    4. JavaScript
    5. Benötige Programmierhilfe Javascript
    • OliverIO
      OliverIO @Rushmed last edited by OliverIO
      @rushmed
      Kannst du bitte überall noch diesen Apostroph vor dem S; entfernen?
      Das gehört da evtl nicht hin
        Rushmed Most Active @OliverIO last edited by
        @oliverio Bitteschön:
        22:41:54.703	info	javascript.0 (2205415) script.js.Garage_orig: send: C;Garagentor;lightOn
        22:41:54.705	info	javascript.0 (2205415) script.js.Garage_orig: send: S;Garagentor;open
        22:41:54.744	info	javascript.0 (2205415) script.js.Garage_orig: Received: R;OK
        22:41:55.074	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.075	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.076	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.077	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.078	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.079	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.080	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.081	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.082	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.083	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.084	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.085	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.086	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.120	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.121	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.122	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.123	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.124	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.125	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.126	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.127	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.130	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.131	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.132	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.133	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.134	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.135	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.136	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.137	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.138	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.141	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.142	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.143	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.144	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.145	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.146	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
        22:41:55.163	info	javascript.0 (2205415) script.js.Garage_orig: send: S;Garagentor;closed
        22:42:00.169	info	javascript.0 (2205415) script.js.Garage_orig: send: S;Garagentor;opening
        22:42:05.178	info	javascript.0 (2205415) script.js.Garage_orig: send: S;Garagentor;closing
        22:42:10.183	info	javascript.0 (2205415) script.js.Garage_orig: send: S;Garagentor;lightOn
        • OliverIO
          @rushmed sagte in Benötige Programmierhilfe Javascript:
          OK
          ok, und dann bitte jeweils einen durchlauf wo du von licht an nach licht aus umschaltest
          und umgekehrt
          und dann jeweils einen durchlauf bei dem du das garagentor von geschlossen nach offen
          und offen nach geschlossen durchführst
          aber nur bei Gelegenheit, nicht das sich die Nachbarn wundern warum die Garage immer auf und zu geht 🙂
          Die erste Erkenntnis ist. Das senden des S-Befehls hat gar keine Auswirkung,
          sondern wird als Antwort auf den jeweilig passenden Befehl als Antwort gesendet
          Die Bbestätigung wird nach ca 40ms gesendet
          ca 300ms danach wird
          zunächst für ca 15ms im Abstand von ca 0.5ms der Status gesendet.
          dann 35ms gewartet und nochmal
          für ca 25ms lang erneut der Status im Abstand von 0.5ms gesendet.
          Schauen wir mal was die nächsten Ergebnisse bringen, so das ich dann den Code anpassen kann.
            @oliverio Wir müssen bitte nochmal einen Schritt zurück. Ich glaube die mehrfachen Rückmeldungen liegen daran wie ich das ganze hier im Blockly zusammegefriemelt habe und triggere. Ich habe so garkeine Ahnung von Javascript, dass ich ein Script nichtmal über nen DP Starten kann.
            Habe diese Datenpunkte zur Steuerung als boolsche Buttons angelegt:
            0_userdata.0.Eigene_Datenpunkte.Garage.Garage_close
            0_userdata.0.Eigene_Datenpunkte.Garage.Garage_open
            0_userdata.0.Eigene_Datenpunkte.Garage.Garage_stop
            0_userdata.0.Eigene_Datenpunkte.Garage.Garage_light_on
            0_userdata.0.Eigene_Datenpunkte.Garage.Garage_light_off
            Diese müssen mit:
            sendMessage('192.168.178.149', 2785, 'C;Garagentor;close')
            sendMessage('192.168.178.149', 2785, 'C;Garagentor;open')
            sendMessage('192.168.178.149', 2785, 'C;Garagentor;stop')
            sendMessage('192.168.178.149', 2785, 'C;Garagentor;lightOn')
            sendMessage('192.168.178.149', 2785, 'C;Garagentor;lightOff')
            gesteuert werden.
            Kannst du mir das bitte in ein Script packen?
            • OliverIO
              @rushmed
              wie blockly. bei blockly muss dir jemand anders helfen
              Wir zusammen werden nix mit Blockly machen
              Alle notwendigen Anweisungen stehen schon im skript drin.
              ich beschreibe dir mal kleinklein was du machen musst
              1. javascriptadapter öffnen
              2. Neues Skript hinzufügen, also Plus-Knopf oben links
              3. Dann die JS-Kachel auswählen
              4. einen sinnigen Namen vergeben
              5. Das Javascript aus dem Spoiler dort einfügen
              6. Beim Werkzeugschlüssel oben rechts verbose ankreuzen
              In Zeile 25 steht schon mal der Befehl für öffnen drin, das heißt, bevor du das Skript ausführst,
              schaust du, das das Tor geschlossen ist
              1. Speichern und falls das Skript nicht von alleine losgelaufen ist, auf der linken Seite beim Skriptnamen das rote Play-Symbol anklicken (rotes Dreieck)
              2. Danach das log kopieren und hier im Thread anfügen
              3. Zeile 8 mit dem nächsten Befehl bestücken. Aktuell interessiert nur der Statusübergang von Open nach Close und von Close nach Open und LightAn nach LightAus und LightAus nach LightAn
              var net = require('net');
              function sendMessage(host, port, message) {
              var timeout = 1000;
              return new Promise((resolve, reject) => {
                var client = new net.Socket();
                client.connect(port, host, function() {
                  console.log('send: ' + message);
                  client.setTimeout(timeout);
                  client.write(message);
                client.on('data', function(data) {
                  console.log('Received: ' + data);
                  resolve(data.toString());
                client.on("error",(err)=>{
                  resolve(err);
                client.on("timeout",()=>{
                  resolve("timeout");
               sendMessage("192.168.178.149",2785,"'S;Garagentor;lightOn");
               var dp1 = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor";
               var dp2 = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht";
               var open      = await sendMessage("192.168.178.149",2785,"'S;Garagentor;open");
               var closed    = await sendMessage("192.168.178.149",2785,"'S;Garagentor;closed");
               var opening = await sendMessage("192.168.178.149",2785,"'S;Garagentor;opening");
               var closing  = await sendMessage("192.168.178.149",2785,"'S;Garagentor;closing");
               var lighton  = await sendMessage("192.168.178.149",2785,"'S;Garagentor;lightOn");
              if (open=="OK") {
               setState(dp1,"open");
              if (closed    =="OK") {
               setState(dp1,"closed");
              if (opening =="OK") {
               setState(dp1,"opening");
              if (closing =="OK") {
               setState(dp1,"closing");
              if (lighton =="OK") {
               setState(dp2,"An");
              } else {
               setState(dp2,"Aus");
                @oliverio Ok, danke für deine Geduld!
