    4. JavaScript
    5. E3DC Hauskraftwerk steuern
      ArnoD @ArnoD last edited by
      Habe eine neue Version Charge-Control auf GitHub hochgeladen.
      Version: 1.0.16
      Änderungen:
      • Ein-/ Ausschaltkriterium der Lade/Entladeleistung E3DC geändert. Es wird jetzt die Astro-Funktion "sunset" verwendet.
        Chilihead last edited by
        @ArnoD hab jetzt mal das neue Script ausporbiert.
        Irgendwas zwickts da bei mir wohl oder ist das so gewollt?
        Das Script "spamt" mir die IOB Warnungen voll mit set power mode...
        javascript.0
        2022-08-30 13:04:33.017	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2605 M_Power = 2652
        javascript.0
        2022-08-30 13:04:27.015	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2604 M_Power = 2652
        javascript.0
        2022-08-30 13:04:21.018	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2603 M_Power = 2652
        admin.0
        2022-08-30 13:04:20.720	info	<== Disconnect system.user.admin from ::ffff:192.168.1.62 javascript
        admin.0
        javascript.0
        2022-08-30 13:04:15.012	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2602 M_Power = 2652
        javascript.0
        2022-08-30 13:04:09.021	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2601 M_Power = 2652
        javascript.0
        2022-08-30 13:04:03.011	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2600 M_Power = 2652
        javascript.0
        2022-08-30 13:03:57.010	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2599 M_Power = 2652
        javascript.0
        2022-08-30 13:03:51.014	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2598 M_Power = 2652
        javascript.0
        2022-08-30 13:03:51.004	info	script.js.E3DC_Charge_Control: -==== 2 M_Power:2652 = Math.round(((Ladeende_Proz:80 - Batterie_SOC_Proz:72)*Speichergroesse_kWh:15*10*3600) / (tRegelende:41460 - Zeit_aktuell_UTC_sek:39831)) ====-
        javascript.0
        2022-08-30 13:03:45.012	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2597 M_Power = 2600
        javascript.0
        2022-08-30 13:03:39.010	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2596 M_Power = 2600
        javascript.0
        2022-08-30 13:03:33.042	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2595 M_Power = 2600
        javascript.0
        2022-08-30 13:03:27.028	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2594 M_Power = 2600
        javascript.0
        2022-08-30 13:03:21.011	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2593 M_Power = 2600
        javascript.0
        2022-08-30 13:03:15.015	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2592 M_Power = 2600
        javascript.0
        2022-08-30 13:03:09.016	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2591 M_Power = 2600
        javascript.0
        2022-08-30 13:03:03.020	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2590 M_Power = 2600
        javascript.0
        2022-08-30 13:02:57.010	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2589 M_Power = 2600
        javascript.0
        2022-08-30 13:02:51.016	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2588 M_Power = 2600
        javascript.0
        2022-08-30 13:02:45.036	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2587 M_Power = 2600
        javascript.0
        2022-08-30 13:02:39.011	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2586 M_Power = 2600
        javascript.0
        2022-08-30 13:02:33.018	warn	script.js.E3DC_Charge_Control: Schritt = 2 E3DC_Set_Power_Mode = 3 (laden) Set_Power_Value_W = 2585 M_Power = 2600
          ArnoD @Chilihead last edited by
          @chilihead
          Im Skript die Konstante LogAusgabeSteuerung = false setzen.
            jans_ios last edited by
            @arnod
            Hi, vielen Dank erstmal für die ganze Arbeit, die Du in das Thema gesteckt hast. Ich habe Deine Skripte jetzt bei mir soweit importiert und auch die Views, jedoch wird mir im View nicht alles angezeigt. Dort, wo eigentlich rechts und unten das Menu angezeigt werden sollte, steht in roter Schrift "Fehler: View wurde nicht gefunden".
