    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер MegaD-2561
    Драйвер MegaD-2561
    • Bluefox
      Bluefox last edited by
      Я тебе pull request прислал
        Haus last edited by
        @Bluefox:
        Я тебе pull request прислал `
        Дублирует запрос, соответственно и ответ. РЕШЕНО!!!
        ! megadd.0 2017-03-14 06:41:43.232 debug inMem message megadd.0.* megadd.0.p33_P33_31c5b8000000
        ! megadd.0 2017-03-14 06:41:43.232 debug inMem message megadd.0.* megadd.0.p33_P33_32c5b8000000
        ! megadd.0 2017-03-14 06:41:43.218 debug inMem message megadd.0.* megadd.0.p33_P33_30c5b8000000
        ! megadd.0 2017-03-14 06:41:43.202 debug detected new value on port [33_31c5b8000000]: -15.81
        ! megadd.0 2017-03-14 06:41:43.201 debug detected new value on port [33_32c5b8000000]: 27
        ! megadd.0 2017-03-14 06:41:43.201 debug detected new value on port [33_30c5b8000000]: 31.81
        ! megadd.0 2017-03-14 06:41:43.201 debug Response: 30c5b8000000:31.81;32c5b8000000:27.00;31c5b8000000:-15.81
        ! megadd.0 2017-03-14 06:41:42.982 debug inMem message megadd.0.* megadd.0.p15_P15_31c6b8000000
        ! megadd.0 2017-03-14 06:41:42.982 debug inMem message megadd.0.* megadd.0.p15_P15_32c6b8000000
        ! megadd.0 2017-03-14 06:41:42.982 debug inMem message megadd.0.* megadd.0.p15_P15_30c6b8000000
        ! megadd.0 2017-03-14 06:41:42.982 debug detected new value on port [15_31c6b8000000]: -15.18
        ! megadd.0 2017-03-14 06:41:42.981 debug detected new value on port [15_32c6b8000000]: 17.12
        ! megadd.0 2017-03-14 06:41:42.981 debug detected new value on port [15_30c6b8000000]: 28.31
        ! megadd.0 2017-03-14 06:41:42.980 debug Response: 30c6b8000000:28.31;32c6b8000000:17.12;31c6b8000000:-15.18
        ! megadd.0 2017-03-14 06:41:42.671 debug Response: 30c9b8000000:-10.56
        ! megadd.0 2017-03-14 06:41:42.576 debug inMem message megadd.0.* megadd.0.p33_P33_31c5b8000000
        ! megadd.0 2017-03-14 06:41:42.575 debug inMem message megadd.0.* megadd.0.p33_P33_32c5b8000000
        ! megadd.0 2017-03-14 06:41:42.556 debug inMem message megadd.0.* megadd.0.p33_P33_30c5b8000000
        ! megadd.0 2017-03-14 06:41:42.555 debug detected new value on port [33_31c5b8000000]: -15.81
        ! megadd.0 2017-03-14 06:41:42.555 debug detected new value on port [33_32c5b8000000]: 27
        ! megadd.0 2017-03-14 06:41:42.555 debug detected new value on port [33_30c5b8000000]: 31.81
        ! megadd.0 2017-03-14 06:41:42.554 debug Response: 30c5b8000000:31.81;32c5b8000000:27.00;31c5b8000000:-15.81
        ! megadd.0 2017-03-14 06:41:42.344 debug inMem message megadd.0.* megadd.0.p15_P15_31c6b8000000
        ! megadd.0 2017-03-14 06:41:42.343 debug inMem message megadd.0.* megadd.0.p15_P15_32c6b8000000
        ! megadd.0 2017-03-14 06:41:42.342 debug inMem message megadd.0.* megadd.0.p15_P15_30c6b8000000
        ! megadd.0 2017-03-14 06:41:42.342 debug detected new value on port [15_31c6b8000000]: -15.18
        ! megadd.0 2017-03-14 06:41:42.342 debug detected new value on port [15_32c6b8000000]: 17.12
        ! megadd.0 2017-03-14 06:41:42.341 debug detected new value on port [15_30c6b8000000]: 28.31
        ! megadd.0 2017-03-14 06:41:42.340 debug Response: 30c6b8000000:28.31;32c6b8000000:17.12;31c6b8000000:-15.18
        ! megadd.0 2017-03-14 06:41:42.118 debug Response: 30c9b8000000:-10.56
        ! megadd.0 2017-03-14 06:41:41.890 debug getPortStateW http://192.168.1.14/sec/?pt=33&cmd=list
        ! megadd.0 2017-03-14 06:41:41.890 debug getPortStateW http://192.168.1.14/sec/?pt=15&cmd=list
        ! megadd.0 2017-03-14 06:41:41.890 debug getPortStateW http://192.168.1.14/sec/?pt=5&cmd=list
