    4. (Gelöst) Wieviel freien Speicher
    • Damrak2022
      Damrak2022 @Glasfaser last edited by
      @glasfaser sagte in Wieviel freien Speicher:
      ls
      pi@homebridge:~ $ ls -lh /opt/iobroker/log
      total 833M
      -rw-rw-r--+ 1 iobroker iobroker 128M Aug 29 00:01 iobroker.2022-08-28.log.gz
      -rw-rw-r--+ 1 iobroker iobroker 128M Aug 30 00:01 iobroker.2022-08-29.log.gz
      -rw-rw-r--+ 1 iobroker iobroker 128M Aug 31 00:01 iobroker.2022-08-30.log.gz
      -rw-rw-r--+ 1 iobroker iobroker 128M Sep  1 00:01 iobroker.2022-08-31.log.gz
      -rw-rw-r--+ 1 iobroker iobroker 137M Sep  2 00:01 iobroker.2022-09-01.log.gz
      -rw-rw-r--+ 1 iobroker iobroker 129M Sep  3 00:01 iobroker.2022-09-02.log.gz
      -rw-rw-r--+ 1 iobroker iobroker  57M Sep  3 01:15 iobroker.2022-09-03.log
      -rw-rwxr--+ 1 iobroker iobroker  793 Sep  3 00:35 iobroker-audit.json
      lrwxrwxrwx  1 iobroker iobroker   23 Sep  3 01:15 iobroker.current.log -> iobroker.2022-09-03.log
      pi@homebridge:~ $
      • mickym
        mickym Most Active @Damrak2022 last edited by
        @damrak2022 Na Deine Logs sind alle ziemllich groß - findest Du denn da drin überhaupt noch was?
        ls -lh
        insgesamt 192K
        -rw-rw-r--+ 1 iobroker iobroker  13K 28. Aug 00:00 iobroker.2022-08-27.log.gz
        -rw-rw-r--+ 1 iobroker iobroker  18K 29. Aug 00:00 iobroker.2022-08-28.log.gz
        -rw-rw-r--+ 1 iobroker iobroker  19K 30. Aug 00:00 iobroker.2022-08-29.log.gz
        -rw-rw-r--+ 1 iobroker iobroker  32K 31. Aug 00:00 iobroker.2022-08-30.log.gz
        -rw-rw-r--+ 1 iobroker iobroker 7,6K  1. Sep 00:00 iobroker.2022-08-31.log.gz
        -rw-rw-r--+ 1 iobroker iobroker  34K  2. Sep 00:00 iobroker.2022-09-01.log.gz
        -rw-rw-r--+ 1 iobroker iobroker  13K  3. Sep 00:00 iobroker.2022-09-02.log.gz
        -rw-rw-r--+ 1 iobroker iobroker  39K  3. Sep 01:15 iobroker.2022-09-03.log
        -rw-rwxr--+ 1 iobroker iobroker  793  3. Sep 00:51 iobroker-audit.json
        lrwxrwxrwx  1 iobroker iobroker   23  3. Sep 01:15 iobroker.current.log -> iobroker.2022-09-03.log
        Im Schnitt bei mir ca. 20 kB - bei Dir 128 MB
        Damrak2022 Jey Cee 2 Replies Last reply Reply Quote 0
        • Damrak2022
          @mickym Ich muss jetzt erstmal meine Datenpunkte durchgehen und schauen wo ich einen Log aktiviert habe und vergessen ihn auszuschalten.
          • mickym
            @damrak2022 Nee geh erst mal Deine Instanzen von den Adaptern durch - ob da einer auf DEBUG steht- poste halt mal einen Teil Deinen Logs - da siehst Du doch welcher Adapter da am meisten reinschreibt.
            • Damrak2022
              @mickym Auf debug stand:
              hue
              ical
              iot
              Pegelalarm
              • mickym
                @damrak2022 Na dann weisst Du ja woran - es liegt - also alle auf info stellen. 😉
                • Damrak2022
                  @mickym Habe ich schon. War selbst überrascht
                  • mickym
                    @damrak2022 sagte in Wieviel freien Speicher:
                    Wahrscheinlich springt Deine Performance um einiges in die Höhe - mich wundert ja, dass Dein System das so klaglos mitgemacht hat.
                    • Damrak2022
                      @mickym Vielleicht sollte ich mich heute mal "Glückspilz" nennen.
                      • mickym
                        @damrak2022 Im Prinzip würde ich den Flow aber nicht laufen lassen - Du hast im iobroker die Daten doch alle zur Verfügung - da musst Du nicht permanent Betriebssystem-Kommandos rausschicken.
                        Schau mal in Deinen iobroker Datenpunkten unter system und dann host und Deinem host-namen
                        Da musst Du nicht dauernd pollen - das belastet das System auch nur und in den Datenpunkten hast Du doch alle Informationen.
                        • Damrak2022
                          @mickym Welches Script sollte ich nicht laufen lassen?
                          • mickym
                            @damrak2022 Na den NodeRed Flow.Das frägt alle 10s die CPU Parameter ab und alle Minuten die Festplattenbelegung. Und diese Daten hast Du alle schon im iobroker. Lediglich die Temperatur ist nicht verfügbar.
                            • Damrak2022
                              @mickym Ach so. Mir gefällt die grafische Darstellung schon. Aber das kann ich doch bestimmt deaktivieren und nur aktivieren, wenn ich draufscahuen möchte. Du hast schon recht, ich halte mir das ja nicht permanent vor die Nase
                              • mickym
                                @damrak2022 Na bis auf die Temperatur - kannst Du das ja lassen, aber anstelle Betriebssystembefehle abzusetzen kannst Du doch die Datenpunkte abfragen. Hast Du die gesehen? - Ich hab einen Screenshot gemacht.
                                • Damrak2022
                                  @mickym Ja, habe ich gesehen. Verstehe ich Dich richtig das Du meinst die könnte ich über einen Node abfragen, was dann effektiver wäre. Oder meinst Du ich könnte ie mir so wie in einem Screenshot anzeigen lassen.
                                  • mickym
                                    @damrak2022 Genau Du kannst diese Punkte mit einer iobroker-IN Node direkt abfragen und in der Gauge darstellen.
                                    • Damrak2022
                                      @mickym Gut, wieder was gelernt. Da mache ich mich morgen dran. Mein Backup läuft noch. An der Stelle braucht er extrem lange:
                                      • Damrak2022
                                        @mickym Kannst Du mir noch eine letzte Frage beantworten?
                                        Wie hast Du Dein Dashboard gestaltet, sodass es exakt aufs iPad passt?
                                        • mickym
                                          @damrak2022 Na das sind ja auch die Riesendateien - 1 Influx-DB Sicherungsdatei - 6 Gigabyte. 😉 - Wie gesagt kläre das, warum das lokal gespeichert wird. Ich kann mir ja vorstellen, dass es zwischen gespeichert werden muss, aber sobald es auf Google Drive übertragen ist, sollte es gelöscht werden. Ausser es gibt ein Problem mit dem Upload - aber das musst Du selbst klären. 😉
                                          • mickym
                                            Wie gehts Deiner Festplatte - wurden die übrigen Backups gelöscht?
                                            1.0k
                                            4418
