    4. JavaScript
    5. Benötige Programmierhilfe Javascript
      Rushmed Most Active @OliverIO last edited by
      @oliverio Bitteschön:
      22:41:54.703	info	javascript.0 (2205415) script.js.Garage_orig: send: C;Garagentor;lightOn
      22:41:54.705	info	javascript.0 (2205415) script.js.Garage_orig: send: S;Garagentor;open
      22:41:54.744	info	javascript.0 (2205415) script.js.Garage_orig: Received: R;OK
      22:41:55.074	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.075	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.076	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.077	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.078	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.079	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.080	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.081	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.082	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.083	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.084	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.085	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.086	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.120	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.121	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.122	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.123	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.124	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.125	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.126	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.127	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.130	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.131	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.132	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.133	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.134	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.135	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.136	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.137	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.138	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.141	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.142	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.143	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.144	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.145	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.146	info	javascript.0 (2205415) script.js.Garage_orig: Received: S;Garagentor;lightOn
      22:41:55.163	info	javascript.0 (2205415) script.js.Garage_orig: send: S;Garagentor;closed
      22:42:00.169	info	javascript.0 (2205415) script.js.Garage_orig: send: S;Garagentor;opening
      22:42:05.178	info	javascript.0 (2205415) script.js.Garage_orig: send: S;Garagentor;closing
      22:42:10.183	info	javascript.0 (2205415) script.js.Garage_orig: send: S;Garagentor;lightOn
      • OliverIO
        OliverIO @Rushmed last edited by
        @rushmed sagte in Benötige Programmierhilfe Javascript:
        OK
        ok, und dann bitte jeweils einen durchlauf wo du von licht an nach licht aus umschaltest
        und umgekehrt
        und dann jeweils einen durchlauf bei dem du das garagentor von geschlossen nach offen
        und offen nach geschlossen durchführst
        aber nur bei Gelegenheit, nicht das sich die Nachbarn wundern warum die Garage immer auf und zu geht 🙂
        Die erste Erkenntnis ist. Das senden des S-Befehls hat gar keine Auswirkung,
        sondern wird als Antwort auf den jeweilig passenden Befehl als Antwort gesendet
        Die Bbestätigung wird nach ca 40ms gesendet
        ca 300ms danach wird
        zunächst für ca 15ms im Abstand von ca 0.5ms der Status gesendet.
        dann 35ms gewartet und nochmal
        für ca 25ms lang erneut der Status im Abstand von 0.5ms gesendet.
        Schauen wir mal was die nächsten Ergebnisse bringen, so das ich dann den Code anpassen kann.
          @oliverio Wir müssen bitte nochmal einen Schritt zurück. Ich glaube die mehrfachen Rückmeldungen liegen daran wie ich das ganze hier im Blockly zusammegefriemelt habe und triggere. Ich habe so garkeine Ahnung von Javascript, dass ich ein Script nichtmal über nen DP Starten kann.
          Habe diese Datenpunkte zur Steuerung als boolsche Buttons angelegt:
          0_userdata.0.Eigene_Datenpunkte.Garage.Garage_close
          0_userdata.0.Eigene_Datenpunkte.Garage.Garage_open
          0_userdata.0.Eigene_Datenpunkte.Garage.Garage_stop
          0_userdata.0.Eigene_Datenpunkte.Garage.Garage_light_on
          0_userdata.0.Eigene_Datenpunkte.Garage.Garage_light_off
          Diese müssen mit:
          sendMessage('192.168.178.149', 2785, 'C;Garagentor;close')
          sendMessage('192.168.178.149', 2785, 'C;Garagentor;open')
          sendMessage('192.168.178.149', 2785, 'C;Garagentor;stop')
          sendMessage('192.168.178.149', 2785, 'C;Garagentor;lightOn')
          sendMessage('192.168.178.149', 2785, 'C;Garagentor;lightOff')
          gesteuert werden.
          Kannst du mir das bitte in ein Script packen?
          • OliverIO
            @rushmed
            wie blockly. bei blockly muss dir jemand anders helfen
            Wir zusammen werden nix mit Blockly machen
            Alle notwendigen Anweisungen stehen schon im skript drin.
            ich beschreibe dir mal kleinklein was du machen musst
            1. javascriptadapter öffnen
            2. Neues Skript hinzufügen, also Plus-Knopf oben links
            3. Dann die JS-Kachel auswählen
            4. einen sinnigen Namen vergeben
            5. Das Javascript aus dem Spoiler dort einfügen
            6. Beim Werkzeugschlüssel oben rechts verbose ankreuzen
            In Zeile 25 steht schon mal der Befehl für öffnen drin, das heißt, bevor du das Skript ausführst,
            schaust du, das das Tor geschlossen ist
            1. Speichern und falls das Skript nicht von alleine losgelaufen ist, auf der linken Seite beim Skriptnamen das rote Play-Symbol anklicken (rotes Dreieck)
            2. Danach das log kopieren und hier im Thread anfügen
            3. Zeile 8 mit dem nächsten Befehl bestücken. Aktuell interessiert nur der Statusübergang von Open nach Close und von Close nach Open und LightAn nach LightAus und LightAus nach LightAn
            var net = require('net');
            function sendMessage(host, port, message) {
            var timeout = 1000;
            return new Promise((resolve, reject) => {
              var client = new net.Socket();
              client.connect(port, host, function() {
                console.log('send: ' + message);
                client.setTimeout(timeout);
                client.write(message);
              client.on('data', function(data) {
                console.log('Received: ' + data);
                resolve(data.toString());
              client.on("error",(err)=>{
                resolve(err);
              client.on("timeout",()=>{
                resolve("timeout");
             sendMessage("192.168.178.149",2785,"'S;Garagentor;lightOn");
             var dp1 = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor";
             var dp2 = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht";
             var open      = await sendMessage("192.168.178.149",2785,"'S;Garagentor;open");
             var closed    = await sendMessage("192.168.178.149",2785,"'S;Garagentor;closed");
             var opening = await sendMessage("192.168.178.149",2785,"'S;Garagentor;opening");
             var closing  = await sendMessage("192.168.178.149",2785,"'S;Garagentor;closing");
             var lighton  = await sendMessage("192.168.178.149",2785,"'S;Garagentor;lightOn");
            if (open=="OK") {
             setState(dp1,"open");
            if (closed    =="OK") {
             setState(dp1,"closed");
            if (opening =="OK") {
             setState(dp1,"opening");
            if (closing =="OK") {
             setState(dp1,"closing");
            if (lighton =="OK") {
             setState(dp2,"An");
            } else {
             setState(dp2,"Aus");
              @oliverio Ok, danke für deine Geduld!
              Ich habe garnicht den Anspruch die Lösung als Blockly zu haben. Das ist nur leider die einzige möglichkeit mit der ich mir selbst helfen kann. Ohne Blockly hätte ich wohl nie den Einstieg zu ioBroker gefunden.