            Lt. VIS-Editor sieht es so aus, als wenn die Views "920_Menueleiste" und "900_Menueleiste_unten_Energie" fehlen würden.
            Hast Du eine Idee, wo mein Fehler liegt?
            Danke!
            Z A 2 Replies Last reply Reply Quote 0
            • Z
              Zelkin @jans_ios last edited by
              @jans_ios
              Die Menüs sind doch bei jedem anders?!
              Du hast schließlich andere endpunkte als Arno ..... also selber anlegen bzw. füllen 🙂
                Robbi12 last edited by
                Also schon mal super Arbeit. Aber ich komme auch nicht so ganz zurecht.
                Ich scheitere schon bei den VIS. Da sind verschiedene Ordner. Welche soll ich denn nehmen?
                Ich habe keine Wallbox von E3DC angeschlossen.
                  ArnoD @Robbi12 last edited by
                  @robbi12
                  Welche Ordner meinst du?
                  Du benötigst auch nicht zwingend eine Wallbox.
                  Du musst immer daran denken, dass man nicht vor deinem Rechner sitzt und sich somit schwertut, wenn es nicht genauer beschrieben wird. Bilder helfen hier meistens weiter.
                    Danke für deine schnelle Rückmail.
                    Auf deiner Github Seite sind einmal der Ordner E3DC Control und einmal direkt die Datei Charge-Control_Ver_1.0.16.js, dann noch die Datei Modbus.js.
                    Ich denke ich muss die Charge-Control_Ver_1.0.16.js verwenden.
                    Für den Modbus muss ich dann die Daten aus dem Ordner "Modbus Import Dateien Register" nehmen?
                      ArnoD @Robbi12 last edited by ArnoD
                      @robbi12
                      Richtig, von Github das Script Charge-Control Ver 1.0.16 verwenden und wenn du dein E3DC noch nicht über Modbus eingebunden hast, kannst du die Importdatei
                      Modbus Import Dateien Register/Modbus_E3DC_Import_V1.90_2022-01-28.tsv verwenden.
                      Bitte auch die Anleitung Charge-Control.pdf von Github lesen.
                        ArnoD @jans_ios last edited by
                        @jans_ios
                        Ich habe heute auf Github alle Views aktualisiert und auch die Menüleisten unten und rechts hinzugefügt.
                        Wie aber @Zelkin schon richtig schreibt, wird es dir nur bedingt was nützen, da die Menüleiste und Verlinkung der einzelnen Views bei jedem anders ist und immer angepasst werden müssen.
                          @ArnoD
                          Ah cool - danke für die Info und die Dateien. Dann hatte ich das tatsächlich falsch verstanden mit den Menus 😉
                          Andere Frage: Ich habe einen My-PV Elwa Heizstab und habe reines Überschuss-Laden im E3DC aktiviert. Ich hatte eigentlich erwartet, dass bei Zur-Verfügung-Stehen von Strom aufgrund verringerter Ladeleistung der Heizstab vom E3DC aktiviert wird, das geschieht jedoch nicht. Ich vermute, das geschieht erst, wenn der Akku zu 100% geladen ist.
                          Habt Ihr eine Idee, wie man das in den Griff bekommen könnte?
                          Danke!
                          • stiwy18
                            stiwy18 last edited by
                            @ArnoD
                            Jetzt hab ich mal eine andere Frage, mein Auto (Hybrid) übermittelt regelmäßig über einen Adapter den Ladezustand des Autos.
                            Aktuell habe ich es so gemacht, dass ich den Eigenverbrauch um die kWh erhöhe, was der Akku vom Auto benötigt um voll zu werden. Funktioniert soweit auch, dass E3DC Charge Control ggf. auf "Alles laden" umschaltet, wenn die Prognose nicht ausreicht um das Auto später zu laden.
