    4. Backitup kein JavaScript Restore möglich!
    • Glasfaser
      Glasfaser @BenjaminCz last edited by Glasfaser
      @benjamincz
      Zeige mal die Ausgaben , ich habe da so eine Befürchtung.
      Ein/ und Ausgabe davon in Code-Tags </> hier einstellen
      cd /opt/iobroker
      npm ls | grep -E 'github.com|ERR'
      iobroker update -i
      sudo ln -s /usr/bin/node /usr/bin/nodejs
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      zu CodeTags ...
      Verzeichniss und auch deine Backups gehören root ... sollte iobroker sein
      wxrwxrwx 2 root root 0 Aug 28 20:36 tmp
        BenjaminCz @Glasfaser last edited by
        @glasfaser ```
        code_text
        ```pi@raspberrypi:~ $ cd /opt/iobroker
        iobroker update -i
        ├── iobroker.samsung_tizen@0.0.12 (git+ssh://git@github.com/dahuby/iobroker.sams        ung_tizen.git#defeef34bd3f460c77b4fff115de34fd1c11bff7)
        Used repository: Stable (default)
        Adapter    "admin"        : 6.2.17   , installed 6.2.17
        Adapter    "alexa2"       : 3.11.2   , installed 3.19.7
        Adapter    "backitup"     : 2.4.10   , installed 2.4.12
        Adapter    "device-reminder": 1.2.9  , installed 1.2.9
        Adapter    "discovery"    : 3.0.5    , installed 3.0.5
        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
        Adapter    "history"      : 2.2.0    , installed 2.2.0
        Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
        Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
        Adapter    "hs100"        : 2.1.2    , installed 2.1.2
        Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
        Adapter    "ical"         : 1.13.1   , installed 1.13.1
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.11.8   , installed 1.11.9
        Adapter    "jarvis"       : 3.0.11   , installed 3.0.13
        Adapter    "javascript"   : 6.0.0    , installed 6.0.0
        Adapter    "midea"        : 0.0.7    , installed 0.0.7
        Adapter    "pushover"     : 3.0.2    , installed 3.0.2
        Adapter    "samsung"      : 0.5.8    , installed 0.5.11
        Adapter    "shelly"       : 6.0.0    , installed 6.0.0
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "socketio"     : 4.2.0    , installed 6.1.7
        Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
        Adapter    "trashschedule": 2.0.3    , installed 2.0.3
        Adapter    "web"          : 4.3.0    , installed 5.2.2
        Adapter    "ws"           : 1.3.0    , installed 2.1.2
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.17.0
        v16.17.0
        8.15.0
        pi
        /opt/iobroker
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
        Reading package lists... Done
        Building dependency tree... Done
        All packages are up to date.
        nodejs:
          Installed: 16.17.0-deb-1nodesource1
          Candidate: 16.17.0-deb-1nodesource1
          Version table:
         *** 16.17.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u1 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package        s
        pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:~ $ cd /opt/iobroker
        iobroker update -i
        uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs        ├── iobroker.samsung_tizen@0.0.12 (git+ssh://git@github.com/dahuby/iobroker.samsung_tizen.git#defeef34bd3f460c77b4fff115de34fd1c11bff7)
        Used repository: Stable (default) (git+ssh://git@github.com/dahuby/iobroker.sams        Adapter    "admin"        : 6.2.17   , installed 6.2.17
        Adapter    "device-reminder": 1.2.9  , installed 1.2.97
        Adapter    "discovery"    : 3.0.5    , installed 3.0.52
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.17.0
        v16.17.0
        8.15.0
        pi
        /opt/iobroker
        nodejs:
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          @glasfaser said in Backitup kein JavaScript Restore möglich!:
          wie soll ich dass genau verstehen bzw umsetzen. Also im NAS habe ich Benutzer IOBroker und das zugehörige pw. Was genau muss ich dann ändern ?
          Und vielen vielen dank für die Mühe und unterstützung!
            BenjaminCz @BenjaminCz last edited by
            @benjamincz said in Backitup kein JavaScript Restore möglich!:
            wie soll ich dass genau verstehen bzw umsetzen. Also im NAS habe ich Benutzer IOBroker und das zugehörige pw. Das gleiche steht auch dann im Backitup Config "NAS/Kopieren" wie im Screenshot oben. Was genau muss ich dann ändern ?