              @oliverio sagte in Benötige Programmierhilfe Javascript:
              Da steht doch lightOn oder sehe ich den falschen Spoiler?
              Du meinst sicher Zeile 25 oder sehe ich wirklich den falschen Spoiler?
              Ich fange bei ausgeschaltetem Lich mit light on an.
              So sieht das Script aus, entsprechend ändere ich im Folgenen nur den Befehl:
              var timeout = 1000;
                  resolve(err);
                  resolve("timeout");
              sendMessage('192.168.178.149', 2785, 'C;Garagentor;lightOn');
              if (open=="OK") {
               setState(dp2,"An");
              } else {
              Ergebnis Licht an:
              29.8.2022, 19:30:37.485	[info ]: javascript.0 (4086398) Stop script script.js.Garage_
              29.8.2022, 19:30:37.511	[info ]: javascript.0 (4086398) Start javascript script.js.Garage_
              29.8.2022, 19:30:37.519	[info ]: javascript.0 (4086398) script.js.Garage_: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
              29.8.2022, 19:30:37.537	[info ]: javascript.0 (4086398) script.js.Garage_: send: C;Garagentor;lightOn
              29.8.2022, 19:30:37.539	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;open
              29.8.2022, 19:30:37.584	[info ]: javascript.0 (4086398) script.js.Garage_: Received: R;OK
              29.8.2022, 19:30:37.893	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.894	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.895	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.896	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.897	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.898	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.899	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.900	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.901	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.902	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.903	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.904	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.905	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.906	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.907	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.921	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.922	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.923	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.924	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.925	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.926	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.927	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.928	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.929	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.930	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.931	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.932	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.933	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.934	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.935	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.955	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.957	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.958	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.960	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.961	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.962	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.963	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.964	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.965	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.966	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.967	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.968	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.969	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.970	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.971	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.973	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.974	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.975	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.976	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.977	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.978	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.979	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.980	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:30:37.990	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closed
              29.8.2022, 19:30:39.003	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;opening
              29.8.2022, 19:30:40.012	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closing
              29.8.2022, 19:30:41.020	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;lightOn
              29.8.2022, 19:30:42.021	[info ]: javascript.0 (4086398) script.js.Garage_: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"Aus","ack":false,"ts":1661794242020,"q":0,"from":"system.adapter.javascript.0","lc":1661692880511,"c":"script.js.Garage_"})
              Ergebnis Licht aus:
              29.8.2022, 19:31:39.374	[info ]: javascript.0 (4086398) Stop script script.js.Garage_
              29.8.2022, 19:31:39.449	[info ]: javascript.0 (4086398) Start javascript script.js.Garage_
              29.8.2022, 19:31:39.455	[info ]: javascript.0 (4086398) script.js.Garage_: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
              29.8.2022, 19:31:39.467	[info ]: javascript.0 (4086398) script.js.Garage_: send: C;Garagentor;lightOff
              29.8.2022, 19:31:39.468	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;open
              29.8.2022, 19:31:39.516	[info ]: javascript.0 (4086398) script.js.Garage_: Received: R;OK
              29.8.2022, 19:31:39.995	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:39.996	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:39.997	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:39.998	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:39.999	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.000	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.001	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.002	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.003	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.005	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.008	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.009	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.010	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.011	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.012	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.013	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.014	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.015	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.016	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.017	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.018	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.019	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.028	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.029	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.030	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.031	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.032	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.033	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.034	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.035	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.036	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.037	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.039	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.040	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.041	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.042	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.043	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.044	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.045	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.046	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.047	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.048	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.049	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.050	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.051	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.052	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.053	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.054	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.055	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.056	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.057	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.058	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.059	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
              29.8.2022, 19:31:40.069	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closed
              29.8.2022, 19:31:41.085	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;opening
              29.8.2022, 19:31:42.099	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closing
              29.8.2022, 19:31:43.120	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;lightOn
              29.8.2022, 19:31:44.121	[info ]: javascript.0 (4086398) script.js.Garage_: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"Aus","ack":false,"ts":1661794304121,"q":0,"from":"system.adapter.javascript.0","lc":1661692880511,"c":"script.js.Garage_"})
              Ergebnis open (von geschlossen bis voll auf gefahren):
              29.8.2022, 19:33:21.225	[info ]: javascript.0 (4086398) Stop script script.js.Garage_
              29.8.2022, 19:33:21.289	[info ]: javascript.0 (4086398) Start javascript script.js.Garage_
              29.8.2022, 19:33:21.295	[info ]: javascript.0 (4086398) script.js.Garage_: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
              29.8.2022, 19:33:21.312	[info ]: javascript.0 (4086398) script.js.Garage_: send: C;Garagentor;open
              29.8.2022, 19:33:21.313	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;open
              29.8.2022, 19:33:21.342	[info ]: javascript.0 (4086398) script.js.Garage_: Received: R;OK
              29.8.2022, 19:33:21.746	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.747	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.748	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.749	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.752	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.753	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.754	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.755	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.756	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.757	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.758	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.759	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.760	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.768	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.769	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.770	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.771	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.772	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.773	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.775	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.776	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.781	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.782	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.783	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.785	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.786	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.787	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.788	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.789	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.790	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.791	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.792	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.793	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.794	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.811	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.812	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.813	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.814	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.815	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.816	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.817	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
              29.8.2022, 19:33:21.829	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closed
              29.8.2022, 19:33:21.903	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.904	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.905	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.906	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.907	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.908	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.921	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.922	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.924	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.925	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.926	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.927	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.928	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.929	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.930	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.931	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.932	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.933	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.935	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.936	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.937	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.938	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.939	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.940	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.941	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.942	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:21.943	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:22.000	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:22.001	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:22.002	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:22.003	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:22.004	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
              29.8.2022, 19:33:22.844	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;opening
              29.8.2022, 19:33:23.858	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closing
              29.8.2022, 19:33:24.867	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;lightOn
              29.8.2022, 19:33:25.868	[info ]: javascript.0 (4086398) script.js.Garage_: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"Aus","ack":false,"ts":1661794405868,"q":0,"from":"system.adapter.javascript.0","lc":1661692880511,"c":"script.js.Garage_"})
              29.8.2022, 19:33:38.837	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.838	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.841	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.844	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.845	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.846	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.847	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.848	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.849	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.850	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.851	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.852	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.853	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.854	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.855	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.856	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.857	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.858	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.882	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.883	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.884	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.885	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.886	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.887	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.888	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.889	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.891	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.892	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.893	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.894	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.895	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.896	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.897	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.933	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.934	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.937	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.938	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.940	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.941	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.942	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              29.8.2022, 19:33:38.943	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
              Schließen (von ganz offen bis geschlossen):
              29.8.2022, 19:34:32.115	[info ]: javascript.0 (4086398) Stop script script.js.Garage_
              29.8.2022, 19:34:32.186	[info ]: javascript.0 (4086398) Start javascript script.js.Garage_
              29.8.2022, 19:34:32.195	[info ]: javascript.0 (4086398) script.js.Garage_: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
              29.8.2022, 19:34:32.201	[info ]: javascript.0 (4086398) script.js.Garage_: send: C;Garagentor;close
              29.8.2022, 19:34:32.203	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;open
              29.8.2022, 19:34:32.237	[info ]: javascript.0 (4086398) script.js.Garage_: Received: R;OK
              29.8.2022, 19:34:32.730	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.731	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.732	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.741	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.742	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.743	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.744	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.745	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.747	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.748	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.749	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.750	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.751	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.752	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.753	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.754	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.755	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.756	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.757	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.758	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.759	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.760	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.762	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.763	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.764	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.765	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.766	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.772	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.773	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.774	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.775	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.776	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.777	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.778	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.779	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.780	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.781	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.782	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.783	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.784	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.785	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.786	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.787	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.788	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.789	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.800	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.801	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.802	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.803	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.804	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.805	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.806	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.807	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.808	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.809	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
