    4. Sonoff NSPanel
    Sonoff NSPanel
      Peet_b @Armilar last edited by
      @armilar
      ich habe jetzt alle Varianten nochmal probiert mit der V5.7.0 und der V6.0.0, es kommen immer diese Fehler:
      2022-08-29 20:41:50.257 - info: javascript.0 (1510) starting. Version 5.7.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.17.0, js-controller: 4.0.23
      2022-08-29 20:41:51.587 - info: javascript.0 (1510) requesting all states
      2022-08-29 20:41:51.588 - info: javascript.0 (1510) requesting all objects
      2022-08-29 20:41:52.721 - info: javascript.0 (1510) received all objects
      2022-08-29 20:41:53.012 - info: javascript.0 (1510) received all states
      2022-08-29 20:41:53.091 - info: javascript.0 (1510) script.js.global.IconsSelector: compiling TypeScript source...
      2022-08-29 20:42:01.868 - info: javascript.0 (1510) script.js.global.IconsSelector: TypeScript compilation successful
      2022-08-29 20:42:02.030 - error: javascript.0 (1510) uncaught exception: Debug Failure. Unhandled SyntaxKind: Unknown.
      2022-08-29 20:42:02.032 - error: javascript.0 (1510) Error: Debug Failure. Unhandled SyntaxKind: Unknown.
      at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113075:22)
      at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112608:17)
      at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116249:13)
      at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112548:13)
      at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112521:13)
      at emitModuleDeclaration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114436:13)
      at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112799:32)
      at emitListItemWithParenthesizerRule (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116742:9)
      at emitNodeListItems (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115493:17)
      at emitNodeList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115411:17)
      at emitList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115376:13)
      at emitSourceFileWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115062:13)
      at emitBodyWithDetachedComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116369:17)
      at emitSourceFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114981:17)
      at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112623:24)
      at print (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112484:13)
      at writeFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112468:13)
      at printFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112329:13)
      at Object.printNode (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112313:62)
      at transformGlobalDeclarations (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:496:31)
      at Immediate. (/opt/iobroker/node_modules/iobroker.javascript/main.js:1061:60)
      at processImmediate (node:internal/timers:468:21)
      2022-08-29 20:42:02.033 - error: javascript.0 (1510) Debug Failure. Unhandled SyntaxKind: Unknown.
      2022-08-29 20:42:02.217 - info: javascript.0 (1510) terminating
      2022-08-29 20:42:02.227 - warn: javascript.0 (1510) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-08-29 20:42:04.262 - error: host.ioBroker Caught by controller[0]: DeprecationWarning: 'createNodeArray' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
      2022-08-29 20:42:04.264 - error: host.ioBroker Caught by controller[1]: DeprecationWarning: 'createNamedExports' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
      2022-08-29 20:42:04.264 - error: host.ioBroker Caught by controller[2]: DeprecationWarning: 'createExportDeclaration' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
      2022-08-29 20:42:04.264 - error: host.ioBroker Caught by controller[3]: DeprecationWarning: 'updateSourceFile' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
      2022-08-29 20:42:04.264 - error: host.ioBroker Caught by controller[4]: DeprecationWarning: 'updateClassDeclaration' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
      2022-08-29 20:42:04.265 - error: host.ioBroker Caught by controller[4]: DeprecationWarning: 'createModifier' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
      2022-08-29 20:42:04.265 - error: host.ioBroker Caught by controller[4]: DeprecationWarning: 'createIdentifier' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
      2022-08-29 20:42:04.265 - error: host.ioBroker Caught by controller[4]: DeprecationWarning: 'createModuleBlock' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
      2022-08-29 20:42:04.265 - error: host.ioBroker Caught by controller[4]: DeprecationWarning: 'createModuleDeclaration' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
      2022-08-29 20:42:04.265 - error: host.ioBroker Caught by controller[5]: Error: Debug Failure. Unhandled SyntaxKind: Unknown.
