    4. "Verbunden mit influxdb" Falsch -> Keine Werte in Datenbank
      eastcoast last edited by
      @apollon77:
      Ich blick es genauso wenig wie bei Homoran … Bitte update vom Github. Jetzt gibts error-logging wenn "connected" nicht aktualisiert werden kann. Mal schauen ob das mehr Infos bringt. `
      installiert via console mit "npm install https://github.com/ioBroker/ioBroker.influxdb.git" und hier der Log:
      influxdb.0	2017-03-06 18:53:13.083	debug	influxdb.0 Datatype javascript.0.froniusSymo.meter.PowerReal_P_Sum: Currently: number, StorageType: false
      influxdb.0	2017-03-06 18:53:13.083	debug	influxdb.0 Datatype javascript.0.froniusSymo.inverter.DAY_ENERGY: Currently: number, StorageType: false
      influxdb.0	2017-03-06 18:53:13.074	debug	influxdb.0 Datatype javascript.0.froniusSymo.inverter.PAC: Currently: number, StorageType: false
      influxdb.0	2017-03-06 18:53:03.064	debug	inMem message javascript.0.froniusSymo.meter.PowerReal_P_Sum javascript.0.froniusSymo.meter.PowerReal_P_Sum
      influxdb.0	2017-03-06 18:53:03.056	debug	inMem message javascript.0.froniusSymo.inverter.DAY_ENERGY javascript.0.froniusSymo.inverter.DAY_ENERGY
      influxdb.0	2017-03-06 18:53:03.021	debug	inMem message javascript.0.froniusSymo.inverter.PAC javascript.0.froniusSymo.inverter.PAC
      influxdb.0	2017-03-06 18:52:34.215	info	enabled logging of javascript.0.froniusSymo.history.energyProdDay, 6 points now activated
      influxdb.0	2017-03-06 18:52:34.215	info	enabled logging of javascript.0.froniusSymo.history.energyRetDay, 5 points now activated
      influxdb.0	2017-03-06 18:52:34.214	info	enabled logging of javascript.0.froniusSymo.history.energyConsDay, 4 points now activated
      influxdb.0	2017-03-06 18:52:34.214	info	enabled logging of javascript.0.froniusSymo.meter.PowerReal_P_Sum, 3 points now activated
      influxdb.0	2017-03-06 18:52:34.213	info	enabled logging of javascript.0.froniusSymo.inverter.DAY_ENERGY, 2 points now activated
      influxdb.0	2017-03-06 18:52:34.209	info	enabled logging of javascript.0.froniusSymo.inverter.PAC, 1 points now activated
      influxdb.0	2017-03-06 18:52:34.175	info	Connected!
      influxdb.0	2017-03-06 18:52:34.025	info	Connecting http://localhost:8086 ...
      influxdb.0	2017-03-06 18:52:34.021	info	Buffer initialized with data for 0 points and 0 conflicts from last exit
      influxdb.0	2017-03-06 18:52:34.014	info	starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.influxdb, node: v4.8.0
      influxdb.0	2017-03-06 18:52:33.969	debug	statesDB connected
      influxdb.0	2017-03-06 18:52:33.889	debug	objectDB connected
      host.xxxx-iobroker	2017-03-06 18:52:32.034	info	instance system.adapter.influxdb.0 started with pid 13381
        apollon77 last edited by
        Kooooomisch …
        Bitte nochmal und "iobroker upload influxdb" nicht vergessen!! Habe jetzt auch Success-Logging eingebaut 🙂
          der fast erste Satz ist "connected"
          dann finde ich nur noch Datenaktualisierungen und sonst nichts.
          Unter Objekte nach wie vor keine Angabe ob connected = true oder false
          Gibt es etwas wonach man das log filtern kann?
          Rainer
            also basierend auf "debug"-level hatte ich das eingebaut
            adapter.log.debug('connected set to ' + connected);
            also es sollte etwas kommen wie "connected set to true". Aber halt als Debug.
            https://github.com/ioBroker/ioBroker.in … in.js#L123
            Kannst es lokal auch einfach in info ändern oder so
              Kann das nochmal einer machen/checken bitte?!