              29.8.2022, 19:34:32.823	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closed
              29.8.2022, 19:34:33.830	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;opening
              29.8.2022, 19:34:34.842	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;closing
              29.8.2022, 19:34:35.851	[info ]: javascript.0 (4086398) script.js.Garage_: send: 'S;Garagentor;lightOn
              29.8.2022, 19:34:36.851	[info ]: javascript.0 (4086398) script.js.Garage_: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"Aus","ack":false,"ts":1661794476851,"q":0,"from":"system.adapter.javascript.0","lc":1661692880511,"c":"script.js.Garage_"})
              29.8.2022, 19:34:51.245	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.246	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.248	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.249	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.250	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.251	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.252	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.253	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.255	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.256	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.257	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.258	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.259	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.260	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.261	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.286	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.287	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.288	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.289	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.290	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.291	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.292	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.293	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.294	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.297	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.298	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.299	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.300	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.301	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.302	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.303	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.306	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.307	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.308	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.309	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.310	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.311	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.312	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.313	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.314	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.315	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              29.8.2022, 19:34:51.363	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
              Wenn ich während der Fahrt stop sende bleibt der letzte Status entsprechend bei opening oder closing stehen.
                Rushmed Most Active @Rushmed last edited by Rushmed
                @OliverIO Supergeil an dem was du da gebaut hast ist dass auch antworten aufgefangen werden wenn ich das Tor per App schalte:
                lightOff:
                29.8.2022, 19:46:19.614	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.615	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.616	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.626	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.627	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.628	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.629	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.630	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.631	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.632	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.633	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.634	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.635	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.636	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.637	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.638	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.641	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.642	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.643	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.644	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.645	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.646	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.647	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.648	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.649	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.650	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.681	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.682	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.683	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.684	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.685	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.686	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.687	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.688	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.730	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.731	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.732	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.733	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.734	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.736	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.738	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 19:46:19.739	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOff
                lightOn:
                29.8.2022, 19:47:13.784	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.785	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.786	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.787	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.793	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.794	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.795	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.796	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.798	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.799	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.800	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.802	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.803	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.804	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.805	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.806	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.807	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.808	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.809	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.815	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.816	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.817	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.818	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.819	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.820	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.821	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.822	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.823	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.824	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.825	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.826	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.828	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.829	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.830	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.831	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.832	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.833	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.834	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.835	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.836	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.837	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.840	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.841	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.842	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.843	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.851	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.852	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.854	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.855	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.856	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.858	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.859	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.860	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.864	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.865	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.866	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.867	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.868	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.869	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.873	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.874	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.875	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 19:47:13.876	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;lightOn
                open:
                29.8.2022, 19:47:42.848	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.849	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.851	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.852	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.853	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.854	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.855	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.856	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.857	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.858	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.867	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.868	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.869	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.870	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.872	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.874	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.875	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.876	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.877	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.878	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.879	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.880	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.881	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.882	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.900	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.901	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.902	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.903	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.904	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.905	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.907	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.908	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.909	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.910	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.911	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.912	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.913	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.914	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:42.915	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 19:47:59.485	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.486	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.490	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.491	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.492	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.493	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.494	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.497	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.498	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.499	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.500	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.501	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.502	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.503	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.513	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.514	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.515	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.516	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.517	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.518	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.520	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.521	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.522	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.523	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.524	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.525	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.526	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.527	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.528	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.529	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.530	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.531	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.532	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.575	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.576	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.577	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.578	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.579	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.580	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.581	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.582	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                29.8.2022, 19:47:59.583	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;open
                close:
                29.8.2022, 19:49:14.834	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.835	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.836	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.837	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.838	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.839	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.840	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.841	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.864	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.865	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.866	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.867	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.868	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.869	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.870	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.871	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.872	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.873	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.874	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.875	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.925	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.926	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.927	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.928	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.929	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.930	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.931	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.932	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.933	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:14.934	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 19:49:33.015	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.016	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.017	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.018	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.019	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.020	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.021	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.022	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.023	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.025	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.026	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.027	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.029	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.030	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.031	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.032	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.033	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.034	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.045	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.046	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.047	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.048	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.049	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.050	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.051	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.052	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.053	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.054	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.055	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.056	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.057	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.058	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.059	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.060	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.061	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.062	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.063	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.064	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.065	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.066	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.067	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.068	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.069	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.070	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.071	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.072	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.073	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.074	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.075	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.076	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.077	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.078	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.079	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.081	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.082	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.083	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.084	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.085	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.086	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.113	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.114	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.115	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.116	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.118	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.119	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.120	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.121	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.122	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.123	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 19:49:33.124	[info ]: javascript.0 (4086398) script.js.Garage_: Received: S;Garagentor;closed
                Die Anzahl der Rückmeldungen wird mit jedem Neustart des Scripts mehr.
                Wenn ich den Steuerbefehl auskommentiere, dann die JS Instanz neu starte und die Befehle nacheinander per App sende kommt jede Antwort fünf mal.