        ! megadd.0 2017-03-14 06:41:41.889 debug Response: temp:24.00;OFF/0;OFF/0;;OFF;;temp:0.00/hum:0.00;OFF/OFF;NA/NA;OFF;0;0;0;255;ON;;OFF;temp:0.04/press:1.76;OFF/0;OFF/0;temp:6.00/hum:76.00;temp:0.00/hum:0.00;OFF;;OFF;;;OFF;OFF;ON;;OFF;temp:-2
        ! megadd.0 2017-03-14 06:41:39.658 debug getPortStateW http://192.168.1.14/sec/?pt=33&cmd=list
        ! megadd.0 2017-03-14 06:41:39.658 debug getPortStateW http://192.168.1.14/sec/?pt=15&cmd=list
        ! megadd.0 2017-03-14 06:41:39.658 debug getPortStateW http://192.168.1.14/sec/?pt=5&cmd=list
        ! megadd.0 2017-03-14 06:41:39.657 debug Response: temp:24.00;OFF/0;OFF/0;;OFF;;temp:0.00/hum:0.00;OFF/OFF;NA/NA;OFF;0;0;0;255;ON;;OFF;temp:0.04/press:1.76;OFF/0;OFF/0;temp:6.00/hum:76.00;temp:0.00/hum:0.00;OFF;;OFF;;;OFF;OFF;ON;;OFF;temp:-2
        ! megadd.0 2017-03-14 06:41:37.758 debug getPortState http://192.168.1.14/sec/?cmd=all
        P.S. Лишние строки затесались 🙂
        Ну и самое главное в чем был вопрос, как создать эти порты. p5_P5_30c9b8000000, p15_P15_30c6b8000000, p15_P15_31c6b8000000, ….p33P33_..
        ! if (settings.pty == 3) {
        ! obj.common.write = false;
        ! obj.common.read = true;
        ! obj.common.def = 0;
        ! obj.common.type = 'number';
        ! if (settings.d == 1 || settings.d == 2 || settings.d == 3) {
        ! } else if (settings.d == 5) { // 1Wire
        ! obj.common.min = -30;
        ! obj.common.max = 30;
        ! obj.common.unit = '°C';
        ! obj.common.desc = 'P' + p + ' - temperature';
        ! if (!obj.common.role) obj.common.role = 'value.temperature';
        Кое что подправил
        ! if (val !== _ports[_port].value || _ports[_port].q !== q) {
        ! adapter.log.debug('VAL :' + val + ' ' + 'PORT VAL :' + _ports[_port].value);
        ! _ports[_port].oldValue = _ports[_port].value;
        ! if (_ports[_port].pty == 3 && _ports[_port].d == 5) {
        ! adapter.log.debug('detected new value on port [' + port + '' + id[0] + ']: ' + val);
        ! ///adapter.setState(_ports[port].id + '' + id[0], {val: value, ack: true, q: q});
        ! adapter.setState(_ports[port].id + '' + id[0], {val: val, ack: true, q: q}); //haus
        ! _ports[_port].value = val;
        ! _ports[_port].q = q;
        Вбил руками порты megadd.0.p33_P33_32c5b8000000, …... Неправильно определяет if (val !== _ports[_port].value || _ports[_port].q !== q) { если больше одного датчика
        ! megadd.0 2017-03-14 17:21:29.678 debug inMem message megadd.0.* megadd.0.p33_P33_31c5b8000000
        ! megadd.0 2017-03-14 17:21:29.677 debug inMem message megadd.0.* megadd.0.p33_P33_32c5b8000000
        ! megadd.0 2017-03-14 17:21:29.665 debug inMem message megadd.0.* megadd.0.p33_P33_30c5b8000000
        ! megadd.0 2017-03-14 17:21:29.664 debug detected new value on port [33_31c5b8000000]: -17.37
        ! megadd.0 2017-03-14 17:21:29.663 debug VAL :-17.37 PORT VAL :27
        ! megadd.0 2017-03-14 17:21:29.663 debug detected new value on port [33_32c5b8000000]: 27
        ! megadd.0 2017-03-14 17:21:29.663 debug VAL :27 PORT VAL :31.81
        ! megadd.0 2017-03-14 17:21:29.662 debug detected new value on port [33_30c5b8000000]: 31.81
        ! megadd.0 2017-03-14 17:21:29.662 debug VAL :31.81 PORT VAL :-17.37
        ! megadd.0 2017-03-14 17:21:29.661 debug Response: 30c5b8000000:31.81;32c5b8000000:27.00;31c5b8000000:-17.37
        Иногда MegaD на запрос http://192.168.1.14/sec/?pt=33&cmd=list может вернуть "busy" если шина занята конвертацией, здесь главное чтобы драйвер не парсил этот ответ или как вариант повторил запрос скажем через 5-10 секунд.