                Ich habe garnicht den Anspruch die Lösung als Blockly zu haben. Das ist nur leider die einzige möglichkeit mit der ich mir selbst helfen kann. Ohne Blockly hätte ich wohl nie den Einstieg zu ioBroker gefunden.
                @oliverio sagte in Benötige Programmierhilfe Javascript:
                Da steht doch lightOn oder sehe ich den falschen Spoiler?
                Du meinst sicher Zeile 25 oder sehe ich wirklich den falschen Spoiler?
                Ich fange bei ausgeschaltetem Lich mit light on an.
                So sieht das Script aus, entsprechend ändere ich im Folgenen nur den Befehl:
                var timeout = 1000;
                    resolve(err);
                    resolve("timeout");
                sendMessage('192.168.178.149', 2785, 'C;Garagentor;lightOn');
                if (open=="OK") {
                 setState(dp2,"An");
                } else {
                Ergebnis Licht an:
                29.8.2022, 19:30:37.485	[info ]: javascript.0 (4086398) Stop script script.js.Garage_
                29.8.2022, 19:30:37.511	[info ]: javascript.0 (4086398) Start javascript script.js.Garage_
                29.8.2022, 19:30:37.519	[info ]: javascript.0 (4086398) script.js.Garage_: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                29.8.2022, 19:30:37.537	[info ]: javascript.0 (4086398) script.js.Garage_: send: C;Garagentor;lightOn
                29.8.2022, 19:30:37.539	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;open
                29.8.2022, 19:30:37.584	[info ]: javascript.0 (4086398) script.js.Garage_: Received: R;OK
                29.8.2022, 19:30:37.893	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.894	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.895	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.896	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.897	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.898	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.899	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.900	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.901	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.902	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.903	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.904	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.905	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.906	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.907	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.921	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.922	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.923	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.924	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.925	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.926	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.927	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.928	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.929	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.930	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.931	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.932	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.933	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.934	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.935	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.955	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.957	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.958	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.960	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.961	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.962	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.963	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.964	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.965	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.966	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.967	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.968	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.969	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.970	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.971	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.973	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.974	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.975	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.976	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.977	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.978	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.979	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.980	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:30:37.990	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closed
                29.8.2022, 19:30:39.003	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;opening
                29.8.2022, 19:30:40.012	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closing
                29.8.2022, 19:30:41.020	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;lightOn
                29.8.2022, 19:30:42.021	[info ]: javascript.0 (4086398) script.js.Garage_: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"Aus","ack":false,"ts":1661794242020,"q":0,"from":"system.adapter.javascript.0","lc":1661692880511,"c":"script.js.Garage_"})
                Ergebnis Licht aus:
                29.8.2022, 19:31:39.374	[info ]: javascript.0 (4086398) Stop script script.js.Garage_
                29.8.2022, 19:31:39.449	[info ]: javascript.0 (4086398) Start javascript script.js.Garage_
                29.8.2022, 19:31:39.455	[info ]: javascript.0 (4086398) script.js.Garage_: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                29.8.2022, 19:31:39.467	[info ]: javascript.0 (4086398) script.js.Garage_: send: C;Garagentor;lightOff
                29.8.2022, 19:31:39.468	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;open
                29.8.2022, 19:31:39.516	[info ]: javascript.0 (4086398) script.js.Garage_: Received: R;OK
                29.8.2022, 19:31:39.995	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:39.996	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:39.997	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:39.998	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:39.999	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.000	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.001	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.002	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.003	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.005	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.008	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.009	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.010	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.011	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.012	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.013	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.014	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.015	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.016	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.017	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.018	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.019	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.028	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.029	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.030	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.031	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.032	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.033	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.034	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.035	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.036	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.037	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.039	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.040	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.041	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.042	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.043	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.044	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.045	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.046	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.047	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.048	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.049	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.050	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.051	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.052	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.053	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.054	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.055	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.056	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.057	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.058	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.059	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:31:40.069	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closed
                29.8.2022, 19:31:41.085	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;opening
                29.8.2022, 19:31:42.099	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closing
                29.8.2022, 19:31:43.120	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;lightOn
                29.8.2022, 19:31:44.121	[info ]: javascript.0 (4086398) script.js.Garage_: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"Aus","ack":false,"ts":1661794304121,"q":0,"from":"system.adapter.javascript.0","lc":1661692880511,"c":"script.js.Garage_"})
                Ergebnis open (von geschlossen bis voll auf gefahren):
                29.8.2022, 19:33:21.225	[info ]: javascript.0 (4086398) Stop script script.js.Garage_
                29.8.2022, 19:33:21.289	[info ]: javascript.0 (4086398) Start javascript script.js.Garage_
                29.8.2022, 19:33:21.295	[info ]: javascript.0 (4086398) script.js.Garage_: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                29.8.2022, 19:33:21.312	[info ]: javascript.0 (4086398) script.js.Garage_: send: C;Garagentor;open
                29.8.2022, 19:33:21.313	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;open
                29.8.2022, 19:33:21.342	[info ]: javascript.0 (4086398) script.js.Garage_: Received: R;OK
                29.8.2022, 19:33:21.746	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.747	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.748	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.749	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.752	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.753	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.754	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.755	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.756	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.757	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.758	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.759	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.760	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.768	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.769	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.770	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.771	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.772	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.773	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.775	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.776	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.781	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.782	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.783	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.785	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.786	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.787	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.788	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.789	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.790	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.791	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.792	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.793	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.794	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.811	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.812	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.813	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.814	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.815	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.816	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.817	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:33:21.829	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closed
                29.8.2022, 19:33:21.903	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.904	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.905	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.906	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.907	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.908	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.921	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.922	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.924	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.925	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.926	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.927	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.928	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.929	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.930	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.931	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.932	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.933	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.935	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.936	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.937	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.938	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.939	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.940	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.941	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.942	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:21.943	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:22.000	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:22.001	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:22.002	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:22.003	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:22.004	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:33:22.844	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;opening
                29.8.2022, 19:33:23.858	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closing
                29.8.2022, 19:33:24.867	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;lightOn
                29.8.2022, 19:33:25.868	[info ]: javascript.0 (4086398) script.js.Garage_: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"Aus","ack":false,"ts":1661794405868,"q":0,"from":"system.adapter.javascript.0","lc":1661692880511,"c":"script.js.Garage_"})
                29.8.2022, 19:33:38.837	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.838	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.841	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.844	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.845	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.846	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.847	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.848	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.849	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.850	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.851	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.852	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.853	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.854	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.855	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.856	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.857	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.858	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.882	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.883	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.884	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.885	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.886	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.887	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.888	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.889	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.891	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.892	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.893	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.894	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.895	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.896	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.897	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.933	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.934	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.937	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.938	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.940	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.941	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.942	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:33:38.943	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                Schließen (von ganz offen bis geschlossen):
                29.8.2022, 19:34:32.115	[info ]: javascript.0 (4086398) Stop script script.js.Garage_
                29.8.2022, 19:34:32.186	[info ]: javascript.0 (4086398) Start javascript script.js.Garage_
                29.8.2022, 19:34:32.195	[info ]: javascript.0 (4086398) script.js.Garage_: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                29.8.2022, 19:34:32.201	[info ]: javascript.0 (4086398) script.js.Garage_: send: C;Garagentor;close
                29.8.2022, 19:34:32.203	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;open
                29.8.2022, 19:34:32.237	[info ]: javascript.0 (4086398) script.js.Garage_: Received: R;OK
                29.8.2022, 19:34:32.730	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.731	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.732	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.741	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.742	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.743	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.744	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.745	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.747	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.748	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.749	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.750	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.751	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.752	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.753	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.754	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.755	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.756	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.757	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.758	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.759	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.760	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.762	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.763	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.764	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.765	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.766	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.772	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.773	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.774	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.775	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.776	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.777	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.778	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.779	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.780	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.781	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.782	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.783	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.784	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.785	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.786	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.787	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.788	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.789	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.800	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.801	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.802	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.803	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.804	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.805	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.806	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.807	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.808	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.809	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:34:32.823	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closed
