    4. Server Cannot start inMem-objects on port 9001
      apollon77 @Rene 3 last edited by
      @rene-3 „cat iobroker.json“
        Rene 3 @apollon77 last edited by
        @apollon77
        pi@ReneRaspel:/opt/iobroker/iobroker-data $ cat iobroker.json
          "system": {
            "memoryLimitMB": 0,
            "hostname": "",
            "statisticsInterval": 15000,
            "statisticsIntervalComment": "Interval how often the counters for input/output in adapters and controller will be updated",
            "checkDiskInterval": 300000,
            "checkDiskIntervalComment": "Interval how often the disk size will be checked",
            "instanceStartInterval": 2000,
            "noChmodComment": "Flag to test new feature with no chmod call. Must be deleted later and noChmod must be mainline (2018.06.04)",
            "compact": false,
            "compactComment": "Controller will try to start the instances as a part of the same process. No spawn will be done. Only by adapters that support it and have flag compact flag in io-package.json",
            "allowShellCommands": false,
            "allowShellCommandsComment": "Allow execution of \"shell\" sendToHost commands",
            "memLimitWarn": 100,
            "memLimitWarnComment": "If the available RAM is below this threshold on adapter start, a warning will be logged.",
            "memLimitError": 50,
            "memLimitErrorComment": "If the available RAM is below this threshold on adapter start, an error will be logged."
          "multihostService": {
            "enabled": false,
            "secure": true,
            "password": ""
          "objects": {
            "type": "jsonl",
            "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
            "host": "127.0.0.1",
            "port": 9001,
            "noFileCache": false,
            "maxQueue": 1000,
            "connectTimeout": 30000,
            "writeFileInterval": 5000,
            "dataDir": "",
            "options": {
              "auth_pass": null,
              "retry_max_delay": 5000,
              "retry_max_count": 19,
              "db": 0,
              "family": 0
            "backup": {
              "disabled": false,
              "files": 24,
              "filesComment": "Minimal number of backup files, after the deletion will be executed according to backupTime settings",
              "hours": 48,
              "hoursComment": "All backups older than 48 hours will be deleted. But only if the number of files is greater than of backupNumber",
              "period": 120,
              "periodComment": "by default backup every 2 hours. Time is in minutes. To disable backup set the value to 0",
              "path": "",
              "pathComment": "Absolute path to backup directory or empty to backup in data directory"
          "states": {
            "type": "jsonl",
            "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379].",
            "port": 9000,
            "writeFileInterval": 30000,
            "dataDir": "",
            "options": {
              "auth_pass": null,
              "db": 0,
              "family": 0
            "backup": {
              "disabled": false,
              "files": 24,
              "hours": 48,
              "period": 120,
              "path": "",
          "log": {
            "level": "info",
            "maxDays": 7,
            "noStdout": true,
            "transport": {
              "file1": {
                "type": "file",
                "enabled": true,
                "filename": "log/iobroker",
                "fileext": ".log",
                "maxsize": null,
                "maxFiles": null
              "syslog1": {
                "type": "syslog",
                "enabled": false,
                "host": "localhost",
                "hostComment": "The host running syslogd, defaults to localhost.",
                "portComment": "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).",
                "protocol": "udp4",
                "protocolComment": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).",
                "pathComment": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
                "facilityComment": "Syslog facility to use (Default: local0).",
                "localhost": "iobroker",
                "localhostComment": "Host to indicate that log messages are coming from (Default: localhost).",
                "sysLogTypeComment": "The type of the syslog protocol to use (Default: BSD).",
                "app_nameComment": "The name of the application (Default: process.title).",
                "eolComment": "The end of line character to be added to the end of the message (Default: Message without modifications)."
              "seq1": {
                "type": "seq",
                "enabled": false,
                "serverUrl": "http://IP:PORT",
                "serverUrlComment": "The http(s) URL including port of the seq server. If you use HTTPS a real certificate is needed; self signed certs are ot accepted.",
                "apiKey": "",
                "apiKeyComment": "The apiKey of the seq system"
          "dataDirComment": "Always relative to iobroker.js-controller/",
          "plugins": {},
          "dataDir": "../../iobroker-data/"
          @rene-3 ok dann bitte noch sagen was „iob Version“ sagt
          Dann bitte im iobroker.json unter objects die Zeile mit „connectTimeout“ (Zeile 33 laut deinem post) die Zahl von 30000 auf 600000 ändern (6 hundert tausend).
          Dann bitte einmal „iob status“ ausführen und Geduld haben! Kannst ja mal Zeit stoppen wie lange es dauert.