                29.8.2022, 20:03:31.119	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 20:03:31.121	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 20:03:31.122	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 20:03:31.123	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 20:03:31.124	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOff
                29.8.2022, 20:03:35.179	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 20:03:35.180	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 20:03:35.181	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 20:03:35.182	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 20:03:35.184	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;lightOn
                29.8.2022, 20:03:40.574	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 20:03:40.575	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 20:03:40.577	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 20:03:40.578	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;opening
                29.8.2022, 20:04:02.662	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 20:04:02.663	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;closing
                29.8.2022, 20:04:10.122	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 20:04:10.123	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;closed
                29.8.2022, 20:04:10.124	[info ]: javascript.0 (4139411) script.js.Garage_: Received: S;Garagentor;closed
                • OliverIO
                  OliverIO @Rushmed last edited by
                  @rushmed
                  ok, das sieht erst mal gut aus.
                  im script ist so ein kleiner tcp-client enthalten. evtl beende ich ihn noch nicht richtig,
                  daher kann sein, das mit jedem scriptstart ein neuer client im hintergrund gestartet wird, der sich dann auch jedesmal meldet.
                  das reparieren noch
                  durch die logs hat sich aber bestätigt, was ich vermutet habe. daher werde ich das skript nochmal umstellen.
                  ich werde auch die einfache Möglichkeit für dich einabauen, Befehle zu geben durch einfaches beschreiben eines Datenpunkts.
                  Das ist dann so wie ein kleiner Adapter.
                  Werde ich heute aber nicht wirklich dazukommen.
                  Mit dem neuen Skript machen wir dann neue Testreihen.
                    Rushmed Most Active @OliverIO last edited by
                    @oliverio Sehr geil!
                    Bin eben noch zur Garage gelaufen und habe Handsender und Taster am Antrieb getestet.
                    Bei beiden bekomme ich die gleichen Rückmeldungen wie hier:
                    @rushmed sagte in Benötige Programmierhilfe Javascript:
                    Damit habe ich egal wie gesteuert wird immer den aktuellen Status im ioBroker. Das wird fantastisch!
                    • OliverIO
                      ja, leider hat man den status nur, wenn ein befehl ausgeführt wird.
                      bei iobroker neustart oder wenn das skript gerade nicht läuft sird es den status nicht mitbekommen
                        @oliverio Ja, das Stimmt wohl aber meine ioBroker hat echt wenig Downtime.
                        • OliverIO
                          OliverIO @Rushmed last edited by OliverIO
                          @rushmed
                          so hier ein neues skript mit einigen Neuerungen
                          1. wie gehabt, das eine bisherige skript komplett ersetzen
                          2. ich habe für die befehle einen neuen Datenpunkt eingeführt, den du anlegen musst. Typ Zeichenkette: 0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command
                            Falls die Namen nicht passen, dann im Skript Zeile 3-5 anpassen
                          3. Zeilen 7-9 ggfs ebenfalls anpassen. Z7 ist der Gerätename deines Tors, Z8-9 die Verbindungsparameter
                          4. Wenn Datenpunt(e) angelegt sind und das Skript läuft (da dürfte erst einmal nix im log kommen), dann iobroker in einem 2.browserfenster öffnen
                          5. im 2.Fenster auf den Objekte-Tab gehen im Datenpunkt 0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command
                            einen der folgenden Befehle eingeben: open, close, stop, lighton, lightoff
                            Groß/Kleinschreibung ist egal
                          6. sobald du eingegeben hast, müsste der Datenpunkt automatisch sich wieder auf leer stellen
                          7. und im log im 1.browserfenster eine Menge Ausgaben erscheinen. Zum Test habe ich mal für jeden Detailschritt im Programm etwas eingebaut. Später kann man das wieder entfernen oder auskommentieren.
                          8. Als Test machen wir das selbe wie das letzte mal
                            -> Tor offen, dann Befehl close eingeben
                            -> Tor geschlossen, dann open eingeben
                            -> Licht ist an, dann lightoff eingeben
                            -> Licht ist aus, dann lighton eingeben
                          ich habe mal die verschiedenen javascripot zeilen kommentiert, damit du nachvollziehen kannst was da so passiert
                          var net = require('net');
                          var dp_door = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor"; //door state
                          var dp_light = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht"; //light state
                          var dp_cmd = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command"; //Befehlsdatenpunkt: Mögliche Werte: open, close, stop, lighton, lightoff. Nach Beschreiben wird der Datenpunkt wieder auf leer gesetzt
                          var deviceName = "Garagentor";
                          var host = "192.168.178.149";
                          var port = 2785;
                          function sendMessage(host, port, message) {
                           var timeout = 1000;                           //timeout für Antwort vom Server
                           var time2termination = 1000;                  //genereller Timeout falls gar keine Reaktion mehr kommt
                           var terminator;
                           var terminatorStart;
                           var terminatorEnd;
                           return new Promise((resolve, reject) => {     // Funktion ist asynchron, daher Rückgabe promise
                             var client = new net.Socket();                 // Erzeugen eines neuen Verbindungsobjekts
                             client.connect(port, host, function() {     // Gerät über host:port anwählen und Verbindung erzeugen
                               console.debug('cliend started');
                               terminatorStart();                        // Time starten, der die Verbindung beendet, falls keine Antwort mehr kommt
                               client.setTimeout(timeout);               // internes timeout setzen
                               client.write(message);                    // Nachricht an Gerät senden
                             client.on('data', function(data) {          // Wenn daten ankommen, dann verarbeiten
                               console.log('client received: ' + data);
                               terminatorStart();                        // Den Timeout verlängern
                               var dataS = data.toString();              // Datenbuffer in lesbaren Text umwandeln
                               switch(dataS) {                           // je nach rückgabewert unterschiedliche Bearbeitung
                                   case "S;"+deviceName+";open":         // wenn open
                                   setState(dp_door,"open");             // dann Datenpunkt setzen
                                   break;
                                   case "S;"+deviceName+";closed":
                                   setState(dp_door,"closed");
                                   break;
                                   case "S;"+deviceName+";opening":
                                   setState(dp_door,"opening");
                                   break;
                                   case "S;"+deviceName+";closing":
                                   setState(dp_door,"closing");
                                   break;
                                   case "S;"+deviceName+";lightOn":
                                   setState(dp_light,"lightOn");
                                   break;
                                   case "S;"+deviceName+";lightOff":
                                   setState(dp_light,"lightOff");
                                   break;
                             client.on("error",(err)=>{                  // wenn ein Fehler entsteht
                               console.log("client error");
                               terminatorEnd();                          // dann timeout beenden
                              client.end();                             // Kommunikation beenden
                               resolve(err);                             // und Fehlerdetails zurückgeben
                             client.on("timeout",()=>{                   // wenn timeout entsteht
                               console.log("client timeout");
                               resolve("timeout");                       // text timeout zurückgeben
                             terminatorStart = function() {              // timeout starten oder verlängern
                               console.log("client terminatorStart");
                               if (terminator) clearTimeout(terminator); // evtl vorhanden timeout beenden
                               terminator = setTimeout(() => {           // neuen timeout starten. wenn timeout eintritt, dann folgende funktionen ausführen
                                 console.log('cliend ended');
                                 client.end();                           // kommunikation beenden
                                 resolve("ok");                          // ok zurückgeben
                               }, time2termination);                     // zeit für timeout angeben
                             terminatorEnd = function() {                // timeout beenden
                               console.log("client terminatorEnd");
                          on(dp_cmd, function (obj) {                     // trigger wenn datenpunkt beschrieben wird
                             var cmd;
                             if (!obj.state.ack) {                       // aber nur wenn es sich um einen unbestätigten wert handelt
                                 cmd = String(obj.state.val).toLowerCase();  // Datenpunktinhalt in Kleinbuchstaben umwandeln
                                 console.debug('execute command: ' + cmd);
                                 switch(cmd) {                           // je nach Datenpunktinhalt verschiedene Befehle
                                     case "open":                        // wenn open
                                         sendMessage(host, port, "C;"+deviceName+";open"); // dann richtigen Befehl an Gerät senden
                                         break;
                                     case "close":
                                         sendMessage(host, port, "C;"+deviceName+";close");
                                         break;
                                     case "stop":
                                         sendMessage(host, port, "C;"+deviceName+";stop");
                                         break;
                                     case "lighton":
                                         sendMessage(host, port, "C;"+deviceName+";lightOn");
                                         break;
                                     case "lightoff":
                                         sendMessage(host, port, "C;"+deviceName+";lightOff");
                                         break;
                                 setState(obj.id, {val: "", ack: true}); // datenpunkt auf leer als bestätigt setzen
                            Rushmed Most Active @OliverIO last edited by Rushmed
                            @oliverio Vielen Dank, hier die Ausgaben:
                            öffnen:
                            30.8.2022, 18:15:36.287	[info ]: javascript.0 (853) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661876136287,"q":0,"from":"system.adapter.javascript.0","lc":1661876136287,"c":"script.js.Garage"})
                            30.8.2022, 18:15:36.306	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                            30.8.2022, 18:15:36.307	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                            30.8.2022, 18:15:36.345	[info ]: javascript.0 (853) script.js.Garage: client received: R;OK
                            30.8.2022, 18:15:36.345	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                            30.8.2022, 18:15:36.346	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                            30.8.2022, 18:15:36.347	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                            30.8.2022, 18:15:36.610	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.611	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.613	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.614	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.616	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.617	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.618	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.619	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.620	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.624	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.625	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.635	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.636	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.637	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.638	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.639	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.640	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.641	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.643	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.644	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.645	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.646	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.647	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.648	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.649	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.652	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.653	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.654	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.655	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.656	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.657	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.658	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.659	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.660	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.670	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.671	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.672	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.673	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.674	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.675	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.676	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.677	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.678	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.679	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.680	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.681	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.682	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.688	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;opening
