    4. Backitup kein JavaScript Restore möglich!
      BenjaminCz @simatec last edited by
      @simatec OK vielen dank. Wie stelle ich das dann genau im Backitup um auf Kopieren ?
        BenjaminCz @Thomas Braun last edited by
        @thomas-braun ok was mache ich falsch ? Soll ich auf NFS umsteigen ?
          Thomas Braun Most Active @BenjaminCz last edited by Thomas Braun
          @benjamincz sagte in Backitup kein JavaScript Restore möglich!:
          Du stapelst da wohl 5 Freigaben übereinander.
          Ich würde es tun. @simatec auch.
          sudo umount /opt/iobroker/backups && mount | sort
          sagt?
            pi@raspberrypi:~ $ sudo umount /opt/iobroker/backups && mount | sort
            //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=2.0,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1)
            //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=2.0,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1)
            //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1)
            //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1)
            bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
            cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
            configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
            debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
            /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro)
            /dev/mmcblk0p2 on / type ext4 (rw,noatime)
            devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
            devtmpfs on /dev type devtmpfs (rw,relatime,size=1800664k,nr_inodes=84204,mode=755)
            fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
            mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
            proc on /proc type proc (rw,relatime)
            securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
            sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
            sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
            systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
            tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
            tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
            tmpfs on /run type tmpfs (rw,nosuid,nodev,size=786212k,nr_inodes=819200,mode=755)
            tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=393104k,nr_inodes=98276,mode=700,uid=1000,gid=1000)
            tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
            pi@raspberrypi:~ $
              @thomas-braun Ich würde es dann mit NFS Probieren. Hat von euch einer eine Idee ob ich da dann im Adapter NAS/Kopieren eingestellt haben muss so wie jetzt auch oder dann FTP ?
                @benjamincz
                Schalt mal den ganzen anderen Kram da aus. Also NT-LAN-Manager bis LLTD. Das sind offenbar die ganzen unnötigen Freigaben da bei dir.
                Oder halt komplett auf NFS gehen.
                  oder dann FTP
                  Warum FTP? Das ist ein komplett anderes Protokoll. Hat mit NFS nix zu schaffen. Who wants to use FTP anyway?
                    @thomas-braun Habe es auf NFS umgestellt und gleicher Fehler.
                    Error:
                    {"errno":-1,"code":"EPERM","syscall":"utime","path":"/opt/iobroker/backups/tmpScripts/"}
                      @benjamincz
                      Das gleiche Spiel...
                      mount | sort
                        pi@raspberrypi:~ $ mount | sort
                        pi@raspberrypi:~ $
                        Danke für eure gedult!
                          @benjamincz
                          Da ist noch der komische CIFS/SMB Kram aktiv.
                            @thomas-braun wie bekomme ich den weg. EInfach IOBRoker neustarten ?
                              @benjamincz
                              Die 'Windows-Dienste' von NT-LAN Manager bis einschließlich LLTD ausstellen.
                                Ist alles Aus außer den Lan Manager Aus gibts da nicht nur andere Option...
                                  @benjamincz
                                  Ich hasse GUIs...
                                  Waren die immer aus? Und oben war das DropDown-Menü von smb nur drüber gelegt?
                                    So sieht es normal aus ohne Dropdown.
                                      @benjamincz
                                      Stell mal das SMB Protokoll auf 'Nur 3'.
                                      Und auf dem Pi:
                                      solange bis die Freigabe nicht mehr in
                                      mount | sort
                                      auftaucht.
                                        BenjaminCz @Thomas Braun last edited by BenjaminCz
                                        @thomas-braun said in Backitup kein JavaScript Restore möglich!:
                                        mount | sort
                                          @benjamincz
                                          Weiter umounten. Bis das alles weg ist.
                                            @thomas-braun erledigt
                                            siehe oben
                                            3948