            • simatec
              simatec Developer Most Active @BenjaminCz last edited by
              @benjamincz sagte in Backitup kein JavaScript Restore möglich!:
              {"errno":-1,"code":"EPERM","syscall":"utime","path":"/opt/iobroker/backups/tmpScripts/"}
              Deine Benutzerrechte scheinen nicht zu stimmen, so dass der Schreibzugriff fehlt.
              Stelle mal auf SMB 3.1.1 um und führe mal einen iob fix durch.
              Zeige mal die Ausgabe von:
              ls -lah /opt/iobroker/backups
              L B 2 Replies Last reply Reply Quote 0
                legro @simatec last edited by legro
                @simatec
                Ich schlage mich wohl mit demselben Fehler herum - lediglich sind's bei mir andere Adapter: YAHKA und ZigBee.
                Versuche ich nun das Backup von YAHKA einzuspielen, erhalte ich folgende Fehlermeldung; dasselbe geschieht in vergleichbarer Weise bei ZigBee.
                Erwartet BackItUp etwa die Backup-Datei im Verzeichnis /opt/iobroker/backups/yahka_0.hapdate/, oder wie soll ich das verstehen?
                Und hier meine Hausaufgaben ..
                pi@raspiBullseye:~ $ iob fix
                library: loaded
                Library version=2022-06-15
                ioBroker or some processes are still running:
                 io.telegram.0
                 io.admin.0
                 io.javascript.0
                 io.pushover.0
                 io.scenes.0
                 io.daikin.0
                 io.daikin.1
                 io.daikin.2
                 io.hue.0
                 io.modbus.0
                 io.netatmo.0
                 io.rpi2.0
                 io.shelly.0
                 io.web.0
                 io.info.0
                 io.trashschedule.0
                 io.tankerkoenig.0
                 io.backitup.0
                Please stop them first and try again!
                pi@raspiBullseye:~ $ ls -lah /opt/iobroker/backups
                total 8.0K
                drwxrwxr-x+ 2 iobroker iobroker 4.0K Aug 29 10:24 .
                drwxrwxr-x+ 6 iobroker iobroker 4.0K Aug 29 10:24 ..
                Glasfaser simatec 2 Replies Last reply Reply Quote 0
                • Glasfaser
                  Glasfaser @legro last edited by
                  @legro
                  Über deinen Beitrag steht ein ( ToDo ) .
                  hast du das auch gemacht , bzw. was sagt die Ausgabe davon , wer ist der Besitzer .
                  • simatec
                    simatec Developer Most Active @legro last edited by
                    @legro Entweder ihr überprüft die Userrechte auf dem NAS, denn dort fehlen dir Schreibrechte für Unterordner oder du legst die Backup vor dem Restore lokal ab und startest den Restore lokal.
                    Grundsätzlich ist es aber kein Problem von Backitup sondern ein Problem eurer NAS Konfiguration
                      BenjaminCz @simatec last edited by
                      @simatec
                      pi@raspberrypi:~ $ ls -lah /opt/iobroker/backups
                      total 131M
                      drwxrwxrwx  2 root     root        0 Aug 29 08:11  .
                      drwxrwxr-x+ 8 iobroker iobroker 4.0K Aug 28 20:49  ..