                            30.8.2022, 18:15:36.688	[info ]: javascript.0 (853) script.js.Garage: client received: S;Garagentor;opening
                            30.8.2022, 18:15:36.689	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                            30.8.2022, 18:15:36.689	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                            30.8.2022, 18:15:36.690	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                            30.8.2022, 18:15:36.739	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.740	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.741	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.742	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.743	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.744	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.745	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.752	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.753	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.754	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.755	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.756	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.758	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.759	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.760	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.761	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.762	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.763	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.764	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.765	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.768	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.769	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.770	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.771	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.772	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.773	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.774	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.777	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.778	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.779	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.781	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.788	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.789	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.790	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.791	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.792	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.793	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.794	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.811	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.812	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.814	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.815	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.816	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.817	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.817	[info ]: javascript.0 (853) script.js.Garage: client received: S;Garagentor;lightOn
                            30.8.2022, 18:15:36.818	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                            30.8.2022, 18:15:36.818	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                            30.8.2022, 18:15:36.818	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                            30.8.2022, 18:15:37.817	[info ]: javascript.0 (853) script.js.Garage: client timeout
                            30.8.2022, 18:15:37.818	[info ]: javascript.0 (853) script.js.Garage: client terminatorEnd
                            30.8.2022, 18:15:37.818	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                            30.8.2022, 18:15:53.301	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.302	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.303	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.304	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.305	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.306	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.308	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.309	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.310	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.311	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.313	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.322	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.323	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.324	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.325	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.326	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.327	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.328	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.331	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.332	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.333	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.334	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.335	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.336	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.337	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.338	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.339	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.340	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.341	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.342	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.344	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.346	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.347	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.348	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.381	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.382	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.383	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.384	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.386	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.387	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.389	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.390	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.391	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            30.8.2022, 18:15:53.392	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;open
                            close:
                            30.8.2022, 18:17:56.379	[info ]: javascript.0 (853) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661876276379,"q":0,"from":"system.adapter.javascript.0","lc":1661876276379,"c":"script.js.Garage"})
                            30.8.2022, 18:17:56.393	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                            30.8.2022, 18:17:56.394	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                            30.8.2022, 18:17:56.464	[info ]: javascript.0 (853) script.js.Garage: client received: R;OK
                            30.8.2022, 18:17:56.465	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                            30.8.2022, 18:17:56.465	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                            30.8.2022, 18:17:56.465	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                            30.8.2022, 18:17:56.707	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.708	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.709	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.710	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.711	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.721	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.722	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.723	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.724	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.725	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.726	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.727	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.728	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.729	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.730	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.733	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.734	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.735	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.736	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.741	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.742	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.743	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.744	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.746	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.747	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.748	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.749	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.750	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.751	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.752	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.753	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.754	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.755	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.757	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.758	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.759	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.760	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.761	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closing
                            30.8.2022, 18:17:56.761	[info ]: javascript.0 (853) script.js.Garage: client received: S;Garagentor;closing
                            30.8.2022, 18:17:56.762	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                            30.8.2022, 18:17:56.762	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                            30.8.2022, 18:17:56.762	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                            30.8.2022, 18:17:57.761	[info ]: javascript.0 (853) script.js.Garage: client timeout
                            30.8.2022, 18:17:57.762	[info ]: javascript.0 (853) script.js.Garage: client terminatorEnd
                            30.8.2022, 18:17:57.763	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                            30.8.2022, 18:18:15.200	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.201	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.202	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.204	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.205	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.206	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.207	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.208	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.209	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.210	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.211	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.212	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.213	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.214	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.215	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.224	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.226	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.227	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.228	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.229	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.230	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.231	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.232	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.233	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.234	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.237	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.238	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.239	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.240	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.241	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.242	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.243	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.244	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.246	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.247	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.290	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.291	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.292	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.294	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.295	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            30.8.2022, 18:18:15.296	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;closed
                            Licht an:
                            30.8.2022, 18:19:35.737	[info ]: javascript.0 (853) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661876375737,"q":0,"from":"system.adapter.javascript.0","lc":1661876375737,"c":"script.js.Garage"})
                            30.8.2022, 18:19:35.748	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                            30.8.2022, 18:19:35.749	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                            30.8.2022, 18:19:36.042	[info ]: javascript.0 (853) script.js.Garage: client received: R;OK