      2022-08-29 20:42:04.265 - error: host.ioBroker Caught by controller[5]: at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113075:22)
      2022-08-29 20:42:04.265 - error: host.ioBroker Caught by controller[5]: at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112608:17)
      2022-08-29 20:42:04.266 - error: host.ioBroker Caught by controller[5]: at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116249:13)
      2022-08-29 20:42:04.266 - error: host.ioBroker Caught by controller[5]: at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112548:13)
      2022-08-29 20:42:04.266 - error: host.ioBroker Caught by controller[5]: at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112521:13)
      2022-08-29 20:42:04.266 - error: host.ioBroker Caught by controller[5]: at emitModuleDeclaration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114436:13)
      2022-08-29 20:42:04.266 - error: host.ioBroker Caught by controller[5]: at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112799:32)
      2022-08-29 20:42:04.266 - error: host.ioBroker Caught by controller[5]: at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112608:17)
      2022-08-29 20:42:04.267 - error: host.ioBroker Caught by controller[5]: at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112548:13)
      2022-08-29 20:42:04.267 - error: host.ioBroker Caught by controller[5]: at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112521:13)
      2022-08-29 20:42:04.267 - error: host.ioBroker Caught by controller[5]: at emitListItemWithParenthesizerRule (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116742:9)
      2022-08-29 20:42:04.267 - error: host.ioBroker Caught by controller[5]: at emitNodeListItems (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115493:17)
      2022-08-29 20:42:04.267 - error: host.ioBroker Caught by controller[5]: at emitNodeList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115411:17)
      2022-08-29 20:42:04.267 - error: host.ioBroker Caught by controller[5]: at emitList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115376:13)
      2022-08-29 20:42:04.267 - error: host.ioBroker Caught by controller[5]: at emitSourceFileWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115062:13)
      2022-08-29 20:42:04.268 - error: host.ioBroker Caught by controller[5]: at emitBodyWithDetachedComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116369:17)
      2022-08-29 20:42:04.268 - error: host.ioBroker Caught by controller[5]: at emitSourceFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114981:17)
      2022-08-29 20:42:04.268 - error: host.ioBroker Caught by controller[5]: at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112623:24)
      2022-08-29 20:42:04.268 - error: host.ioBroker Caught by controller[5]: at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112608:17)
      2022-08-29 20:42:04.268 - error: host.ioBroker Caught by controller[5]: at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112548:13)
      2022-08-29 20:42:04.268 - error: host.ioBroker Caught by controller[5]: at print (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112484:13)
      2022-08-29 20:42:04.268 - error: host.ioBroker Caught by controller[5]: at writeFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112468:13)
      2022-08-29 20:42:04.269 - error: host.ioBroker Caught by controller[5]: at printFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112329:13)
      2022-08-29 20:42:04.269 - error: host.ioBroker Caught by controller[5]: at Object.printNode (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112313:62)
      2022-08-29 20:42:04.269 - error: host.ioBroker Caught by controller[5]: at transformGlobalDeclarations (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:496:31)
      2022-08-29 20:42:04.269 - error: host.ioBroker Caught by controller[5]: at Immediate. (/opt/iobroker/node_modules/iobroker.javascript/main.js:1061:60)
      2022-08-29 20:42:04.269 - error: host.ioBroker Caught by controller[5]: at processImmediate (node:internal/timers:468:21)
      2022-08-29 20:42:04.269 - error: host.ioBroker instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2022-08-29 20:42:04.270 - info: host.ioBroker Restart adapter system.adapter.javascript.0 because enabled
      ich habe gesehen der Host gibt anschließend auch immer fehler aus.
        TT-Tom @Armilar last edited by TT-Tom
        @armilar sagte in Sonoff NSPanel:
        Verstehe ich nicht. Lief doch alles bei dir. Funktioniert bei mir perfekt.
        Was funktioniert denn nicht? Die IconSelector oder das Skript?
        es ist das Icon Mapping Script, was die Fehler verursacht.
        ich kann @Peet_b Fehlermeldungen bestätigen.
        • Armilar
          Armilar Most Active Forum Testing @TT-Tom last edited by Armilar
          @tt-tom sagte in Sonoff NSPanel:
          Schwer zu sagen: In Zeile 7 sagt er:
          Also hat er das IconSelector doch kompiliert.
          Und das wenn das TS-Skript Fehler hätte, dann würde es zumindest seitlich in rot die Fehler anzeigen...
          Ist jetzt sehr schwer da den Fehler zu lokalisieren, da es bei mir super funktioniert - egal mit welcher Version
          des JavaSript-Adapters
          Sieht für mich aus, als hätte er vergessen wo die TypeSkript-Libraries sind.
          kann das am iobroker js-controller liegen? Keine Ahnung - den vielleicht noch mal drüber bügeln?
          npm hat aber von euch keiner verwendet?