                      -rwxrwxrwx  1 root     root     4.8M Aug 27 22:41 'historyDB_2022_08_27-22_41_49                                          _IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     4.8M Aug 27 23:06 'historyDB_2022_08_27-23_06_27                                          _IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     4.8M Aug 28 08:11 'historyDB_2022_08_28-08_10_36                                          _IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     4.9M Aug 28 21:01 'historyDB_2022_08_28-20_59_57                                          _IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     4.9M Aug 28 21:03 'historyDB_2022_08_28-21_02_05                                          _IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     4.9M Aug 28 21:10 'historyDB_2022_08_28-21_09_47                                          _IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     4.9M Aug 29 08:11 'historyDB_2022_08_29-08_10_36                                          _IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     6.8M Aug 27 22:41 'iobroker_2022_08_27-22_41_32_                                          IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     7.0M Aug 27 23:06 'iobroker_2022_08_27-23_06_11_                                          IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     7.0M Aug 28 08:10 'iobroker_2022_08_28-08_10_20_                                          IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     7.0M Aug 28 21:01 'iobroker_2022_08_28-20_59_41_                                          IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     7.0M Aug 28 21:03 'iobroker_2022_08_28-21_01_48_                                          IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     6.4M Aug 28 21:10 'iobroker_2022_08_28-21_09_32_                                          IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     7.0M Aug 29 08:10 'iobroker_2022_08_29-08_10_20_                                          IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     6.7M Aug 27 22:42 'jarvis.0_2022_08_27-22_41_55_                                          IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     6.7M Aug 27 23:06 'jarvis.0_2022_08_27-23_06_34_                                          IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     6.7M Aug 28 08:11 'jarvis.0_2022_08_28-08_10_42_                                          IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     6.7M Aug 28 21:01 'jarvis.0_2022_08_28-21_00_06_                                          IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     6.7M Aug 28 21:03 'jarvis.0_2022_08_28-21_02_11_                                          IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     6.7M Aug 28 21:11 'jarvis.0_2022_08_28-21_09_53_                                          IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     6.7M Aug 29 08:11 'jarvis.0_2022_08_29-08_10_42_                                          IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     354K Aug 22 08:11 'javascripts_2022_08_22-08_10_                                          45_IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     359K Aug 27 22:42 'javascripts_2022_08_27-22_41_                                          58_IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     359K Aug 27 23:06 'javascripts_2022_08_27-23_06_                                          37_IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     359K Aug 28 08:11 'javascripts_2022_08_28-08_10_                                          45_IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     359K Aug 28 21:01 'javascripts_2022_08_28-21_00_                                          09_IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     359K Aug 28 21:03 'javascripts_2022_08_28-21_02_                                          14_IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root      399 Aug 28 21:11 'javascripts_2022_08_28-21_09_                                          56_IOBroker Backup_backupiobroker.tar.gz'
                      -rwxrwxrwx  1 root     root     367K Aug 29 08:11 'javascripts_2022_08_29-08_10_                                          45_IOBroker Backup_backupiobroker.tar.gz'
                      pi@raspberrypi:~ $
                      Danke vielmals. Ich frage mich nur was ich nun machen soll bzw. wo genau der Fehler liegt...
                        Thomas Braun Most Active @BenjaminCz last edited by
                        @benjamincz
                        War die Freigabe des NAS zu dem Zeitpunkt gemountet?
                          BenjaminCz @Thomas Braun last edited by
                          @thomas-braun ja
                            @benjamincz
                            Und auf dem NAS ist das ganze wie angelegt?
                            Glasfaser B 2 Replies Last reply Reply Quote 0
                            • Glasfaser
                              Glasfaser @Thomas Braun last edited by
                              @thomas-braun sagte in Backitup kein JavaScript Restore möglich!:
                              @benjamincz
                              In deinen Einstellung ist aber dieser Pfad .
                              und du zeigst auf der Pi .
                                @thomas-braun Es handlet sich um die Western Digital Cloud EX2 Ultra 8TB. DOrt habe ich einen Benutzer Erstellt namens iobroker und das passwort dazu. Der Freigabe Ordner Heißt IOBroker-Backup. Dort Ist ein Unterordner namens IOBroker und ein Unterordner namens Raspberymatic. In jedem Unterordner werden also Backups Hinterlegt. Sie sind auch Erfolgreich auf dem NAS laufwerk dann auch Drauf. Es geht Jarvis nicht zu Restoren und es geht auch kein Javascript. IOBroker gesamt Restore Funktioniert und auch History geht.
                                Ich lese immer lokal Update einspielen ja aber der Backup ordner in opt/iobroker/backups ist ja gleichzeitig der ordner auf meinem NAS. D.h wenn ich dort etwas lösche ist es auch dann auf meinem NAS gelöscht.
                                  Das ist richtig (und korrekt auch...)
                                  Zeig mal die Einstellungen im NAS.
                                    @glasfaser
                                    Ja der Backup Ordner Stimmt schon.
                                      @benjamincz
                                      Hier sieht man es nochmals Besser.
                                        Thomas Braun Most Active @BenjaminCz last edited by Thomas Braun
                                        @benjamincz
                                        Ich nicht. Besser sieht man es mit:
                                        ls -lA /opt/iobroker/backups
                                        Und zeig mal die Ausgabe zu
                                        mount
                                          NAS Config
                                          Thomas Braun simatec 2 Replies Last reply Reply Quote 0
                                            @benjamincz
                                            Das Ding kann NFS? Dann nimm das.
                                            3948
