    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер MegaD-2561
    Драйвер MegaD-2561
      Haus last edited by
      @Bluefox:
      Работает? `
      megadd.0	2017-03-13 18:49:57.227	error	at process._tickCallback (node.js:425:17)
      megadd.0	2017-03-13 18:49:57.227	error	at nextTickCallbackWith2Args (node.js:511:9)
      megadd.0	2017-03-13 18:49:57.227	error	at endReadableNT (_stream_readable.js:923:12)
      megadd.0	2017-03-13 18:49:57.227	error	at IncomingMessage.emit (events.js:166:7)
      megadd.0	2017-03-13 18:49:57.227	error	at emitNone (events.js:72:20)
      megadd.0	2017-03-13 18:49:57.227	error	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.megadd/main.js:130:25)
      megadd.0	2017-03-13 18:49:57.227	error	at /opt/iobroker/node_modules/iobroker.megadd/main.js:816:23
      megadd.0	2017-03-13 18:49:57.227	error	at /opt/iobroker/node_modules/iobroker.megadd/main.js:1151:25
      megadd.0	2017-03-13 18:49:57.227	error	at getPortStateW (/opt/iobroker/node_modules/iobroker.megadd/main.js:777:20)
      megadd.0	2017-03-13 18:49:57.227	error	TypeError: ip.split is not a function
      megadd.0	2017-03-13 18:49:57.217	error	uncaught exception: ip.split is not a function
      • Bluefox
        Bluefox last edited by
        Я тебе pull request прислал
          Haus last edited by
          @Bluefox:
          Я тебе pull request прислал `
          Дублирует запрос, соответственно и ответ. РЕШЕНО!!!
          ! megadd.0 2017-03-14 06:41:43.232 debug inMem message megadd.0.* megadd.0.p33_P33_31c5b8000000
          ! megadd.0 2017-03-14 06:41:43.232 debug inMem message megadd.0.* megadd.0.p33_P33_32c5b8000000
          ! megadd.0 2017-03-14 06:41:43.218 debug inMem message megadd.0.* megadd.0.p33_P33_30c5b8000000
          ! megadd.0 2017-03-14 06:41:43.202 debug detected new value on port [33_31c5b8000000]: -15.81
          ! megadd.0 2017-03-14 06:41:43.201 debug detected new value on port [33_32c5b8000000]: 27
          ! megadd.0 2017-03-14 06:41:43.201 debug detected new value on port [33_30c5b8000000]: 31.81
          ! megadd.0 2017-03-14 06:41:43.201 debug Response: 30c5b8000000:31.81;32c5b8000000:27.00;31c5b8000000:-15.81
          ! megadd.0 2017-03-14 06:41:42.982 debug inMem message megadd.0.* megadd.0.p15_P15_31c6b8000000
          ! megadd.0 2017-03-14 06:41:42.982 debug inMem message megadd.0.* megadd.0.p15_P15_32c6b8000000
          ! megadd.0 2017-03-14 06:41:42.982 debug inMem message megadd.0.* megadd.0.p15_P15_30c6b8000000
          ! megadd.0 2017-03-14 06:41:42.982 debug detected new value on port [15_31c6b8000000]: -15.18
          ! megadd.0 2017-03-14 06:41:42.981 debug detected new value on port [15_32c6b8000000]: 17.12
          ! megadd.0 2017-03-14 06:41:42.981 debug detected new value on port [15_30c6b8000000]: 28.31
          ! megadd.0 2017-03-14 06:41:42.980 debug Response: 30c6b8000000:28.31;32c6b8000000:17.12;31c6b8000000:-15.18
          ! megadd.0 2017-03-14 06:41:42.671 debug Response: 30c9b8000000:-10.56