                @apollon77:
                Kann das nochmal einer machen/checken bitte?! `
                Was willst du sehen?
                Mein log von heute ist inzwischen 188MB groß, da muss ich schon wissen wonach ich suchen kann.
                Habe nochmal aus dem git upgedated und upgeloaded 😉
                Auf Anhieb finde ich jetzt:
                `2017-03-07 18:02:59.020  - [32minfo[39m: host.ioBroker_Pine64 object change system.adapter.influxdb.0
                2017-03-07 18:02:59.022  - [32minfo[39m: host.ioBroker_Pine64 "system.adapter.influxdb.0" enabled
                2017-03-07 18:02:59.022  - [32minfo[39m: host.ioBroker_Pine64 stopInstance system.adapter.influxdb.0
                2017-03-07 18:02:59.023  - [32minfo[39m: host.ioBroker_Pine64 stopInstance system.adapter.influxdb.0 killing pid 1350
                2017-03-07 18:02:59.219  - [33mwarn[39m: host.ioBroker_Pine64 instance system.adapter.influxdb.0 terminated due to SIGTERM
                2017-03-07 18:02:59.220  - [32minfo[39m: host.ioBroker_Pine64 instance system.adapter.influxdb.0 terminated with code null ()
                2017-03-07 18:03:01.558  - [32minfo[39m: host.ioBroker_Pine64 instance system.adapter.influxdb.0 started with pid 1392
                2017-03-07 18:03:02.597  - [32minfo[39m: host.ioBroker_Pine64 instance system.adapter.rflink.0 started with pid 1398
                2017-03-07 18:03:04.024  - [32minfo[39m: solarwetter.0 force terminating adapter after 1 minute
                2017-03-07 18:03:04.593  - [32minfo[39m: host.ioBroker_Pine64 instance system.adapter.solarwetter.0 terminated with code 0 (OK)
                2017-03-07 18:03:05.741  - [32minfo[39m: host. States connected to redis 127.0.0.1:6379
                2017-03-07 18:03:05.860  - [32minfo[39m: rflink.0 starting. Version 1.0.8 in /opt/iobroker/node_modules/iobroker.rflink, node: v4.6.1
                2017-03-07 18:03:05.830  - [34mdebug[39m: influxdb.0 objectDB connected
                2017-03-07 18:03:05.917  - [34mdebug[39m: influxdb.0 statesDB connected
                2017-03-07 18:03:05.948  - [32minfo[39m: host. States connected to redis 127.0.0.1:6379
                2017-03-07 18:03:05.983  - [34mdebug[39m: host. redis get system.adapter.influxdb.0.alive ok: {"val":false,"ack":true,"ts":1488906179221,"q":0,"from":"system.host.ioBroker_Pine64","lc":1488906179221}
                2017-03-07 18:03:06.079  - [32minfo[39m: influxdb.0 starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.influxdb, node: v4.6.1
                2017-03-07 18:03:06.086  - [32minfo[39m: vis.0 400 files uploaded...
                2017-03-07 18:03:06.191  - [32minfo[39m: rflink.0 Serial port opened
                2017-03-07 18:03:06.116  - [32minfo[39m: influxdb.0 No stored data from last exit found
                2017-03-07 18:03:06.126  - [32minfo[39m: influxdb.0 Connecting http://localhost:8086 ...
