = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht";
        var open      = await sendMessage("192.168.178.149",2785,"'S;Garagentor;open");
        var closed    = await sendMessage("192.168.178.149",2785,"'S;Garagentor;closed");
        var opening = await sendMessage("192.168.178.149",2785,"'S;Garagentor;opening");
        var closing  = await sendMessage("192.168.178.149",2785,"'S;Garagentor;closing");
        var lighton  = await sendMessage("192.168.178.149",2785,"'S;Garagentor;lightOn");
      if (open=="OK") {
        setState(dp1,"open");
      if (closed    =="OK") {
        setState(dp1,"closed");
      if (opening =="OK") {
        setState(dp1,"opening");
      if (closing =="OK") {
        setState(dp1,"closing");
      if (lighton =="OK") {
        setState(dp2,"An");
      } else {
        setState(dp2,"Aus");
      Damit kann ich alles schalten und die Antworten werden empfangen und im Log angezeigt.
      javascript.0
      2022-08-28 18:59:59.566	info	script.js.Garage_orig: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.564	info	script.js.Garage_orig: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.563	info	script.js.Garage_orig: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.562	info	script.js.Garage_orig: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.516	info	script.js.Garage_orig: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.515	info	script.js.Garage_orig: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.514	info	script.js.Garage_orig: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.513	info	script.js.Garage_orig: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.512	info	script.js.Garage_orig: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.511	info	script.js.Garage_orig: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.510	info	script.js.Garage_orig: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.510	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.509	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.507	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.506	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.505	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.504	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.503	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.502	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.501	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.500	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.499	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.438	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.437	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.436	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.435	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.434	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.433	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.432	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.431	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.430	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.424	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.423	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.422	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.421	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.420	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.419	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.417	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.416	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.415	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.414	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.376	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.375	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.374	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.373	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.372	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.371	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.358	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.357	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.356	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.355	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.354	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.353	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.352	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.351	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.350	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.348	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.347	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.346	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.345	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.344	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.343	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.342	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.331	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.330	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.329	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.328	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.327	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.326	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.325	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.324	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.323	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.322	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.318	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.317	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.316	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.315	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.314	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.312	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.311	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.310	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.285	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.284	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.283	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.282	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.281	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.280	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.279	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.277	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.276	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.275	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.271	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.270	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.269	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.268	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.267	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      2022-08-28 18:59:59.266	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:59.262	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.261	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      2022-08-28 18:59:59.260	info	script.js.Garage1: Received: S;Garagentor;closed
      javascript.0
      2022-08-28 18:59:49.199	info	script.js.Garage_orig: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.198	info	script.js.Garage_orig: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.197	info	script.js.Garage_orig: Received: S;Garagentor;closing
      javascript.0
      javascript.0
      2022-08-28 18:59:49.196	info	script.js.Garage_orig: Received: S;Garagentor;closing
      javascript.0
      javascript.0
      2022-08-28 18:59:49.195	info	script.js.Garage_orig: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.194	info	script.js.Garage_orig: Received: S;Garagentor;closing
      javascript.0
      javascript.0
      2022-08-28 18:59:49.193	info	script.js.Garage_orig: Received: S;Garagentor;closing
      javascript.0
      javascript.0
      2022-08-28 18:59:49.191	info	script.js.Garage_orig: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.190	info	script.js.Garage_orig: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.189	info	script.js.Garage_orig: Received: S;Garagentor;closing
      javascript.0
      javascript.0
      2022-08-28 18:59:49.188	info	script.js.Garage_orig: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.187	info	script.js.Garage_orig: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.186	info	script.js.Garage_orig: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.185	info	script.js.Garage_orig: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.184	info	script.js.Garage1: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.183	info	script.js.Garage1: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.180	info	script.js.Garage1: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.179	info	script.js.Garage1: Received: S;Garagentor;closing
      javascript.0
      javascript.0
      2022-08-28 18:59:49.178	info	script.js.Garage1: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.177	info	script.js.Garage1: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.175	info	script.js.Garage1: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.174	info	script.js.Garage1: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.172	info	script.js.Garage1: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.171	info	script.js.Garage1: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.170	info	script.js.Garage1: Received: S;Garagentor;closing
      javascript.0
      javascript.0
      2022-08-28 18:59:49.130	info	script.js.Garage1: Received: S;Garagentor;closing
      javascript.0
      javascript.0
      2022-08-28 18:59:49.126	info	script.js.Garage1: Received: S;Garagentor;closing
      javascript.0
      javascript.0
      2022-08-28 18:59:49.125	info	script.js.Garage1: Received: S;Garagentor;closing
      javascript.0
      javascript.0
      2022-08-28 18:59:49.122	info	script.js.Garage1: Received: S;Garagentor;closing
      javascript.0
      2022-08-28 18:59:49.121	info	script.js.Garage1: Received: S;Garagentor;closing
      javascript.0
      javascript.0
      Die Datenpunkte sind aber nur einmal am Anfang beschrieben worden und dann nicht mehr.
      Was bedeutet:
      @oliverio sagte in Benötige Programmierhilfe Javascript:
      Der Rückgabewert der Funktion sendMessage ist dann timeou
      • OliverIO
        OliverIO @Rushmed last edited by
        @rushmed
        Das Skript ist nur dafür da den Status abzufragen
        Das steuern machen wir wenn das funktioniert
        Du hast die beiden Teile korrekt zusammen kopiert
        Eine Zeile die du selbst hinzugefügt hast muss noch raus. Ist aber für den Test nicht so schlimm.
        Das Skript ist erst mal so gedacht das einmalig der Status ermittelt wird. Durch wiederholten Aufruf in einem noch zu wählenden Zeitabstand aktualisiert es dann regelmäßig.
        Am log finde ich aktuell noch komisch das sehr viele gleiche Einträge in sehr kurzer Zeit hintereinander steht
        Um das zu überprüfen kannst du bitte noch den Client connect Teil mit dem folgenden tauschen
        Eine Zeile davon habe ich angepasst.