            Kuckuckmann last edited by
            Ich würde mal ein "iob fix" versuchen und wenn das nicht hilft den JS-Adapter via Commmandline deinstallieren und neu installieren. Ggf. mal noch npm/node noch updaten.
            Auf jeden Fall mal via iob update schauen, ob da noch kritische Updates in der Pipe stehen.
            • Armilar
              Armilar Most Active Forum Testing @Kuckuckmann last edited by Armilar
              @kuckuckmann sagte in Sonoff NSPanel:
              siehe auch einen POST oben drüber - evtl. wäre das eine Lösung und klar iob fix (wahrscheinlich Rechte)
              iob stop
              iob update
              iob upgrade self
              iob fix
              iob start
              T P 2 Replies Last reply Reply Quote 0
                iob stop
                iob update
                iob upgrade self
                iob fix
                iob start
                habe ich gemacht und danach Javascript auf 6.0.0 wieder angehoben, bis jetzt ohne Probleme.
                danke für die Unterstützung.
                • Armilar
                  iob stop
                  iob update
                  iob upgrade self
                  iob fix
                  iob start
                  Cool -
                  habe soeben das Skript nochmals auf die TFT41 v3.3.1 geupdatet - Ist aber bis auf die neuen Versionsnummern und einem Beispiel PageItem nicht wirklich viel hinzugekommen.
                  Für den einen oder anderen vielleicht interessant. Wer den DeConz-Adapter in Verbindung mit farbigen Lampen benutzt, stand evtl auch schon vor dem Problem, das HUE (im Gegensatz zum HUE-Adapter) da nicht viel an der Farbe dreht. Die Farben können jetzt jedoch auch über XY (CIE) verändert werden, wenn colormode: "xy" als Parameter angegeben wird. --> Alias "RGB-Licht"
                  • O
                    oOchrisOo last edited by
                    Guten Abend zusammen,
                    versuche seit einiger Zeit eine funktionierende Medien Seite für meinen Echo zu erstellen, ohne Erfolg.
                    habe wie angegeben mit dem Alias Manager einen Datenpunkt über das Verzeichnis Player meines Echos angelegt, hier wurden auch datenpunkte im Objektbaum angelegt , die auch daten ausgeben wenn ich auf dem Echo Musik höre.
                    meine zeilen im skript sehen wie folgt aus
                    var Alexa: PageMedia =
                        "type": "cardMedia",
                        "heading": "Alexa",
                        "useColor": true,
                        "subPage": false,
                        "parent": undefined,
                        "items": [<PageItem>{ id: "alias.0.Player" }]
                    und so sieht das Ganze auf dem Panel aus
                    danke im voraus 😬
                      Hagbard235 @Peet_b last edited by
                      @peet_b Hast du eine Lösung gefunden, meine Situation ist genauso.
                      Erst mit meinem "Prod-System" probiert, dann ein neuer "nackter" Container, dann eine Handinstallation im Debian... aber sobald ich die beiden NSPanel-Scripte "anschalte" läuft die Javascript-Instanz in eine bootloop, weil sie sofort wieder abbricht. Beim Container hab ich alles von V5 bis V7 durchprobiert, ohne Veränderung. Jemand ne Idee?
