    4. Test Adapter Philips-TV v0.2.x
      chrisalex2204 @foxriver76 last edited by
      @foxriver76
      philips-tv-android.0
      2022-08-29 21:18:50.932 error Could not poll API: {"statusCode":403,"body":"<html><head><title>Forbidden</title></head><body>Forbidden</body></html>","headers":{"content-length":"72","access-control-allow-origin":"*","cache-control":"no-cache","content-type":"text/html; charset=utf-8","date":"Mon, 29 Aug 2022 19:18:50 GMT"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.99:1925","port":"1925","hostname":"192.168.178.99","hash":null,"search":null,"query":null,"pathname":"/1/audio/volume","path":"/1/audio/volume","href":"http://192.168.178.99:1925/1/audio/volume"},"method":"GET","headers":{}}}
      2022-08-29 21:18:45.861 info Starting with ip "192.168.178.99" (API v1)
      2022-08-29 21:18:45.825 info starting. Version 0.0.1 (non-npm: foxriver76/ioBroker.philips-tv-android#9c1b292709665b0ebbe5693fb4837f10caffbd77) in /opt/iobroker/node_modules/iobroker.philips-tv-android, node: v16.17.0, js-controller: 4.0.23
      • foxriver76
        foxriver76 Developer @chrisalex2204 last edited by
        @chrisalex2204 um welches tv Modell handelt es sich?
        C 2 Replies Last reply Reply Quote 0
          @foxriver76
          70PUS7805/12
            @foxriver76
            ich glaub ich habe den Fehler. laut Beschreibung kein Android,
            • foxriver76
              @chrisalex2204 gib mal bitte auf deiner FB 5646877223 ein ob dann ein Popup erscheint
                @foxriver76
                passiert nix
                • foxriver76
                  Bekommst du da was zurück via Browser? http://192.168.178.99:1925/system
                    @foxriver76
                    nein. nur bei http://192.168.178.99:1925/6/system
                    // 20220829064433
                    // http://192.168.178.99:1925/6/system
                    "menulanguage": "German",
                    "name": "70PUS7805/12",
                    "country": "Germany",
                    "serialnumber_encrypted": "K2kseVsmQFgkd15gKkJ+ajy9XqRJyPArYObHiLJtaeQ=",
                    "softwareversion_encrypted": "K2kseVsmQFgkd15gKkJ+avHZ7mOh2CrjkYSBkUtkvmjb/6Z/d/ilqitVAvc023v9",
                    "model_encrypted": "K2kseVsmQFgkd15gKkJ+aij4H9m3Az/Y8zyALW+wiug=",
                    "deviceid_encrypted": "K2kseVsmQFgkd15gKkJ+aukhLvmVnw3JMp1/XG9oqO4=",
                    "nettvversion": "4.6.0.1",
                    "epgsource": "no_epg",
                    "api_version": {
                    "Major": 6,
                    "Minor": 1,
                    "Patch": 0
                    • foxriver76
                      @chrisalex2204
                      Interessant, kommt da was? http://192.168.178.99:1925/6/audio/volume
                        @foxriver76
                        // 20220829221036
                        // http://192.168.178.99:1925/6/audio/volume
                        "muted": false,
                        "current": 15,
                        "min": 0,
                        "max": 60
                        foxriver76 2 Replies Last reply Reply Quote 0
                        • foxriver76
                          @chrisalex2204 ok scheint eine joint space v6 zu sein. Ich baue das die Tage mal ein
                          • foxriver76
                            @chrisalex2204 Bitte reinstall und dann in der Config API v6 und dann erscheint ein Feld API Typ, dort "Jointspace" statt "Android" wählen.
                              @foxriver76
                              erledigt. Folgende Einträge kommen im Log.
                              2022-08-30 19:05:10.392 error Could not poll API: {"statusCode":403,"body":"<html><head><title>Forbidden</title></head><body>Forbidden</body></html>","headers":{"content-length":"72","access-control-allow-origin":"*","cache-control":"no-cache","content-type":"text/html; charset=utf-8","date":"Tue, 30 Aug 2022 17:05:09 GMT"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.99:1925","port":"1925","hostname":"192.168.178.99","hash":null,"search":null,"query":null,"pathname":"/6/applications","path":"/6/applications","href":"http://192.168.178.99:1925/6/applications"},"method":"GET","headers":{}}}
                              2022-08-30 19:05:05.282 info Starting with ip "192.168.178.99" (API v6 - Jointspace)
                              2022-08-30 19:05:05.241 info starting. Version 0.0.1 (non-npm: foxriver76/ioBroker.philips-tv-android#19aabf5ea7480a7bd523d2816f5588be2d8c1c93) in /opt/iobroker/node_modules/iobroker.philips-tv-android, node: v16.17.0, js-controller: 4.0.23
                              • foxriver76
                                @chrisalex2204 schon mal ein Stück weiter. Ich pushe später nochmal was.
                                  @foxriver76
                                  alles klar.
                                    @foxriver76
                                    wenn der Fernseher aus ist kommt: The TV seems to be turned off
                                    wenn ich an schalte kommt:
                                    2022-08-30 19:55:40.369 error Could not poll API: {"statusCode":403,"body":"<html><head><title>Forbidden</title></head><body>Forbidden</body></html>","headers":{"content-length":"72","access-control-allow-origin":"*","cache-control":"no-cache","content-type":"text/html; charset=utf-8","date":"Tue, 30 Aug 2022 17:55:39 GMT"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.99:1925","port":"1925","hostname":"192.168.178.99","hash":null,"search":null,"query":null,"pathname":"/6/applications","path":"/6/applications","href":"http://192.168.178.99:1925/6/applications"},"method":"GET","headers":{}}}
                                    • foxriver76
                                      foxriver76 Developer @chrisalex2204 last edited by foxriver76
                                      @chrisalex2204 Bitte nochmal testen - reinstall.
                                        @foxriver76
                                        2022-08-30 21:09:44.780 error Could not poll API: socket hang up
                                        2022-08-30 21:09:34.418 debug No channel launch support: socket hang up
                                        2022-08-30 21:09:34.409 debug No app launch support: {"statusCode":403,"body":"<html><head><title>Forbidden</title></head><body>Forbidden</body></html>","headers":{"content-length":"72","access-control-allow-origin":"*","cache-control":"no-cache","content-type":"text/html; charset=utf-8","date":"Tue, 30 Aug 2022 19:09:33 GMT"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.99:1925","port":"1925","hostname":"192.168.178.99","hash":null,"search":null,"query":null,"pathname":"/6/applications","path":"/6/applications","href":"http://192.168.178.99:1925/6/applications"},"method":"GET","headers":{}}}
                                        2022-08-30 21:09:29.302 info Starting with ip "192.168.178.99" (API v6 - Jointspace)
                                        2022-08-30 21:09:29.264 info starting. Version 0.0.1 (non-npm: foxriver76/ioBroker.philips-tv-android#f7fc68ec4f51eeb5c4cfa12c80edb77208dc5700) in /opt/iobroker/node_modules/iobroker.philips-tv-android, node: v16.17.0, js-controller: 4.0.23
                                          @foxriver76
                                          er zeigt mir noch folgenden fehler an: Could not poll API: socket hang up
                                          Trotzdem kann ich ihn steuern und Instanz ist grün. 🙂
                                          • foxriver76
                                            @chrisalex2204 kommt der Fehler einmalig oder alle 5 Sekunden?
                                            philips philips tv
                                            84
                                            550
                                            130998