        Dann bitte das Script genau einmal laufen lassen und das Ergebnis hier wieder posten.
             console.log('send: ' + message);
          @oliverio Habe meine Message raus genommen und deine Anpassung einegfügt.
          Funktion jetz wie folgt:
           var timeout = 1000;
               resolve(err);
               resolve("timeout");
          if (open=="OK") {
            setState(dp2,"An");
          } else {
          Hier das Ergebnis:
          21:36:43.129	info	javascript.0 (2205415) script.js.Garage_orig: send: 'S;Garagentor;open
          21:36:44.154	info	javascript.0 (2205415) script.js.Garage_orig: send: 'S;Garagentor;closed
          21:36:45.176	info	javascript.0 (2205415) script.js.Garage_orig: send: 'S;Garagentor;opening
          21:36:46.194	info	javascript.0 (2205415) script.js.Garage_orig: send: 'S;Garagentor;closing
          21:36:47.206	info	javascript.0 (2205415) script.js.Garage_orig: send: 'S;Garagentor;lightOn
          Damit kommt nichts zurück. Ich der Status wird nur nach dem Senden der Steuerbefehle gesandt.
          Bei 5 s Timeout passiert auch nichts.
          Wenn ich die Message einfüge kommt die Antwort nach etwa 3 s.
          OliverIO 2 Replies Last reply Reply Quote 0
          • OliverIO
            OliverIO @Rushmed last edited by OliverIO
            @rushmed
            Füge bitte deinen steuerbefehl nochmal ein, führe das Skript aus und sende mir dann nochmal das log.
            Wie du vermutest wird der Status wohl nur beim senden eines Befehls zurück gesendet.
            Aber mal schauen was da steht
            Wahrscheinlich muss man dann das Skript nochmal umstellen
            • OliverIO
              @rushmed
              Kannst du bitte überall noch diesen Apostroph vor dem S; entfernen?
              Das gehört da evtl nicht hin
                @oliverio Bitteschön:
                22:41:54.703	info	javascript.0 (2205415) script.js.Garage_orig: send: C;Garagentor;lightOn
                22:41:54.705	info	javascript.0 (2205415) script.js.Garage_orig: send: S;Garagentor;open
                22:41:54.744	info	javascript.0 (2205415) script.js.Garage_orig: Received: R;OK
                22:41:55.074	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.075	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.076	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.077	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.078	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.079	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.080	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.081	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.082	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.083	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.084	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.085	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.086	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.120	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.121	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.122	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.123	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.124	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.125	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.126	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.127	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.130	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.131	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.132	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.133	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.134	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.135	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.136	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.137	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.138	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.141	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.142	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.143	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.144	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.145	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.146	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
                22:41:55.163	info	javascript.0 (2205415) script.js.Garage_orig: send: S;Garagentor;closed
                22:42:00.169	info	javascript.0 (2205415) script.js.Garage_orig: send: S;Garagentor;opening
                22:42:05.178	info	javascript.0 (2205415) script.js.Garage_orig: send: S;Garagentor;closing
                22:42:10.183	info	javascript.0 (2205415) script.js.Garage_orig: send: S;Garagentor;lightOn
                • OliverIO
                  @rushmed sagte in Benötige Programmierhilfe Javascript:
                  OK
                  ok, und dann bitte jeweils einen durchlauf wo du von licht an nach licht aus umschaltest
                  und umgekehrt
                  und dann jeweils einen durchlauf bei dem du das garagentor von geschlossen nach offen
                  und offen nach geschlossen durchführst
                  aber nur bei Gelegenheit, nicht das sich die Nachbarn wundern warum die Garage immer auf und zu geht 🙂
                  Die erste Erkenntnis ist. Das senden des S-Befehls hat gar keine Auswirkung,
                  sondern wird als Antwort auf den jeweilig passenden Befehl als Antwort gesendet
                  Die Bbestätigung wird nach ca 40ms gesendet
                  ca 300ms danach wird
                  zunächst für ca 15ms im Abstand von ca 0.5ms der Status gesendet.
                  dann 35ms gewartet und nochmal
                  für ca 25ms lang erneut der Status im Abstand von 0.5ms gesendet.
                  Schauen wir mal was die nächsten Ergebnisse bringen, so das ich dann den Code anpassen kann.
                    @oliverio Wir müssen bitte nochmal einen Schritt zurück. Ich glaube die mehrfachen Rückmeldungen liegen daran wie ich das ganze hier im Blockly zusammegefriemelt habe und triggere. Ich habe so garkeine Ahnung von Javascript, dass ich ein Script nichtmal über nen DP Starten kann.
                    Habe diese Datenpunkte zur Steuerung als boolsche Buttons angelegt:
                    0_userdata.0.Eigene_Datenpunkte.Garage.Garage_close
                    0_userdata.0.Eigene_Datenpunkte.Garage.Garage_open
                    0_userdata.0.Eigene_Datenpunkte.Garage.Garage_stop
                    0_userdata.0.Eigene_Datenpunkte.Garage.Garage_light_on
                    0_userdata.0.Eigene_Datenpunkte.Garage.Garage_light_off
                    Diese müssen mit:
                    sendMessage('192.168.178.149', 2785, 'C;Garagentor;close')
                    sendMessage('192.168.178.149', 2785, 'C;Garagentor;stop')
                    sendMessage('192.168.178.149', 2785, 'C;Garagentor;lightOn')
                    sendMessage('192.168.178.149', 2785, 'C;Garagentor;lightOff')
                    gesteuert werden.
                    Kannst du mir das bitte in ein Script packen?