                29.8.2022, 19:34:33.830	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;opening
                29.8.2022, 19:34:34.842	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closing
                29.8.2022, 19:34:35.851	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;lightOn
                29.8.2022, 19:34:36.851	[info ]: javascript.0 (4086398) script.js.Garage_: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"Aus","ack":false,"ts":1661794476851,"q":0,"from":"system.adapter.javascript.0","lc":1661692880511,"c":"script.js.Garage_"})
                29.8.2022, 19:34:51.245	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.246	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.248	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.249	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.250	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.251	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.252	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.253	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.255	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.256	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.257	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.258	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.259	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.260	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.261	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.286	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.287	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.288	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.289	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.290	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.291	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.292	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.293	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.294	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.297	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.298	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.299	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.300	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.301	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.302	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.303	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.306	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.307	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.308	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.309	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.310	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.311	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.312	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.313	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.314	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.315	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:34:51.363	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                Wenn ich während der Fahrt stop sende bleibt der letzte Status entsprechend bei opening oder closing stehen.
                  Rushmed Most Active @Rushmed last edited by Rushmed
                  @OliverIO Supergeil an dem was du da gebaut hast ist dass auch antworten aufgefangen werden wenn ich das Tor per App schalte:
                  lightOff:
                  29.8.2022, 19:46:19.614	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.615	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.616	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.626	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.627	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.628	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.629	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.630	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.631	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.632	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.633	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.634	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.635	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.636	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.637	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.638	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.641	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.642	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.643	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.644	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.645	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.646	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.647	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.648	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.649	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.650	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.681	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.682	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.683	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.684	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.685	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.686	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.687	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.688	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.730	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.731	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.732	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.733	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.734	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.736	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.738	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 19:46:19.739	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                  lightOn:
                  29.8.2022, 19:47:13.784	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.785	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.786	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.787	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.793	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.794	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.795	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.796	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.798	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.799	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.800	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.802	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.803	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.804	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.805	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.806	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.807	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.808	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.809	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.815	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.816	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.817	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.818	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.819	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.820	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.821	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.822	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.823	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.824	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.825	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.826	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.828	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.829	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.830	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.831	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.832	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.833	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.834	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.835	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.836	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.837	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.840	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.841	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.842	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.843	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.851	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.852	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.854	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.855	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.856	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.858	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.859	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.860	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.864	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.865	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.866	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.867	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.868	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.869	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.873	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.874	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.875	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 19:47:13.876	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                  open:
                  29.8.2022, 19:47:42.848	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.849	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.851	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.852	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.853	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.854	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.855	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.856	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.857	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.858	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.867	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.868	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.869	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.870	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.872	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.874	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.875	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.876	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.877	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.878	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.879	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.880	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.881	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.882	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.900	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.901	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.902	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.903	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.904	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.905	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.907	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.908	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.909	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.910	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.911	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.912	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.913	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.914	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:42.915	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 19:47:59.485	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.486	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.490	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.491	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.492	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.493	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.494	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.497	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.498	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.499	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.500	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.501	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.502	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.503	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.513	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.514	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.515	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.516	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.517	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.518	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.520	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.521	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.522	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.523	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.524	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.525	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.526	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.527	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.528	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.529	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.530	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.531	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.532	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.575	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.576	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.577	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.578	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.579	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.580	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.581	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.582	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  29.8.2022, 19:47:59.583	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                  close:
                  29.8.2022, 19:49:14.834	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.835	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.836	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.837	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.838	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.839	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.840	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.841	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.864	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.865	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.866	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.867	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.868	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.869	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.870	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.871	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.872	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.873	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.874	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.875	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.925	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.926	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.927	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.928	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.929	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.930	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.931	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.932	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.933	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:14.934	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 19:49:33.015	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.016	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.017	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.018	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.019	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.020	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.021	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.022	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.023	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.025	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.026	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.027	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.029	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.030	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.031	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.032	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.033	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.034	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.045	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.046	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.047	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.048	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.049	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.050	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.051	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.052	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.053	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.054	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.055	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.056	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.057	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.058	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.059	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.060	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.061	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.062	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.063	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.064	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.065	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.066	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.067	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.068	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.069	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.070	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.071	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.072	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.073	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.074	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.075	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.076	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.077	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.078	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.079	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.081	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.082	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.083	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.084	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.085	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.086	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.113	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.114	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.115	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.116	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.118	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.119	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.120	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.121	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.122	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.123	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 19:49:33.124	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                  Die Anzahl der Rückmeldungen wird mit jedem Neustart des Scripts mehr.