                2017-03-07 18:03:06.202  - [34mdebug[39m: host. redis psubscribe io.influxdb.0.checkLogging
                2017-03-07 18:03:06.241  - [34mdebug[39m: host. redis keys 1 *.logging[/code]`
                Die Ampel ist gelb, unter influxdb.0.info.connection steht immer noch nichts
                EDIT:
                das noch gefunden:
                `~~[code]~~2017-03-07 17:59:43.956  - [32minfo[39m: iobroker got /opt/iobroker/node_modules/iobroker.influxdb/admin
                2017-03-07 17:59:43.986  - [32minfo[39m: iobroker upload [2] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/influxdb.png influxdb.png image/png
                2017-03-07 17:59:44.124  - [32minfo[39m: iobroker upload [1] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/index.html index.html text/html
                2017-03-07 17:59:44.224  - [32minfo[39m: iobroker upload [0] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/custom.html custom.html text/html
                2017-03-07 17:59:44.305  - [34mdebug[39m: host. redis pmessage  io.* io.system.adapter.influxdb.upload {"val":0,"ack":false,"ts":1488905984302,"q":0,"lc":1480363337473}
                2017-03-07 17:59:44.412  - [32minfo[39m: host.ioBroker_Pine64 object change system.adapter.influxdb.0
                2017-03-07 17:59:44.439  - [33mwarn[39m: influxdb.0 Store data for 0 points and 0 conflicts
                2017-03-07 17:59:44.444  - [34mdebug[39m: host. redis publish io.system.adapter.influxdb.0.alive {"val":false,"ack":true,"ts":1488905984444,"q":0,"from":"system.adapter.influxdb.0","lc":1488905984444}
                2017-03-07 17:59:44.413  - [32minfo[39m: host.ioBroker_Pine64 "system.adapter.influxdb.0" disabled
                2017-03-07 17:59:44.416  - [32minfo[39m: host.ioBroker_Pine64 stopInstance system.adapter.influxdb.0
                2017-03-07 17:59:44.417  - [32minfo[39m: host.ioBroker_Pine64 stopInstance system.adapter.influxdb.0 killing pid 12189
                2017-03-07 17:59:44.456  - [32minfo[39m: influxdb.0 terminating
                2017-03-07 17:59:44.492  - [32minfo[39m: host.ioBroker_Pine64 object change system.adapter.influxdb.0
                2017-03-07 17:59:44.494  - [32minfo[39m: host.ioBroker_Pine64 "system.adapter.influxdb.0" enabled
                2017-03-07 17:59:44.539  - [32minfo[39m: host.ioBroker_Pine64 instance system.adapter.influxdb.0 started with pid 23258
                2017-03-07 17:59:44.602  - [32minfo[39m: host.ioBroker_Pine64 instance system.adapter.influxdb.0 terminated with code 0 (OK)
                2017-03-07 17:59:44.623  - [32minfo[39m: iobroker Adapter "system.adapter.influxdb.0" restarted.
                2017-03-07 17:59:44.643  - [32minfo[39m: iobroker exit 0
                2017-03-07 17:59:45.061  - [32minfo[39m: host.ioBroker_Pine64 Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                2017-03-07 17:59:47.801  - [34mdebug[39m: influxdb.0 objectDB connected
                2017-03-07 17:59:47.867  - [34mdebug[39m: influxdb.0 statesDB connected
                2017-03-07 17:59:47.882  - [32minfo[39m: host. States connected to redis 127.0.0.1:6379
                2017-03-07 17:59:47.906  - [34mdebug[39m: host. redis get system.adapter.influxdb.0.alive ok: {"val":false,"ack":true,"ts":1488905984628,"q":0,"from":"system.host.ioBroker_Pine64","lc":1488905984444}
                2017-03-07 17:59:47.966  - [32minfo[39m: influxdb.0 starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.influxdb, node: v4.6.1
                2017-03-07 17:59:47.982  - [32minfo[39m: influxdb.0 Buffer initialized with data for 0 points and 0 conflicts from last exit
                2017-03-07 17:59:47.989  - [32minfo[39m: influxdb.0 Connecting http://localhost:8086 ...