                    • OliverIO
                      @rushmed
                      wie blockly. bei blockly muss dir jemand anders helfen
                      Wir zusammen werden nix mit Blockly machen
                      Alle notwendigen Anweisungen stehen schon im skript drin.
                      ich beschreibe dir mal kleinklein was du machen musst
                      1. javascriptadapter öffnen
                      2. Neues Skript hinzufügen, also Plus-Knopf oben links
                      3. Dann die JS-Kachel auswählen
                      4. einen sinnigen Namen vergeben
                      5. Das Javascript aus dem Spoiler dort einfügen
                      6. Beim Werkzeugschlüssel oben rechts verbose ankreuzen
                      In Zeile 25 steht schon mal der Befehl für öffnen drin, das heißt, bevor du das Skript ausführst,
                      schaust du, das das Tor geschlossen ist
                      1. Speichern und falls das Skript nicht von alleine losgelaufen ist, auf der linken Seite beim Skriptnamen das rote Play-Symbol anklicken (rotes Dreieck)
                      2. Danach das log kopieren und hier im Thread anfügen
                      3. Zeile 8 mit dem nächsten Befehl bestücken. Aktuell interessiert nur der Statusübergang von Open nach Close und von Close nach Open und LightAn nach LightAus und LightAus nach LightAn
                      var timeout = 1000;
                          resolve(err);
                          resolve("timeout");
                      if (open=="OK") {
                       setState(dp2,"An");
                      } else {
                        @oliverio Ok, danke für deine Geduld!
                        Ich habe garnicht den Anspruch die Lösung als Blockly zu haben. Das ist nur leider die einzige möglichkeit mit der ich mir selbst helfen kann. Ohne Blockly hätte ich wohl nie den Einstieg zu ioBroker gefunden.
                        Da steht doch lightOn oder sehe ich den falschen Spoiler?
                        Du meinst sicher Zeile 25 oder sehe ich wirklich den falschen Spoiler?
                        Ich fange bei ausgeschaltetem Lich mit light on an.
                        So sieht das Script aus, entsprechend ändere ich im Folgenen nur den Befehl:
                        var timeout = 1000;
                            resolve(err);
                            resolve("timeout");
                        sendMessage('192.168.178.149', 2785, 'C;Garagentor;lightOn');
                        if (open=="OK") {
                         setState(dp2,"An");
                        } else {
                        Ergebnis Licht an:
                        29.8.2022, 19:30:37.485	[info ]: javascript.0 (4086398) Stop script script.js.Garage_
                        29.8.2022, 19:30:37.511	[info ]: javascript.0 (4086398) Start javascript script.js.Garage_
                        29.8.2022, 19:30:37.519	[info ]: javascript.0 (4086398) script.js.Garage_: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        29.8.2022, 19:30:37.537	[info ]: javascript.0 (4086398) script.js.Garage_: send: C;Garagentor;lightOn
                        29.8.2022, 19:30:37.539	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;open
                        29.8.2022, 19:30:37.584	[info ]: javascript.0 (4086398) script.js.Garage_: Received: R;OK
                        29.8.2022, 19:30:37.893	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.894	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.895	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.896	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.897	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.898	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.899	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.900	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.901	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.902	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.903	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.904	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.905	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.906	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.907	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.921	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.922	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.923	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.924	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.925	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.926	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.927	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.928	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.929	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.930	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.931	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.932	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.933	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.934	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.935	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.955	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.957	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.958	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.960	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.961	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.962	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.963	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.964	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.965	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.966	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.967	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.968	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.969	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.970	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.971	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.973	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.974	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.975	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.976	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.977	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.978	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.979	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.980	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:30:37.990	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closed
                        29.8.2022, 19:30:39.003	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;opening
                        29.8.2022, 19:30:40.012	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closing
                        29.8.2022, 19:30:41.020	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;lightOn
                        29.8.2022, 19:30:42.021	[info ]: javascript.0 (4086398) script.js.Garage_: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"Aus","ack":false,"ts":1661794242020,"q":0,"from":"system.adapter.javascript.0","lc":1661692880511,"c":"script.js.Garage_"})
                        Ergebnis Licht aus:
                        29.8.2022, 19:31:39.374	[info ]: javascript.0 (4086398) Stop script script.js.Garage_
                        29.8.2022, 19:31:39.449	[info ]: javascript.0 (4086398) Start javascript script.js.Garage_
                        29.8.2022, 19:31:39.455	[info ]: javascript.0 (4086398) script.js.Garage_: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        29.8.2022, 19:31:39.467	[info ]: javascript.0 (4086398) script.js.Garage_: send: C;Garagentor;lightOff
                        29.8.2022, 19:31:39.468	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;open
                        29.8.2022, 19:31:39.516	[info ]: javascript.0 (4086398) script.js.Garage_: Received: R;OK
                        29.8.2022, 19:31:39.995	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:39.996	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:39.997	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:39.998	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:39.999	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.000	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.001	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.002	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.003	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.005	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.008	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.009	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.010	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.011	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.012	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.013	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.014	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.015	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.016	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.017	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.018	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.019	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.028	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.029	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.030	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.031	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.032	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.033	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.034	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.035	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.036	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.037	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.039	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.040	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.041	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.042	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.043	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.044	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.045	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.046	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.047	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.048	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.049	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.050	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.051	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.052	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.053	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.054	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.055	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.056	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.057	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.058	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.059	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                        29.8.2022, 19:31:40.069	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closed
                        29.8.2022, 19:31:41.085	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;opening
                        29.8.2022, 19:31:42.099	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closing
                        29.8.2022, 19:31:43.120	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;lightOn
                        29.8.2022, 19:31:44.121	[info ]: javascript.0 (4086398) script.js.Garage_: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"Aus","ack":false,"ts":1661794304121,"q":0,"from":"system.adapter.javascript.0","lc":1661692880511,"c":"script.js.Garage_"})
                        Ergebnis open (von geschlossen bis voll auf gefahren):
                        29.8.2022, 19:33:21.225	[info ]: javascript.0 (4086398) Stop script script.js.Garage_
                        29.8.2022, 19:33:21.289	[info ]: javascript.0 (4086398) Start javascript script.js.Garage_
                        29.8.2022, 19:33:21.295	[info ]: javascript.0 (4086398) script.js.Garage_: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        29.8.2022, 19:33:21.312	[info ]: javascript.0 (4086398) script.js.Garage_: send: C;Garagentor;open
                        29.8.2022, 19:33:21.313	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;open
                        29.8.2022, 19:33:21.342	[info ]: javascript.0 (4086398) script.js.Garage_: Received: R;OK
