    4. Backitup kein JavaScript Restore möglich!
      Thomas Braun Most Active @BenjaminCz last edited by
      @benjamincz
      Stell mal das SMB Protokoll auf 'Nur 3'.
      Und auf dem Pi:
      sudo umount /opt/iobroker/backups
      solange bis die Freigabe nicht mehr in
      mount | sort
      auftaucht.
        BenjaminCz @Thomas Braun last edited by BenjaminCz
        @thomas-braun said in Backitup kein JavaScript Restore möglich!:
        mount | sort
        pi@raspberrypi:~ $ mount | sort
        bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
        cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
        configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
        debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
        /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro)
        /dev/mmcblk0p2 on / type ext4 (rw,noatime)
        devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
        devtmpfs on /dev type devtmpfs (rw,relatime,size=1800664k,nr_inodes=84204,mode=755)
        fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
        mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
        proc on /proc type proc (rw,relatime)
        securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
        sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
        sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
        systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
        tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
        tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
        tmpfs on /run type tmpfs (rw,nosuid,nodev,size=786212k,nr_inodes=819200,mode=755)
        tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=393104k,nr_inodes=98276,mode=700,uid=1000,gid=1000)
        tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
          @benjamincz
          Weiter umounten. Bis das alles weg ist.
            @thomas-braun erledigt
            siehe oben
              @benjamincz
              Jetzt mal ein stinknormales Backitup-Backup manuell ausführen.
              Währenddessen nochmal in
              mount | sort
              schauen was da wohin gemountet wird.
                bin noch beschäftigt es auszu Probieren da leider error kommt beim mounten. (NFS)
                B Thomas Braun 2 Replies Last reply Reply Quote 0
                  BenjaminCz @BenjaminCz last edited by
                  @benjamincz
                  Started iobroker ...
                  [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58/:/IOBroker-Backup/IOBroker /opt/iobroker/backups"
                  [ERROR] [mount] - [undefined mount.nfs: Failed to resolve server 192.168.178.58/: Name or service not known
                  [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58/:/IOBroker-Backup/IOBroker /opt/iobroker/backups
                    @benjamincz
                    Jetzt NFS?
                    Der Freigabepfad ist falsch.
                    Muss
                    IOBroker-Backup
                    lauten. Im Übrigen ist Groß/Kleinschreibung nur ein zusätzlicher Stolperstein. Schreib Verzeichnisnamen durchweg klein.
                      @benjamincz sagte in Backitup kein JavaScript Restore möglich!:
                      Das muss wohl
                      192.168.178.58:/IOBroker-Backup
                      lauten.
                        jetzt kommt der Fehler:
                        [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58:/IOBroker-Backup :/IOBroker-Backup\IOBroker /opt/iobroker/backups"
                        [ERROR] [mount] - [undefined mount: bad usage
                        Try 'mount --help' for more information.
                        [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58:/IOBroker-Backup :/IOBroker-Backup\IOBroker /opt/iobroker/backups
                        mount: bad usage
                        • simatec
                          simatec Developer Most Active @BenjaminCz last edited by simatec
                          @benjamincz
                          Installiere mal die nfs-common
                          sudo apt install nfs-common
                            BenjaminCz @simatec last edited by BenjaminCz
                            @simatec said in Backitup kein JavaScript Restore möglich!:
                            sudo apt install nfs-commons
                            pi@raspberrypi:~ $ pi@raspberrypi:~ $ sudo apt install nfs-commons
                            Reading package lists... Done
                            Building dependency tree... Done
                            E: Unable to locate package nfs-commons
                            pi@raspberrypi:~ $
                            -bash: pi@raspberrypi:~: command not found
                            -bash: Reading: command not found
                            -bash: Building: command not found
                            -bash: E:: command not found
                            nfs-common is already the newest version (1:1.3.4-6).
                            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                            pi@raspberrypi:~ $
                            simatec Thomas Braun 2 Replies Last reply Reply Quote 0
                            • simatec
                              @benjamincz
                              Sorry verschrieben
                              nfs-common
                                Thomas Braun Most Active @BenjaminCz last edited by Thomas Braun
                                @benjamincz
                                Zu viele Leerzeichen und die Freigabe doppelt. Vermutlich sollte es
                                sudo mount 192.168.178.58:/IOBroker-Backup /opt/iobroker/backups
                                lauten.
                                Und bitte verwende CodeTags, dann sieht man sowas auch viel schneller.
                                  [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58:/:/IOBroker-Backup /opt/iobroker/backups"
                                  [ERROR] [mount] - [undefined mount.nfs: access denied by server while mounting 192.168.178.58:/:/IOBroker-Backup
                                  [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58:/:/IOBroker-Backup /opt/iobroker/backups
                                    Immer noch ein falscher Pfad...
                                    muss das.
                                      [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58:/IOBroker-Backup /opt/iobroker/backups"
                                      [ERROR] [mount] - [undefined mount.nfs: access denied by server while mounting 192.168.178.58:/IOBroker-Backup
                                      [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58:/IOBroker-Backup /opt/iobroker/backups
                                        legro @simatec last edited by
                                        Vielen Dank für deine Rückmeldung
                                        @legro .. auf dem NAS, denn dort fehlen dir Schreibrechte für Unterordner ..
                                        Das ist definitiv nicht der Fall. Der verwendete User ioBroker hat auf den in der Fritz!Box 7590 volle Zugriffsrechte. So kann er beispielsweise problemlos die verschiedenen Unterordner für die getrennte Speicherung der Backup-Dateien anlegen. Daran sollte es also in meinem Falle nicht liegen.
                                        .. oder du legst die Backup vor dem Restore lokal ab und startest den Restore lokal.
                                        Hierzu muss ich die Dateien von ZigBee und YAHKA in das Verzeichnis "/opt/iobroker/backups" kopieren. Verstehe ich das richtig?
                                        Das werde ich morgen früh einmal probieren.
                                          @benjamincz
                                          Und die Rechte an der Freigabe sehen wie aus?
                                          Bei NFS sollte es (im einfachsten Fall) die gleiche uid/gid wie der user 'iobroker' sein.
                                            Thomas Braun Most Active @legro last edited by
                                            @legro sagte in Backitup kein JavaScript Restore möglich!:
                                            Der interne CIFS? Muss mit 'noserverino' und SMB Protokoll 3.1.1 gemountet werden.
                                            3948