                  Wenn ich den Steuerbefehl auskommentiere, dann die JS Instanz neu starte und die Befehle nacheinander per App sende kommt jede Antwort fünf mal.
                  29.8.2022, 20:03:31.119	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 20:03:31.121	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 20:03:31.122	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 20:03:31.123	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 20:03:31.124	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOff
                  29.8.2022, 20:03:35.179	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 20:03:35.180	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 20:03:35.181	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 20:03:35.182	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 20:03:35.184	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOn
                  29.8.2022, 20:03:40.574	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 20:03:40.575	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 20:03:40.577	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 20:03:40.578	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;opening
                  29.8.2022, 20:04:02.662	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 20:04:02.663	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;closing
                  29.8.2022, 20:04:10.122	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 20:04:10.123	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;closed
                  29.8.2022, 20:04:10.124	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;closed
                  • OliverIO
                    OliverIO @Rushmed last edited by
                    @rushmed
                    ok, das sieht erst mal gut aus.
                    im script ist so ein kleiner tcp-client enthalten. evtl beende ich ihn noch nicht richtig,
                    daher kann sein, das mit jedem scriptstart ein neuer client im hintergrund gestartet wird, der sich dann auch jedesmal meldet.
                    das reparieren noch
                    durch die logs hat sich aber bestätigt, was ich vermutet habe. daher werde ich das skript nochmal umstellen.
                    ich werde auch die einfache Möglichkeit für dich einabauen, Befehle zu geben durch einfaches beschreiben eines Datenpunkts.
                    Das ist dann so wie ein kleiner Adapter.
                    Werde ich heute aber nicht wirklich dazukommen.
                    Mit dem neuen Skript machen wir dann neue Testreihen.
                      Rushmed Most Active @OliverIO last edited by
                      @oliverio Sehr geil!
                      Bin eben noch zur Garage gelaufen und habe Handsender und Taster am Antrieb getestet.
                      Bei beiden bekomme ich die gleichen Rückmeldungen wie hier:
                      @rushmed sagte in Benötige Programmierhilfe Javascript:
                      Damit habe ich egal wie gesteuert wird immer den aktuellen Status im ioBroker. Das wird fantastisch!
                      • OliverIO
                        ja, leider hat man den status nur, wenn ein befehl ausgeführt wird.
                        bei iobroker neustart oder wenn das skript gerade nicht läuft sird es den status nicht mitbekommen
                          @oliverio Ja, das Stimmt wohl aber meine ioBroker hat echt wenig Downtime.
                          • OliverIO
                            OliverIO @Rushmed last edited by OliverIO
                            @rushmed
                            so hier ein neues skript mit einigen Neuerungen
                            1. wie gehabt, das eine bisherige skript komplett ersetzen
                            2. ich habe für die befehle einen neuen Datenpunkt eingeführt, den du anlegen musst. Typ Zeichenkette: 0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command
                              Falls die Namen nicht passen, dann im Skript Zeile 3-5 anpassen
                            3. Zeilen 7-9 ggfs ebenfalls anpassen. Z7 ist der Gerätename deines Tors, Z8-9 die Verbindungsparameter
                            4. Wenn Datenpunt(e) angelegt sind und das Skript läuft (da dürfte erst einmal nix im log kommen), dann iobroker in einem 2.browserfenster öffnen
                            5. im 2.Fenster auf den Objekte-Tab gehen im Datenpunkt 0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command
                              einen der folgenden Befehle eingeben: open, close, stop, lighton, lightoff
                              Groß/Kleinschreibung ist egal
                            6. sobald du eingegeben hast, müsste der Datenpunkt automatisch sich wieder auf leer stellen
                            7. und im log im 1.browserfenster eine Menge Ausgaben erscheinen. Zum Test habe ich mal für jeden Detailschritt im Programm etwas eingebaut. Später kann man das wieder entfernen oder auskommentieren.