        ! megadd.0 2017-03-14 09:45:38.692 debug Response: busy
        ! megadd.0 2017-03-14 09:45:38.611 debug Response: busy
        ! megadd.0 2017-03-14 09:45:38.600 debug Response: busy
        ! megadd.0 2017-03-14 09:45:32.537 debug getPortStateW http://192.168.1.14/sec/?pt=33&cmd=list
        ! megadd.0 2017-03-14 09:45:32.536 debug getPortStateW http://192.168.1.14/sec/?pt=15&cmd=list
        ! megadd.0 2017-03-14 09:45:32.534 debug getPortStateW http://192.168.1.14/sec/?pt=5&cmd=list
          Pooh last edited by
          Помогите, плз, пошагово настроить мегу2561 и драйвер, делал по аналогии с драйвером мега328 (который работает отлично), не получилось - состояние портов меняется раз в 30 сек, а не по факту нажатия кнопки
          кнопка на порту 18, реле на порту 25. с каждым нажатием кнопки меняем состояние реле
            Haus last edited by
            @Pooh:
            кнопка на порту 18, реле на порту 25. с каждым нажатием кнопки меняем состояние реле `
            Настройки отличаются от Megad-328. В принципе достаточно считать настройки с Megad-2561(если настроен) и после этого записать настройки в Megad-2561 (что бы прописался сервер и инстанция(скрипт)).
            Пример если кнопка
            script
            on({id: 'megadd.0.p1_P1', change: 'any'}, function (obj) {
                if (obj.newState.val === true && getState('megadd.0.p24_P24').val === false) {
                    setState('megadd.0.p24_P24', true);
                } else if (obj.newState.val === true && getState('megadd.0.p24_P24').val === true) {
                    setState('megadd.0.p24_P24', false);
              Pooh last edited by
              @Haus:
              ..В принципе достаточно считать настройки с Megad-2561(если настроен) и после этого записать настройки в Megad-2561 (что бы прописался сервер и инстанция(скрипт)).. `
              НИФИГА
              Два вечера бился практически методом тыка
              настроил mega2561: каждый вход "mod P с галочкой". при этом без сервера выполняется автономная команда
              прочитал драйвером настройки.
              изменил в драйвере режим входов на "при изменении" (после считывания было "при замыкании")
              сохранил (без сохранения в сам мегад3561!)
              скрипт типа:
              on('megadd.0.p2_P2', function (obj) {
                  if (obj.newState.val === true && getState('megadd.0.p9_P9').val === false) {
                      setState ('megadd.0.p9_P9', true);
                  }else if(obj.newState.val === true && getState('megadd.0.p9_P9').val === true){
                      setState ('megadd.0.p9_P9', false);
              ВУАЛЯ
                Haus last edited by
                @Pooh:
                @Haus:
                ..В принципе достаточно считать настройки с Megad-2561(если настроен) и после этого записать настройки в Megad-2561 (что бы прописался сервер и инстанция(скрипт)).. НИФИГА
                ????? что не так?
                @Pooh:
                прочитал драйвером настройки. `
                Считал драйвер настройки правильно?
                @Pooh:
                сохранил (без сохранения в сам мегад3561!) `
                Драйвер MegaD-2561, как я писал выше отличается от MegaD-328. При считывание конфига в настройках драйвера менять ничего не надо, а если поменял то надо записать изменения в MegaD-2561. ТО ЕСТЬ ИЗ ДРАЙВЕРА МОЖНО ПОМЕНЯТЬ ВСЕ НАСТРОЙКИ MegaD-2561, НЕ ИСПОЛЬЗУЯ WEB MegaD-2561.
                  Pooh last edited by
                  у меня в драйвере нет "текущая версия прошивки… доступная версия прошивки..."
                  v0.2.0
                    Pooh last edited by
                    @Haus:
                    ..????? что не так?.. `
                    думаю драйвером не учитывается, что "Флажок (чекбокс) справа от поля Mode указывает, что при наличии сервера, устройство отправляет на сервер сообщения всегда в режиме P&R, а при его отсутствии Action выполняется только в том режиме, который установлен в Mode." (http://ab-log.ru/smart-house/ethernet/megad-2561)
                    т.е. если установить в модуле режим P&R и считать драйвером, то все хорошо, пока сервер работает. если установить в модуле режим P с галочкой и считать драйвером, то все хорошо, пока сервер (драйвер) не работает.