                        29.8.2022, 19:33:21.746	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.747	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.748	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.749	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.752	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.753	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.754	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.755	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.756	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.757	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.758	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.759	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.760	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.768	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.769	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.770	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.771	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.772	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.773	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.775	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.776	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.781	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.782	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.783	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.785	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.786	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.787	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.788	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.789	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.790	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.791	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.792	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.793	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.794	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.811	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.812	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.813	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.814	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.815	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.816	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.817	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                        29.8.2022, 19:33:21.829	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closed
                        29.8.2022, 19:33:21.903	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.904	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.905	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.906	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.907	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.908	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.921	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.922	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.924	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.925	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.926	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.927	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.928	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.929	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.930	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.931	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.932	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.933	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.935	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.936	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.937	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.938	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.939	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.940	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.941	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.942	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:21.943	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:22.000	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:22.001	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:22.002	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:22.003	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:22.004	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                        29.8.2022, 19:33:22.844	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;opening
                        29.8.2022, 19:33:23.858	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closing
                        29.8.2022, 19:33:24.867	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;lightOn
                        29.8.2022, 19:33:25.868	[info ]: javascript.0 (4086398) script.js.Garage_: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"Aus","ack":false,"ts":1661794405868,"q":0,"from":"system.adapter.javascript.0","lc":1661692880511,"c":"script.js.Garage_"})
                        29.8.2022, 19:33:38.837	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.838	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.841	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.844	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.845	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.846	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.847	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.848	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.849	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.850	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.851	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.852	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.853	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.854	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.855	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.856	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.857	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.858	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.882	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.883	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.884	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.885	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.886	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.887	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.888	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.889	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.891	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.892	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.893	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.894	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.895	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.896	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.897	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.933	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.934	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.937	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.938	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.940	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.941	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.942	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        29.8.2022, 19:33:38.943	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                        Schließen (von ganz offen bis geschlossen):
                        29.8.2022, 19:34:32.115	[info ]: javascript.0 (4086398) Stop script script.js.Garage_
                        29.8.2022, 19:34:32.186	[info ]: javascript.0 (4086398) Start javascript script.js.Garage_
                        29.8.2022, 19:34:32.195	[info ]: javascript.0 (4086398) script.js.Garage_: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        29.8.2022, 19:34:32.201	[info ]: javascript.0 (4086398) script.js.Garage_: send: C;Garagentor;close
                        29.8.2022, 19:34:32.203	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;open
                        29.8.2022, 19:34:32.237	[info ]: javascript.0 (4086398) script.js.Garage_: Received: R;OK
                        29.8.2022, 19:34:32.730	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.731	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.732	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.741	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.742	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.743	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.744	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.745	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.747	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.748	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.749	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.750	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.751	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.752	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.753	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.754	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.755	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.756	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.757	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.758	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.759	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.760	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.762	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.763	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.764	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.765	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.766	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.772	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.773	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.774	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.775	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.776	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.777	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.778	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.779	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.780	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.781	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.782	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.783	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.784	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.785	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.786	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.787	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.788	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.789	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.800	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.801	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.802	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.803	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.804	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.805	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.806	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.807	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.808	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.809	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                        29.8.2022, 19:34:32.823	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closed
                        29.8.2022, 19:34:33.830	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;opening
                        29.8.2022, 19:34:34.842	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closing
                        29.8.2022, 19:34:35.851	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;lightOn
                        29.8.2022, 19:34:36.851	[info ]: javascript.0 (4086398) script.js.Garage_: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"Aus","ack":false,"ts":1661794476851,"q":0,"from":"system.adapter.javascript.0","lc":1661692880511,"c":"script.js.Garage_"})
                        29.8.2022, 19:34:51.245	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.246	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.248	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.249	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.250	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.251	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.252	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.253	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.255	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.256	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.257	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.258	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.259	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.260	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.261	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.286	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.287	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.288	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.289	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.290	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.291	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.292	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.293	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.294	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.297	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.298	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.299	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.300	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.301	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.302	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.303	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.306	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.307	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.308	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.309	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.310	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.311	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.312	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.313	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.314	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.315	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        29.8.2022, 19:34:51.363	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                        Wenn ich während der Fahrt stop sende bleibt der letzte Status entsprechend bei opening oder closing stehen.
