    4. Backitup kein JavaScript Restore möglich!
      BenjaminCz @Thomas Braun last edited by
      @thomas-braun Habe es auf NFS umgestellt und gleicher Fehler.
      Error:
      {"errno":-1,"code":"EPERM","syscall":"utime","path":"/opt/iobroker/backups/tmpScripts/"}
        Thomas Braun Most Active @BenjaminCz last edited by
        @benjamincz
        Das gleiche Spiel...
        mount | sort
          pi@raspberrypi:~ $ mount | sort
          //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=2.0,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1)
          //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=2.0,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1)
          //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1)
          //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1)
          bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
          cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
          configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
          debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
          /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro)
          /dev/mmcblk0p2 on / type ext4 (rw,noatime)
          devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
          devtmpfs on /dev type devtmpfs (rw,relatime,size=1800664k,nr_inodes=84204,mode=755)
          fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
          mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
          proc on /proc type proc (rw,relatime)
          securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
          sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
          sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
          systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
          tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
          tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
          tmpfs on /run type tmpfs (rw,nosuid,nodev,size=786212k,nr_inodes=819200,mode=755)
          tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=393104k,nr_inodes=98276,mode=700,uid=1000,gid=1000)
          tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
          pi@raspberrypi:~ $
          Danke für eure gedult!
            @benjamincz
            Da ist noch der komische CIFS/SMB Kram aktiv.
              @thomas-braun wie bekomme ich den weg. EInfach IOBRoker neustarten ?
                @benjamincz
                Die 'Windows-Dienste' von NT-LAN Manager bis einschließlich LLTD ausstellen.
                  Ist alles Aus außer den Lan Manager Aus gibts da nicht nur andere Option...
                    @benjamincz
                    Ich hasse GUIs...
                    Waren die immer aus? Und oben war das DropDown-Menü von smb nur drüber gelegt?
                      So sieht es normal aus ohne Dropdown.
                        @benjamincz
                        Stell mal das SMB Protokoll auf 'Nur 3'.
                        Und auf dem Pi:
                        sudo umount /opt/iobroker/backups
                        solange bis die Freigabe nicht mehr in
                        mount | sort
                        auftaucht.
                          BenjaminCz @Thomas Braun last edited by BenjaminCz
                          @thomas-braun said in Backitup kein JavaScript Restore möglich!:
                          mount | sort
                            @benjamincz
                            Weiter umounten. Bis das alles weg ist.
                              @thomas-braun erledigt
                              siehe oben
                                @benjamincz
                                Jetzt mal ein stinknormales Backitup-Backup manuell ausführen.
                                Währenddessen nochmal in
                                mount | sort
                                schauen was da wohin gemountet wird.
                                  bin noch beschäftigt es auszu Probieren da leider error kommt beim mounten. (NFS)
                                  B Thomas Braun 2 Replies Last reply Reply Quote 0
                                    BenjaminCz @BenjaminCz last edited by
                                    @benjamincz
                                    Started iobroker ...
                                    [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58/:/IOBroker-Backup/IOBroker /opt/iobroker/backups"
                                    [ERROR] [mount] - [undefined mount.nfs: Failed to resolve server 192.168.178.58/: Name or service not known
                                    [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58/:/IOBroker-Backup/IOBroker /opt/iobroker/backups
                                      @benjamincz
                                      Jetzt NFS?
                                      Der Freigabepfad ist falsch.
                                      Muss
                                      IOBroker-Backup
                                      lauten. Im Übrigen ist Groß/Kleinschreibung nur ein zusätzlicher Stolperstein. Schreib Verzeichnisnamen durchweg klein.
                                        @benjamincz sagte in Backitup kein JavaScript Restore möglich!:
                                        Das muss wohl
                                        192.168.178.58:/IOBroker-Backup
                                        lauten.
                                          jetzt kommt der Fehler:
                                          [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58:/IOBroker-Backup :/IOBroker-Backup\IOBroker /opt/iobroker/backups"
                                          [ERROR] [mount] - [undefined mount: bad usage
                                          Try 'mount --help' for more information.
                                          [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58:/IOBroker-Backup :/IOBroker-Backup\IOBroker /opt/iobroker/backups
                                          mount: bad usage
                                          • simatec
                                            simatec Developer Most Active @BenjaminCz last edited by simatec
                                            @benjamincz
                                            Installiere mal die nfs-common
                                            sudo apt install nfs-common
                                            3948