          Danach bitte wieder mit „ls -la“ schauen wie groß die objects.jsonl jetzt ist. Müsste deutlich kleiner sein.
          R F 2 Replies Last reply Reply Quote 0
            @apollon77
            pi@ReneRaspel:/opt/iobroker/iobroker-data $ iob version
            4.0.23
              Rene 3 @Rene 3 last edited by
              @apollon77
              Vielleicht war der Wert doch etwas zu hoch.
              Sitz hier ca. 25 Min.
              Dann kam leider nur
              pi@ReneRaspel:~ $ iob status
              iobroker is not running on this host.
              Objects type: jsonl
              States  type: jsonl
                @apollon77
                pi@ReneRaspel:~ $ ls -la /opt/iobroker/iobroker-data
                insgesamt 1111480
                drwxrwxr-x+  9 iobroker iobroker       4096  3. Sep 16:59 .
                drwxrwxr-x+  6 iobroker iobroker       4096  1. Sep 11:58 ..
                drwxrwxr-x+  2 iobroker iobroker       4096 21. Aug 02:40 backitup
                drwxrwxr-x+  2 iobroker iobroker      12288  3. Sep 15:47 backup-objects
                drwxrwxr-x+ 26 iobroker iobroker       4096 27. Jun 19:27 files
                drwxrwxr-x+ 14 iobroker iobroker       4096 29. Aug 08:24 history
                drwxrwxr-x+  2 iobroker iobroker       4096 10. Mär 20:00 homekit-controller.0
                -rw-rwxr--+  1 iobroker iobroker       5092  3. Sep 16:31 iobroker.json
                -rw-rwxr--+  1 iobroker iobroker          3 29. Aug 08:24 notifications.json
                -rw-rwxr--+  1 iobroker iobroker    6008528  9. Feb 2022  objects.json.bak.migrated
                -rw-rwxr--+  1 iobroker iobroker 1123892076  3. Sep 16:53 objects.jsonl
                drwxrwxr-x+  2 iobroker iobroker       4096  3. Sep 16:59 objects.jsonl.lock
                -rw-rwxr--+  1 iobroker iobroker    6008525  9. Feb 2022  objects.json.migrated
                -rw-rwxr--+  1 iobroker iobroker      92518  9. Feb 2022  states.json.bak.migrated
                -rw-rwxr--+  1 iobroker iobroker    1994374  3. Sep 16:53 states.jsonl
                -rw-rwxr--+  1 iobroker iobroker      92661  9. Feb 2022  states.json.migrated
                drwxrwxr-x+  2 iobroker iobroker       4096 11. Mär 17:06 yahka.0.hapdata
                  @apollon77
                  Date ist:
                  Samstag 3. Sep 17:36:00 CEST 2022
                  hatte ich ewt. gestern nicht richtig beantwortet
                  Also hier im letzten Bild sieht man es auch wieder, das in der vorletzten Spalte mal JJJJ und mal die Zeit TT:TT eingetragen wird ?
                  Irgendwie komisch
                    Thomas Braun Most Active @Rene 3 last edited by
                    @rene-3
                    rm /opt/iobroker/iobroker-data/*.migrated
                    Dann ist es weg.
                      Rene 3 @Thomas Braun last edited by
                      Danke - probiere ich gleich aus
                        @Thomas-Braun und @apollon77
                        hat geklappt
                        insgesamt 1099560
                        drwxrwxr-x+  9 iobroker iobroker       4096  3. Sep 17:45 .
                        drwxrwxr-x+  2 iobroker iobroker       4096  3. Sep 17:45 objects.jsonl.lock
                        pi@ReneRaspel:~ $
                          fastfoot @apollon77 last edited by
                          @apollon77 sagte in Server Cannot start inMem-objects on port 9001:
                          iob status vergrössert beide *.jsonl Dateien. Hier meine, man sieht es aber auch bei @rene-3
                          root@iobroker01:/opt/iobroker/iobroker-data# ps -ef && ls -ls *jsonl&&iob status && ls -ls *jsonl
                          UID        PID  PPID  C STIME TTY          TIME CMD
                          root         1     0  0 11:54 ?        00:00:00 /bin/bash /opt/scripts/iobroker_startup.sh
                          root     21046     0  0 16:33 pts/0    00:00:00 bash
                          root     25048     1  0 17:27 ?        00:00:00 tail -f /dev/null
                          root     25972 21046  0 17:51 pts/0    00:00:00 ps -ef
                          25980 -rw-r--r-- 1 iobroker iobroker 26600624 Sep  3 17:50 objects.jsonl
                          19944 -rw-r--r-- 1 iobroker iobroker 20422637 Sep  3 17:50 states.jsonl
                          Objects type: jsonl
                          States  type: jsonl
                          root@iobroker01:/opt/iobroker/iobroker-data# ls -ls *jsonl
                          25980 -rw-r--r-- 1 iobroker iobroker 26601216 Sep  3 17:51 objects.jsonl
                          19948 -rw-r--r-- 1 iobroker iobroker 20422811 Sep  3 17:51 states.jsonl
                            Thomas Braun Most Active @fastfoot last edited by
                            @fastfoot
                            Kann ich nicht bestätigen.