          ! megadd.0 2017-03-14 06:41:42.576 debug inMem message megadd.0.* megadd.0.p33_P33_31c5b8000000
          ! megadd.0 2017-03-14 06:41:42.575 debug inMem message megadd.0.* megadd.0.p33_P33_32c5b8000000
          ! megadd.0 2017-03-14 06:41:42.556 debug inMem message megadd.0.* megadd.0.p33_P33_30c5b8000000
          ! megadd.0 2017-03-14 06:41:42.555 debug detected new value on port [33_31c5b8000000]: -15.81
          ! megadd.0 2017-03-14 06:41:42.555 debug detected new value on port [33_32c5b8000000]: 27
          ! megadd.0 2017-03-14 06:41:42.555 debug detected new value on port [33_30c5b8000000]: 31.81
          ! megadd.0 2017-03-14 06:41:42.554 debug Response: 30c5b8000000:31.81;32c5b8000000:27.00;31c5b8000000:-15.81
          ! megadd.0 2017-03-14 06:41:42.344 debug inMem message megadd.0.* megadd.0.p15_P15_31c6b8000000
          ! megadd.0 2017-03-14 06:41:42.343 debug inMem message megadd.0.* megadd.0.p15_P15_32c6b8000000
          ! megadd.0 2017-03-14 06:41:42.342 debug inMem message megadd.0.* megadd.0.p15_P15_30c6b8000000
          ! megadd.0 2017-03-14 06:41:42.342 debug detected new value on port [15_31c6b8000000]: -15.18
          ! megadd.0 2017-03-14 06:41:42.342 debug detected new value on port [15_32c6b8000000]: 17.12
          ! megadd.0 2017-03-14 06:41:42.341 debug detected new value on port [15_30c6b8000000]: 28.31
          ! megadd.0 2017-03-14 06:41:42.340 debug Response: 30c6b8000000:28.31;32c6b8000000:17.12;31c6b8000000:-15.18
          ! megadd.0 2017-03-14 06:41:42.118 debug Response: 30c9b8000000:-10.56
          ! megadd.0 2017-03-14 06:41:41.890 debug getPortStateW http://192.168.1.14/sec/?pt=33&cmd=list
          ! megadd.0 2017-03-14 06:41:41.890 debug getPortStateW http://192.168.1.14/sec/?pt=15&cmd=list
          ! megadd.0 2017-03-14 06:41:41.890 debug getPortStateW http://192.168.1.14/sec/?pt=5&cmd=list
          ! megadd.0 2017-03-14 06:41:41.889 debug Response: temp:24.00;OFF/0;OFF/0;;OFF;;temp:0.00/hum:0.00;OFF/OFF;NA/NA;OFF;0;0;0;255;ON;;OFF;temp:0.04/press:1.76;OFF/0;OFF/0;temp:6.00/hum:76.00;temp:0.00/hum:0.00;OFF;;OFF;;;OFF;OFF;ON;;OFF;temp:-2
          ! megadd.0 2017-03-14 06:41:39.658 debug getPortStateW http://192.168.1.14/sec/?pt=33&cmd=list
          ! megadd.0 2017-03-14 06:41:39.658 debug getPortStateW http://192.168.1.14/sec/?pt=15&cmd=list
          ! megadd.0 2017-03-14 06:41:39.658 debug getPortStateW http://192.168.1.14/sec/?pt=5&cmd=list
          ! megadd.0 2017-03-14 06:41:39.657 debug Response: temp:24.00;OFF/0;OFF/0;;OFF;;temp:0.00/hum:0.00;OFF/OFF;NA/NA;OFF;0;0;0;255;ON;;OFF;temp:0.04/press:1.76;OFF/0;OFF/0;temp:6.00/hum:76.00;temp:0.00/hum:0.00;OFF;;OFF;;;OFF;OFF;ON;;OFF;temp:-2
          ! megadd.0 2017-03-14 06:41:37.758 debug getPortState http://192.168.1.14/sec/?cmd=all
          P.S. Лишние строки затесались 🙂
          Ну и самое главное в чем был вопрос, как создать эти порты. p5_P5_30c9b8000000, p15_P15_30c6b8000000, p15_P15_31c6b8000000, ….p33P33_..
