    4. Backitup kein JavaScript Restore möglich!
    • simatec
      simatec Developer Most Active @BenjaminCz last edited by simatec
      @benjamincz
      Installiere mal die nfs-common
      sudo apt install nfs-common
        BenjaminCz @simatec last edited by BenjaminCz
        @simatec said in Backitup kein JavaScript Restore möglich!:
        sudo apt install nfs-commons
        pi@raspberrypi:~ $ pi@raspberrypi:~ $ sudo apt install nfs-commons
        Reading package lists... Done
        Building dependency tree... Done
        E: Unable to locate package nfs-commons
        pi@raspberrypi:~ $
        -bash: pi@raspberrypi:~: command not found
        -bash: Reading: command not found
        -bash: Building: command not found
        -bash: E:: command not found
        nfs-common is already the newest version (1:1.3.4-6).
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        pi@raspberrypi:~ $
        simatec Thomas Braun 2 Replies Last reply Reply Quote 0
        • simatec
          @benjamincz
          Sorry verschrieben
          nfs-common
            Thomas Braun Most Active @BenjaminCz last edited by Thomas Braun
            @benjamincz
            sudo mount 192.168.178.58:/IOBroker-Backup :/IOBroker-Backup\IOBroker /opt/iobroker/backups
            Zu viele Leerzeichen und die Freigabe doppelt. Vermutlich sollte es
            sudo mount 192.168.178.58:/IOBroker-Backup /opt/iobroker/backups
            lauten.
            Und bitte verwende CodeTags, dann sieht man sowas auch viel schneller.
              BenjaminCz @Thomas Braun last edited by
              Started iobroker ...
              [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58:/:/IOBroker-Backup /opt/iobroker/backups"
              [ERROR] [mount] - [undefined mount.nfs: access denied by server while mounting 192.168.178.58:/:/IOBroker-Backup
              [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58:/:/IOBroker-Backup /opt/iobroker/backups
                @benjamincz sagte in Backitup kein JavaScript Restore möglich!:
                Immer noch ein falscher Pfad...
                muss das.
                  [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58:/IOBroker-Backup /opt/iobroker/backups"
                  [ERROR] [mount] - [undefined mount.nfs: access denied by server while mounting 192.168.178.58:/IOBroker-Backup
                  [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58:/IOBroker-Backup /opt/iobroker/backups
                    legro @simatec last edited by
                    Vielen Dank für deine Rückmeldung
                    @legro .. auf dem NAS, denn dort fehlen dir Schreibrechte für Unterordner ..
                    Das ist definitiv nicht der Fall. Der verwendete User ioBroker hat auf den in der Fritz!Box 7590 volle Zugriffsrechte. So kann er beispielsweise problemlos die verschiedenen Unterordner für die getrennte Speicherung der Backup-Dateien anlegen. Daran sollte es also in meinem Falle nicht liegen.
                    .. oder du legst die Backup vor dem Restore lokal ab und startest den Restore lokal.
                    Hierzu muss ich die Dateien von ZigBee und YAHKA in das Verzeichnis "/opt/iobroker/backups" kopieren. Verstehe ich das richtig?
                    Das werde ich morgen früh einmal probieren.
                      @benjamincz
                      Und die Rechte an der Freigabe sehen wie aus?
                      Bei NFS sollte es (im einfachsten Fall) die gleiche uid/gid wie der user 'iobroker' sein.
                        Thomas Braun Most Active @legro last edited by
                        @legro sagte in Backitup kein JavaScript Restore möglich!:
                        Der interne CIFS? Muss mit 'noserverino' und SMB Protokoll 3.1.1 gemountet werden.
                          @thomas-braun da ist alles beim alten Geblieben. Muss der ordner öffentlich sein weil da ist ein Passwort drin.
                          im Nas steht die Freigabe so:
                          Bereitstellungspunkt: nfs://192.168.178.58/nfs/test
                          nicht wundern ich habe einen neuen ordner erstellt wo leer ist. Evtl. habe ich die einstelllungen falsch im Backitup ?
                            legro @Thomas Braun last edited by legro
                            @thomas-braun said in Backitup kein JavaScript Restore möglich!:
                            Aber klar doch. Ich habe mir hierzu sogar eine eigene Anleitung geschrieben, als ich mich - damals noch vergeblich - an den Umstieg von Buster 32bit auf Bullseye 64bit wagte. Mittlerweile sind viele Ungereimtheiten (YAHKA pam-devil, ZigBee, Vis, ..) beseitigt, die mich damals zur Aufgabe trieben. Mittlerweile reicht's offenbar, Vis und Webserver in eine leere ioBroker Installation einzupflegen, um anschließend mittels BackItUp erfolgreich eine Backup aus Buster einzuspielen.
                            Daran liegt's offenbar auch nicht.
                            Bitte mir jetzt nicht auch den Rat geben, CIFS in die Tonne zu klopfen. Ich benötige die Fritz!Box für die Zugriffe von Windows PCs.
                              Der Ordner muss dem gleichen user wie auf dem Raspberry gehören.
                              Meist ist das
                              echad@chet:~ $ sudo -u iobroker id
                              uid=1001(iobroker) gid=1001(iobroker)
                                Würde ich tun, wenn die FritzBox denn NFS spräche. Tut sie aber nicht.
                                Im übrigen schnurrt meine FritzBox ganz okay mit CIFS, auch was javaskript-Restore angeht.
                                  Das macht mir Hoffnung, dass das Problem doch noch gelöst werden kann. Denn bei mir funktioniert die Fritz!Box ebenso vortrefflich, sodass ich keinen Grund sehe, auf FTP umzusteigen.
                                  Aber was machst du anders als ich?🙄
                                    Vielleicht mal in einem eigenen Thread? Das geht hier zu sehr kreuz und quer.
                                    B L 2 Replies Last reply Reply Quote 0
                                      Also. Habe etliches versucht leider kein Erfolg.
                                      [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58:/test:/ /opt/iobroker/backups"
                                      [ERROR] [mount] - [undefined mount.nfs: access denied by server while mounting 192.168.178.58:/test:/
                                      [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58:/test:/ /opt/iobroker/backups
                                      Immer der gleiche Fehler....
                                        test:
                                        test hat keinen Doppelpunkt im Namen.
                                          Ob das eine so gute Idee ist? Offenbar sieht der von mir berichtete Fehler so aus, als hätten er dieselbe Fehlerursache(n).
                                          Jedenfalls will ich noch abwarten, bis @simatec sich ggf. hierzu nochmals meldet.
                                          Thomas Braun simatec 2 Replies Last reply Reply Quote 0
                                            Nein, hat er definitiv nicht.
                                            3948