                            Wenn ich jedoch morgens unterwegs bin, hält Charge Control den Speicher auf der Ladeschwelle und ich verkaufe dann den Strom, anstatt, den Speicher mehr zu füllen für das Auto, somit zieht das Auto dann relativ schnell den Speicher leer (Auto lädt mit 7,2 kW und PV hat 8,3 kWp).
                            Hast du da eine Idee, wie ich den Speicher mehr fülle, wenn das Auto "leerer" wird?
                            Stefan
                              Mich würde hier allgemein das Zusammenspiel der 2 Skripte "Charge Control" und "E3DC_Wallbox" interessieren - nehmen die aufeinander Rücksicht? Ich habe "Charge Control" jetzt am Laufen, die Wallbox hängt noch am E3DC und das nur-Überschuss-Laden funktioniert nun nicht mehr, es wird einfach auch Netzstrom verwendet, wenn die PV-Leistung nicht ausreicht.
                              Auch die Ansteuerung eines Heizstabs wie dem My-PV Elwa (s. Post auch zwei Einträge weiter oben) gestaltet sich schwierig. Ich probiere gerade mit einem Blockly-basierten Skript rum, um nur den Überschuss, der nach
                              • "e3dc-rscp.0.EMS.SET_POWER_VALUE" (Ladestrom für den Akku, der von "Charge Control" gesetzt wird),
                              • Hausverbrauch abzgl. am Heizstab anliegendem Strom und
                              • Wallbox-Leistung
                              noch übrig bleibt, in den Heizstab zu schicken, das will aber noch nicht so recht.
                              Nutze ich allen zur Verfügung stehenden Strom aus, schaltet "Charge Control" die Steuerung ab, weil der Rest-Strom kleiner als 500W ist - so habe ich das jedenfalls verstanden.
                              Kann man den per Modbus-Adapter für den Heizstab zu setzenden Wert evtl. auch im Charge-Control-Skript mit unterbringen? Wenn ja - wie und wo?
                              Hat jemand so etwas schon umgesetzt? Wenn ja, gerne mehr Details - ich halte Euch von meiner Seite auch auf dem Laufenden.
                                ArnoD @stiwy18 last edited by
                                @stiwy18
                                Wenn die Prognose minus Eigenverbrauch nicht mehr ausreicht, sollte Einstellung 1 alles laden angewählt werden.
                                In dieser Einstellung kannst du die Ladeschwelle höher setzen, um bereits vor Start Regelzeitraum alles zu laden.
                                Dein Problem ist dann aber, wenn das Auto nicht rechtzeitig angesteckt wird, dass du eventuell nicht mehr ausreichend Kapazität zum Puffern vom Überschuss hast.
                                  @jans_ios sagte in E3DC Hauskraftwerk steuern:
                                  Master ist hier Charge-Control und das Wallbox Script passt sich je nach Einstellung an.
                                  Das E3DC_Wallbox Skript berücksichtigt je nach Einstellung, ob gerade in das Netz eingespeist wird oder ob die Batterie entladen werden darf. Dafür sind vier Ladeeinstellungen möglich:
                                  1. Überschuss Laden mit Prio. Speicherbatterie.
                                  (Netzbezug und Entladen Batterie ist während der Haltezeit möglich). Bei dieser Einstellung wird die erzeugte Solarenergie nach Abzug, Hausverbrauch und Ladeleistung Speicherbatterie zur Ladung vom E-Auto benutzt. Wenn nach Abzug vom Hausverbrauch und Ladeleistung Speicherbatterie die PV-Leistung den Wert „MinLadestromStart_A“ übersteigt, wird mit dem Laden vom E-Auto begonnen und es wird die „Haltezeit“ gestartet. (Erklärung Haltezeit weiter unten).
                                  2. Überschuss Laden mit Prio. Wallbox ohne Netzbezug.