                          Rushmed Most Active @Rushmed last edited by Rushmed
                          @OliverIO Supergeil an dem was du da gebaut hast ist dass auch antworten aufgefangen werden wenn ich das Tor per App schalte:
                          lightOff:
                          29.8.2022, 19:46:19.614	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.615	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.616	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.626	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.627	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.628	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.629	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.630	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.631	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.632	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.633	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.634	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.635	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.636	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.637	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.638	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.641	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.642	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.643	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.644	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.645	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.646	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.647	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.648	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.649	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.650	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.681	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.682	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.683	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.684	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.685	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.686	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.687	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.688	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.730	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.731	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.732	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.733	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.734	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.736	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.738	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 19:46:19.739	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                          lightOn:
                          29.8.2022, 19:47:13.784	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.785	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.786	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.787	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.793	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.794	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.795	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.796	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.798	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.799	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.800	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.802	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.803	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.804	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.805	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.806	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.807	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.808	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.809	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.815	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.816	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.817	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.818	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.819	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.820	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.821	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.822	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.823	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.824	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.825	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.826	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.828	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.829	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.830	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.831	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.832	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.833	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.834	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.835	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.836	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.837	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.840	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.841	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.842	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.843	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.851	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.852	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.854	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.855	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.856	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.858	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.859	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.860	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.864	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.865	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.866	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.867	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.868	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.869	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.873	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.874	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.875	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 19:47:13.876	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                          open:
                          29.8.2022, 19:47:42.848	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.849	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.851	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.852	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.853	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.854	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.855	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.856	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.857	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.858	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.867	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.868	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.869	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.870	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.872	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.874	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.875	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.876	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.877	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.878	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.879	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.880	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.881	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.882	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.900	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.901	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.902	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.903	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.904	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.905	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.907	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.908	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.909	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.910	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.911	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.912	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.913	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.914	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:42.915	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 19:47:59.485	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.486	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.490	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.491	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.492	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.493	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.494	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.497	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.498	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.499	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.500	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.501	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.502	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.503	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.513	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.514	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.515	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.516	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.517	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.518	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.520	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.521	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.522	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.523	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.524	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.525	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.526	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.527	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.528	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.529	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.530	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.531	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.532	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.575	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.576	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.577	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.578	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.579	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.580	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.581	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.582	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          29.8.2022, 19:47:59.583	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                          close:
                          29.8.2022, 19:49:14.834	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.835	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.836	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.837	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.838	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.839	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.840	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.841	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.864	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.865	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.866	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.867	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.868	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.869	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.870	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.871	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.872	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.873	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.874	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.875	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.925	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.926	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.927	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.928	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.929	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.930	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.931	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.932	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.933	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:14.934	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 19:49:33.015	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.016	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.017	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.018	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.019	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.020	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.021	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.022	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.023	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.025	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.026	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.027	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.029	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.030	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.031	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.032	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.033	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.034	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.045	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.046	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.047	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.048	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.049	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.050	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.051	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.052	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.053	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.054	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.055	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.056	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.057	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.058	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.059	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.060	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.061	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.062	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.063	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.064	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.065	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.066	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.067	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.068	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.069	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.070	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.071	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.072	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.073	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.074	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.075	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.076	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.077	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.078	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.079	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.081	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.082	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.083	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.084	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.085	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.086	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.113	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.114	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.115	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.116	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.118	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.119	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.120	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.121	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.122	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.123	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 19:49:33.124	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                          Die Anzahl der Rückmeldungen wird mit jedem Neustart des Scripts mehr.
                          Wenn ich den Steuerbefehl auskommentiere, dann die JS Instanz neu starte und die Befehle nacheinander per App sende kommt jede Antwort fünf mal.
                          29.8.2022, 20:03:31.119	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 20:03:31.121	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 20:03:31.122	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 20:03:31.123	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 20:03:31.124	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOff
                          29.8.2022, 20:03:35.179	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 20:03:35.180	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 20:03:35.181	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 20:03:35.182	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 20:03:35.184	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOn
                          29.8.2022, 20:03:40.574	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 20:03:40.575	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 20:03:40.577	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 20:03:40.578	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;opening
                          29.8.2022, 20:04:02.662	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 20:04:02.663	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;closing
                          29.8.2022, 20:04:10.122	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 20:04:10.123	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;closed
                          29.8.2022, 20:04:10.124	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;closed
                          • OliverIO
                            OliverIO @Rushmed last edited by
                            @rushmed
                            ok, das sieht erst mal gut aus.
                            im script ist so ein kleiner tcp-client enthalten. evtl beende ich ihn noch nicht richtig,
                            daher kann sein, das mit jedem scriptstart ein neuer client im hintergrund gestartet wird, der sich dann auch jedesmal meldet.
                            das reparieren noch
                            durch die logs hat sich aber bestätigt, was ich vermutet habe. daher werde ich das skript nochmal umstellen.
                            ich werde auch die einfache Möglichkeit für dich einabauen, Befehle zu geben durch einfaches beschreiben eines Datenpunkts.
                            Das ist dann so wie ein kleiner Adapter.
                            Werde ich heute aber nicht wirklich dazukommen.
                            Mit dem neuen Skript machen wir dann neue Testreihen.
                              Rushmed Most Active @OliverIO last edited by
                              @oliverio Sehr geil!
                              Bin eben noch zur Garage gelaufen und habe Handsender und Taster am Antrieb getestet.
                              Bei beiden bekomme ich die gleichen Rückmeldungen wie hier:
                              @rushmed sagte in Benötige Programmierhilfe Javascript:
                              Damit habe ich egal wie gesteuert wird immer den aktuellen Status im ioBroker. Das wird fantastisch!
                              • OliverIO
                                ja, leider hat man den status nur, wenn ein befehl ausgeführt wird.
                                bei iobroker neustart oder wenn das skript gerade nicht läuft sird es den status nicht mitbekommen
                                  @oliverio Ja, das Stimmt wohl aber meine ioBroker hat echt wenig Downtime.
                                  • OliverIO
                                    OliverIO @Rushmed last edited by OliverIO
                                    @rushmed
                                    so hier ein neues skript mit einigen Neuerungen
                                    1. wie gehabt, das eine bisherige skript komplett ersetzen
                                    2. ich habe für die befehle einen neuen Datenpunkt eingeführt, den du anlegen musst. Typ Zeichenkette: 0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command
                                      Falls die Namen nicht passen, dann im Skript Zeile 3-5 anpassen
                                    3. Zeilen 7-9 ggfs ebenfalls anpassen. Z7 ist der Gerätename deines Tors, Z8-9 die Verbindungsparameter
                                    4. Wenn Datenpunt(e) angelegt sind und das Skript läuft (da dürfte erst einmal nix im log kommen), dann iobroker in einem 2.browserfenster öffnen
                                    5. im 2.Fenster auf den Objekte-Tab gehen im Datenpunkt 0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command
                                      einen der folgenden Befehle eingeben: open, close, stop, lighton, lightoff
                                      Groß/Kleinschreibung ist egal
                                    6. sobald du eingegeben hast, müsste der Datenpunkt automatisch sich wieder auf leer stellen
                                    7. und im log im 1.browserfenster eine Menge Ausgaben erscheinen. Zum Test habe ich mal für jeden Detailschritt im Programm etwas eingebaut. Später kann man das wieder entfernen oder auskommentieren.