                2017-03-07 17:59:48.034  - [34mdebug[39m: host. redis psubscribe io.influxdb.0.checkLogging
                2017-03-07 17:59:48.062  - [34mdebug[39m: host. redis keys 1 *.logging
                2017-03-07 17:59:48.066  - [34mdebug[39m: host. redis publish io.system.adapter.influxdb.0.alive {"val":true,"ack":true,"ts":1488905988066,"q":0,"from":"system.adapter.influxdb.0","lc":1488905988066}
                2017-03-07 17:59:48.072  - [34mdebug[39m: host. redis publish io.system.adapter.influxdb.0.connected {"val":true,"ack":true,"ts":1488905988068,"q":0,"from":"system.adapter.influxdb.0","lc":1488905988068}
                2017-03-07 17:59:48.075  - [34mdebug[39m: host. redis publish io.system.adapter.influxdb.0.memRss {"val":41.66,"ack":true,"ts":1488905988074,"q":0,"from":"system.adapter.influxdb.0","lc":1488905988074}
                2017-03-07 17:59:48.079  - [34mdebug[39m: host. redis publish io.system.adapter.influxdb.0.memHeapTotal {"val":36.73,"ack":true,"ts":1488905988078,"q":0,"from":"system.adapter.influxdb.0","lc":1488905988078}
                2017-03-07 17:59:48.083  - [34mdebug[39m: host. redis publish io.system.adapter.influxdb.0.memHeapUsed {"val":25.55,"ack":true,"ts":1488905988082,"q":0,"from":"system.adapter.influxdb.0","lc":1488905988082}
                2017-03-07 17:59:48.088  - [34mdebug[39m: host. redis publish io.system.adapter.influxdb.0.uptime {"val":3,"ack":true,"ts":1488905988087,"q":0,"from":"system.adapter.influxdb.0","lc":1488905988087}
                2017-03-07 17:59:48.093  - [34mdebug[39m: host. redis publish io.influxdb.0.info.connected {"val":false,"ack":true,"ts":1488905988093,"q":0,"from":"system.adapter.influxdb.0","lc":1488905988093}
                2017-03-07 17:59:48.108  - [34mdebug[39m: host. redis mget 1 1
                2017-03-07 17:59:48.113  - [34mdebug[39m: influxdb.0 connected set to false
                2017-03-07 17:59:48.171  - [32minfo[39m: influxdb.0 Connected!
                2017-03-07 17:59:48.172  - [34mdebug[39m: host. redis publish io.influxdb.0.info.connected {"val":true,"ack":true,"ts":1488905988172,"q":0,"from":"system.adapter.influxdb.0","lc":1488905988172}
                2017-03-07 17:59:48.178  - [34mdebug[39m: influxdb.0 connected set to true[/code]`
                Rainer[/code]
                  @apollon77:
                  habe gerade nochmal von github aktualisiert…
                  Status ist noch gelb, Objekt influxdb.0.info.connection hat keinen Wert, hier der Log:
                  influxdb.0	2017-03-07 18:42:12.333	debug	influxdb.0 Datatype javascript.0.froniusSymo.meter.PowerReal_P_Sum: Currently: number, StorageType: false
                  influxdb.0	2017-03-07 18:42:12.274	debug	influxdb.0 Datatype javascript.0.froniusSymo.inverter.DAY_ENERGY: Currently: number, StorageType: false
                  influxdb.0	2017-03-07 18:42:12.271	debug	influxdb.0 Datatype javascript.0.froniusSymo.inverter.PAC: Currently: number, StorageType: false
                  influxdb.0	2017-03-07 18:42:02.329	debug	inMem message javascript.0.froniusSymo.meter.PowerReal_P_Sum javascript.0.froniusSymo.meter.PowerReal_P_Sum
                  influxdb.0	2017-03-07 18:42:02.250	debug	inMem message javascript.0.froniusSymo.inverter.DAY_ENERGY javascript.0.froniusSymo.inverter.DAY_ENERGY
                  influxdb.0	2017-03-07 18:42:02.243	debug	inMem message javascript.0.froniusSymo.inverter.PAC javascript.0.froniusSymo.inverter.PAC
                  influxdb.0	2017-03-07 18:41:04.279	info	enabled logging of javascript.0.froniusSymo.history.energyProdDay, 6 points now activated
                  influxdb.0	2017-03-07 18:41:04.279	info	enabled logging of javascript.0.froniusSymo.history.energyRetDay, 5 points now activated
                  influxdb.0	2017-03-07 18:41:04.279	info	enabled logging of javascript.0.froniusSymo.history.energyConsDay, 4 points now activated
                  influxdb.0	2017-03-07 18:41:04.279	info	enabled logging of javascript.0.froniusSymo.meter.PowerReal_P_Sum, 3 points now activated
                  influxdb.0	2017-03-07 18:41:04.278	info	enabled logging of javascript.0.froniusSymo.inverter.DAY_ENERGY, 2 points now activated
                  influxdb.0	2017-03-07 18:41:04.278	info	enabled logging of javascript.0.froniusSymo.inverter.PAC, 1 points now activated
                  influxdb.0	2017-03-07 18:41:04.266	debug	connected set to true
                  influxdb.0	2017-03-07 18:41:04.257	info	Connected!