          ! if (settings.pty == 3) {
          ! obj.common.write = false;
          ! obj.common.read = true;
          ! obj.common.def = 0;
          ! obj.common.type = 'number';
          ! if (settings.d == 1 || settings.d == 2 || settings.d == 3) {
          ! } else if (settings.d == 5) { // 1Wire
          ! obj.common.min = -30;
          ! obj.common.max = 30;
          ! obj.common.unit = '°C';
          ! obj.common.desc = 'P' + p + ' - temperature';
          ! if (!obj.common.role) obj.common.role = 'value.temperature';
          Кое что подправил
          ! if (val !== _ports[_port].value || _ports[_port].q !== q) {
          ! adapter.log.debug('VAL :' + val + ' ' + 'PORT VAL :' + _ports[_port].value);
          ! _ports[_port].oldValue = _ports[_port].value;
          ! if (_ports[_port].pty == 3 && _ports[_port].d == 5) {
          ! adapter.log.debug('detected new value on port [' + port + '' + id[0] + ']: ' + val);
          ! ///adapter.setState(_ports[port].id + '' + id[0], {val: value, ack: true, q: q});
          ! adapter.setState(_ports[port].id + '' + id[0], {val: val, ack: true, q: q}); //haus
          ! _ports[_port].value = val;
          ! _ports[_port].q = q;
          Вбил руками порты megadd.0.p33_P33_32c5b8000000, …... Неправильно определяет if (val !== _ports[_port].value || _ports[_port].q !== q) { если больше одного датчика
          ! megadd.0 2017-03-14 17:21:29.678 debug inMem message megadd.0.* megadd.0.p33_P33_31c5b8000000
          ! megadd.0 2017-03-14 17:21:29.677 debug inMem message megadd.0.* megadd.0.p33_P33_32c5b8000000
          ! megadd.0 2017-03-14 17:21:29.665 debug inMem message megadd.0.* megadd.0.p33_P33_30c5b8000000
          ! megadd.0 2017-03-14 17:21:29.664 debug detected new value on port [33_31c5b8000000]: -17.37
          ! megadd.0 2017-03-14 17:21:29.663 debug VAL :-17.37 PORT VAL :27
          ! megadd.0 2017-03-14 17:21:29.663 debug detected new value on port [33_32c5b8000000]: 27
          ! megadd.0 2017-03-14 17:21:29.663 debug VAL :27 PORT VAL :31.81
          ! megadd.0 2017-03-14 17:21:29.662 debug detected new value on port [33_30c5b8000000]: 31.81
          ! megadd.0 2017-03-14 17:21:29.662 debug VAL :31.81 PORT VAL :-17.37
          ! megadd.0 2017-03-14 17:21:29.661 debug Response: 30c5b8000000:31.81;32c5b8000000:27.00;31c5b8000000:-17.37
          Иногда MegaD на запрос http://192.168.1.14/sec/?pt=33&cmd=list может вернуть "busy" если шина занята конвертацией, здесь главное чтобы драйвер не парсил этот ответ или как вариант повторил запрос скажем через 5-10 секунд.