                                    8. Als Test machen wir das selbe wie das letzte mal
                                      -> Tor offen, dann Befehl close eingeben
                                      -> Tor geschlossen, dann open eingeben
                                      -> Licht ist an, dann lightoff eingeben
                                      -> Licht ist aus, dann lighton eingeben
                                    ich habe mal die verschiedenen javascripot zeilen kommentiert, damit du nachvollziehen kannst was da so passiert
                                    var net = require('net');
                                    var dp_door = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor"; //door state
                                    var dp_light = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht"; //light state
                                    var dp_cmd = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command"; //Befehlsdatenpunkt: Mögliche Werte: open, close, stop, lighton, lightoff. Nach Beschreiben wird der Datenpunkt wieder auf leer gesetzt
                                    var deviceName = "Garagentor";
                                    var host = "192.168.178.149";
                                    var port = 2785;
                                    function sendMessage(host, port, message) {
                                     var timeout = 1000;                           //timeout für Antwort vom Server
                                     var time2termination = 1000;                  //genereller Timeout falls gar keine Reaktion mehr kommt
                                     var terminator;
                                     var terminatorStart;
                                     var terminatorEnd;
                                     return new Promise((resolve, reject) => {     // Funktion ist asynchron, daher Rückgabe promise
                                       var client = new net.Socket();                 // Erzeugen eines neuen Verbindungsobjekts
                                       client.connect(port, host, function() {     // Gerät über host:port anwählen und Verbindung erzeugen
                                         console.debug('cliend started');
                                         terminatorStart();                        // Time starten, der die Verbindung beendet, falls keine Antwort mehr kommt
                                         client.setTimeout(timeout);               // internes timeout setzen
                                         client.write(message);                    // Nachricht an Gerät senden
                                       client.on('data', function(data) {          // Wenn daten ankommen, dann verarbeiten
                                         console.log('client received: ' + data);
                                         terminatorStart();                        // Den Timeout verlängern
                                         var dataS = data.toString();              // Datenbuffer in lesbaren Text umwandeln
                                         switch(dataS) {                           // je nach rückgabewert unterschiedliche Bearbeitung
                                             case "S;"+deviceName+";open":         // wenn open
                                             setState(dp_door,"open");             // dann Datenpunkt setzen
                                             break;
                                             case "S;"+deviceName+";closed":
                                             setState(dp_door,"closed");
                                             break;
                                             case "S;"+deviceName+";opening":
                                             setState(dp_door,"opening");
                                             break;
                                             case "S;"+deviceName+";closing":
                                             setState(dp_door,"closing");
                                             break;
                                             case "S;"+deviceName+";lightOn":
                                             setState(dp_light,"lightOn");
                                             break;
                                             case "S;"+deviceName+";lightOff":
                                             setState(dp_light,"lightOff");
                                             break;
                                       client.on("error",(err)=>{                  // wenn ein Fehler entsteht
                                         console.log("client error");
                                         terminatorEnd();                          // dann timeout beenden
                                        client.end();                             // Kommunikation beenden
                                         resolve(err);                             // und Fehlerdetails zurückgeben
                                       client.on("timeout",()=>{                   // wenn timeout entsteht
                                         console.log("client timeout");
                                         resolve("timeout");                       // text timeout zurückgeben
                                       terminatorStart = function() {              // timeout starten oder verlängern
                                         console.log("client terminatorStart");
                                         if (terminator) clearTimeout(terminator); // evtl vorhanden timeout beenden
                                         terminator = setTimeout(() => {           // neuen timeout starten. wenn timeout eintritt, dann folgende funktionen ausführen
                                           console.log('cliend ended');
                                           client.end();                           // kommunikation beenden
                                           resolve("ok");                          // ok zurückgeben
                                         }, time2termination);                     // zeit für timeout angeben
                                       terminatorEnd = function() {                // timeout beenden
                                         console.log("client terminatorEnd");
                                    on(dp_cmd, function (obj) {                     // trigger wenn datenpunkt beschrieben wird
                                       var cmd;
                                       if (!obj.state.ack) {                       // aber nur wenn es sich um einen unbestätigten wert handelt
                                           cmd = String(obj.state.val).toLowerCase();  // Datenpunktinhalt in Kleinbuchstaben umwandeln
                                           console.debug('execute command: ' + cmd);
                                           switch(cmd) {                           // je nach Datenpunktinhalt verschiedene Befehle
                                               case "open":                        // wenn open
                                                   sendMessage(host, port, "C;"+deviceName+";open"); // dann richtigen Befehl an Gerät senden
                                                   break;
                                               case "close":
                                                   sendMessage(host, port, "C;"+deviceName+";close");
                                                   break;
                                               case "stop":
                                                   sendMessage(host, port, "C;"+deviceName+";stop");
                                                   break;
                                               case "lighton":
                                                   sendMessage(host, port, "C;"+deviceName+";lightOn");
                                                   break;
                                               case "lightoff":
                                                   sendMessage(host, port, "C;"+deviceName+";lightOff");
                                                   break;
                                           setState(obj.id, {val: "", ack: true}); // datenpunkt auf leer als bestätigt setzen
                                      Rushmed Most Active @OliverIO last edited by Rushmed
                                      @oliverio Vielen Dank, hier die Ausgaben:
                                      öffnen:
                                      30.8.2022, 18:15:36.287	[info ]: javascript.0 (853) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661876136287,"q":0,"from":"system.adapter.javascript.0","lc":1661876136287,"c":"script.js.Garage"})
                                      30.8.2022, 18:15:36.306	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                                      30.8.2022, 18:15:36.307	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                                      30.8.2022, 18:15:36.345	[info ]: javascript.0 (853) script.js.Garage: client received: R;OK
                                      30.8.2022, 18:15:36.345	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                                      30.8.2022, 18:15:36.346	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                                      30.8.2022, 18:15:36.347	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                                      30.8.2022, 18:15:36.610	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.611	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.613	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.614	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.616	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.617	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.618	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.619	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.620	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.624	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.625	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.635	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.636	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.637	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.638	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.639	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.640	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.641	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.643	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.644	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.645	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.646	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.647	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.648	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.649	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.652	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.653	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.654	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.655	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.656	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.657	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.658	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.659	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.660	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.670	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.671	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.672	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.673	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.674	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.675	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.676	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.677	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.678	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.679	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.680	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.681	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.682	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.688	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.688	[info ]: javascript.0 (853) script.js.Garage: client received: S;Garagentor;opening
                                      30.8.2022, 18:15:36.689	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                                      30.8.2022, 18:15:36.689	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                                      30.8.2022, 18:15:36.690	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                                      30.8.2022, 18:15:36.739	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.740	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.741	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.742	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.743	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.744	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.745	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.752	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.753	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.754	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.755	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.756	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.758	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.759	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.760	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.761	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.762	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.763	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.764	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.765	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.768	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.769	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.770	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.771	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.772	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.773	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.774	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.777	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.778	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.779	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.781	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.788	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.789	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.790	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.791	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.792	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.793	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.794	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.811	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.812	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.814	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.815	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.816	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.817	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.817	[info ]: javascript.0 (853) script.js.Garage: client received: S;Garagentor;lightOn
                                      30.8.2022, 18:15:36.818	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                                      30.8.2022, 18:15:36.818	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                                      30.8.2022, 18:15:36.818	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                                      30.8.2022, 18:15:37.817	[info ]: javascript.0 (853) script.js.Garage: client timeout
                                      30.8.2022, 18:15:37.818	[info ]: javascript.0 (853) script.js.Garage: client terminatorEnd
                                      30.8.2022, 18:15:37.818	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                                      30.8.2022, 18:15:53.301	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.302	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.303	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.304	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.305	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.306	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.308	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.309	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.310	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.311	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.313	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.322	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.323	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.324	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.325	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.326	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.327	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.328	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.331	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.332	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.333	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.334	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.335	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.336	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.337	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.338	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.339	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.340	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.341	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.342	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.344	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.346	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.347	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.348	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.381	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.382	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.383	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.384	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.386	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.387	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.389	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.390	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.391	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      30.8.2022, 18:15:53.392	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                                      close:
