    4. Backitup kein JavaScript Restore möglich!
      BenjaminCz @Thomas Braun last edited by
      So sieht es normal aus ohne Dropdown.
        Thomas Braun Most Active @BenjaminCz last edited by
        @benjamincz
        Stell mal das SMB Protokoll auf 'Nur 3'.
        Und auf dem Pi:
        sudo umount /opt/iobroker/backups
        solange bis die Freigabe nicht mehr in
        mount | sort
        auftaucht.
          BenjaminCz @Thomas Braun last edited by BenjaminCz
          @thomas-braun said in Backitup kein JavaScript Restore möglich!:
          mount | sort
          pi@raspberrypi:~ $ mount | sort
          bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
          cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
          configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
          debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
          /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro)
          /dev/mmcblk0p2 on / type ext4 (rw,noatime)
          devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
          devtmpfs on /dev type devtmpfs (rw,relatime,size=1800664k,nr_inodes=84204,mode=755)
          fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
          mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
          proc on /proc type proc (rw,relatime)
          securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
          sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
          sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
          systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
          tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
          tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
          tmpfs on /run type tmpfs (rw,nosuid,nodev,size=786212k,nr_inodes=819200,mode=755)
          tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=393104k,nr_inodes=98276,mode=700,uid=1000,gid=1000)
          tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
            @benjamincz
            Weiter umounten. Bis das alles weg ist.
              @thomas-braun erledigt
              siehe oben
                @benjamincz
                Jetzt mal ein stinknormales Backitup-Backup manuell ausführen.
                Währenddessen nochmal in
                mount | sort
                schauen was da wohin gemountet wird.
                  bin noch beschäftigt es auszu Probieren da leider error kommt beim mounten. (NFS)
                  B Thomas Braun 2 Replies Last reply Reply Quote 0
                    BenjaminCz @BenjaminCz last edited by
                    @benjamincz
                    Started iobroker ...
                    [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58/:/IOBroker-Backup/IOBroker /opt/iobroker/backups"
                    [ERROR] [mount] - [undefined mount.nfs: Failed to resolve server 192.168.178.58/: Name or service not known
                    [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58/:/IOBroker-Backup/IOBroker /opt/iobroker/backups
                      @benjamincz
                      Jetzt NFS?
                      Der Freigabepfad ist falsch.
                      Muss
                      IOBroker-Backup
                      lauten. Im Übrigen ist Groß/Kleinschreibung nur ein zusätzlicher Stolperstein. Schreib Verzeichnisnamen durchweg klein.
                        @benjamincz sagte in Backitup kein JavaScript Restore möglich!:
                        Das muss wohl
                        192.168.178.58:/IOBroker-Backup
                        lauten.
                          jetzt kommt der Fehler:
                          [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58:/IOBroker-Backup :/IOBroker-Backup\IOBroker /opt/iobroker/backups"
                          [ERROR] [mount] - [undefined mount: bad usage
                          Try 'mount --help' for more information.
                          [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58:/IOBroker-Backup :/IOBroker-Backup\IOBroker /opt/iobroker/backups
                          mount: bad usage
                          • simatec
                            simatec Developer Most Active @BenjaminCz last edited by simatec
                            @benjamincz
                            Installiere mal die nfs-common
                            sudo apt install nfs-common
                              BenjaminCz @simatec last edited by BenjaminCz
                              @simatec said in Backitup kein JavaScript Restore möglich!:
                              sudo apt install nfs-commons
                              pi@raspberrypi:~ $ pi@raspberrypi:~ $ sudo apt install nfs-commons
                              Reading package lists... Done
                              Building dependency tree... Done
                              E: Unable to locate package nfs-commons
                              pi@raspberrypi:~ $
                              -bash: pi@raspberrypi:~: command not found
                              -bash: Reading: command not found
                              -bash: Building: command not found
                              -bash: E:: command not found
                              nfs-common is already the newest version (1:1.3.4-6).
                              0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                              pi@raspberrypi:~ $
                              simatec Thomas Braun 2 Replies Last reply Reply Quote 0
                              • simatec
                                @benjamincz
                                Sorry verschrieben
                                nfs-common
                                  Thomas Braun Most Active @BenjaminCz last edited by Thomas Braun
                                  @benjamincz
                                  Zu viele Leerzeichen und die Freigabe doppelt. Vermutlich sollte es
                                  sudo mount 192.168.178.58:/IOBroker-Backup /opt/iobroker/backups
                                  lauten.
                                  Und bitte verwende CodeTags, dann sieht man sowas auch viel schneller.
                                    [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58:/:/IOBroker-Backup /opt/iobroker/backups"
                                    [ERROR] [mount] - [undefined mount.nfs: access denied by server while mounting 192.168.178.58:/:/IOBroker-Backup
                                    [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58:/:/IOBroker-Backup /opt/iobroker/backups
                                      Immer noch ein falscher Pfad...
                                      muss das.
                                        [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58:/IOBroker-Backup /opt/iobroker/backups"
                                        [ERROR] [mount] - [undefined mount.nfs: access denied by server while mounting 192.168.178.58:/IOBroker-Backup
                                        [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58:/IOBroker-Backup /opt/iobroker/backups
                                          legro @simatec last edited by
                                          Vielen Dank für deine Rückmeldung
                                          @legro .. auf dem NAS, denn dort fehlen dir Schreibrechte für Unterordner ..
                                          Das ist definitiv nicht der Fall. Der verwendete User ioBroker hat auf den in der Fritz!Box 7590 volle Zugriffsrechte. So kann er beispielsweise problemlos die verschiedenen Unterordner für die getrennte Speicherung der Backup-Dateien anlegen. Daran sollte es also in meinem Falle nicht liegen.
                                          .. oder du legst die Backup vor dem Restore lokal ab und startest den Restore lokal.
                                          Hierzu muss ich die Dateien von ZigBee und YAHKA in das Verzeichnis "/opt/iobroker/backups" kopieren. Verstehe ich das richtig?
                                          Das werde ich morgen früh einmal probieren.
                                            @benjamincz
                                            Und die Rechte an der Freigabe sehen wie aus?
                                            Bei NFS sollte es (im einfachsten Fall) die gleiche uid/gid wie der user 'iobroker' sein.
                                            3948