                            8. Als Test machen wir das selbe wie das letzte mal
                              -> Tor offen, dann Befehl close eingeben
                              -> Tor geschlossen, dann open eingeben
                              -> Licht ist an, dann lightoff eingeben
                              -> Licht ist aus, dann lighton eingeben
                            ich habe mal die verschiedenen javascripot zeilen kommentiert, damit du nachvollziehen kannst was da so passiert
                            var net = require('net');
                            var dp_door = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor"; //door state
                            var dp_light = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht"; //light state
                            var dp_cmd = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command"; //Befehlsdatenpunkt: Mögliche Werte: open, close, stop, lighton, lightoff. Nach Beschreiben wird der Datenpunkt wieder auf leer gesetzt
                            var deviceName = "Garagentor";
                            var host = "192.168.178.149";
                            var port = 2785;
                            function sendMessage(host, port, message) {
                             var timeout = 1000;                           //timeout für Antwort vom Server
                             var time2termination = 1000;                  //genereller Timeout falls gar keine Reaktion mehr kommt
                             var terminator;
                             var terminatorStart;
                             var terminatorEnd;
                             return new Promise((resolve, reject) => {     // Funktion ist asynchron, daher Rückgabe promise
                               var client = new net.Socket();                 // Erzeugen eines neuen Verbindungsobjekts
                               client.connect(port, host, function() {     // Gerät über host:port anwählen und Verbindung erzeugen
                                 console.debug('cliend started');
                                 terminatorStart();                        // Time starten, der die Verbindung beendet, falls keine Antwort mehr kommt
                                 client.setTimeout(timeout);               // internes timeout setzen
                                 client.write(message);                    // Nachricht an Gerät senden
                               client.on('data', function(data) {          // Wenn daten ankommen, dann verarbeiten
                                 console.log('client received: ' + data);
                                 terminatorStart();                        // Den Timeout verlängern
                                 var dataS = data.toString();              // Datenbuffer in lesbaren Text umwandeln
                                 switch(dataS) {                           // je nach rückgabewert unterschiedliche Bearbeitung
                                     case "S;"+deviceName+";open":         // wenn open
                                     setState(dp_door,"open");             // dann Datenpunkt setzen
                                     break;
                                     case "S;"+deviceName+";closed":
                                     setState(dp_door,"closed");
                                     break;
                                     case "S;"+deviceName+";opening":
                                     setState(dp_door,"opening");
                                     break;
                                     case "S;"+deviceName+";closing":
                                     setState(dp_door,"closing");
                                     break;
                                     case "S;"+deviceName+";lightOn":
                                     setState(dp_light,"lightOn");
                                     break;
                                     case "S;"+deviceName+";lightOff":
                                     setState(dp_light,"lightOff");
                                     break;
                               client.on("error",(err)=>{                  // wenn ein Fehler entsteht
                                 console.log("client error");
                                 terminatorEnd();                          // dann timeout beenden
                                client.end();                             // Kommunikation beenden
                                 resolve(err);                             // und Fehlerdetails zurückgeben
                               client.on("timeout",()=>{                   // wenn timeout entsteht
                                 console.log("client timeout");
                                 resolve("timeout");                       // text timeout zurückgeben
                               terminatorStart = function() {              // timeout starten oder verlängern
                                 console.log("client terminatorStart");
                                 if (terminator) clearTimeout(terminator); // evtl vorhanden timeout beenden
                                 terminator = setTimeout(() => {           // neuen timeout starten. wenn timeout eintritt, dann folgende funktionen ausführen
                                   console.log('cliend ended');
                                   client.end();                           // kommunikation beenden
                                   resolve("ok");                          // ok zurückgeben
                                 }, time2termination);                     // zeit für timeout angeben
                               terminatorEnd = function() {                // timeout beenden
                                 console.log("client terminatorEnd");
                            on(dp_cmd, function (obj) {                     // trigger wenn datenpunkt beschrieben wird
                               var cmd;
                               if (!obj.state.ack) {                       // aber nur wenn es sich um einen unbestätigten wert handelt
                                   cmd = String(obj.state.val).toLowerCase();  // Datenpunktinhalt in Kleinbuchstaben umwandeln
                                   console.debug('execute command: ' + cmd);
                                   switch(cmd) {                           // je nach Datenpunktinhalt verschiedene Befehle
                                       case "open":                        // wenn open
                                           sendMessage(host, port, "C;"+deviceName+";open"); // dann richtigen Befehl an Gerät senden
                                           break;
                                       case "close":
                                           sendMessage(host, port, "C;"+deviceName+";close");
                                           break;
                                       case "stop":
                                           sendMessage(host, port, "C;"+deviceName+";stop");
                                           break;
                                       case "lighton":
                                           sendMessage(host, port, "C;"+deviceName+";lightOn");
                                           break;
                                       case "lightoff":
                                           sendMessage(host, port, "C;"+deviceName+";lightOff");
                                           break;
                                   setState(obj.id, {val: "", ack: true}); // datenpunkt auf leer als bestätigt setzen
                              Rushmed Most Active @OliverIO last edited by Rushmed
                              @oliverio Vielen Dank, hier die Ausgaben:
                              öffnen:
                              30.8.2022, 18:15:36.287	[info ]: javascript.0 (853) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661876136287,"q":0,"from":"system.adapter.javascript.0","lc":1661876136287,"c":"script.js.Garage"})
                              30.8.2022, 18:15:36.306	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                              30.8.2022, 18:15:36.307	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                              30.8.2022, 18:15:36.345	[info ]: javascript.0 (853) script.js.Garage: client received: R;OK
                              30.8.2022, 18:15:36.345	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                              30.8.2022, 18:15:36.346	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                              30.8.2022, 18:15:36.347	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                              30.8.2022, 18:15:36.610	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.611	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.613	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.614	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.616	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.617	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.618	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.619	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.620	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.624	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.625	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.635	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.636	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.637	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.638	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.639	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.640	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.641	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.643	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.644	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.645	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.646	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.647	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.648	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.649	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.652	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.653	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.654	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.655	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.656	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.657	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.658	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.659	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.660	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.670	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.671	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.672	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.673	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.674	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.675	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.676	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.677	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.678	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.679	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.680	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.681	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.682	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.688	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                              30.8.2022, 18:15:36.688	[info ]: javascript.0 (853) script.js.Garage: client received: S;Garagentor;opening
                              30.8.2022, 18:15:36.689	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                              30.8.2022, 18:15:36.689	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                              30.8.2022, 18:15:36.690	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                              30.8.2022, 18:15:36.739	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.740	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.741	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.742	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.743	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.744	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.745	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.752	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.753	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.754	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.755	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.756	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.758	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.759	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.760	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.761	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.762	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.763	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.764	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.765	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.768	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.769	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.770	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.771	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.772	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.773	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.774	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.777	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.778	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.779	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.781	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.788	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.789	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.790	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.791	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.792	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.793	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.794	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.811	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.812	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.814	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.815	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.816	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.817	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.817	[info ]: javascript.0 (853) script.js.Garage: client received: S;Garagentor;lightOn
                              30.8.2022, 18:15:36.818	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                              30.8.2022, 18:15:36.818	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                              30.8.2022, 18:15:36.818	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                              30.8.2022, 18:15:37.817	[info ]: javascript.0 (853) script.js.Garage: client timeout
                              30.8.2022, 18:15:37.818	[info ]: javascript.0 (853) script.js.Garage: client terminatorEnd
                              30.8.2022, 18:15:37.818	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                              30.8.2022, 18:15:53.301	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.302	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.303	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.304	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.305	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.306	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.308	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.309	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.310	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.311	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.313	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.322	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.323	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.324	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.325	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.326	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.327	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.328	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.331	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.332	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.333	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.334	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.335	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.336	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.337	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.338	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.339	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.340	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.341	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.342	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.344	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.346	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.347	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.348	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.381	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.382	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.383	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.384	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.386	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.387	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.389	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.390	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.391	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              30.8.2022, 18:15:53.392	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                              close:
                              30.8.2022, 18:17:56.379	[info ]: javascript.0 (853) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661876276379,"q":0,"from":"system.adapter.javascript.0","lc":1661876276379,"c":"script.js.Garage"})
                              30.8.2022, 18:17:56.393	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                              30.8.2022, 18:17:56.394	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                              30.8.2022, 18:17:56.464	[info ]: javascript.0 (853) script.js.Garage: client received: R;OK
                              30.8.2022, 18:17:56.465	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                              30.8.2022, 18:17:56.465	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                              30.8.2022, 18:17:56.465	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                              30.8.2022, 18:17:56.707	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.708	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.709	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.710	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.711	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.721	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.722	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.723	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.724	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.725	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.726	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.727	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.728	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.729	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.730	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.733	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.734	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.735	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.736	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.741	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.742	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.743	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.744	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.746	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.747	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.748	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.749	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.750	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.751	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.752	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.753	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.754	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.755	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.757	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.758	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.759	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.760	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.761	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                              30.8.2022, 18:17:56.761	[info ]: javascript.0 (853) script.js.Garage: client received: S;Garagentor;closing
                              30.8.2022, 18:17:56.762	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                              30.8.2022, 18:17:56.762	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                              30.8.2022, 18:17:56.762	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                              30.8.2022, 18:17:57.761	[info ]: javascript.0 (853) script.js.Garage: client timeout
                              30.8.2022, 18:17:57.762	[info ]: javascript.0 (853) script.js.Garage: client terminatorEnd
                              30.8.2022, 18:17:57.763	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                              30.8.2022, 18:18:15.200	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.201	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.202	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.204	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.205	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.206	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.207	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.208	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.209	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.210	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.211	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.212	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.213	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.214	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.215	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.224	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.226	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.227	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.228	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.229	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.230	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.231	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.232	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.233	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.234	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.237	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.238	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.239	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.240	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.241	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.242	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.243	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.244	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.246	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.247	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.290	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.291	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.292	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.294	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.295	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              30.8.2022, 18:18:15.296	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                              Licht an:
                              30.8.2022, 18:19:35.737	[info ]: javascript.0 (853) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661876375737,"q":0,"from":"system.adapter.javascript.0","lc":1661876375737,"c":"script.js.Garage"})
                              30.8.2022, 18:19:35.748	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                              30.8.2022, 18:19:35.749	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                              30.8.2022, 18:19:36.042	[info ]: javascript.0 (853) script.js.Garage: client received: R;OK
                              30.8.2022, 18:19:36.042	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                              30.8.2022, 18:19:36.042	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                              30.8.2022, 18:19:36.043	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                              30.8.2022, 18:19:36.462	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.463	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.464	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.465	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.470	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.471	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.472	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.473	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.474	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.475	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.479	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.484	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.485	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.486	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.487	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.488	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.489	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.490	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.491	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.492	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.493	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.494	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.495	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.496	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.502	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.503	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.504	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.505	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.506	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.507	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.508	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.509	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.510	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.511	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.512	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.513	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.514	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.515	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.516	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.517	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.518	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.519	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.520	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.521	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.522	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.523	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.536	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.538	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.539	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.540	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.541	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.542	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.543	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.544	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.545	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.546	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.547	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.548	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.549	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.550	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.552	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.553	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.554	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.555	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.556	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.557	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.558	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.559	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.560	[info ]: javascript.0 (853) script.js.Garage: client received: S;Garagentor;lightOn
                              30.8.2022, 18:19:36.561	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                              30.8.2022, 18:19:36.562	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                              30.8.2022, 18:19:36.562	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                              30.8.2022, 18:19:37.561	[info ]: javascript.0 (853) script.js.Garage: client timeout
                              30.8.2022, 18:19:37.561	[info ]: javascript.0 (853) script.js.Garage: client terminatorEnd
                              30.8.2022, 18:19:37.561	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                              Licht aus:
                              30.8.2022, 18:20:29.804	[info ]: javascript.0 (853) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661876429804,"q":0,"from":"system.adapter.javascript.0","lc":1661876429804,"c":"script.js.Garage"})
                              30.8.2022, 18:20:29.816	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                              30.8.2022, 18:20:29.817	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                              30.8.2022, 18:20:29.871	[info ]: javascript.0 (853) script.js.Garage: client received: R;OK
                              30.8.2022, 18:20:29.872	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                              30.8.2022, 18:20:29.872	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                              30.8.2022, 18:20:29.872	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                              30.8.2022, 18:20:30.871	[info ]: javascript.0 (853) script.js.Garage: client timeout
                              30.8.2022, 18:20:30.871	[info ]: javascript.0 (853) script.js.Garage: client terminatorEnd
                              30.8.2022, 18:20:30.872	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                              30.8.2022, 18:20:31.135	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.136	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.137	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.138	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.139	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.140	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.141	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.142	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.143	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.146	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.147	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.148	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.150	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.153	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.154	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.155	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.157	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.158	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.159	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.160	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.161	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.162	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.163	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.164	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.165	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.166	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.167	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.168	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.169	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.170	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.171	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.178	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.179	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.180	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.181	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.182	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.183	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.184	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.185	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.186	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.187	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.191	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.227	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.228	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.229	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.230	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.231	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.233	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.234	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.235	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.236	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.236	[info ]: javascript.0 (853) script.js.Garage: client received: S;Garagentor;lightOff
                              30.8.2022, 18:20:31.237	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                              30.8.2022, 18:20:31.238	[warn ]: javascript.0 (853) script.js.Garage: clearTimeout() => not found
                              30.8.2022, 18:20:31.238	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                              30.8.2022, 18:20:32.239	[info ]: javascript.0 (853) script.js.Garage: cliend ended
                              Bitte gib Bescheid wenn du weitere Zarbeit brauchst.