                    Счастье наступает, когда в модуле режим входов установлен в P с галочкой, конфиг считан драйвером и режим (в драйвере) изменен на "при изменении"
                    запись параметров в модуль из драйвера результатов не дает, ибо драйвер четко записывает режим P&R, при котором не работает автономный режим…
                    и да, считывается/записывается один-в-один
                      Haus last edited by
                      @Pooh:
                      @Haus:
                      ..????? что не так?.. Счастье наступает, когда в модуле режим входов установлен в P с галочкой, конфиг считан драйвером и режим (в драйвере) изменен на "при изменении"
                      А зачем ты меняешь после считывания?
                        Pooh last edited by
                        я ж говорил, если просто считать с меги и сохранить в драйвере, то состояние портов меняется раз в 30 сек, по факту опроса драйвером, а не по факту нажатия кнопки
                        какая сейчас версия драйвера актуальная? у меня 0.2.0..
                          Haus last edited by
                          @Pooh:
                          какая сейчас версия драйвера актуальная? у меня 0.2.0.. `
                          Попробуй с git.
                          cd /opt/iobroker
                          iobroker stop megadd
                          npm install https://github.com/ausHaus/ioBroker.megadd/tarball/master/
                          iobroker upload megadd
                          iobroker restart megadd
                            Pooh last edited by
                            Обновил до 0.2.2
                            Совсем другой коленкор! Теперь все работает как надо! Спасибо!
                            Только теперь в админе вкладка "драйвера" почему-то зеленая, хотя обновлять нечего…
                              Pooh last edited by
                              Наверное вопрос надо было в тему скрипты…. тем не менее:
                              Подключаю счетчик воды (геркон, 10л/импульс). становится ясно, что:
                              • даже в случае бесперебойного аптайма размерности встроенного в мегу счетчика не хватит на длительный срок
                              • при сбросе мегад показания собъются (так же как и при перезапуске айоброкера)
                              Внимание, вопрос: как синхронизировать показания счетчиков и учесть при этом размерность встроенного в мегу (65тыс вроде как)
                              • I
                                instalator last edited by
                                @Pooh:
                                Внимание, вопрос: как синхронизировать показания счетчиков и учесть при этом размерность встроенного в мегу (65тыс вроде как) `
                                Я вот так сделал http://blog.instalator.ru/archives/711
                                  Haus last edited by
                                  @Pooh:
                                  Внимание, вопрос: как синхронизировать показания счетчиков и учесть при этом размерность встроенного в мегу (65тыс вроде как) ` ````
                                  createState('Water_meter',0);
                                  var lastValue = null;
                                  on("megadd.0.p1_P1_counter", function (obj) {
                                  // initialisation
                                  if (lastValue === null) {
                                  lastValue = obj.state.val;
                                  return;
                                  // Megadd have been restarted
                                  if (lastValue > obj.state.val) {
                                      setState('Water_meter', getState('Water_meter').val + obj.state.val, true);
                                  } else if (obj.state.val != lastValue) {
                                      setState('Water_meter', getState('Water_meter').val + (obj.state.val - lastValue), true);
                                  } else {
                                      return;
                                    Pooh last edited by
                                    процесс пошел…
                                    как получить текущее время в миллисекундах?
                                    это нужно для вычисления "мгновенного" потребления
                                      Pooh last edited by
                                      @instalator:
                                      ..Я вот так сделал http://blog.instalator.ru/archives/711 `
                                      излишне, есть же счетчик в мегаД
                                      сейчас я юзаю дополнительный https://www.mysensors.org/build/pulse_power, но хочу от него отказаться…
                                        Haus last edited by
                                        @Pooh:
                                        процесс пошел…
                                        это нужно для вычисления "мгновенного" потребления `
                                        http://forum.iobroker.net/viewtopic.php … 528#p72334
                                          Pooh last edited by
                                          javascript.0 2017-06-25 23:04:45.557 error Error in callback: TypeError: Cannot read property 'ts' of undefined
                                          • I
                                            @Pooh:
                                            @instalator:
                                            сейчас я юзаю дополнительный https://www.mysensors.org/build/pulse_power, но хочу от него отказаться… `
                                            Который обнуляется при пропадании питания и при отвале сети или сервера или иоброкера….
                                            81.1k
                                            160
                                            43607