                            30.8.2022, 18:19:36.042	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                            30.8.2022, 18:19:36.042	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                            30.8.2022, 18:19:36.043	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                            30.8.2022, 18:19:36.462	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.463	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.464	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.465	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.470	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.471	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.472	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.473	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.474	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.475	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.479	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.484	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.485	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.486	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.487	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.488	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.489	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.490	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.491	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.492	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.493	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.494	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.495	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.496	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.502	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.503	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.504	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.505	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.506	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.507	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.508	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.509	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.510	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.511	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.512	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.513	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.514	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.515	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.516	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.517	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.518	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.519	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.520	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.521	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.522	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.523	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.536	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.538	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.539	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.540	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.541	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.542	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.543	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.544	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.545	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.546	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.547	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.548	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.549	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.550	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.552	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.553	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.554	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.555	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.556	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.557	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.558	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.559	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.560	[info ]: javascript.0 (853) script.js.Garage: client received: S;Garagentor;lightOn
                            30.8.2022, 18:19:36.561	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                            30.8.2022, 18:19:36.562	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                            30.8.2022, 18:19:36.562	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                            30.8.2022, 18:19:37.561	[info ]: javascript.0 (853) script.js.Garage: client timeout
                            30.8.2022, 18:19:37.561	[info ]: javascript.0 (853) script.js.Garage: client terminatorEnd
                            30.8.2022, 18:19:37.561	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                            Licht aus:
                            30.8.2022, 18:20:29.804	[info ]: javascript.0 (853) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661876429804,"q":0,"from":"system.adapter.javascript.0","lc":1661876429804,"c":"script.js.Garage"})
                            30.8.2022, 18:20:29.816	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                            30.8.2022, 18:20:29.817	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                            30.8.2022, 18:20:29.871	[info ]: javascript.0 (853) script.js.Garage: client received: R;OK
                            30.8.2022, 18:20:29.872	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                            30.8.2022, 18:20:29.872	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                            30.8.2022, 18:20:29.872	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                            30.8.2022, 18:20:30.871	[info ]: javascript.0 (853) script.js.Garage: client timeout
                            30.8.2022, 18:20:30.871	[info ]: javascript.0 (853) script.js.Garage: client terminatorEnd
                            30.8.2022, 18:20:30.872	[info ]: javascript.0 (853) script.js.Garage: clearTimeout() => cleared
                            30.8.2022, 18:20:31.135	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.136	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.137	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.138	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.139	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.140	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.141	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.142	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.143	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.146	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.147	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.148	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.150	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.153	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.154	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.155	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.157	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.158	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.159	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.160	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.161	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.162	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.163	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.164	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.165	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.166	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.167	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.168	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.169	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.170	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.171	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.178	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.179	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.180	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.181	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.182	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.183	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.184	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.185	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.186	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.187	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.191	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.227	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.228	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.229	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.230	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.231	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.233	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.234	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.235	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.236	[info ]: javascript.0 (853) script.js.Garage_: Received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.236	[info ]: javascript.0 (853) script.js.Garage: client received: S;Garagentor;lightOff
                            30.8.2022, 18:20:31.237	[info ]: javascript.0 (853) script.js.Garage: client terminatorStart
                            30.8.2022, 18:20:31.238	[warn ]: javascript.0 (853) script.js.Garage: clearTimeout() => not found
                            30.8.2022, 18:20:31.238	[info ]: javascript.0 (853) script.js.Garage: setTimeout(ms=1000)
                            30.8.2022, 18:20:32.239	[info ]: javascript.0 (853) script.js.Garage: cliend ended
                            Bitte gib Bescheid wenn du weitere Zarbeit brauchst.
                            • OliverIO
                              @rushmed
                              du musst leider nochmal. die console.debug anweisungen sind nicht im log erschienen.
                              hab wieder auf console.log umgestellt.
                              es reicht erst mal eines. dann prüfen wir ob alles so abläuft wie gewünscht.
                              noch eins.
                              stoppe und starte bitte den javascript-adapter bevor du testest.
                              dass räumt die evtl. reste aus dem speicher die nur stören.
                              var port = 2785;
                              var terminator;
                              var terminatorEnd;
                                  console.log('cliend started');
                                      break;
                                      break;
                                      break;
                                      break;
                                      break;
                                      break;
                                var cmd;
                                    console.log('execute command: ' + cmd);
                                            break;
                                        case "close":
                                            break;
                                        case "stop":
                                            break;
                                        case "lighton":
                                            break;
                                        case "lightoff":
                                            break;
                                @oliverio sagte in Benötige Programmierhilfe Javascript:
                                Kein Problem.
                                Öffnen:
                                30.8.2022, 19:58:37.852	[info ]: javascript.0 (1060380) script.js.Garage: execute command: open
                                30.8.2022, 19:58:37.858	[info ]: javascript.0 (1060380) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661882317857,"q":0,"from":"system.adapter.javascript.0","lc":1661882317857,"c":"script.js.Garage"})
                                30.8.2022, 19:58:37.872	[info ]: javascript.0 (1060380) script.js.Garage: cliend started
                                30.8.2022, 19:58:37.873	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                30.8.2022, 19:58:37.874	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                30.8.2022, 19:58:37.909	[info ]: javascript.0 (1060380) script.js.Garage: client received: R;OK
                                30.8.2022, 19:58:37.910	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                30.8.2022, 19:58:37.910	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                30.8.2022, 19:58:37.911	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                30.8.2022, 19:58:38.225	[info ]: javascript.0 (1060380) script.js.Garage: client received: S;Garagentor;opening
                                30.8.2022, 19:58:38.225	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                30.8.2022, 19:58:38.226	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                30.8.2022, 19:58:38.226	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                30.8.2022, 19:58:38.294	[info ]: javascript.0 (1060380) script.js.Garage: client received: S;Garagentor;lightOn
                                30.8.2022, 19:58:38.294	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                30.8.2022, 19:58:38.295	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                30.8.2022, 19:58:38.295	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                30.8.2022, 19:58:39.294	[info ]: javascript.0 (1060380) script.js.Garage: client timeout
                                30.8.2022, 19:58:39.295	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorEnd
                                30.8.2022, 19:58:39.296	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                Schließen:
                                30.8.2022, 19:59:33.336	[info ]: javascript.0 (1060380) script.js.Garage: execute command: close
                                30.8.2022, 19:59:33.337	[info ]: javascript.0 (1060380) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661882373337,"q":0,"from":"system.adapter.javascript.0","lc":1661882373337,"c":"script.js.Garage"})
                                30.8.2022, 19:59:33.356	[info ]: javascript.0 (1060380) script.js.Garage: cliend started
                                30.8.2022, 19:59:33.357	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                30.8.2022, 19:59:33.357	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                30.8.2022, 19:59:33.397	[info ]: javascript.0 (1060380) script.js.Garage: client received: R;OK
                                30.8.2022, 19:59:33.397	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                30.8.2022, 19:59:33.397	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                30.8.2022, 19:59:33.398	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                30.8.2022, 19:59:33.755	[info ]: javascript.0 (1060380) script.js.Garage: client received: S;Garagentor;closing
                                30.8.2022, 19:59:33.756	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
                                30.8.2022, 19:59:33.756	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                30.8.2022, 19:59:33.756	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
                                30.8.2022, 19:59:34.755	[info ]: javascript.0 (1060380) script.js.Garage: client timeout
                                30.8.2022, 19:59:34.756	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorEnd
                                30.8.2022, 19:59:34.757	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
                                Zur Info, VErbose ist noch aktiviert und die DPs für Status Licht, Tor werden nicht beschrieben.