                  influxdb.0	2017-03-07 18:41:04.160	debug	connected set to false
                  influxdb.0	2017-03-07 18:41:04.071	info	Connecting http://localhost:8086 ...
                  influxdb.0	2017-03-07 18:41:04.069	info	Buffer initialized with data for 0 points and 0 conflicts from last exit
                  influxdb.0	2017-03-07 18:41:04.065	info	starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.influxdb, node: v4.8.0
                  influxdb.0	2017-03-07 18:41:04.015	debug	statesDB connected
                  influxdb.0	2017-03-07 18:41:03.952	debug	objectDB connected
                    ` > 2017-03-07 17:59:48.171 - [32minfo[39m: influxdb.0 Connected!
                    2017-03-07 17:59:48.178 - [34mdebug[39m: influxdb.0 connected set to true `
                    Also das hier sagt (und das andere Log ist bis auf die redis-Debug-Logs identisch) hier eindeutig das das setzen des Wertes klappt…
                    Also die Frage ist damit für mich eher: Warum wird es im Admin nicht angezeigt ...? Kann es sein das Ihr irgendwie in die "Anzahl der Meldungten und daher "Unsubscribe im Admin" reingerannt seid?
                    @Homoran: Schalt dorhc für den Datenpunkt mal History ein und schaue nach ein paa ein/aus-Sachen (also Adapte restarts oder so) was History sagt 🙂
                    Und kannst Debug wieder ausschalten. `
                      @apollon77:
                      Also die Frage ist damit für mich eher: Warum wird es im Admin nicht angezeigt …? Kann es sein das Ihr irgendwie in die "Anzahl der Meldungten und daher "Unsubscribe im Admin" reingerannt seid? `
                      Keine Ahnung wie ich einen "Unsubscribe im Admin" feststellen kann,
                      aber die Anzahl neuer Meldungen im Log ist Minimal…
                      @apollon77:
                      @Homoran: Schalt dorhc für den Datenpunkt mal History ein und schaue nach ein paa ein/aus-Sachen (also Adapte restarts oder so) was History sagt 🙂 `
                      Ich hab das mal gemacht, aber es gibt einfach keine Werte…
                      in der Historie Tabelle steht dann nur "No data", hier der Log von History (SQL)
                      sql.0	2017-03-10 14:43:05.709	info	No Data
                      sql.0	2017-03-10 14:43:05.709	warn	Cannot get index of "influxdb.0.info.connection": id not found
                      Bin mitlerweile auf
                      js-controller 0.16.2
                      admin 1.7.0
                      …damit hat sich nichts geändert.
                        So, ich habs … wer lesen kann ist arg im Vorteil ...
                        connected != connection ... Der Adapter hat schlicht den Status in den falschen State geschrieben und ich habs nicht gesehn :-((
                        Bitte version von Github versuchen. Passts damit?
                        5888