                                      30.8.2022, 18:17:56.379	[info ]: javascript.0 (853) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661876276379,"q":0,"from":"system.adapter.javascript.0","lc":1661876276379,"c":"script.js.Garage"})
                                      30.8.2022, 18:17:56.393	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                                      30.8.2022, 18:17:56.394	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                                      30.8.2022, 18:17:56.464	[info ]: javascript.0 (853) script.js.Garage: client received: R;OK
                                      30.8.2022, 18:17:56.465	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                                      30.8.2022, 18:17:56.465	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                                      30.8.2022, 18:17:56.465	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                                      30.8.2022, 18:17:56.707	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.708	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.709	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.710	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.711	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.721	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.722	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.723	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.724	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.725	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.726	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.727	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.728	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.729	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.730	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.733	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.734	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.735	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.736	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.741	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.742	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.743	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.744	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.746	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.747	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.748	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.749	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.750	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.751	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.752	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.753	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.754	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.755	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.757	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.758	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.759	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.760	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.761	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.761	[info ]: javascript.0 (853) script.js.Garage: client received: S;Garagentor;closing
                                      30.8.2022, 18:17:56.762	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                                      30.8.2022, 18:17:56.762	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                                      30.8.2022, 18:17:56.762	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                                      30.8.2022, 18:17:57.761	[info ]: javascript.0 (853) script.js.Garage: client timeout
                                      30.8.2022, 18:17:57.762	[info ]: javascript.0 (853) script.js.Garage: client terminatorEnd
                                      30.8.2022, 18:17:57.763	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                                      30.8.2022, 18:18:15.200	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.201	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.202	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.204	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.205	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.206	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.207	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.208	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.209	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.210	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.211	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.212	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.213	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.214	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.215	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.224	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.226	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.227	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.228	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.229	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.230	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.231	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.232	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.233	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.234	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.237	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.238	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.239	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.240	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.241	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.242	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.243	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.244	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.246	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.247	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.290	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.291	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.292	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.294	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.295	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      30.8.2022, 18:18:15.296	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                                      Licht an:
                                      30.8.2022, 18:19:35.737	[info ]: javascript.0 (853) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661876375737,"q":0,"from":"system.adapter.javascript.0","lc":1661876375737,"c":"script.js.Garage"})
                                      30.8.2022, 18:19:35.748	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                                      30.8.2022, 18:19:35.749	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                                      30.8.2022, 18:19:36.042	[info ]: javascript.0 (853) script.js.Garage: client received: R;OK
                                      30.8.2022, 18:19:36.042	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                                      30.8.2022, 18:19:36.042	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                                      30.8.2022, 18:19:36.043	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                                      30.8.2022, 18:19:36.462	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.463	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.464	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.465	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.470	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.471	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.472	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.473	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.474	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.475	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.479	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.484	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.485	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.486	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.487	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.488	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.489	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.490	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.491	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.492	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.493	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.494	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.495	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.496	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.502	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.503	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.504	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.505	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.506	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.507	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.508	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.509	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.510	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.511	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.512	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.513	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.514	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.515	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.516	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.517	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.518	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.519	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.520	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.521	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.522	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.523	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.536	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.538	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.539	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.540	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.541	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.542	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.543	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.544	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.545	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.546	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.547	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.548	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.549	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.550	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.552	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.553	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.554	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.555	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.556	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.557	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.558	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.559	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.560	[info ]: javascript.0 (853) script.js.Garage: client received: S;Garagentor;lightOn
                                      30.8.2022, 18:19:36.561	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                                      30.8.2022, 18:19:36.562	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                                      30.8.2022, 18:19:36.562	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                                      30.8.2022, 18:19:37.561	[info ]: javascript.0 (853) script.js.Garage: client timeout
                                      30.8.2022, 18:19:37.561	[info ]: javascript.0 (853) script.js.Garage: client terminatorEnd
                                      30.8.2022, 18:19:37.561	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                                      Licht aus:
                                      30.8.2022, 18:20:29.804	[info ]: javascript.0 (853) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661876429804,"q":0,"from":"system.adapter.javascript.0","lc":1661876429804,"c":"script.js.Garage"})
                                      30.8.2022, 18:20:29.816	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                                      30.8.2022, 18:20:29.817	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                                      30.8.2022, 18:20:29.871	[info ]: javascript.0 (853) script.js.Garage: client received: R;OK
                                      30.8.2022, 18:20:29.872	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                                      30.8.2022, 18:20:29.872	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                                      30.8.2022, 18:20:29.872	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                                      30.8.2022, 18:20:30.871	[info ]: javascript.0 (853) script.js.Garage: client timeout
                                      30.8.2022, 18:20:30.871	[info ]: javascript.0 (853) script.js.Garage: client terminatorEnd
                                      30.8.2022, 18:20:30.872	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                                      30.8.2022, 18:20:31.135	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.136	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.137	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.138	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.139	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.140	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.141	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.142	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.143	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.146	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.147	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.148	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.150	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.153	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.154	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.155	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.157	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.158	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.159	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.160	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.161	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.162	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.163	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.164	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.165	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.166	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.167	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.168	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.169	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.170	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.171	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.178	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.179	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.180	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.181	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.182	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.183	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.184	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.185	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.186	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.187	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.191	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.227	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.228	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.229	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.230	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.231	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.233	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.234	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.235	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.236	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.236	[info ]: javascript.0 (853) script.js.Garage: client received: S;Garagentor;lightOff
                                      30.8.2022, 18:20:31.237	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                                      30.8.2022, 18:20:31.238	[warn ]: javascript.0 (853) script.js.Garage: clearTimeout() => not found
                                      30.8.2022, 18:20:31.238	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                                      30.8.2022, 18:20:32.239	[info ]: javascript.0 (853) script.js.Garage: cliend ended
                                      Bitte gib Bescheid wenn du weitere Zarbeit brauchst.