                            echad@chet:/opt/iobroker/iobroker-data $ ls -l && iobroker status && ls -l
                            total 35408
                            drwxrwxr-x+  2 iobroker iobroker     4096 Sep  3 03:43 backitup
                            drwxrwxr-x+  2 iobroker iobroker     4096 Sep  3 17:46 backup-objects
                            drwxrwxr-x+ 41 iobroker iobroker     4096 Aug 19 22:05 files
                            drwxrwxr-x+  9 iobroker iobroker     4096 Sep  3 04:26 history
                            -rw-rwxr--+  1 iobroker iobroker     4972 Sep  3 00:29 iobroker.json
                            drwxrwxr-x+  4 iobroker iobroker     4096 Aug 19 22:02 node-red
                            -rw-rw-r--+  1 iobroker iobroker        3 Aug 31 15:45 notifications.json
                            -rw-rw-r--+  1 iobroker iobroker 31879257 Sep  3 17:58 objects.jsonl
                            drwxrwxr-x+  2 iobroker iobroker     4096 Sep  3 17:59 objects.jsonl.lock
                            -rw-rw-r--+  1 iobroker iobroker  4326154 Sep  3 17:59 states.jsonl
                            drwxrwxr-x+  2 iobroker iobroker     4096 Sep  3 17:59 states.jsonl.lock
                            drwxrwxr-x+  2 iobroker iobroker     4096 Sep  3 17:47 zigbee_0
                            Objects type: jsonl
                            States  type: jsonl
                            total 35408
                              aber bei dir läuft der host
                              Bei uns leider nicht ( @fastfoot ) und mir. 😞
                                fastfoot @Rene 3 last edited by
                                @rene-3 sagte in Server Cannot start inMem-objects on port 9001:
                                leider nicht
                                was heisst leider, das war die Vorgabe dass er vorher gestoppt wird 🙂
                                  Rene 3 @fastfoot last edited by
                                  @fastfoot
                                  also ich kann iob stoppen und starten - aber meine läuft überhaupt nicht mehr.
                                    nach https://forum.iobroker.net/post/852366 hatte ich nur den host(eig. den Container) neu gestartet und jetzt ist die objects.jsonl als auch die states.jsonl nochmal um einiges größer
                                    32924 -rw-r--r-- 1 iobroker iobroker 33708285 Sep  3 18:07 objects.jsonl
                                    22968 -rw-r--r-- 1 iobroker iobroker 23517085 Sep  3 18:07 states.jsonl
                                    ich bin zufrieden, wollte nur meine Beobachtung teilen 🙂
                                      @rene-3 keine Meldung auf der Konsole nach iob start?
                                      tail -f /opt/iobroker/log/*curr*
                                        @fastfoot
                                        Thx, habe es eingegeben, aber mein System ist zur Zeit so seeeehr langsam und zum "iob start" braucht es auch nochmal ein paar Minütchen ...
                                        Vielleicht sieht man so mehr heraus.
                                          apollon77 @fastfoot last edited by
                                          @fastfoot gaaaanz langsam !!! Wir haben hier ZWEI Systeme mit anderen issues ggf.
                                          Bei dir sind die Dateien klein. Das ist vollkommen im normalen Rahmen. Sind ja nur 33mb oder so korrekt??!!
                                          Was ist denn jetzt bei dir noch das problem? Ich dachte deins war längst gelöst?
                                            @rene-3 ok. Um zu dir. Wie lange dauert es denn bis dein System auf das iob status regiert?
                                            Frage: nutzt die vllt den Adapter Ble? Also mit dem hohen timeout startet es Jetzt bei dir. Es dauert nur sehr lange. Jetzt ist die Frage warum du scheinbar wirklich soviel Objekte hast.
                                            429
                                            82880
