    4. Backitup kein JavaScript Restore möglich!
      Thomas Braun Most Active @BenjaminCz last edited by
      @benjamincz
      Das gleiche Spiel...
      mount | sort
        BenjaminCz @Thomas Braun last edited by
        pi@raspberrypi:~ $ mount | sort
        //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=2.0,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1)
        //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=2.0,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1)
        //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1)
        //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1)
        bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
        cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
        configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
        debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
        /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro)
        /dev/mmcblk0p2 on / type ext4 (rw,noatime)
        devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
        devtmpfs on /dev type devtmpfs (rw,relatime,size=1800664k,nr_inodes=84204,mode=755)
        fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
        mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
        proc on /proc type proc (rw,relatime)
        securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
        sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
        sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
        systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
        tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
        tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
        tmpfs on /run type tmpfs (rw,nosuid,nodev,size=786212k,nr_inodes=819200,mode=755)
        tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=393104k,nr_inodes=98276,mode=700,uid=1000,gid=1000)
        tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
        pi@raspberrypi:~ $
        Danke für eure gedult!
          @benjamincz
          Da ist noch der komische CIFS/SMB Kram aktiv.
            @thomas-braun wie bekomme ich den weg. EInfach IOBRoker neustarten ?
              @benjamincz
              Die 'Windows-Dienste' von NT-LAN Manager bis einschließlich LLTD ausstellen.
                Ist alles Aus außer den Lan Manager Aus gibts da nicht nur andere Option...
                  @benjamincz
                  Ich hasse GUIs...
                  Waren die immer aus? Und oben war das DropDown-Menü von smb nur drüber gelegt?
                    So sieht es normal aus ohne Dropdown.
                      @benjamincz
                      Stell mal das SMB Protokoll auf 'Nur 3'.
                      Und auf dem Pi:
                      sudo umount /opt/iobroker/backups
                      solange bis die Freigabe nicht mehr in
                      mount | sort
                      auftaucht.
                        BenjaminCz @Thomas Braun last edited by BenjaminCz
                        @thomas-braun said in Backitup kein JavaScript Restore möglich!:
                        mount | sort
                          @benjamincz
                          Weiter umounten. Bis das alles weg ist.
                            @thomas-braun erledigt
                            siehe oben
                              @benjamincz
                              Jetzt mal ein stinknormales Backitup-Backup manuell ausführen.
                              Währenddessen nochmal in
                              mount | sort
                              schauen was da wohin gemountet wird.
                                bin noch beschäftigt es auszu Probieren da leider error kommt beim mounten. (NFS)
                                B Thomas Braun 2 Replies Last reply Reply Quote 0
                                  BenjaminCz @BenjaminCz last edited by
                                  @benjamincz
                                  Started iobroker ...
                                  [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58/:/IOBroker-Backup/IOBroker /opt/iobroker/backups"
                                  [ERROR] [mount] - [undefined mount.nfs: Failed to resolve server 192.168.178.58/: Name or service not known
                                  [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58/:/IOBroker-Backup/IOBroker /opt/iobroker/backups
                                    @benjamincz
                                    Jetzt NFS?
                                    Der Freigabepfad ist falsch.
                                    Muss
                                    IOBroker-Backup
                                    lauten. Im Übrigen ist Groß/Kleinschreibung nur ein zusätzlicher Stolperstein. Schreib Verzeichnisnamen durchweg klein.
                                      @benjamincz sagte in Backitup kein JavaScript Restore möglich!:
                                      Das muss wohl
                                      192.168.178.58:/IOBroker-Backup
                                      lauten.
                                        jetzt kommt der Fehler:
                                        [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58:/IOBroker-Backup :/IOBroker-Backup\IOBroker /opt/iobroker/backups"
                                        [ERROR] [mount] - [undefined mount: bad usage
                                        Try 'mount --help' for more information.
                                        [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58:/IOBroker-Backup :/IOBroker-Backup\IOBroker /opt/iobroker/backups
                                        mount: bad usage
                                        • simatec
                                          simatec Developer Most Active @BenjaminCz last edited by simatec
                                          @benjamincz
                                          Installiere mal die nfs-common
                                          sudo apt install nfs-common
                                            BenjaminCz @simatec last edited by BenjaminCz
                                            @simatec said in Backitup kein JavaScript Restore möglich!:
                                            sudo apt install nfs-commons
                                            pi@raspberrypi:~ $ pi@raspberrypi:~ $ sudo apt install nfs-commons
                                            Reading package lists... Done
                                            Building dependency tree... Done
                                            E: Unable to locate package nfs-commons
                                            pi@raspberrypi:~ $
                                            -bash: pi@raspberrypi:~: command not found
                                            -bash: Reading: command not found
                                            -bash: Building: command not found
                                            -bash: E:: command not found
                                            nfs-common is already the newest version (1:1.3.4-6).
                                            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                            pi@raspberrypi:~ $
                                            simatec Thomas Braun 2 Replies Last reply Reply Quote 0
                                            3948