                                      • OliverIO
                                        @rushmed
                                        du musst leider nochmal. die console.debug anweisungen sind nicht im log erschienen.
                                        hab wieder auf console.log umgestellt.
                                        es reicht erst mal eines. dann prüfen wir ob alles so abläuft wie gewünscht.
                                        noch eins.
                                        stoppe und starte bitte den javascript-adapter bevor du testest.
                                        dass räumt die evtl. reste aus dem speicher die nur stören.
                                        var port = 2785;
                                        var terminator;
                                        var terminatorEnd;
                                            console.log('cliend started');
                                                break;
                                                break;
                                                break;
                                                break;
                                                break;
                                                break;
                                          var cmd;
                                              console.log('execute command: ' + cmd);
                                                      break;
                                                  case "close":
                                                      break;
                                                  case "stop":
                                                      break;
                                                  case "lighton":
                                                      break;
                                                  case "lightoff":
                                                      break;
                                          @oliverio sagte in Benötige Programmierhilfe Javascript:
                                          Kein Problem.
                                          Öffnen:
                                          30.8.2022, 19:58:37.852	[info ]: javascript.0 (1060380) script.js.Garage: execute command: open
                                          30.8.2022, 19:58:37.858	[info ]: javascript.0 (1060380) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661882317857,"q":0,"from":"system.adapter.javascript.0","lc":1661882317857,"c":"script.js.Garage"})
                                          30.8.2022, 19:58:37.872	[info ]: javascript.0 (1060380) script.js.Garage: cliend started
                                          30.8.2022, 19:58:37.873	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                          30.8.2022, 19:58:37.874	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                          30.8.2022, 19:58:37.909	[info ]: javascript.0 (1060380) script.js.Garage: client received: R;OK
                                          30.8.2022, 19:58:37.910	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                          30.8.2022, 19:58:37.910	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                          30.8.2022, 19:58:37.911	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                          30.8.2022, 19:58:38.225	[info ]: javascript.0 (1060380) script.js.Garage: client received: S;Garagentor;opening
                                          30.8.2022, 19:58:38.225	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                          30.8.2022, 19:58:38.226	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                          30.8.2022, 19:58:38.226	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                          30.8.2022, 19:58:38.294	[info ]: javascript.0 (1060380) script.js.Garage: client received: S;Garagentor;lightOn
                                          30.8.2022, 19:58:38.294	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                          30.8.2022, 19:58:38.295	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                          30.8.2022, 19:58:38.295	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                          30.8.2022, 19:58:39.294	[info ]: javascript.0 (1060380) script.js.Garage: client timeout
                                          30.8.2022, 19:58:39.295	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorEnd
                                          30.8.2022, 19:58:39.296	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                          Schließen:
                                          30.8.2022, 19:59:33.336	[info ]: javascript.0 (1060380) script.js.Garage: execute command: close
                                          30.8.2022, 19:59:33.337	[info ]: javascript.0 (1060380) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661882373337,"q":0,"from":"system.adapter.javascript.0","lc":1661882373337,"c":"script.js.Garage"})
                                          30.8.2022, 19:59:33.356	[info ]: javascript.0 (1060380) script.js.Garage: cliend started
                                          30.8.2022, 19:59:33.357	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                          30.8.2022, 19:59:33.357	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                          30.8.2022, 19:59:33.397	[info ]: javascript.0 (1060380) script.js.Garage: client received: R;OK
                                          30.8.2022, 19:59:33.397	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                          30.8.2022, 19:59:33.397	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                          30.8.2022, 19:59:33.398	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                          30.8.2022, 19:59:33.755	[info ]: javascript.0 (1060380) script.js.Garage: client received: S;Garagentor;closing
                                          30.8.2022, 19:59:33.756	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                          30.8.2022, 19:59:33.756	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                          30.8.2022, 19:59:33.756	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                          30.8.2022, 19:59:34.755	[info ]: javascript.0 (1060380) script.js.Garage: client timeout
                                          30.8.2022, 19:59:34.756	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorEnd
                                          30.8.2022, 19:59:34.757	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                          Zur Info, VErbose ist noch aktiviert und die DPs für Status Licht, Tor werden nicht beschrieben.
                                          • OliverIO
                                            @rushmed
                                            schau mal an dem schraubenschlüssel oben rechts, ob da debug aus ist?
                                            dadurch werden keine datenpunkte beschrieben. also es muss aus sein
                                            1.2k
                                            communication javascript monitoring
                                            4751
