    4. Backitup kein JavaScript Restore möglich!
    • simatec
      simatec Developer Most Active @BenjaminCz last edited by
      @benjamincz also dein NAS kann NFS.
      Dann würde ich es an deiner Stelle auch nutzen.
      CIFS ist nur ein Notfall
        BenjaminCz @simatec last edited by BenjaminCz
        @simatec
        pi@raspberrypi:~ $ mount
        /dev/mmcblk0p2 on / type ext4 (rw,noatime)
        devtmpfs on /dev type devtmpfs (rw,relatime,size=1800664k,nr_inodes=84204,mode=755)
        proc on /proc type proc (rw,relatime)
        sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
        securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
        tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
        devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
        tmpfs on /run type tmpfs (rw,nosuid,nodev,size=786212k,nr_inodes=819200,mode=755)
        tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
        cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
        bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
        systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
        mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
        sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
        debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
        tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
        configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
        fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
        /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro)
        //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1)
        //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=2.0,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1)
        //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=2.0,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1)
        //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1)
        tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=393104k,nr_inodes=98276,mode=700,uid=1000,gid=1000)
        pi@raspberrypi:~ $
          Thomas Braun Most Active @BenjaminCz last edited by
          @benjamincz
          5 Freigaben auf den gleichen Mountpunkt kann nicht funktionieren.
            @simatec OK vielen dank. Wie stelle ich das dann genau im Backitup um auf Kopieren ?
              BenjaminCz @Thomas Braun last edited by
              @thomas-braun ok was mache ich falsch ? Soll ich auf NFS umsteigen ?
                Thomas Braun Most Active @BenjaminCz last edited by Thomas Braun
                @benjamincz sagte in Backitup kein JavaScript Restore möglich!:
                Du stapelst da wohl 5 Freigaben übereinander.
                Ich würde es tun. @simatec auch.
                sudo umount /opt/iobroker/backups && mount | sort
                sagt?
                  pi@raspberrypi:~ $ sudo umount /opt/iobroker/backups && mount | sort
                  pi@raspberrypi:~ $
                    @thomas-braun Ich würde es dann mit NFS Probieren. Hat von euch einer eine Idee ob ich da dann im Adapter NAS/Kopieren eingestellt haben muss so wie jetzt auch oder dann FTP ?
                      @benjamincz
                      Schalt mal den ganzen anderen Kram da aus. Also NT-LAN-Manager bis LLTD. Das sind offenbar die ganzen unnötigen Freigaben da bei dir.
                      Oder halt komplett auf NFS gehen.
                        oder dann FTP
                        Warum FTP? Das ist ein komplett anderes Protokoll. Hat mit NFS nix zu schaffen. Who wants to use FTP anyway?
                          @thomas-braun Habe es auf NFS umgestellt und gleicher Fehler.
                          Error:
                          {"errno":-1,"code":"EPERM","syscall":"utime","path":"/opt/iobroker/backups/tmpScripts/"}
                            @benjamincz
                            Das gleiche Spiel...
                            mount | sort
                              pi@raspberrypi:~ $ mount | sort
                              pi@raspberrypi:~ $
                              Danke für eure gedult!
                                @benjamincz
                                Da ist noch der komische CIFS/SMB Kram aktiv.
                                  @thomas-braun wie bekomme ich den weg. EInfach IOBRoker neustarten ?
                                    @benjamincz
                                    Die 'Windows-Dienste' von NT-LAN Manager bis einschließlich LLTD ausstellen.
                                      Ist alles Aus außer den Lan Manager Aus gibts da nicht nur andere Option...
                                        @benjamincz
                                        Ich hasse GUIs...
                                        Waren die immer aus? Und oben war das DropDown-Menü von smb nur drüber gelegt?
                                          So sieht es normal aus ohne Dropdown.
                                            @benjamincz
                                            Stell mal das SMB Protokoll auf 'Nur 3'.
                                            Und auf dem Pi:
                                            solange bis die Freigabe nicht mehr in
                                            mount | sort
                                            auftaucht.
                                            3948