          ! megadd.0 2017-03-14 09:45:38.692 debug Response: busy
          ! megadd.0 2017-03-14 09:45:38.611 debug Response: busy
          ! megadd.0 2017-03-14 09:45:38.600 debug Response: busy
          ! megadd.0 2017-03-14 09:45:32.537 debug getPortStateW http://192.168.1.14/sec/?pt=33&cmd=list
          ! megadd.0 2017-03-14 09:45:32.536 debug getPortStateW http://192.168.1.14/sec/?pt=15&cmd=list
          ! megadd.0 2017-03-14 09:45:32.534 debug getPortStateW http://192.168.1.14/sec/?pt=5&cmd=list
            Pooh last edited by
            Помогите, плз, пошагово настроить мегу2561 и драйвер, делал по аналогии с драйвером мега328 (который работает отлично), не получилось - состояние портов меняется раз в 30 сек, а не по факту нажатия кнопки
            кнопка на порту 18, реле на порту 25. с каждым нажатием кнопки меняем состояние реле
              Haus last edited by
              @Pooh:
              кнопка на порту 18, реле на порту 25. с каждым нажатием кнопки меняем состояние реле `
              Настройки отличаются от Megad-328. В принципе достаточно считать настройки с Megad-2561(если настроен) и после этого записать настройки в Megad-2561 (что бы прописался сервер и инстанция(скрипт)).
              Пример если кнопка
              script
              on({id: 'megadd.0.p1_P1', change: 'any'}, function (obj) {
                  if (obj.newState.val === true && getState('megadd.0.p24_P24').val === false) {
                      setState('megadd.0.p24_P24', true);
                  } else if (obj.newState.val === true && getState('megadd.0.p24_P24').val === true) {
                      setState('megadd.0.p24_P24', false);
                Pooh last edited by
                @Haus:
                ..В принципе достаточно считать настройки с Megad-2561(если настроен) и после этого записать настройки в Megad-2561 (что бы прописался сервер и инстанция(скрипт)).. `
                НИФИГА
                Два вечера бился практически методом тыка
                настроил mega2561: каждый вход "mod P с галочкой". при этом без сервера выполняется автономная команда
                прочитал драйвером настройки.
                изменил в драйвере режим входов на "при изменении" (после считывания было "при замыкании")
                сохранил (без сохранения в сам мегад3561!)
                скрипт типа:
                on('megadd.0.p2_P2', function (obj) {
                    if (obj.newState.val === true && getState('megadd.0.p9_P9').val === false) {
                        setState ('megadd.0.p9_P9', true);
                    }else if(obj.newState.val === true && getState('megadd.0.p9_P9').val === true){
                        setState ('megadd.0.p9_P9', false);
                ВУАЛЯ
                  Haus last edited by
                  @Pooh:
                  @Haus:
                  ..В принципе достаточно считать настройки с Megad-2561(если настроен) и после этого записать настройки в Megad-2561 (что бы прописался сервер и инстанция(скрипт)).. НИФИГА
                  ????? что не так?
                  @Pooh:
                  прочитал драйвером настройки. `
                  Считал драйвер настройки правильно?
                  @Pooh:
                  сохранил (без сохранения в сам мегад3561!) `
                  Драйвер MegaD-2561, как я писал выше отличается от MegaD-328. При считывание конфига в настройках драйвера менять ничего не надо, а если поменял то надо записать изменения в MegaD-2561. ТО ЕСТЬ ИЗ ДРАЙВЕРА МОЖНО ПОМЕНЯТЬ ВСЕ НАСТРОЙКИ MegaD-2561, НЕ ИСПОЛЬЗУЯ WEB MegaD-2561.
                    Pooh last edited by
                    у меня в драйвере нет "текущая версия прошивки… доступная версия прошивки..."
                    v0.2.0
                      Pooh last edited by
                      @Haus:
                      ..????? что не так?.. `
                      думаю драйвером не учитывается, что "Флажок (чекбокс) справа от поля Mode указывает, что при наличии сервера, устройство отправляет на сервер сообщения всегда в режиме P&R, а при его отсутствии Action выполняется только в том режиме, который установлен в Mode." (http://ab-log.ru/smart-house/ethernet/megad-2561)
                      т.е. если установить в модуле режим P&R и считать драйвером, то все хорошо, пока сервер работает. если установить в модуле режим P с галочкой и считать драйвером, то все хорошо, пока сервер (драйвер) не работает.