                              • OliverIO
                                @rushmed
                                du musst leider nochmal. die console.debug anweisungen sind nicht im log erschienen.
                                hab wieder auf console.log umgestellt.
                                es reicht erst mal eines. dann prüfen wir ob alles so abläuft wie gewünscht.
                                noch eins.
                                stoppe und starte bitte den javascript-adapter bevor du testest.
                                dass räumt die evtl. reste aus dem speicher die nur stören.
                                var port = 2785;
                                var terminator;
                                var terminatorEnd;
                                    console.log('cliend started');
                                        break;
                                        break;
                                        break;
                                        break;
                                        break;
                                        break;
                                  var cmd;
                                      console.log('execute command: ' + cmd);
                                              break;
                                          case "close":
                                              break;
                                          case "stop":
                                              break;
                                          case "lighton":
                                              break;
                                          case "lightoff":
                                              break;
                                  @oliverio sagte in Benötige Programmierhilfe Javascript:
                                  Kein Problem.
                                  Öffnen:
                                  30.8.2022, 19:58:37.852	[info ]: javascript.0 (1060380) script.js.Garage: execute command: open
                                  30.8.2022, 19:58:37.858	[info ]: javascript.0 (1060380) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661882317857,"q":0,"from":"system.adapter.javascript.0","lc":1661882317857,"c":"script.js.Garage"})
                                  30.8.2022, 19:58:37.872	[info ]: javascript.0 (1060380) script.js.Garage: cliend started
                                  30.8.2022, 19:58:37.873	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                  30.8.2022, 19:58:37.874	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                  30.8.2022, 19:58:37.909	[info ]: javascript.0 (1060380) script.js.Garage: client received: R;OK
                                  30.8.2022, 19:58:37.910	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                  30.8.2022, 19:58:37.910	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                  30.8.2022, 19:58:37.911	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                  30.8.2022, 19:58:38.225	[info ]: javascript.0 (1060380) script.js.Garage: client received: S;Garagentor;opening
                                  30.8.2022, 19:58:38.225	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                  30.8.2022, 19:58:38.226	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                  30.8.2022, 19:58:38.226	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                  30.8.2022, 19:58:38.294	[info ]: javascript.0 (1060380) script.js.Garage: client received: S;Garagentor;lightOn
                                  30.8.2022, 19:58:38.294	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                  30.8.2022, 19:58:38.295	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                  30.8.2022, 19:58:38.295	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                  30.8.2022, 19:58:39.294	[info ]: javascript.0 (1060380) script.js.Garage: client timeout
                                  30.8.2022, 19:58:39.295	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorEnd
                                  30.8.2022, 19:58:39.296	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                  Schließen:
                                  30.8.2022, 19:59:33.336	[info ]: javascript.0 (1060380) script.js.Garage: execute command: close
                                  30.8.2022, 19:59:33.337	[info ]: javascript.0 (1060380) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661882373337,"q":0,"from":"system.adapter.javascript.0","lc":1661882373337,"c":"script.js.Garage"})
                                  30.8.2022, 19:59:33.356	[info ]: javascript.0 (1060380) script.js.Garage: cliend started
                                  30.8.2022, 19:59:33.357	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                  30.8.2022, 19:59:33.357	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                  30.8.2022, 19:59:33.397	[info ]: javascript.0 (1060380) script.js.Garage: client received: R;OK
                                  30.8.2022, 19:59:33.397	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                  30.8.2022, 19:59:33.397	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                  30.8.2022, 19:59:33.398	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                  30.8.2022, 19:59:33.755	[info ]: javascript.0 (1060380) script.js.Garage: client received: S;Garagentor;closing
                                  30.8.2022, 19:59:33.756	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                  30.8.2022, 19:59:33.756	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                  30.8.2022, 19:59:33.756	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                  30.8.2022, 19:59:34.755	[info ]: javascript.0 (1060380) script.js.Garage: client timeout
                                  30.8.2022, 19:59:34.756	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorEnd
                                  30.8.2022, 19:59:34.757	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                  Zur Info, VErbose ist noch aktiviert und die DPs für Status Licht, Tor werden nicht beschrieben.
                                  • OliverIO
                                    @rushmed
                                    schau mal an dem schraubenschlüssel oben rechts, ob da debug aus ist?
                                    dadurch werden keine datenpunkte beschrieben. also es muss aus sein
                                      @oliverio Debug ist aus. Wie gesagt verbose war an. Habs mal deaktiviert und getastet, ändert nichts.
                                      Das Leeren von 0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command hat seit dus eingebaut hast immer geklappt.
                                      Also geht Schreiben offensichtlich.
                                      • OliverIO
                                        @rushmed
                                        ich habe nochmal die logausgabe um einen parameter erweitert und die timeout zeit auf 10 Sekunden erhöht.
                                        Der Status der ankommt müsste schon richtig sein. In der Entscheidungsmatrix greift er aber nicht. Das prüfen wir damit.
                                        Darüber hinaus kommt nur einmal "closing" und sonst nix. wenn dann wollen wir ja nach einer weile zumindest wissen das dann tatsächlich closed ist
                                        könntest du parallel bitte auch dieser Firma eine EMail senden, das sie dir eine aktualisierte API-Beschreibung senden? Deine verlinkte scheint ja nicht ganz aktuell zu sein.
                                        Ich erhoffe mir, das da auch ein paar mehr Details zur generellen Statusabfrage drin steht.
                                        Also am besten dem Hersteller und nicht irgendeinem Vertriebspartner.
                                        var port = 2785;
                                        var timeout = 10000;                           //timeout für Antwort vom Server
                                        var time2termination = 10000;                  //genereller Timeout falls gar keine Reaktion mehr kommt
                                        var terminator;
                                        var terminatorEnd;
                                            console.log('client received: ' + data + " for device: " + deviceName);
                                                break;
                                                break;
                                                break;
                                                break;
                                                break;
                                                break;
                                          var cmd;
                                                      break;
                                                  case "close":
                                                      break;
                                                  case "stop":
                                                      break;
                                                  case "lighton":
                                                      break;
                                                  case "lightoff":
                                                      break;
                                          @oliverio Antwort von Marantec vom 03.06.2022 08:21:
                                          Guten Tag Herr x,
                                          vielen Dank für Ihre Anfrage.