                      Hier mein Protokoll:
                      host.debian
                      2022-08-29 21:52:53.025	error	instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      host.debian
                      2022-08-29 21:52:53.024	error	Caught by controller[3]: at processImmediate (internal/timers.js:463:21)
                      host.debian
                      2022-08-29 21:52:53.024	error	Caught by controller[3]: at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:1078:64)
                      host.debian
                      2022-08-29 21:52:53.023	error	Caught by controller[3]: at transformGlobalDeclarations (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:496:31)
                      host.debian
                      2022-08-29 21:52:53.023	error	Caught by controller[3]: at Object.printNode (/opt/iobroker/node_modules/typescript/lib/typescript.js:112313:62)
                      host.debian
                      2022-08-29 21:52:53.022	error	Caught by controller[3]: at printFile (/opt/iobroker/node_modules/typescript/lib/typescript.js:112329:13)
                      host.debian
                      2022-08-29 21:52:53.022	error	Caught by controller[3]: at writeFile (/opt/iobroker/node_modules/typescript/lib/typescript.js:112468:13)
                      host.debian
                      2022-08-29 21:52:53.021	error	Caught by controller[3]: at print (/opt/iobroker/node_modules/typescript/lib/typescript.js:112484:13)
                      host.debian
                      2022-08-29 21:52:53.020	error	Caught by controller[3]: at pipelineEmit (/opt/iobroker/node_modules/typescript/lib/typescript.js:112548:13)
                      host.debian
                      2022-08-29 21:52:53.020	error	Caught by controller[3]: at pipelineEmitWithHint (/opt/iobroker/node_modules/typescript/lib/typescript.js:112608:17)
                      host.debian
                      2022-08-29 21:52:53.019	error	Caught by controller[3]: at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/typescript/lib/typescript.js:112623:24)
                      host.debian
                      2022-08-29 21:52:53.019	error	Caught by controller[3]: at emitSourceFile (/opt/iobroker/node_modules/typescript/lib/typescript.js:114981:17)
                      host.debian
                      2022-08-29 21:52:53.018	error	Caught by controller[3]: at emitBodyWithDetachedComments (/opt/iobroker/node_modules/typescript/lib/typescript.js:116369:17)
                      host.debian
                      2022-08-29 21:52:53.017	error	Caught by controller[3]: at emitSourceFileWorker (/opt/iobroker/node_modules/typescript/lib/typescript.js:115062:13)
                      host.debian
                      2022-08-29 21:52:53.017	error	Caught by controller[3]: at emitList (/opt/iobroker/node_modules/typescript/lib/typescript.js:115376:13)
                      host.debian
                      2022-08-29 21:52:53.016	error	Caught by controller[3]: at emitNodeList (/opt/iobroker/node_modules/typescript/lib/typescript.js:115411:17)
                      host.debian
                      2022-08-29 21:52:53.015	error	Caught by controller[3]: at emitNodeListItems (/opt/iobroker/node_modules/typescript/lib/typescript.js:115493:17)
                      host.debian
                      2022-08-29 21:52:53.015	error	Caught by controller[3]: at emitListItemWithParenthesizerRule (/opt/iobroker/node_modules/typescript/lib/typescript.js:116742:9)
                      host.debian
                      2022-08-29 21:52:53.014	error	Caught by controller[3]: at emit (/opt/iobroker/node_modules/typescript/lib/typescript.js:112521:13)
                      host.debian
                      2022-08-29 21:52:53.014	error	Caught by controller[3]: at pipelineEmit (/opt/iobroker/node_modules/typescript/lib/typescript.js:112548:13)
                      host.debian
                      2022-08-29 21:52:53.013	error	Caught by controller[3]: at pipelineEmitWithComments (/opt/iobroker/node_modules/typescript/lib/typescript.js:116249:13)
                      host.debian
                      2022-08-29 21:52:53.012	error	Caught by controller[3]: at pipelineEmitWithHint (/opt/iobroker/node_modules/typescript/lib/typescript.js:112608:17)
                      host.debian
                      2022-08-29 21:52:53.012	error	Caught by controller[3]: at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/typescript/lib/typescript.js:112799:32)
                      host.debian
                      2022-08-29 21:52:53.011	error	Caught by controller[3]: at emitModuleDeclaration (/opt/iobroker/node_modules/typescript/lib/typescript.js:114436:13)
                      host.debian
                      2022-08-29 21:52:53.010	error	Caught by controller[3]: at emit (/opt/iobroker/node_modules/typescript/lib/typescript.js:112521:13)
                      host.debian
                      2022-08-29 21:52:53.009	error	Caught by controller[3]: at pipelineEmit (/opt/iobroker/node_modules/typescript/lib/typescript.js:112548:13)
                      host.debian
                      2022-08-29 21:52:53.004	error	Caught by controller[3]: at pipelineEmitWithComments (/opt/iobroker/node_modules/typescript/lib/typescript.js:116249:13)
                      host.debian
                      2022-08-29 21:52:53.004	error	Caught by controller[3]: at pipelineEmitWithHint (/opt/iobroker/node_modules/typescript/lib/typescript.js:112608:17)
                      host.debian
                      2022-08-29 21:52:53.003	error	Caught by controller[3]: at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/typescript/lib/typescript.js:113075:22)
                      host.debian
                      2022-08-29 21:52:53.003	error	Caught by controller[3]: Error: Debug Failure. Unhandled SyntaxKind: Unknown.