                      Счастье наступает, когда в модуле режим входов установлен в P с галочкой, конфиг считан драйвером и режим (в драйвере) изменен на "при изменении"
                      запись параметров в модуль из драйвера результатов не дает, ибо драйвер четко записывает режим P&R, при котором не работает автономный режим…
                      и да, считывается/записывается один-в-один
                        Haus last edited by
                        @Pooh:
                        @Haus:
                        ..????? что не так?.. Счастье наступает, когда в модуле режим входов установлен в P с галочкой, конфиг считан драйвером и режим (в драйвере) изменен на "при изменении"
                        А зачем ты меняешь после считывания?
                          Pooh last edited by
                          я ж говорил, если просто считать с меги и сохранить в драйвере, то состояние портов меняется раз в 30 сек, по факту опроса драйвером, а не по факту нажатия кнопки
                          какая сейчас версия драйвера актуальная? у меня 0.2.0..
                            Haus last edited by
                            @Pooh:
                            какая сейчас версия драйвера актуальная? у меня 0.2.0.. `
                            Попробуй с git.
                            cd /opt/iobroker
                            iobroker stop megadd
                            npm install https://github.com/ausHaus/ioBroker.megadd/tarball/master/
                            iobroker upload megadd
                            iobroker restart megadd
                              Pooh last edited by
                              Обновил до 0.2.2
                              Совсем другой коленкор! Теперь все работает как надо! Спасибо!
                              Только теперь в админе вкладка "драйвера" почему-то зеленая, хотя обновлять нечего…
                                Pooh last edited by
                                Наверное вопрос надо было в тему скрипты…. тем не менее:
                                Подключаю счетчик воды (геркон, 10л/импульс). становится ясно, что:
                                • даже в случае бесперебойного аптайма размерности встроенного в мегу счетчика не хватит на длительный срок
                                • при сбросе мегад показания собъются (так же как и при перезапуске айоброкера)
                                Внимание, вопрос: как синхронизировать показания счетчиков и учесть при этом размерность встроенного в мегу (65тыс вроде как)
                                • I
                                  instalator last edited by
                                  @Pooh:
                                  Внимание, вопрос: как синхронизировать показания счетчиков и учесть при этом размерность встроенного в мегу (65тыс вроде как) `
                                  Я вот так сделал http://blog.instalator.ru/archives/711
                                    Haus last edited by
                                    @Pooh:
                                    Внимание, вопрос: как синхронизировать показания счетчиков и учесть при этом размерность встроенного в мегу (65тыс вроде как) ` ````
                                    createState('Water_meter',0);
                                    var lastValue = null;
                                    on("megadd.0.p1_P1_counter", function (obj) {
                                    // initialisation
                                    if (lastValue === null) {
                                    lastValue = obj.state.val;
                                    return;
                                    // Megadd have been restarted
                                    if (lastValue > obj.state.val) {
                                        setState('Water_meter', getState('Water_meter').val + obj.state.val, true);
                                    } else if (obj.state.val != lastValue) {
                                        setState('Water_meter', getState('Water_meter').val + (obj.state.val - lastValue), true);
                                    } else {
                                        return;
                                      Pooh last edited by
                                      процесс пошел…
                                      как получить текущее время в миллисекундах?
                                      это нужно для вычисления "мгновенного" потребления
                                        Pooh last edited by
                                        @instalator:
                                        ..Я вот так сделал http://blog.instalator.ru/archives/711 `
                                        излишне, есть же счетчик в мегаД
                                        сейчас я юзаю дополнительный https://www.mysensors.org/build/pulse_power, но хочу от него отказаться…
                                          Haus last edited by
                                          @Pooh:
                                          процесс пошел…
                                          это нужно для вычисления "мгновенного" потребления `
                                          http://forum.iobroker.net/viewtopic.php … 528#p72334
                                            Pooh last edited by
                                            javascript.0 2017-06-25 23:04:45.557 error Error in callback: TypeError: Cannot read property 'ts' of undefined
                                            81.1k
                                            160
                                            43613