                                • OliverIO
                                  @rushmed
                                  schau mal an dem schraubenschlüssel oben rechts, ob da debug aus ist?
                                  dadurch werden keine datenpunkte beschrieben. also es muss aus sein
                                    @oliverio Debug ist aus. Wie gesagt verbose war an. Habs mal deaktiviert und getastet, ändert nichts.
                                    Das Leeren von 0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command hat seit dus eingebaut hast immer geklappt.
                                    Also geht Schreiben offensichtlich.
                                    • OliverIO
                                      @rushmed
                                      ich habe nochmal die logausgabe um einen parameter erweitert und die timeout zeit auf 10 Sekunden erhöht.
                                      Der Status der ankommt müsste schon richtig sein. In der Entscheidungsmatrix greift er aber nicht. Das prüfen wir damit.
                                      Darüber hinaus kommt nur einmal "closing" und sonst nix. wenn dann wollen wir ja nach einer weile zumindest wissen das dann tatsächlich closed ist
                                      könntest du parallel bitte auch dieser Firma eine EMail senden, das sie dir eine aktualisierte API-Beschreibung senden? Deine verlinkte scheint ja nicht ganz aktuell zu sein.
                                      Ich erhoffe mir, das da auch ein paar mehr Details zur generellen Statusabfrage drin steht.
                                      Also am besten dem Hersteller und nicht irgendeinem Vertriebspartner.
                                      var port = 2785;
                                      var timeout = 10000;                           //timeout für Antwort vom Server
                                      var time2termination = 10000;                  //genereller Timeout falls gar keine Reaktion mehr kommt
                                      var terminator;
                                      var terminatorEnd;
                                          console.log('client received: ' + data + " for device: " + deviceName);
                                              break;
                                              break;
                                              break;
                                              break;
                                              break;
                                              break;
                                        var cmd;
                                                    break;
                                                case "close":
                                                    break;
                                                case "stop":
                                                    break;
                                                case "lighton":
                                                    break;
                                                case "lightoff":
                                                    break;
                                        @oliverio Antwort von Marantec vom 03.06.2022 08:21:
                                        Guten Tag Herr x,
                                        vielen Dank für Ihre Anfrage.
                                        Anbei erhalten Sie eine Übersicht der Befehle
                                        Status                                      Code
                                        Tor ist geöffnet:                        S;'garageDoorName';open
                                        Tor ist geschlossen:                 S;'garageDoorName';closed
                                        Tor öffnet sich:                         S;'garageDoorName';opening
                                        Tor schließt sich:                      S;'garageDoorName';closing
                                        Antriebsbeleuchtung ist an:     S;'garageDoorName';lightOn
                                        Antriebsbeleuchtung ist aus:   S:'garageDoorName';lightOff
                                        Befehl                                      Code
                                        Öffnen:                                    C;'garageDoorName';open
                                        Schließen:                               C;'garageDoorName';close
                                        Stop:                                       C;'garageDoorName';stop
                                        Antriebsbeleuchtung an:         C;'garageDoorName';lightOn
                                        Antriebsbeleuchtung aus:       C;'garageDoorName';lightOf
                                        garageDoorName = Der Name Ihres Tores
                                        Mit freundlichen Grüßen / Best regards
                                        Christian Pieper
                                        T +49 5247 705-221 · F +49 5247 705-234
                                        service@marantec.de · www.marantec.com
                                        Vermutlich fehlt beim letzten Befehl das zweite "f".
                                        Open:
                                        31.8.2022, 11:51:12.425	[info ]: javascript.0 (612549) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661939472425,"q":0,"from":"system.adapter.javascript.0","lc":1661939472425,"c":"script.js.Garage"})
                                        31.8.2022, 11:51:12.440	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                        31.8.2022, 11:51:12.441	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
                                        31.8.2022, 11:51:12.472	[info ]: javascript.0 (612549) script.js.Garage: client received: R;OK
                                        for device: Garagentor
                                        31.8.2022, 11:51:12.473	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                        31.8.2022, 11:51:12.473	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                        31.8.2022, 11:51:12.473	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
                                        31.8.2022, 11:51:12.696	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;opening
                                        31.8.2022, 11:51:12.696	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                        31.8.2022, 11:51:12.696	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                        31.8.2022, 11:51:12.697	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
                                        31.8.2022, 11:51:12.760	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;lightOn
                                        31.8.2022, 11:51:12.761	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                        31.8.2022, 11:51:12.762	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                        31.8.2022, 11:51:12.762	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
                                        31.8.2022, 11:51:22.760	[info ]: javascript.0 (612549) script.js.Garage: client timeout
                                        31.8.2022, 11:51:22.762	[info ]: javascript.0 (612549) script.js.Garage: client terminatorEnd
                                        31.8.2022, 11:51:22.762	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                        Close:
                                        31.8.2022, 11:52:45.628	[info ]: javascript.0 (612549) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661939565627,"q":0,"from":"system.adapter.javascript.0","lc":1661939565627,"c":"script.js.Garage"})
                                        31.8.2022, 11:52:45.646	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                        31.8.2022, 11:52:45.646	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
                                        31.8.2022, 11:52:45.698	[info ]: javascript.0 (612549) script.js.Garage: client received: R;OK
                                        31.8.2022, 11:52:45.699	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                        31.8.2022, 11:52:45.699	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                        31.8.2022, 11:52:45.699	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
                                        31.8.2022, 11:52:46.144	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;closing
                                        31.8.2022, 11:52:46.145	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                        31.8.2022, 11:52:46.145	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                        31.8.2022, 11:52:46.146	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
                                        31.8.2022, 11:52:56.144	[info ]: javascript.0 (612549) script.js.Garage: client timeout
                                        31.8.2022, 11:52:56.145	[info ]: javascript.0 (612549) script.js.Garage: client terminatorEnd
                                        31.8.2022, 11:52:56.145	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                        Ja stimmt, die Bestätigung der Endlagen kommt nichtmehr an. Mit dem neuen Code auch nicht.
                                        Auch die Datenpunkte bleiben leer.