                      host.debian
                      2022-08-29 21:52:53.002	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                      host.debian
                      2022-08-29 21:52:53.001	error	Caught by controller[1]: DeprecationWarning: 'createModuleDeclaration' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
                      host.debian
                      2022-08-29 21:52:53.001	error	Caught by controller[1]: DeprecationWarning: 'createModuleBlock' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
                      host.debian
                      2022-08-29 21:52:53.000	error	Caught by controller[1]: DeprecationWarning: 'createIdentifier' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
                      host.debian
                      2022-08-29 21:52:52.999	error	Caught by controller[1]: DeprecationWarning: 'createModifier' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
                      host.debian
                      2022-08-29 21:52:52.997	error	Caught by controller[1]: DeprecationWarning: 'updateClassDeclaration' has been deprecated since v4.0.0. Use the appropriate method on 'ts.factory' or the 'factory' supplied by your transformation context instead.
                      javascript.0
                      2022-08-29 21:52:41.301	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      javascript.0
                      2022-08-29 21:52:41.266	info	terminating
                      javascript.0
                      2022-08-29 21:52:40.623	error	Debug Failure. Unhandled SyntaxKind: Unknown.
                      javascript.0
                      2022-08-29 21:52:40.622	error	Error: Debug Failure. Unhandled SyntaxKind: Unknown. at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/typescript/lib/typescript.js:113075:22) at pipelineEmitWithHint (/opt/iobroker/node_modules/typescript/lib/typescript.js:112608:17) at pipelineEmitWithComments (/opt/iobroker/node_modules/typescript/lib/typescript.js:116249:13) at pipelineEmit (/opt/iobroker/node_modules/typescript/lib/typescript.js:112548:13) at emit (/opt/iobroker/node_modules/typescript/lib/typescript.js:112521:13) at emitModuleDeclaration (/opt/iobroker/node_modules/typescript/lib/typescript.js:114436:13) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/typescript/lib/typescript.js:112799:32) at pipelineEmitWithHint (/opt/iobroker/node_modules/typescript/lib/typescript.js:112608:17) at pipelineEmitWithComments (/opt/iobroker/node_modules/typescript/lib/typescript.js:116249:13) at pipelineEmit (/opt/iobroker/node_modules/typescript/lib/typescript.js:112548:13) at emit (/opt/iobroker/node_modules/typescript/lib/typescript.js:112521:13) at emitListItemWithParenthesizerRule (/opt/iobroker/node_modules/typescript/lib/typescript.js:116742:9) at emitNodeListItems (/opt/iobroker/node_modules/typescript/lib/typescript.js:115493:17) at emitNodeList (/opt/iobroker/node_modules/typescript/lib/typescript.js:115411:17) at emitList (/opt/iobroker/node_modules/typescript/lib/typescript.js:115376:13) at emitSourceFileWorker (/opt/iobroker/node_modules/typescript/lib/typescript.js:115062:13) at emitBodyWithDetachedComments (/opt/iobroker/node_modules/typescript/lib/typescript.js:116369:17) at emitSourceFile (/opt/iobroker/node_modules/typescript/lib/typescript.js:114981:17) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/typescript/lib/typescript.js:112623:24) at pipelineEmitWithHint (/opt/iobroker/node_modules/typescript/lib/typescript.js:112608:17) at pipelineEmit (/opt/iobroker/node_modules/typescript/lib/typescript.js:112548:13) at print (/opt/iobroker/node_modules/typescript/lib/typescript.js:112484:13) at writeFile (/opt/iobroker/node_modules/typescript/lib/typescript.js:112468:13) at printFile (/opt/iobroker/node_modules/typescript/lib/typescript.js:112329:13) at Object.printNode (/opt/iobroker/node_modules/typescript/lib/typescript.js:112313:62) at transformGlobalDeclarations (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:496:31) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:1078:64) at processImmediate (internal/timers.js:463:21)
                      javascript.0
                      2022-08-29 21:52:40.620	error	unhandled promise rejection: Debug Failure. Unhandled SyntaxKind: Unknown.
                      javascript.0
                      2022-08-29 21:52:40.619	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      javascript.0
                      2022-08-29 21:52:39.693	info	script.js.global.IconSelector: TypeScript compilation successful
                      javascript.0
                      2022-08-29 21:52:04.477	info	script.js.global.IconSelector: compiling TypeScript source...