                                  (Netzbezug / Entladen Batterie ist während der Haltezeit möglich). Bei dieser Einstellung wird die erzeugte Solarenergie nach Abzug vom Hausverbrauch zur Ladung vom E-Auto benutzt. Wenn nach Abzug vom Hausverbrauch die PV-Leistung den Wert „MinLadestromStart_A“ übersteigt, wird mit dem Laden vom E-Auto begonnen und es wird die „Haltezeit“ gestartet. (Erklärung Haltezeit weiter unten).
                                  3. max. Ladeleistung Wallbox.
                                  Die Wallbox wird auf den Wert „MaxLadestrom_A“ eingestellt und diese Ladeleistung wird ohne Rücksicht auf Eigenverbrauch, PV-Leistung oder Speicherbatterie SoC gehalten. Sollte die PV-Leistung und Speicherbatterie SoC nicht ausreichen, wird der Rest aus dem Netz bezogen.
                                  4. Entladen Speicherbatterie E3DC bis eingestelltem SoC Wert.
                                  Das E-Auto wird mit der max. Entladeleistung der Speicherbatterie „MaxEntladeLeistungBatterie_W“ geladen, bis der min. SoC Wert „MinBatterieSoC“ erreicht wird. Wenn nach Abzug vom Eigenverbrauch noch überschüssige PV-Leistung vorhanden ist, wird diese auch zum Laden vom E-Auto verwendet.
                                  Haltezeit:
                                  Um ein ständiges Unterbrechen des Ladevorgangs beim E-Auto (bei Bewölkung mit schwankender Solarleistung) zu verhindern, habe ich drei Haltezeiten für die Einstellungen 1,2,4 programmiert. Diese kann jeder selbst im Skript einstellen. Während der Haltezeit wird nur mit „MinLadestromAuto_A“ geladen und die fehlende Leistung aus der Batterie oder aus dem Netz bezogen.
                                  Ich bin aber gerade noch am Optimieren vom Script und werde zeitnah eine neue Version hochladen.
                                    Pr0tag0n last edited by
                                    Charge-Control funktioniert bei mir mittlerweile tippitoppi.
                                    Ich versuche jetzt für mein neues E-Auto die Wallbox einzustellen.
                                    Wenn ich das Vis Wallbox importieren möchte, wie ich es bei vis Charge-Control oder vis Prognosen getan habe, bekomme ich bei Vis oben rechts den Fehler "Verbindungsfehler" und nichts wird importiert. Woran kann das liegen und wie kann ich es ändern?
                                    Vielen Dank schon mal
                                      ArnoD @Pr0tag0n last edited by
                                      @pr0tag0n
                                      Kannst du mal ein Bild von der Fehlermeldung hier posten.
                                        Pr0tag0n @ArnoD last edited by
                                        klar
                                          @pr0tag0n
                                          Hast du in letzter Zeit ein Update vom Web-Server Adapter gemacht?
                                          Versuch mal in den Instanz Einstellungen vom WEB-Server die Option "Reine Web-Sockets (iobroker.ws) verwenden"
                                          anzuwählen und "Eingebautes 'Simple-API'" abzuwählen, ob es dann wieder funktioniert.
                                            jans_ios @ArnoD last edited by jans_ios
                                            @arnod
                                            Hey super, danke Dir!
                                            Ich warte dann aber noch auf die optimierte Version. Kannst Du schon anteasern, woran Du konkret arbeitest? 😉 Bspw. ein automatisches Entscheiden, welche Ladeeinstellung aufgrund der Prognose und der im Auto benötigten kWh zu einer bestimmten Uhrzeit am meisten Sinn macht?
                                            Andere Frage: E3DC hat in einem ihrer letzten Videos (E3DC - Wie lange halten Stromspeicher-Batterien? ca. ab Minute 32:40) angesprochen, dass das optimierte Laden dieses Jahr stark auf der Agenda bei deren Entwicklern steht. Stehen die eigentlich in Kontakt zu Dir? Wäre ja sinnvoll bei dem Hirnschmalz, den Du bereits investiert hast.
                                            1.4k
                                            3439
                                            1574189