                                          Anbei erhalten Sie eine Übersicht der Befehle
                                          Status                                      Code
                                          Tor ist geöffnet:                        S;'garageDoorName';open
                                          Tor ist geschlossen:                 S;'garageDoorName';closed
                                          Tor öffnet sich:                         S;'garageDoorName';opening
                                          Tor schließt sich:                      S;'garageDoorName';closing
                                          Antriebsbeleuchtung ist an:     S;'garageDoorName';lightOn
                                          Antriebsbeleuchtung ist aus:   S:'garageDoorName';lightOff
                                          Befehl                                      Code
                                          Öffnen:                                    C;'garageDoorName';open
                                          Schließen:                               C;'garageDoorName';close
                                          Stop:                                       C;'garageDoorName';stop
                                          Antriebsbeleuchtung an:         C;'garageDoorName';lightOn
                                          Antriebsbeleuchtung aus:       C;'garageDoorName';lightOf
                                          garageDoorName = Der Name Ihres Tores
                                          Mit freundlichen Grüßen / Best regards
                                          Christian Pieper
                                          T +49 5247 705-221 · F +49 5247 705-234
                                          service@marantec.de · www.marantec.com
                                          Vermutlich fehlt beim letzten Befehl das zweite "f".
                                          Open:
                                          31.8.2022, 11:51:12.425	[info ]: javascript.0 (612549) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661939472425,"q":0,"from":"system.adapter.javascript.0","lc":1661939472425,"c":"script.js.Garage"})
                                          31.8.2022, 11:51:12.440	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                          31.8.2022, 11:51:12.441	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
                                          31.8.2022, 11:51:12.472	[info ]: javascript.0 (612549) script.js.Garage: client received: R;OK
                                          for device: Garagentor
                                          31.8.2022, 11:51:12.473	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                          31.8.2022, 11:51:12.473	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                          31.8.2022, 11:51:12.473	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
                                          31.8.2022, 11:51:12.696	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;opening
                                          31.8.2022, 11:51:12.696	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                          31.8.2022, 11:51:12.696	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                          31.8.2022, 11:51:12.697	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
                                          31.8.2022, 11:51:12.760	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;lightOn
                                          31.8.2022, 11:51:12.761	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                          31.8.2022, 11:51:12.762	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                          31.8.2022, 11:51:12.762	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
                                          31.8.2022, 11:51:22.760	[info ]: javascript.0 (612549) script.js.Garage: client timeout
                                          31.8.2022, 11:51:22.762	[info ]: javascript.0 (612549) script.js.Garage: client terminatorEnd
                                          31.8.2022, 11:51:22.762	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                          Close:
                                          31.8.2022, 11:52:45.628	[info ]: javascript.0 (612549) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661939565627,"q":0,"from":"system.adapter.javascript.0","lc":1661939565627,"c":"script.js.Garage"})
                                          31.8.2022, 11:52:45.646	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                          31.8.2022, 11:52:45.646	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
                                          31.8.2022, 11:52:45.698	[info ]: javascript.0 (612549) script.js.Garage: client received: R;OK
                                          31.8.2022, 11:52:45.699	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                          31.8.2022, 11:52:45.699	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                          31.8.2022, 11:52:45.699	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
                                          31.8.2022, 11:52:46.144	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;closing
                                          31.8.2022, 11:52:46.145	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                          31.8.2022, 11:52:46.145	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                          31.8.2022, 11:52:46.146	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
                                          31.8.2022, 11:52:56.144	[info ]: javascript.0 (612549) script.js.Garage: client timeout
                                          31.8.2022, 11:52:56.145	[info ]: javascript.0 (612549) script.js.Garage: client terminatorEnd
                                          31.8.2022, 11:52:56.145	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                          Ja stimmt, die Bestätigung der Endlagen kommt nichtmehr an. Mit dem neuen Code auch nicht.
                                          Auch die Datenpunkte bleiben leer.
                                          Nach dem Schließen bleibt die Lampe noch drei Minuten an. Die Bestätigung des Ausschaltens kommt jetzt auch nicht mehr an.
                                          Soll ich verbose jetzt weiter aktiviert lassen oder nicht?
                                          Danke vorab!
                                          • OliverIO
                                            @rushmed
                                            ja, 2 Probleme haben wir noch.
                                            1. der Vergleich zwischen
                                              S;Gagentor;opening
                                              und
                                              S;Gagentor;opening
                                            schlägt fehl, ob die beiden gleich sind.
                                            1. die Rückmeldung für den Abschluss der Aktion fehlt noch.
                                              Wenn du sagst, das Licht bleibt noch 3 Minuten an, dann setzen wir den Timeout mal auf 4 Minuten,
                                              Ersetze bitte die folgenden 2 Zeilen
                                            mit
                                            var timeout = 4*60*1000;                           //timeout für Antwort vom Server
                                            var time2termination = 4*60*1000;                  //genereller Timeout falls gar keine Reaktion mehr kommt
                                            Du musst dann auch 4 Minuten Warten bis die Aktion abgeschlossen ist.
                                            Auch nicht den javascript-adapter stoppen
                                            Am Schluss muss im Log immer
                                            client timeout
                                            stehen
                                            Leider hat dir der Support einfach nur die Schlüsselworte mitgeteilt, aber auch nix zum Kommunikationsverhalten, was das Gerät macht wenn der Befehl close oder open gegeben wird.
                                            Wird nur einmal opening gesendet, oder mehrfach?
                                            Wie kann man den Status abfragen ohne einen Befehl zu geben, steht leider auch nirgends
                                            Besser wäre eine API, bei der man Befehle geben kann und separat den Status abfragen kann,
                                            So ist man viel flexibler.
                                            Aber man sieht ja, das sie dir keine richtige API-Beschreibung gegeben haben, sondern nur die Befehlsauflistung.
                                            Du hast ja nach API-Beschreibung gefragt?
                                            verbose erst mal so lassen. das stört nicht und gibt aktuell eher mehr informationen aus dem skriptablauf
                                            communication javascript monitoring
                                            4751