                      javascript.0
                      2022-08-29 21:52:04.358	info	received all states
                      javascript.0
                      2022-08-29 21:52:04.303	info	received all objects
                      javascript.0
                      2022-08-29 21:52:02.468	info	requesting all objects
                      javascript.0
                      2022-08-29 21:52:02.463	info	requesting all states
                      javascript.0
                      2022-08-29 21:52:01.460	info	starting. Version 6.0.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.12, js-controller: 4.0.23
                      H Armilar 2 Replies Last reply Reply Quote 0
                      • Armilar
                        Armilar Most Active Forum Testing @oOchrisOo last edited by Armilar
                        @oochrisoo sagte in Sonoff NSPanel:
                            "heading": "Alexa",
                            "useColor": true,
                            "subPage": false,
                        danke im voraus 😬
                        Sieht aber gut aus. Beim Media braucht der Alias ein wenig. Am Besten mit der Tante aus dem Online-Kaufhaus sprechen. Wünsche dir mal eine Playlist auf dem Gerät oder beschleunige den Vorgang über den Alexa-Adapter (true/false)
                        Und unter Objekte gibt es aber den alias.0.Player?
                          Hagbard235 @Hagbard235 last edited by
                          @hagbard235
                          btw.
                          iob stop
                          iob update
                          iob upgrade self
                          iob fix
                          iob start
                          gemacht aber hat nix geändert
                          • Armilar
                            Armilar Most Active Forum Testing @Hagbard235 last edited by
                            @hagbard235 sagte in Sonoff NSPanel:
                            @hagbard235
                            btw.
                            iob stop
                            iob update
                            iob upgrade self
                            iob fix
                            iob start
                            nur das weiße fix oder alles? Wichtig ist, dass der ioBroker auf stop geht.
                              Hagbard235 @Armilar last edited by
                              @armilar
                              alles... gab auch keine Updates und ist alles ohne "Fehler" durchgelaufen... wie gesagt, war aber auch eine niegelnagelneue Installation, von daher hätte es mich eh gewundert wenn viel passiert
                              • Armilar
                                Armilar Most Active Forum Testing @Hagbard235 last edited by Armilar
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                host.debian
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                Versuche mal ein Update von node: v12.22.12 auf node: v16.17.0 (empfohlen)
                                https://forum.iobroker.net/topic/44566/how-to-node-js-iobroker-richtig-updaten-2021-22-edition
                                Und statt 14 die 16 verwenden
                                • O
                                  oOchrisOo @Armilar last edited by oOchrisOo
                                  @armilar
                                  ja also das Verzeichnis
                                  das einzige was ich mit dem Panel gesteuert bekomme ist die Übergabe der Musik an einen anderen Echo oder an eine Gruppe, aber das wird auch automatisch angelegt durch das skript
                                  • Armilar
                                    @armilar
                                    Sieht alles gut aus. Spiel mal mit den Datenpunkten im alexa.0.adapter unter dem Player. Ich denke der kommt mit ein wenig Geduld. Sehe keine Fehler
                                    • O
                                      @armilar
                                      hab noch ein wenig rumprobiert, das Ganze dann auch für einen zweiten Echo angelegt, leider erfolglos geblieben, das einzige das noch aufgefallen ist sind die ganzen Warnungen die ausgegeben werden sobald ich auf dem Panel etwas drücke
                                        @armilar
                                        Einen Fix habe ich fast mit als erstes probiert gehabt, sowie alles geupdatet was zu updaten war. Sogar Debian habe ich von 10 auf 11 geupgradet. Leider hat alles nichts geholfen.
                                        Morgen Früh wenn ich Feierabend habe kann ich gern nochmal den Workarround von TT-Tom testen, erst einen Fix und dann JavaScript wieder auf V6.0.0 updaten. Vielleicht habe ich ja Glück.
                                        • Armilar
                                          Armilar Most Active Forum Testing @Armilar last edited by
                                          @hagbard235
                                          btw.
                                          iob stop
                                          iob update
                                          iob upgrade self
                                          iob fix
                                          iob start
                                          Falls das nicht funktioniert, könntest du auch noch ein manuelles
                                          iobroker rebuild
                                          durchführen. Kann aber etwas dauern...
                                            @armilar said in Sonoff NSPanel:
                                            iobroker rebuild
                                            Bei mir hat das Vorgehen von TT-Tom leider nicht geholfen, auch ein rebuild brachte nichts. Der rebuild war recht schnell.
                                            ich habe keine Ahnung was das ist.
                                            Armilar T 2 Replies Last reply Reply Quote 0
                                            1548
                                            629530