                                        Nach dem Schließen bleibt die Lampe noch drei Minuten an. Die Bestätigung des Ausschaltens kommt jetzt auch nicht mehr an.
                                        Soll ich verbose jetzt weiter aktiviert lassen oder nicht?
                                        Danke vorab!
                                        • OliverIO
                                          @rushmed
                                          ja, 2 Probleme haben wir noch.
                                          1. der Vergleich zwischen
                                            S;Gagentor;opening
                                            und
                                            S;Gagentor;opening
                                          schlägt fehl, ob die beiden gleich sind.
                                          1. die Rückmeldung für den Abschluss der Aktion fehlt noch.
                                            Wenn du sagst, das Licht bleibt noch 3 Minuten an, dann setzen wir den Timeout mal auf 4 Minuten,
                                            Ersetze bitte die folgenden 2 Zeilen
                                          mit
                                          var timeout = 4*60*1000;                           //timeout für Antwort vom Server
                                          var time2termination = 4*60*1000;                  //genereller Timeout falls gar keine Reaktion mehr kommt
                                          Du musst dann auch 4 Minuten Warten bis die Aktion abgeschlossen ist.
                                          Auch nicht den javascript-adapter stoppen
                                          Am Schluss muss im Log immer
                                          client timeout
                                          stehen
                                          Leider hat dir der Support einfach nur die Schlüsselworte mitgeteilt, aber auch nix zum Kommunikationsverhalten, was das Gerät macht wenn der Befehl close oder open gegeben wird.
                                          Wird nur einmal opening gesendet, oder mehrfach?
                                          Wie kann man den Status abfragen ohne einen Befehl zu geben, steht leider auch nirgends
                                          Besser wäre eine API, bei der man Befehle geben kann und separat den Status abfragen kann,
                                          So ist man viel flexibler.
                                          Aber man sieht ja, das sie dir keine richtige API-Beschreibung gegeben haben, sondern nur die Befehlsauflistung.
                                          Du hast ja nach API-Beschreibung gefragt?
                                          verbose erst mal so lassen. das stört nicht und gibt aktuell eher mehr informationen aus dem skriptablauf
                                            @oliverio Zu1) Hast du da noch ne Idee? Ansonsten eürde es mir reichen wenn opening, closing, closed, lighton und lightoff in einem Datenpunkt landen. Dann werte ich die Status mit Blockly selber aus.
                                            zu2) Habe das halboffene Tor zugefahren, lightoff kam an.
                                            31.8.2022, 19:27:24.317	[info ]: javascript.0 (612549) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661966844317,"q":0,"from":"system.adapter.javascript.0","lc":1661966844317,"c":"script.js.Garage"})
                                            31.8.2022, 19:27:24.331	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                            31.8.2022, 19:27:24.332	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
                                            31.8.2022, 19:27:24.380	[info ]: javascript.0 (612549) script.js.Garage: client received: R;OK
                                            31.8.2022, 19:27:24.380	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                            31.8.2022, 19:27:24.380	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                            31.8.2022, 19:27:24.381	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
                                            31.8.2022, 19:27:24.608	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;closing
                                            31.8.2022, 19:27:24.609	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                            31.8.2022, 19:27:24.609	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                            31.8.2022, 19:27:24.609	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
                                            31.8.2022, 19:27:24.610	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;closing
                                            31.8.2022, 19:27:24.610	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                            31.8.2022, 19:27:24.610	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                            31.8.2022, 19:27:24.611	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
                                            31.8.2022, 19:27:24.611	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;closing
                                            31.8.2022, 19:27:24.612	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                            31.8.2022, 19:27:24.612	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                            31.8.2022, 19:27:24.612	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
                                            31.8.2022, 19:27:24.672	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;lightOn
                                            31.8.2022, 19:27:24.672	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                            31.8.2022, 19:27:24.673	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                            31.8.2022, 19:27:24.673	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
                                            31.8.2022, 19:27:24.674	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;lightOn
                                            31.8.2022, 19:27:24.674	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                            31.8.2022, 19:27:24.674	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                            31.8.2022, 19:27:24.674	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
                                            31.8.2022, 19:27:24.675	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;lightOn
                                            31.8.2022, 19:27:24.675	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                            31.8.2022, 19:27:24.675	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                            31.8.2022, 19:27:24.676	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
                                            31.8.2022, 19:27:35.420	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;closed
                                            31.8.2022, 19:27:35.421	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                            31.8.2022, 19:27:35.421	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                            31.8.2022, 19:27:35.421	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
                                            31.8.2022, 19:27:35.422	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;closed
                                            31.8.2022, 19:27:35.423	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                            31.8.2022, 19:27:35.423	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                            31.8.2022, 19:27:35.423	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
                                            31.8.2022, 19:27:35.424	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;closed
                                            31.8.2022, 19:27:35.424	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                            31.8.2022, 19:27:35.424	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                            31.8.2022, 19:27:35.424	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
                                            31.8.2022, 19:30:34.088	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;lightOff
                                            31.8.2022, 19:30:34.089	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                            31.8.2022, 19:30:34.089	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                            31.8.2022, 19:30:34.089	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
                                            31.8.2022, 19:30:34.090	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;lightOff
                                            31.8.2022, 19:30:34.090	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                            31.8.2022, 19:30:34.090	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                            31.8.2022, 19:30:34.091	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
                                            31.8.2022, 19:30:34.091	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;lightOff
                                            31.8.2022, 19:30:34.092	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
                                            31.8.2022, 19:30:34.092	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                            31.8.2022, 19:30:34.092	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
                                            31.8.2022, 19:34:34.088	[info ]: javascript.0 (612549) script.js.Garage: client timeout
                                            31.8.2022, 19:34:34.089	[info ]: javascript.0 (612549) script.js.Garage: client terminatorEnd
                                            31.8.2022, 19:34:34.089	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                            31.8.2022, 19:34:34.090	[info ]: javascript.0 (612549) script.js.Garage: client timeout
                                            31.8.2022, 19:34:34.090	[info ]: javascript.0 (612549) script.js.Garage: client terminatorEnd
                                            31.8.2022, 19:34:34.090	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                            31.8.2022, 19:34:34.092	[info ]: javascript.0 (612549) script.js.Garage: client timeout
                                            31.8.2022, 19:34:34.092	[info ]: javascript.0 (612549) script.js.Garage: client terminatorEnd
                                            31.8.2022, 19:34:34.092	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
                                            zu3) Nein ich habe nicht nach API gefragt. Ich wollte eine Anleitung zur Integration, sowie eine Liste möglicher Befehle.
                                            Ich frage da nochmal nach, aber die Antwort wird lange dauern.
                                            Können wir bitte die Antwort von R; in einem DP ausgeben? Wäre aber nur nice to have und eigentlich nur bei der Einrichtung eines Antriebs interessant.
                                            1.2k
                                            communication javascript monitoring
                                            4751
